path: root/block/cfq-iosched.c
2011-01-14block cfq: compensate preempted queue even if it has no slice assignedShaohua Li
If a queue is preempted before it gets slice assigned, the queue doesn't get compensation, which looks unfair. For such queue, we compensate it for a whole slice. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-14block cfq: make queue preempt work for queues from different workloadShaohua Li
I got this: fio-874 [007] 2157.724514: 8,32 m N cfq874 preempt fio-874 [007] 2157.724519: 8,32 m N cfq830 slice expired t=1 fio-874 [007] 2157.724520: 8,32 m N cfq830 sl_used=1 disp=0 charge=1 iops=0 sect=0 fio-874 [007] 2157.724521: 8,32 m N cfq830 set_active wl_prio:0 wl_type:0 fio-874 [007] 2157.724522: 8,32 m N cfq830 Not idling. st->count:1 cfq830 is an async queue, and preempted by a sync queue cfq874. But since we have cfqg->saved_workload_slice mechanism, the preempt is a nop. Looks currently our preempt is totally broken if the two queues are not from the same workload type. Below patch fixes it. This will might make async queue starvation, but it's what our old code does before cgroup is added. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-07block cfq: don't use atomic_t for cfq_groupShaohua Li
cfq_group->ref is used with queue_lock hold, the only exception is cfq_set_request, which looks like a bug to me, so ref doesn't need to be an atomic and atomic operation is slower. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-07block cfq: don't use atomic_t for cfq_queueShaohua Li
cfq_queue->ref is used with queue_lock hold, so ref doesn't need to be an atomic and atomic operation is slower. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17cfq-iosched: don't check cfqg in choose_service_tree()Gui Jianfeng
When cfq_choose_cfqg() is called in select_queue(), there must be at least one backlogged CFQ queue waiting for dispatching, hence there must be at least one backlogged CFQ group on service tree. So we never call choose_service_tree() with cfqg == NULL. Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-13block cfq: select new workload if priority changedShaohua Li writes
If priority is changed, continuing to check workload_expires and service tree count of the previous workload does not make sense. We should always choose the workload with lowest key of new priority in such case. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-30cfq-iosched: Get rid of on_st flagGui Jianfeng
It's able to check whether a CFQ group on a service tree by checking "cfqg->rb_node". There's no need to maintain an extra flag here. Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-30cfq-iosched: Get rid of st->activeGui Jianfeng
When a cfq group is running, it won't be dequeued from service tree, so there's no need to store the active one in st->active. Just gid rid of it. Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-16Merge branch 'v2.6.37-rc2' into for-2.6.38/coreJens Axboe
2010-11-09cfq-iosched: don't schedule a dispatch for a non-idle queueShaohua Li
Vivek suggests we don't need schedule a dispatch when an idle queue becomes nonidle. And he is right, cfq_should_preempt already covers the logic. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-08cfq-iosched: don't idle if a deep seek queue is slowShaohua Li
If a deep seek queue slowly deliver requests but disk is much faster, idle for the queue just wastes disk throughput. If the queue delevers all requests before half its slice is used, the patch disable idle for it. In my test, application delivers 32 requests one time, the disk can accept 128 requests at maxium and disk is fast. without the patch, the throughput is just around 30m/s, while with it, the speed is about 80m/s. The disk is a SSD, but is detected as a rotational disk. I can configure it as SSD, but I thought the deep seek queue logic should be fixed too, for example, considering a fast raid. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-08cfq-iosched: schedule dispatch for noidle queueShaohua Li
A queue is idle at cfq_dispatch_requests(), but it gets noidle later. Unless other task explictly does unplug or all requests are drained, we will not deliever requests to the disk even cfq_arm_slice_timer doesn't make the queue idle. For example, cfq_should_idle() returns true because of service_tree->count == 1, and then other queues are added. Note, I didn't see obvious performance impacts so far with the patch, but just thought this could be a problem. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-08cfq-iosched: do cleanupShaohua Li
Some functions should return boolean. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-10-22cfq-iosched: Fix a gcc 4.5 warning and put some commentsVivek Goyal
