path: root/block/blk.h
2010-10-24Revert "block: fix accounting bug on cross partition merges"Jens Axboe
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327. Conflicts: include/linux/genhd.h It has numerous issues with the cleanup path and non-elevator devices. Revert it for now so we can come up with a clean version without rushing things. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-19block: fix accounting bug on cross partition mergesYasuaki Ishimatsu
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. When reloading partition tables, quiesce IO to ensure that no request references to the partition struct exists. When it is safe to free the partition table, the IO for that device is restarted again. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block/scsi: Provide a limit on the number of integrity segmentsMartin K. Petersen
Some controllers have a hardware limit on the number of protection information scatter-gather list segments they can handle. Introduce a max_integrity_segments limit in the block layer and provide a new scsi_host_template setting that allows HBA drivers to provide a value suitable for the hardware. Add support for honoring the integrity segment limit when merging both bios and requests. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2010-09-10block: implement REQ_FLUSH/FUA based interface for FLUSH/FUA requestsTejun Heo
Now that the backend conversion is complete, export sequenced FLUSH/FUA capability through REQ_FLUSH/FUA flags. REQ_FLUSH means the device cache should be flushed before executing the request. REQ_FUA means that the data in the request should be on non-volatile media on completion. Block layer will choose the correct way of implementing the semantics and execute it. The request may be passed to the device directly if the device can handle it; otherwise, it will be sequenced using one or more proxy requests. Devices will never see REQ_FLUSH and/or FUA which it doesn't support. Also, unlike the original REQ_HARDBARRIER, REQ_FLUSH/FUA requests are never failed with -EOPNOTSUPP. If the underlying device doesn't support FLUSH/FUA, the block layer simply make those noop. IOW, it no longer distinguishes between writeback cache which doesn't support cache flush and writethrough/no cache. Devices which have WB cache w/o flush are very difficult to come by these days and there's nothing much we can do anyway, so it doesn't make sense to require everyone to implement -EOPNOTSUPP handling. This will simplify filesystems and block drivers as they can drop -EOPNOTSUPP retry logic for barriers. * QUEUE_ORDERED_* are removed and QUEUE_FSEQ_* are moved into blk-flush.c. * REQ_FLUSH w/o data can also be directly passed to drivers without sequencing but some drivers assume that zero length requests don't have rq->bio which isn't true for these requests requiring the use of proxy requests. * REQ_COMMON_MASK now includes REQ_FLUSH | REQ_FUA so that they are copied from bio to request. * WRITE_BARRIER is marked deprecated and WRITE_FLUSH, WRITE_FUA and WRITE_FLUSH_FUA are added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: rename barrier/ordered to flushTejun Heo
With ordering requirements dropped, barrier and ordered are misnomers. Now all block layer does is sequencing FLUSH and FUA. Rename them to flush. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: drop barrier ordering by queue drainingTejun Heo
Filesystems will take all the responsibilities for ordering requests around commit writes and will only indicate how the commit writes themselves should be handled by block layers. This patch drops barrier ordering by queue draining from block layer. Ordering by draining implementation was somewhat invasive to request handling. List of notable changes follow. * Each queue has 1 bit color which is flipped on each barrier issue. This is used to track whether a given request is issued before the current barrier or not. REQ_ORDERED_COLOR flag and coloring implementation in __elv_add_request() are removed. * Requests which shouldn't be processed yet for draining were stalled by returning -EAGAIN from blk_do_ordered() according to the test result between blk_ordered_req_seq() and blk_blk_ordered_cur_seq(). This logic is removed. * Draining completion logic in elv_completed_request() removed. * All barrier sequence requests were queued to request queue and then trckled to lower layer according to progress and thus maintaining request orders during requeue was necessary. This is replaced by queueing the next request in the barrier sequence only after the current one is complete from blk_ordered_complete_seq(), which removes the need for multiple proxy requests in struct request_queue and the request sorting logic in the ELEVATOR_INSERT_REQUEUE path of elv_insert(). * As barriers no longer have ordering constraints, there's no need to dump the whole elevator onto the dispatch queue on each barrier. Insert barriers at the front instead. * If other barrier requests come to the front of the dispatch queue while one is already in progress, they are stored in q->pending_barriers and restored to dispatch queue one-by-one after each barrier completion from blk_ordered_complete_seq(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: misc cleanups in barrier codeTejun Heo
Make the following cleanups in preparation of barrier/flush update. * blk_do_ordered() declaration is moved from include/linux/blkdev.h to block/blk.h. * blk_do_ordered() now returns pointer to struct request, with %NULL meaning "try the next request" and ERR_PTR(-EAGAIN) "try again later". The third case will be dropped with further changes. * In the initialization of proxy barrier request, data direction is already set by init_request_from_bio(). Drop unnecessary explicit REQ_WRITE setting and move init_request_from_bio() above REQ_FUA flag setting. * add_request() is collapsed into __make_request(). These changes don't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: Range check cpu in blk_cpu_to_groupBrian King
