path: root/block/blktrace.c
2009-02-18block: fix bad definition of BIO_RW_SYNCJens Axboe
We can't OR shift values, so get rid of BIO_RW_SYNC and use BIO_RW_SYNCIO and BIO_RW_UNPLUG explicitly. This brings back the behaviour from before 213d9417fec62ef4c3675621b9364a667954d4dd. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-30block: get rid of the manual directory counting in blktraceJens Axboe
It can result in a stuck blktrace system, if --kill is used. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-26blktrace: port to tracepointsArnaldo Carvalho de Melo
This was a forward port of work done by Mathieu Desnoyers, I changed it to encode the 'what' parameter on the tracepoint name, so that one can register interest in specific events and not on classes of events to then check the 'what' parameter. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-09blktrace: use BLKTRACE_BDEV_SIZE as the name size for setup structureJens Axboe
Define as 32, which is is what BDEVNAME_SIZE is/was as well. This keeps the user interface the same and gets rid of the difference between kernel and user api here. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09blktrace: simplify flags handling in __blk_add_traceDavid Woodhouse
Let the compiler see what's going on, and it can all get a lot simpler. On PPC64 this reduces the size of the code calculating these bits by about 60%. On x86_64 it's less of a win -- only 40%. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09blktrace: support discard requestsDavid Woodhouse
2008-07-03Added in user-injected messages into blk tracesAlan D. Brunelle
This allows a user to annotate the blk trace stream: writing a suitable message to {/sys/kernel/debug}/block/<dsf>/msg will have it propagated into the trace stream. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-12block: disable IRQs until data is written to relay channelCarl Henrik Lunde
As we may run relay_reserve from interrupt context we must always disable IRQs. This is because a call to relay_reserve may expose previously written data to use space. Updated new message code and an old but related comment. Signed-off-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28block: make blktrace use per-cpu buffers for message notesJens Axboe
Currently it uses a single static char array, but that risks being corrupted when multiple users issue message notes at the same time. Make the buffers dynamically allocated when the trace is setup and make them per-cpu instead. The default max message size of 1k is also very large, the interface is mainly for small text notes. So shrink it to 128 bytes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28Added in MESSAGE notes for blktracesAlan D. Brunelle
Allows messages to be inserted into blktrace streams. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-13Fix misuses of bdevname()Jean Delvare
bdevname() fills the buffer that it is given as a parameter, so calling strcpy() or snprintf() on the returned value is redundant (and probably not guaranteed to work - I don't think strcpy and snprintf support overlapping buffers.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Stephen Tweedie <sct@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28blktrace: Add blktrace ioctls to SCSI generic devicesChristof Schmitt
Since the SCSI layer uses the request queues from the block layer, blktrace can also be used to trace the requests to all SCSI devices (like SCSI tape drives), not only disks. The only missing part is the ioctl interface to start and stop tracing. This patch adds the SETUP, START, STOP and TEARDOWN ioctls from blktrace to the sg device files. With this change, blktrace can be used for SCSI devices like for disks, e.g.: blktrace -d /dev/sg1 -o - | blkparse -i - Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-11blktrace: kill the unneeded initcallJens Axboe
It just inits the mutex, we can do that with DEFINE_MUTEX() instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-11block: fix blktrace timestampsIngo Molnar
David Dillow reported broken blktrace timestamps. The reason is cpu_clock() which is not a global time source. Fix bkltrace timestamps by using ktime_get() like the networking code does for packet timestamps. This also removes a whole lot of complexity from bkltrace.c and shrinks the code by 500 bytes: text data bss dec hex filename 2888 124 44 3056 bf0 blktrace.o.before 2390 116 44 2550 9f6 blktrace.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-27blktrace: Make sure BLKTRACETEARDOWN does the full cleanup.Aneesh Kumar K.V
if blktrace program segfault it will not be able to call BLKTRACETEARDOWN. Now if we run the blktrace again that would result in a failure to create the block/<device> debugfs directory.This will result in blk_remove_root() to be called which will set blk_tree_root to NULL. But the debugfs block dir still exist because it contain subdirectory. Now if we try to fix it using BLKTRACETEARDOWN it won't work because blk_tree_root is NULL. Fix the same. Tested as below root@qemu-image:/home/kvaneesh/blktrace# ./blktrace -d /dev/hdc Segmentation fault root@qemu-image:/home/kvaneesh/blktrace# ./blktrace -d /dev/hdc BLKTRACESETUP: No such file or directory Failed to start trace on /dev/hdc root@qemu-image:/home/kvaneesh/blktrace# ./blktrace -k /dev/hdc root@qemu-image:/home/kvaneesh/blktrace# ./blktrace -d /dev/hdc Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16Convert cpu_sibling_map to be a per cpu variableMike Travis
Convert cpu_sibling_map from a static array sized by NR_CPUS to a per_cpu variable. This saves sizeof(cpumask_t) * NR unused cpus. Access is mostly from startup and CPU HOTPLUG functions. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10compat_ioctl: handle blk_trace ioctlsArnd Bergmann
blk_trace_setup is broken on x86_64 compat systems, this makes the code work correctly on all 64 bit architectures in compat mode. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-27blktrace: use cpu_clock() instead of sched_clock()Ingo Molnar
use cpu_clock() instead of sched_clock(). (the latter is not a proper clock-source) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Relay: add CPU hotplug supportMathieu Desnoyers
Mathieu originally needed to add this for tracing Xen, but it's something that's needed for any application that can be tracing while cpus are added. unplug isn't supported by this patch. The thought was that at minumum a new buffer needs to be added when a cpu comes up, but it wasn't worth the effort to remove buffers on cpu down since they'd be freed soon anyway when the channel was closed. [zanussi@us.ibm.com: avoid lock_cpu_hotplug deadlock] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Allow NULL pointers in percpu_freeAlan Stern
The patch (as824b) makes percpu_free() ignore NULL arguments, as one would expect for a deallocation routine. (Note that free_percpu is #defined as percpu_free in include/linux/percpu.h.) A few callers are updated to remove now-unneeded tests for NULL. A few other callers already seem to assume that passing a NULL pointer to percpu_free() is okay! The patch also removes an unnecessary NULL check in percpu_depopulate(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] blktrace: don't return blktrace_seq from trace_note()Jens Axboe
Only the process notifier needs it, and it can set it manually. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-04[PATCH] blktrace: uninline trace_note()Jens Axboe
It's too large to inline. Additionally clean it up, by fast pathing the likely path. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] blktrace: add timestamp messageOlaf Kirch
This adds a new timestamp message to blktrace, giving the timeofday when we starting tracing. This helps user space correlate block trace events with eg an application strace. This requires a (compatible) update to blkparse. The changed blkparse is still able to process traces generated by older kernels, and older versions of blkparse should silently ignore the new records (because they have a pid of 0). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-09-30[PATCH] Update axboe@suse.de email addressJens Axboe
As people often look for the copyright in files to see who to mail, update the link to a neutral one. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] blktrace: cleanup using on_each_cpuMartin Peschke
This patch kills a few lines of code in blktrace by making use of on_each_cpu(). Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] blktrace: support for logging metadata readsJens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-29[PATCH] ifdef blktrace debugging fieldsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-25[PATCH] blktrace: fix read-ahead bitMilton Miller
It should be toggling the same bit on and off, fix it up. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-06[PATCH] blktrace: readahead supportNathan Scott
Provide the needed kernel support for distinguishing readahead from regular read requests when tracing block devices. Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