- Andi encountedred following warning with gcc 4.5 linux/block/cfq-iosched.c: In function ‘cfq_dispatch_requests’: linux/block/cfq-iosched.c:2156:3: warning: array subscript is above array bounds - Warning happens due to following code. slice = group_slice * count / max_t(unsigned, cfqg->busy_queues_avg[cfqd->serving_prio], cfq_group_busy_queues_wl(cfqd->serving_prio, cfqd, cfqg)); gcc is complaining about cfqg->busy_queues_avg[] being indexed by CFQ prio classes (RT, BE and IDLE) while the array size is only 2. - At run time, we never access cfqg->busy_queues_avg[IDLE] and return from function before this code hits. - To fix warning increase the array size though it will remain unused. This patch also puts some comments to clarify some of the confusions. - I have taken Jens's patch and modified it a bit. - Compile tested with gcc 4.4 and boot tested. I don't have gcc 4.5 running, Andi can you please test it with gcc 4.5 to make sure it worked. Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio: Recalculate the throttled bio dispatch time upon throttle limit changeVivek Goyal
o Currently any cgroup throttle limit changes are processed asynchronousy and the change does not take affect till a new bio is dispatched from same group. o It might happen that a user sets a redicuously low limit on throttling. Say 1 bytes per second on reads. In such cases simple operations like mount a disk can wait for a very long time. o Once bio is throttled, there is no easy way to come out of that wait even if user increases the read limit later. o This patch fixes it. Now if a user changes the cgroup limits, we recalculate the bio dispatch time according to new limits. o Can't take queueu lock under blkcg_lock, hence after the change I wake up the dispatch thread again which recalculates the time. So there are some variables being synchronized across two threads without lock and I had to make use of barriers. Hoping I have used barriers correctly. Any review of memory barrier code especially will help. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-21cfq-iosched: fix a kernel OOPs when usb key is insertedVivek Goyal
Mike reported a kernel crash when a usb key hotplug is performed while all kernel thrads are not in a root cgroup and are running in one of the child cgroups of blkio controller. BUG: unable to handle kernel NULL pointer dereference at 0000002c IP: [<c11c7b08>] cfq_get_queue+0x232/0x412 *pde = 00000000 Oops: 0000 [#1] PREEMPT last sysfs file: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/host3/scsi_host/host3/uevent [..] Pid: 30039, comm: scsi_scan_3 Not tainted 2.6.35.2-fg.roam #1 Volvi2 /Aspire 4315 EIP: 0060:[<c11c7b08>] EFLAGS: 00010086 CPU: 0 EIP is at cfq_get_queue+0x232/0x412 EAX: f705f9c0 EBX: e977abac ECX: 00000000 EDX: 00000000 ESI: f00da400 EDI: f00da4ec EBP: e977a800 ESP: dff8fd00 DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 Process scsi_scan_3 (pid: 30039, ti=dff8e000 task=f6b6c9a0 task.ti=dff8e000) Stack: 00000000 00000000 00000001 01ff0000 f00da508 00000000 f00da524 f00da540 <0> e7994940 dd631750 f705f9c0 e977a820 e977ac44 f00da4d0 00000001 f6b6c9a0 <0> 00000010 00008010 0000000b 00000000 00000001 e977a800 dd76fac0 00000246 Call Trace: [<c11c7f10>] ? cfq_set_request+0x228/0x34c [<c11c7ce8>] ? cfq_set_request+0x0/0x34c [<c11bb3b9>] ? elv_set_request+0xf/0x1c [<c11bdd51>] ? get_request+0x1ad/0x22f [<c11bddf2>] ? get_request_wait+0x1f/0x11a [<c11d013b>] ? kvasprintf+0x33/0x3b [<c127b537>] ? scsi_execute+0x1d/0x103 [<c127b675>] ? scsi_execute_req+0x58/0x83 [<c127c391>] ? scsi_probe_and_add_lun+0x188/0x7c2 [<c12718c6>] ? attribute_container_add_device+0x15/0xfa [<c11c95d1>] ? kobject_get+0xf/0x13 [<c126d1db>] ? get_device+0x10/0x14 [<c127be93>] ? scsi_alloc_target+0x217/0x24d [<c127cbd8>] ? __scsi_scan_target+0x95/0x480 [<c10204eb>] ? dequeue_entity+0x14/0x1fe [<c1020491>] ? update_curr+0x165/0x1ab [<c1020491>] ? update_curr+0x165/0x1ab [<c127d00d>] ? scsi_scan_channel+0x4a/0x76 [<c127d0b0>] ? scsi_scan_host_selected+0x77/0xad [<c127d13c>] ? do_scan_async+0x0/0x11a [<c127d137>] ? do_scsi_scan_host+0x51/0x56 [<c127d13c>] ? do_scan_async+0x0/0x11a [<c127d14a>] ? do_scan_async+0xe/0x11a [<c127d13c>] ? do_scan_async+0x0/0x11a [<c10354c5>] ? kthread+0x5e/0x63 [<c1035467>] ? kthread+0x0/0x63 [<c1002af6>] ? kernel_thread_helper+0x6/0x10 Code: 44 24 1c 54 83 44 24 18 54 83 fa 03 75 94 8b 06 c7 86 64 02 00 00 01 00 00 00 83 e0 03 09 f0 89 06 8b 44 24 28 8b 90 58 01 00 00 <8b> 42 2c 85 c0 75 03 8b 42 08 8d 54 24 48 52 8d 4c 24 50 51 68 EIP: [<c11c7b08>] cfq_get_queue+0x232/0x412 SS:ESP 0068:dff8fd00 CR2: 000000000000002c ---[ end trace 9a88306573f69b12 ]--- The problem here is that we don't have bdi->dev information available when thread does some IO. Hence when dev_name() tries to access bdi->dev, it crashes. This problem does not happen if kernel threads are in root group as root group is statically allocated at device initialization time and we don't hit this piece of code. Fix it by delaying the filling of major and minor number information of device in blk_group. Initially a blk_group is created with 0 as device information and this information is filled later once some more IO comes in from same group. Reported-by: Mike Kazantsev <mk.fraggod@gmail.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-20cfq: improve fsync performance for small filesCorrado Zoccolo