While testing CPU DLPAR, the following problem was discovered. We were DLPAR removing the first CPU, which in this case was logical CPUs 0-3. CPUs 0-2 were already marked offline and we were in the process of offlining CPU 3. After marking the CPU inactive and offline in cpu_disable, but before the cpu was completely idle (cpu_die), we ended up in __make_request on CPU 3. There we looked at the topology map to see which CPU to complete the I/O on and found no CPUs in the cpu_sibling_map. This resulted in the block layer setting the completion cpu to be NR_CPUS, which then caused an oops when we tried to complete the I/O. Fix this by sanity checking the value we return from blk_cpu_to_group to be a valid cpu value. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2009-09-11block: implement mixed merge of different failfast requestsTejun Heo
Failfast has characteristics from other attributes. When issuing, executing and successuflly completing requests, failfast doesn't make any difference. It only affects how a request is handled on failure. Allowing requests with different failfast settings to be merged cause normal IOs to fail prematurely while not allowing has performance penalties as failfast is used for read aheads which are likely to be located near in-flight or to-be-issued normal IOs. This patch introduces the concept of 'mixed merge'. A request is a mixed merge if it is merge of segments which require different handling on failure. Currently the only mixable attributes are failfast ones (or lack thereof). When a bio with different failfast settings is added to an existing request or requests of different failfast settings are merged, the merged request is marked mixed. Each bio carries failfast settings and the request always tracks failfast state of the first bio. When the request fails, blk_rq_err_bytes() can be used to determine how many bytes can be safely failed without crossing into an area which requires further retrials. This allows request merging regardless of failfast settings while keeping the failure handling correct. This patch only implements mixed merge but doesn't enable it. The next one will update SCSI to make use of mixed merge. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Niel Lambrechts <niel.lambrechts@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-27block: fix no diskstat problemKiyoshi Ueda
The commit below in 2.6-block/for-2.6.31 causes no diskstat problem because the blk_discard_rq() check was added with '&&'. It should be 'blk_fs_request() || blk_discard_rq()'. This patch does it and fixes the no diskstat problem. Please review and apply. ------ /proc/diskstat without this patch ------------------------------------- 8 0 sda 0 0 0 0 0 0 0 0 0 0 0 ------------------------------------------------------------------------------ ----- /proc/diskstat with this patch applied --------------------------------- 8 0 sda 4186 303 373621 61600 9578 3859 107468 169479 2 89755 231059 ------------------------------------------------------------------------------ -------------------------------------------------------------------------- commit c69d48540c201394d08cb4d48b905e001313d9b8 Author: Jens Axboe <jens.axboe@oracle.com> Date: Fri Apr 24 08:12:19 2009 +0200 block: include discard requests in IO accounting We currently don't do merging on discard requests, but we potentially could. If we do, then we need to include discard requests in the IO accounting, or merging would end up decrementing in_flight IO counters for an IO which never incremented them. So enable accounting for discard requests. <snip> static inline int blk_do_io_stat(struct request *rq) { - return rq->rq_disk && blk_rq_io_stat(rq) && blk_fs_request(rq); + return rq->rq_disk && blk_rq_io_stat(rq) && blk_fs_request(rq) && + blk_discard_rq(rq); } -------------------------------------------------------------------------- Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19block: Un-export blk_rq_append_bioBoaz Harrosh
OSD was the last in-tree user of blk_rq_append_bio(). Now that it is fixed blk_rq_append_bio is un-exported and is only used internally by block layer. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: drop request->hard_* and *nr_sectorsTejun Heo
struct request has had a few different ways to represent some properties of a request. ->hard_* represent block layer's view of the request progress (completion cursor) and the ones without the prefix are supposed to represent the issue cursor and allowed to be updated as necessary by the low level drivers. The thing is that as block layer supports partial completion, the two cursors really aren't necessary and only cause confusion. In addition, manual management of request detail from low level drivers is cumbersome and error-prone at the very least. Another interesting duplicate fields are rq->[hard_]nr_sectors and rq->{hard_cur|current}_nr_sectors against rq->data_len and rq->bio->bi_size. This is more convoluted than the hard_ case. rq->[hard_]nr_sectors are initialized for requests with bio but blk_rq_bytes() uses it only for !pc requests. rq->data_len is initialized for all request but blk_rq_bytes() uses it only for pc requests. This causes good amount of confusion throughout block layer and its drivers and determining the request length has been a bit of black magic which may or may not work depending on circumstances and what the specific LLD is actually doing. rq->{hard_cur|current}_nr_sectors represent the number of sectors in the contiguous data area at the front. This is mainly used by drivers which transfers data by walking request segment-by-segment. This value always equals rq->bio->bi_size >> 9. However, data length for pc requests may not be multiple of 512 bytes and using this field becomes a bit confusing. In general, having multiple fields to represent the same property leads only to confusion and subtle bugs. With recent block low level driver cleanups, no driver is accessing or manipulating these duplicate fields directly. Drop all the duplicates. Now rq->sector means the current sector, rq->data_len the current total length and rq->bio->bi_size the current segment length. Everything else is defined in terms of these three and available only through accessors. * blk_recalc_rq_sectors() is collapsed into blk_update_request() and now handles pc and fs requests equally other than rq->sector update. This means that now pc requests can use partial completion too (no in-kernel user yet tho). * bio_cur_sectors() is replaced with bio_cur_bytes() as block layer now uses byte count as the primary data length. * blk_rq_pos() is now guranteed to be always correct. In-block users converted. * blk_rq_bytes() is now guaranteed to be always valid as is blk_rq_sectors(). In-block users converted. * blk_rq_sectors() is now guaranteed to equal blk_rq_bytes() >> 9. More convenient one is used. * blk_rq_bytes() and blk_rq_cur_bytes() are now inlined and take const pointer to request. [ Impact: API cleanup, single way to represent one property of a request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: include discard requests in IO accountingJens Axboe