Fsync performance for small files achieved by cfq on high-end disks is lower than what deadline can achieve, due to idling introduced between the sync write happening in process context and the journal commit. Moreover, when competing with a sequential reader, a process writing small files and fsync-ing them is starved. This patch fixes the two problems by: - marking journal commits as WRITE_SYNC, so that they get the REQ_NOIDLE flag set, - force all queues that have REQ_NOIDLE requests to be put in the noidle tree. Having the queue associated to the fsync-ing process and the one associated to journal commits in the noidle tree allows: - switching between them without idling, - fairness vs. competing idling queues, since they will be serviced only after the noidle tree expires its slice. Acked-by: Vivek Goyal <vgoyal@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Corrado Zoccolo <czoccolo@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blk-cgroup: Prepare the base for supporting more than one IO control policiesVivek Goyal
o This patch prepares the base for introducing new IO control policies. Currently all the code is written knowing there is only one policy and that is proportional bandwidth. Creating infrastructure for newer policies to come in. o Also there were many functions which were generated using macro. It was very confusing. Got rid of those. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23cfq-iosched: blktrace print per slice sector statsVivek Goyal
o Divyesh had gotten rid of this code in the past. I want to re-introduce it back as it helps me a lot during debugging. Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Reviewed-by: Divyesh Shah <dpshah@google.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23cfq-iosched: Implement tunable group_idleVivek Goyal
o Implement a new tunable group_idle, which allows idling on the group instead of a cfq queue. Hence one can set slice_idle = 0 and not idle on the individual queues but idle on the group. This way on fast storage we can get fairness between groups at the same time overall throughput improves. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23cfq-iosched: Do group share accounting in IOPS when slice_idle=0Vivek Goyal
o Implement another CFQ mode where we charge group in terms of number of requests dispatched instead of measuring the time. Measuring in terms of time is not possible when we are driving deeper queue depths and there are requests from multiple cfq queues in the request queue. o This mode currently gets activated if one sets slice_idle=0 and associated disk supports NCQ. Again the idea is that on an NCQ disk with idling disabled most of the queues will dispatch 1 or more requests and then cfq queue expiry happens and we don't have a way to measure time. So start providing fairness in terms of IOPS. o Currently IOPS mode works only with cfq group scheduling. CFQ is following different scheduling algorithms for queue and group scheduling. These IOPS stats are used only for group scheduling hence in non-croup mode nothing should change. o For CFQ group scheduling one can disable slice idling so that we don't idle on queue and drive deeper request queue depths (achieving better throughput), at the same time group idle is enabled so one should get service differentiation among groups. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-23cfq-iosched: Do not idle if slice_idle=0Vivek Goyal
Do not idle either on cfq queue or service tree if slice_idle=0. User does not want any queue or service tree idling. Currently even if slice_idle=0, we were waiting for request to finish before expiring the queue and that can lead to lower queue depths. Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-18cfq-iosched: Fixed boot warning with BLK_CGROUP=y and CFQ_GROUP_IOSCHED=nVivek Goyal
Hi Jens, Few days back Ingo noticed a CFQ boot time warning. This patch fixes it. The issue here is that with CFQ_GROUP_IOSCHED=n, CFQ should not really be making blkio stat related calls. > Hm, it's still not entirely fixed, as of 2.6.35-rc2-00131-g7908a9e. With > some > configs i get bad spinlock warnings during bootup: > > [ 28.968013] initcall net_olddevs_init+0x0/0x82 returned 0 after 93750 > usecs > [ 28.972003] calling b44_init+0x0/0x55 @ 1 > [ 28.976009] bus: 'pci': add driver b44 > [ 28.976374] sda: > [ 28.978157] BUG: spinlock bad magic on CPU#1, async/0/117 > [ 28.980000] lock: 7e1c5bbc, .magic: 00000000, .owner: <none>/-1, +.owner_cpu: 0 > [ 28.980000] Pid: 117, comm: async/0 Not tainted +2.6.35-rc2-tip-01092-g010e7ef-dirty #8183 > [ 28.980000] Call Trace: > [ 28.980000] [<41ba6d55>] ? printk+0x20/0x24 > [ 28.980000] [<4134b7b7>] spin_bug+0x7c/0x87 > [ 28.980000] [<4134b853>] do_raw_spin_lock+0x1e/0x123 > [ 28.980000] [<41ba92ca>] ? _raw_spin_lock_irqsave+0x12/0x20 > [ 28.980000] [<41ba92d2>] _raw_spin_lock_irqsave+0x1a/0x20 > [ 28.980000] [<4133476f>] blkiocg_update_io_add_stats+0x25/0xfb > [ 28.980000] [<41335dae>] ? cfq_prio_tree_add+0xb1/0xc1 > [ 28.980000] [<41337bc7>] cfq_insert_request+0x8c/0x425 Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-17cfq: Don't allow queue merges for queues that have no process referencesJeff Moyer
Hi, A user reported a kernel bug when running a particular program that did the following: created 32 threads - each thread took a mutex, grabbed a global offset, added a buffer size to that offset, released the lock - read from the given offset in the file - created a new thread to do the same - exited The result is that cfq's close cooperator logic would trigger, as the threads were issuing I/O within the mean seek distance of one another. This workload managed to routinely trigger a use after free bug when walking the list of merge candidates for a particular cfqq (cfqq->new_cfqq). The logic used for merging queues looks like this: static void cfq_setup_merge(struct cfq_queue *cfqq, struct cfq_queue *new_cfqq) { int process_refs, new_process_refs; struct cfq_queue *__cfqq; /* Avoid a circular list and skip interim queue merges */ while ((__cfqq = new_cfqq->new_cfqq)) { if (__cfqq == cfqq) return; new_cfqq = __cfqq; } process_refs = cfqq_process_refs(cfqq); /* * If the process for the cfqq has gone away, there is no * sense in merging the queues. */ if (process_refs == 0) return; /* * Merge in the direction of the lesser amount of work. */ new_process_refs = cfqq_process_refs(new_cfqq); if (new_process_refs >= process_refs) { cfqq->new_cfqq = new_cfqq; atomic_add(process_refs, &new_cfqq->ref); } else { new_cfqq->new_cfqq = cfqq; atomic_add(new_process_refs, &cfqq->ref); } } When a merge candidate is found, we add the process references for the queue with less references to the queue with more. The actual merging of queues happens when a new request is issued for a given cfqq. In the case of the test program, it only does a single pread call to read in 1MB, so the actual merge never happens. Normally, this is fine, as when the queue exits, we simply drop the references we took on the other cfqqs in the merge chain: /* * If this queue was scheduled to merge with another queue, be * sure to drop the reference taken on that queue (and others in * the merge chain). See cfq_setup_merge and cfq_merge_cfqqs. */ __cfqq = cfqq->new_cfqq; while (__cfqq) { if (__cfqq == cfqq) { WARN(1, "cfqq->new_cfqq loop detected\n"); break; } next = __cfqq->new_cfqq; cfq_put_queue(__cfqq); __cfqq = next; } However, there is a hole in this logic. Consider the following (and keep in mind that each I/O keeps a reference to the cfqq): q1->new_cfqq = q2 // q2 now has 2 process references q3->new_cfqq = q2 // q2 now has 3 process references // the process associated with q2 exits // q2 now has 2 process references // queue 1 exits, drops its reference on q2 // q2 now has 1 process reference // q3 exits, so has 0 process references, and hence drops its references // to q2, which leaves q2 also with 0 process references q4 comes along and wants to merge with q3 q3->new_cfqq still points at q2! We follow that link and end up at an already freed cfqq. So, the fix is to not follow a merge chain if the top-most queue does not have a process reference, otherwise any queue in the chain could be already freed. I also changed the logic to disallow merging with a queue that does not have any process references. Previously, we did this check for one of the merge candidates, but not the other. That doesn't really make sense. Without the attached patch, my system would BUG within a couple of seconds of running the reproducer program. With the patch applied, my system ran the program for over an hour without issues. This addresses the following bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16217 Thanks a ton to Phil Carns for providing the bug report and an excellent reproducer. [ Note for stable: this applies to 2.6.32/33/34 ]. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Reported-by: Phil Carns <carns@mcs.anl.gov> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-25cfq-iosched: fix an oops caused by slab leakShaohua Li
I got below oops when unloading cfq-iosched. Considering scenario: queue A merge to B, C merge to D and B will be merged to D. Before B is merged to D, we do split B. We should put B's reference for D. [ 807.768536] ============================================================================= [ 807.768539] BUG cfq_queue: Objects remaining on kmem_cache_close() [ 807.768541] ----------------------------------------------------------------------------- [ 807.768543] [ 807.768546] INFO: Slab 0xffffea0003e6b4e0 objects=26 used=1 fp=0xffff88011d584fd8 flags=0x200000000004082 [ 807.768550] Pid: 5946, comm: rmmod Tainted: G W 2.6.34-07097-gf4b87de-dirty #724 [ 807.768552] Call Trace: [ 807.768560] [<ffffffff81104e8d>] slab_err+0x8f/0x9d [ 807.768564] [<ffffffff811059e1>] ? flush_cpu_slab+0x0/0x93 [ 807.768569] [<ffffffff8164be52>] ? add_preempt_count+0xe/0xca [ 807.768572] [<ffffffff8164bd9c>] ? sub_preempt_count+0xe/0xb6 [ 807.768577] [<ffffffff81648871>] ? _raw_spin_unlock+0x15/0x30 [ 807.768580] [<ffffffff8164bd9c>] ? sub_preempt_count+0xe/0xb6 [ 807.768584] [<ffffffff811061bc>] list_slab_objects+0x9b/0x19f [ 807.768588] [<ffffffff8164bf0a>] ? add_preempt_count+0xc6/0xca [ 807.768591] [<ffffffff81109e27>] kmem_cache_destroy+0x13f/0x21d [ 807.768597] [<ffffffffa000ff13>] cfq_slab_kill+0x1a/0x43 [cfq_iosched] [ 807.768601] [<ffffffffa000ffcf>] cfq_exit+0x93/0x9e [cfq_iosched] [ 807.768606] [<ffffffff810973a2>] sys_delete_module+0x1b1/0x219 [ 807.768612] [<ffffffff8102fb5b>] system_call_fastpath+0x16/0x1b [ 807.768618] INFO: Object 0xffff88011d584618 @offset=1560 [ 807.768622] INFO: Allocated in cfq_get_queue+0x11e/0x274 [cfq_iosched] age=7173 cpu=1 pid=5496 [ 807.768626] ============================================================================= Cc: stable@kernel.org Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-24cfq-iosched: compact io_context radix_treeKonstantin Khlebnikov
Use small consequent indexes as radix tree keys instead of sparse cfqd address. This change will reduce radix tree depth from 11 (6 for 32-bit hosts) to 1 if host have <=64 disks under cfq control, or to 0 if there only one disk. So, this patch save 10*560 bytes for each process (5*296 for 32-bit hosts) For each cfqd allocate cic index from ida. To unlink dead cic from tree without cfqd access store index into ->key. (bit 0 -- dead mark, bits 1..30 -- index: ida produce id in range 0..2^31-1) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-24cfq-iosched: remove dead_key from cfq_io_contextKonstantin Khlebnikov
Remove ->dead_key field from cfq_io_context to shrink its size to 128 bytes. (64 bytes for 32-bit hosts) Use lower bit in ->key as dead-mark, instead of moving key to separate field. After this for dead cfq_io_context we got cic->key != cfqd automatically. Thus, io_context's last-hit cache should work without changing. Now to check ->key for non-dead state compare it with cfqd, instead of checking ->key for non-null value as it was before. Plus remove obsolete race protection in cfq_cic_lookup. This race gone after v2.6.24-1728-g4ac845a Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21block: remove all rcu head initializationsPaul E. McKenney
Remove all rcu head inits. We don't care about the RCU head state before passing it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can keep track of objects on stack. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-06blk-cgroup: Fix RCU correctness warning in cfq_init_queue()Vivek Goyal
It is necessary to be in an RCU read-side critical section when invoking css_id(), so this patch adds one to blkiocg_add_blkio_group(). This is actually a false positive, because this is called at initialization time and hence always refers to the root cgroup, which cannot go away. [ 103.790505] =================================================== [ 103.790509] [ INFO: suspicious rcu_dereference_check() usage. ] [ 103.790511] --------------------------------------------------- [ 103.790514] kernel/cgroup.c:4432 invoked rcu_dereference_check() without protection! [ 103.790517] [ 103.790517] other info that might help us debug this: [ 103.790519] [ 103.790521] [ 103.790521] rcu_scheduler_active = 1, debug_locks = 1 [ 103.790524] 4 locks held by bash/4422: [ 103.790526] #0: (&buffer->mutex){+.+.+.}, at: [<ffffffff8114befa>] sysfs_write_file+0x3c/0x144 [ 103.790537] #1: (s_active#102){.+.+.+}, at: [<ffffffff8114bfa5>] sysfs_write_file+0xe7/0x144 [ 103.790544] #2: (&q->sysfs_lock){+.+.+.}, at: [<ffffffff812263b1>] queue_attr_store+0x49/0x8f [ 103.790552] #3: (&(&blkcg->lock)->rlock){......}, at: [<ffffffff8122e4db>] blkiocg_add_blkio_group+0x2b/0xad [ 103.790560] [ 103.790561] stack backtrace: [ 103.790564] Pid: 4422, comm: bash Not tainted 2.6.34-rc4-blkio-second-crash #81 [ 103.790567] Call Trace: [ 103.790572] [<ffffffff81068f57>] lockdep_rcu_dereference+0x9d/0xa5 [ 103.790577] [<ffffffff8107fac1>] css_id+0x44/0x57 [ 103.790581] [<ffffffff8122e503>] blkiocg_add_blkio_group+0x53/0xad [ 103.790586] [<ffffffff81231936>] cfq_init_queue+0x139/0x32c [ 103.790591] [<ffffffff8121f2d0>] elv_iosched_store+0xbf/0x1bf [ 103.790595] [<ffffffff812263d8>] queue_attr_store+0x70/0x8f [ 103.790599] [<ffffffff8114bfa5>] ? sysfs_write_file+0xe7/0x144 [ 103.790603] [<ffffffff8114bfc6>] sysfs_write_file+0x108/0x144 [ 103.790609] [<ffffffff810f527f>] vfs_write+0xae/0x10b [ 103.790612] [<ffffffff81069863>] ? trace_hardirqs_on_caller+0x10c/0x130 [ 103.790616] [<ffffffff810f539c>] sys_write+0x4a/0x6e [ 103.790622] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 103.790625] Located-by: Miles Lane <miles.lane@gmail.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28cfq-iosched: fix broken cfq_ref_get_cfqf() for CONFIG_BLK_CGROUP=y && ↵Dmitry Monakhov
CFQ_GROUP_IOSCHED=n We should return the cfq_group for this case, not NULL. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-26blk-cgroup: config options re-arrangementVivek Goyal