We currently don't do merging on discard requests, but we potentially could. If we do, then we need to include discard requests in the IO accounting, or merging would end up decrementing in_flight IO counters for an IO which never incremented them. So enable accounting for discard requests. Problem found by Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: make blk_do_io_stat() do the full "is this rq accountable" checksJens Axboe
We currently check for file system requests outside of blk_do_io_stat(rq), but we may as well just include it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: reorganize request fetching functionsTejun Heo
Impact: code reorganization elv_next_request() and elv_dequeue_request() are public block layer interface than actual elevator implementation. They mostly deal with how requests interact with block layer and low level drivers at the beginning of rqeuest processing whereas __elv_next_request() is the actual eleveator request fetching interface. Move the two functions to blk-core.c. This prepares for further interface cleanup. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-24block: simplify I/O stat accountingJerome Marchand
This simplifies I/O stat accounting switching code and separates it completely from I/O scheduler switch code. Requests are accounted according to the state of their request queue at the time of the request allocation. There is no need anymore to flush the request queue when switching I/O accounting state. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15block: fix bad spelling of quiesceJens Axboe
Credit goes to Andrew Morton for spotting this one. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: fix inconsistency in I/O stat accounting codeJerome Marchand
This forces in_flight to be zero when turning off or on the I/O stat accounting and stops updating I/O stats in attempt_merge() when accounting is turned off. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: elevator quiescing helpersJens Axboe
Simple helper functions to quiesce the request queue. These are currently only used for switching IO schedulers on-the-fly, but we can use them to properly switch IO accounting on and off as well. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-13cpumask: use topology_core_cpumask/topology_thread_cpumask instead of ↵Rusty Russell
cpu_core_map/cpu_sibling_map Impact: cleanup This is presumably what those definitions are for, and while all archs define cpu_core_map/cpu_sibling map, that's changing (eg. x86 wants to change it to a pointer). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-02-02block: fix oops in blk_queue_io_stat()Jens Axboe
Some initial probe requests don't have disk->queue mapped yet, so we can't rely on a non-NULL queue in blk_queue_io_stat(). Wrap it in blk_do_io_stat(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-26cpumask: Replace cpu_coregroup_map with cpu_coregroup_maskRusty Russell
cpu_coregroup_map returned a cpumask_t: it's going away. (Note, the sched part of this patch won't apply meaningfully to the sched tree, but I'm posting it to show the goal). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Ingo Molnar <mingo@redhat.com>
2008-10-17block: remove __generic_unplug_device() from exportsJens Axboe
The only out-of-core user is IDE, and that should be using blk_start_queueing() instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add fault injection mechanism for faking request timeoutsJens Axboe
Only works for the generic request timer handling. Allows one to sporadically ignore request completions, thus exercising the timeout handling. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add support for IO CPU affinityJens Axboe
This patch adds support for controlling the IO completion CPU of either all requests on a queue, or on a per-request basis. We export a sysfs variable (rq_affinity) which, if set, migrates completions of requests to the CPU that originally submitted it. A bio helper (bio_set_completion_cpu()) is also added, so that queuers can ask for completion on that specific CPU. In testing, this has been show to cut the system time by as much as 20-40% on synthetic workloads where CPU affinity is desired. This requires a little help from the architecture, so it'll only work as designed for archs that are using the new generic smp helper infrastructure. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: rename and export rq_init()FUJITA Tomonori
This rename rq_init() blk_rq_init() and export it. Any path that hands the request to the block layer needs to call it to initialize the request. This is a preparation for large command support, which needs to initialize the request in a proper way (that is, just doing a memset() will not work). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04proper prototype for blk_dev_init()Adrian Bunk
This patch adds a proper prototye for blk_dev_init() in block/blk.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: ll_rw_blk.c split, add blk-merge.cJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: split tag and sysfs handling from blk-core.cJens Axboe
Seperates the tag and sysfs handling from ll_rw_blk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