This patch fixes few usability and configurability issues. o All the cgroup based controller options are configurable from "Genral Setup/Control Group Support/" menu. blkio is the only exception. Hence make this option visible in above menu and make it configurable from there to bring it inline with rest of the cgroup based controllers. o Get rid of CONFIG_DEBUG_CFQ_IOSCHED. This option currently does two things. - Enable printing of cgroup paths in blktrace - Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat files in cgroup. If we are using group scheduling, blktrace data is of not really much use if cgroup information is not present. To get this data, currently one has to also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of all the additional debug stat files which is not desired. Hence, this patch moves printing of cgroup paths under CONFIG_CFQ_GROUP_IOSCHED. This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which can be enabled through config menu. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-26blkio: Fix another BUG_ON() crash due to cfqq movement across groupsVivek Goyal
o Once in a while, I was hitting a BUG_ON() in blkio code. empty_time was assuming that upon slice expiry, group can't be marked empty already (except forced dispatch). But this assumption is broken if cfqq can move (group_isolation=0) across groups after receiving a request. I think most likely in this case we got a request in a cfqq and accounted the rq in one group, later while adding the cfqq to tree, we moved the queue to a different group which was already marked empty and after dispatch from slice we found group already marked empty and raised alarm. This patch does not error out if group is already marked empty. This can introduce some empty_time stat error only in case of group_isolation=0. This is better than crashing. In case of group_isolation=1 we should still get same stats as before this patch. [ 222.308546] ------------[ cut here ]------------ [ 222.309311] kernel BUG at block/blk-cgroup.c:236! [ 222.309311] invalid opcode: 0000 [#1] SMP [ 222.309311] last sysfs file: /sys/devices/virtual/block/dm-3/queue/scheduler [ 222.309311] CPU 1 [ 222.309311] Modules linked in: dm_round_robin dm_multipath qla2xxx scsi_transport_fc dm_zero dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] [ 222.309311] [ 222.309311] Pid: 4780, comm: fio Not tainted 2.6.34-rc4-blkio-config #68 0A98h/HP xw8600 Workstation [ 222.309311] RIP: 0010:[<ffffffff8121ad88>] [<ffffffff8121ad88>] blkiocg_set_start_empty_time+0x50/0x83 [ 222.309311] RSP: 0018:ffff8800ba6e79f8 EFLAGS: 00010002 [ 222.309311] RAX: 0000000000000082 RBX: ffff8800a13b7990 RCX: ffff8800a13b7808 [ 222.309311] RDX: 0000000000002121 RSI: 0000000000000082 RDI: ffff8800a13b7a30 [ 222.309311] RBP: ffff8800ba6e7a18 R08: 0000000000000000 R09: 0000000000000001 [ 222.309311] R10: 000000000002f8c8 R11: ffff8800ba6e7ad8 R12: ffff8800a13b78ff [ 222.309311] R13: ffff8800a13b7990 R14: 0000000000000001 R15: ffff8800a13b7808 [ 222.309311] FS: 00007f3beec476f0(0000) GS:ffff880001e40000(0000) knlGS:0000000000000000 [ 222.309311] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 222.309311] CR2: 000000000040e7f0 CR3: 00000000a12d5000 CR4: 00000000000006e0 [ 222.309311] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 222.309311] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 222.309311] Process fio (pid: 4780, threadinfo ffff8800ba6e6000, task ffff8800b3d6bf00) [ 222.309311] Stack: [ 222.309311] 0000000000000001 ffff8800bab17a48 ffff8800bab17a48 ffff8800a13b7800 [ 222.309311] <0> ffff8800ba6e7a68 ffffffff8121da35 ffff880000000001 00ff8800ba5c5698 [ 222.309311] <0> ffff8800ba6e7a68 ffff8800a13b7800 0000000000000000 ffff8800bab17a48 [ 222.309311] Call Trace: [ 222.309311] [<ffffffff8121da35>] __cfq_slice_expired+0x2af/0x3ec [ 222.309311] [<ffffffff8121fd7b>] cfq_dispatch_requests+0x2c8/0x8e8 [ 222.309311] [<ffffffff8120f1cd>] ? spin_unlock_irqrestore+0xe/0x10 [ 222.309311] [<ffffffff8120fb1a>] ? blk_insert_cloned_request+0x70/0x7b [ 222.309311] [<ffffffff81210461>] blk_peek_request+0x191/0x1a7 [ 222.309311] [<ffffffffa0002799>] dm_request_fn+0x38/0x14c [dm_mod] [ 222.309311] [<ffffffff810ae61f>] ? sync_page_killable+0x0/0x35 [ 222.309311] [<ffffffff81210fd4>] __generic_unplug_device+0x32/0x37 [ 222.309311] [<ffffffff81211274>] generic_unplug_device+0x2e/0x3c [ 222.309311] [<ffffffffa00011a6>] dm_unplug_all+0x42/0x5b [dm_mod] [ 222.309311] [<ffffffff8120ca37>] blk_unplug+0x29/0x2d [ 222.309311] [<ffffffff8120ca4d>] blk_backing_dev_unplug+0x12/0x14 [ 222.309311] [<ffffffff81109a7a>] block_sync_page+0x35/0x39 [ 222.309311] [<ffffffff810ae616>] sync_page+0x41/0x4a [ 222.309311] [<ffffffff810ae62d>] sync_page_killable+0xe/0x35 [ 222.309311] [<ffffffff8158aa59>] __wait_on_bit_lock+0x46/0x8f [ 222.309311] [<ffffffff810ae4f5>] __lock_page_killable+0x66/0x6d [ 222.309311] [<ffffffff81056f9c>] ? wake_bit_function+0x0/0x33 [ 222.309311] [<ffffffff810ae528>] lock_page_killable+0x2c/0x2e [ 222.309311] [<ffffffff810afbc5>] generic_file_aio_read+0x361/0x4f0 [ 222.309311] [<ffffffff810ea044>] do_sync_read+0xcb/0x108 [ 222.309311] [<ffffffff811e42f7>] ? security_file_permission+0x16/0x18 [ 222.309311] [<ffffffff810ea6ab>] vfs_read+0xab/0x108 [ 222.309311] [<ffffffff810ea7c8>] sys_read+0x4a/0x6e [ 222.309311] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 222.309311] Code: 58 01 00 00 00 48 89 c6 75 0a 48 83 bb 60 01 00 00 00 74 09 48 8d bb a0 00 00 00 eb 35 41 fe cc 74 0d f6 83 c0 01 00 00 04 74 04 <0f> 0b eb fe 48 89 75 e8 e8 be e0 de ff 66 83 8b c0 01 00 00 04 [ 222.309311] RIP [<ffffffff8121ad88>] blkiocg_set_start_empty_time+0x50/0x83 [ 222.309311] RSP <ffff8800ba6e79f8> [ 222.309311] ---[ end trace 32b4f71dffc15712 ]--- Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-21blkio: Fix blkio crash during rq stat updateVivek Goyal
blkio + cfq was crashing even when two sequential readers were put in two separate cgroups (group_isolation=0). The reason being that cfqq can migrate across groups based on its being sync-noidle or not, it can happen that at request insertion time, cfqq belonged to one cfqg and at request dispatch time, it belonged to root group. In this case request stats per cgroup can go wrong and it also runs into BUG_ON(). This patch implements rq stashing away a cfq group pointer and not relying on cfqq->cfqg pointer alone for rq stat accounting. [ 65.163523] ------------[ cut here ]------------ [ 65.164301] kernel BUG at block/blk-cgroup.c:117! [ 65.164301] invalid opcode: 0000 [#1] SMP [ 65.164301] last sysfs file: /sys/devices/pci0000:00/0000:00:05.0/0000:60:00.1/host9/rport-9:0-0/target9:0:0/9:0:0:2/block/sde/stat [ 65.164301] CPU 1 [ 65.164301] Modules linked in: dm_round_robin dm_multipath qla2xxx scsi_transport_fc dm_zero dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] [ 65.164301] [ 65.164301] Pid: 4505, comm: fio Not tainted 2.6.34-rc4-blk-for-35 #34 0A98h/HP xw8600 Workstation [ 65.164301] RIP: 0010:[<ffffffff8121924f>] [<ffffffff8121924f>] blkiocg_update_io_remove_stats+0x5b/0xaf [ 65.164301] RSP: 0018:ffff8800ba5a79e8 EFLAGS: 00010046 [ 65.164301] RAX: 0000000000000096 RBX: ffff8800bb268d60 RCX: 0000000000000000 [ 65.164301] RDX: ffff8800bb268eb8 RSI: 0000000000000000 RDI: ffff8800bb268e00 [ 65.164301] RBP: ffff8800ba5a7a08 R08: 0000000000000064 R09: 0000000000000001 [ 65.164301] R10: 0000000000079640 R11: ffff8800a0bd5bf0 R12: ffff8800bab4af01 [ 65.164301] R13: ffff8800bab4af00 R14: ffff8800bb1d8928 R15: 0000000000000000 [ 65.164301] FS: 00007f18f75056f0(0000) GS:ffff880001e40000(0000) knlGS:0000000000000000 [ 65.164301] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 65.164301] CR2: 000000000040e7f0 CR3: 00000000ba52b000 CR4: 00000000000006e0 [ 65.164301] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 65.164301] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 65.164301] Process fio (pid: 4505, threadinfo ffff8800ba5a6000, task ffff8800ba45ae80) [ 65.164301] Stack: [ 65.164301] ffff8800ba5a7a08 ffff8800ba722540 ffff8800bab4af68 ffff8800bab4af68 [ 65.164301] <0> ffff8800ba5a7a38 ffffffff8121d814 ffff8800ba722540 ffff8800bab4af68 [ 65.164301] <0> ffff8800ba722540 ffff8800a08f6800 ffff8800ba5a7a68 ffffffff8121d8ca [ 65.164301] Call Trace: [ 65.164301] [<ffffffff8121d814>] cfq_remove_request+0xe4/0x116 [ 65.164301] [<ffffffff8121d8ca>] cfq_dispatch_insert+0x84/0xe1 [ 65.164301] [<ffffffff8121e833>] cfq_dispatch_requests+0x767/0x8e8 [ 65.164301] [<ffffffff8120e524>] ? submit_bio+0xc3/0xcc [ 65.164301] [<ffffffff810ad657>] ? sync_page_killable+0x0/0x35 [ 65.164301] [<ffffffff8120ea8d>] blk_peek_request+0x191/0x1a7 [ 65.164301] [<ffffffffa000109c>] ? dm_get_live_table+0x44/0x4f [dm_mod] [ 65.164301] [<ffffffffa0002799>] dm_request_fn+0x38/0x14c [dm_mod] [ 65.164301] [<ffffffff810ad657>] ? sync_page_killable+0x0/0x35 [ 65.164301] [<ffffffff8120f600>] __generic_unplug_device+0x32/0x37 [ 65.164301] [<ffffffff8120f8a0>] generic_unplug_device+0x2e/0x3c [ 65.164301] [<ffffffffa00011a6>] dm_unplug_all+0x42/0x5b [dm_mod] [ 65.164301] [<ffffffff8120b063>] blk_unplug+0x29/0x2d [ 65.164301] [<ffffffff8120b079>] blk_backing_dev_unplug+0x12/0x14 [ 65.164301] [<ffffffff81108a82>] block_sync_page+0x35/0x39 [ 65.164301] [<ffffffff810ad64e>] sync_page+0x41/0x4a [ 65.164301] [<ffffffff810ad665>] sync_page_killable+0xe/0x35 [ 65.164301] [<ffffffff81589027>] __wait_on_bit_lock+0x46/0x8f [ 65.164301] [<ffffffff810ad52d>] __lock_page_killable+0x66/0x6d [ 65.164301] [<ffffffff81055fd4>] ? wake_bit_function+0x0/0x33 [ 65.164301] [<ffffffff810ad560>] lock_page_killable+0x2c/0x2e [ 65.164301] [<ffffffff810aebfd>] generic_file_aio_read+0x361/0x4f0 [ 65.164301] [<ffffffff810e906c>] do_sync_read+0xcb/0x108 [ 65.164301] [<ffffffff811e32a3>] ? security_file_permission+0x16/0x18 [ 65.164301] [<ffffffff810e96d3>] vfs_read+0xab/0x108 [ 65.164301] [<ffffffff810e97f0>] sys_read+0x4a/0x6e [ 65.164301] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 65.164301] Code: 00 74 1c 48 8b 8b 60 01 00 00 48 85 c9 75 04 0f 0b eb fe 48 ff c9 48 89 8b 60 01 00 00 eb 1a 48 8b 8b 58 01 00 00 48 85 c9 75 04 <0f> 0b eb fe 48 ff c9 48 89 8b 58 01 00 00 45 84 e4 74 16 48 8b [ 65.164301] RIP [<ffffffff8121924f>] blkiocg_update_io_remove_stats+0x5b/0xaf [ 65.164301] RSP <ffff8800ba5a79e8> [ 65.164301] ---[ end trace 1b2b828753032e68 ]--- Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-16blkio: Initialize blkg->stats_lock for the root cfqg tooDivyesh Shah
This fixes the lockdep warning reported by Gui Jianfeng. Signed-off-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-14blkio: Fix compile errorsDivyesh Shah
Fixes compile errors in blk-cgroup code for empty_time stat and a merge fix in CFQ. The first error was when CONFIG_DEBUG_CFQ_IOSCHED is not set. Signed-off-by: Divyesh Shah <dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-13Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: block/blk-cgroup.c block/cfq-iosched.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-13block: Update to io-controller statsDivyesh Shah
Changelog from v1: o Call blkiocg_update_idle_time_stats() at cfq_rq_enqueued() instead of at dispatch time. Changelog from original patchset: (in response to Vivek Goyal's comments) o group blkiocg_update_blkio_group_dequeue_stats() with other DEBUG functions o rename blkiocg_update_set_active_queue_stats() to blkiocg_update_avg_queue_size_stats() o s/request/io/ in blkiocg_update_request_add_stats() and blkiocg_update_request_remove_stats() o Call cfq_del_timer() at request dispatch() instead of blkiocg_update_idle_time_stats() Signed-off-by: Divyesh Shah<dpshah@google.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-13io-controller: Add a new interface "weight_device" for IO-ControllerGui Jianfeng
Currently, IO Controller makes use of blkio.weight to assign weight for all devices. Here a new user interface "blkio.weight_device" is introduced to assign different weights for different devices. blkio.weight becomes the default value for devices which are not configured by "blkio.weight_device" You can use the following format to assigned specific weight for a given device: #echo "major:minor weight" > blkio.weight_device major:minor represents device number. And you can remove weight for a given device as following: #echo "major:minor 0" > blkio.weight_device V1->V2 changes: - use user interface "weight_device" instead of "policy" suggested by Vivek - rename some struct suggested by Vivek - rebase to 2.6-block "for-linus" branch - remove an useless list_empty check pointed out by Li Zefan - some trivial typo fix V2->V3 changes: - Move policy_*_node() functions up to get rid of forward declarations - rename related functions by adding prefix "blkio_" Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits) cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch loop: Update mtime when writing using aops block: expose the statistics in blkio.time and blkio.sectors for the root cgroup backing-dev: Handle class_create() failure Block: Fix block/elevator.c elevator_get() off-by-one error drbd: lc_element_by_index() never returns NULL cciss: unlock on error path cfq-iosched: Do not merge queues of BE and IDLE classes cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging i2o: Remove the dangerous kobj_to_i2o_device macro block: remove 16 bytes of padding from struct request on 64bits cfq-iosched: fix a kbuild regression block: make CONFIG_BLK_CGROUP visible Remove GENHD_FL_DRIVERFS block: Export max number of segments and max segment size in sysfs block: Finalize conversion of block limits functions block: Fix overrun in lcm() and move it to lib vfs: improve writeback_inodes_wb() paride: fix off-by-one test drbd: fix al-to-on-disk-bitmap for 4k logical_block_size ...
2010-04-09cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatchDivyesh Shah
When CFQ dispatches requests forcefully due to a barrier or changing iosched, it runs through all cfqq's dispatching requests and then expires each queue. However, it does not activate a cfqq before flushing its IOs resulting in using stale values for computing slice_used. This patch fixes it by calling activate queue before flushing reuqests from each queue. This is useful mostly for barrier requests because when the iosched is changing it really doesnt matter if we have incorrect accounting since we're going to break down all structures anyway. We also now expire the current timeslice before moving on with the dispatch to accurately account slice used for that cfqq. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add more debug-only per-cgroup statsDivyesh Shah
1) group_wait_time - This is the amount of time the cgroup had to wait to get a timeslice for one of its queues from when it became busy, i.e., went from 0 to 1 request queued. This is different from the io_wait_time which is the cumulative total of the amount of time spent by each IO in that cgroup waiting in the scheduler queue. This stat is a great way to find out any jobs in the fleet that are being starved or waiting for longer than what is expected (due to an IO controller bug or any other issue). 2) empty_time - This is the amount of time a cgroup spends w/o any pending requests. This stat is useful when a job does not seem to be able to use its assigned disk share by helping check if that is happening due to an IO controller bug or because the job is not submitting enough IOs. 3) idle_time - This is the amount of time spent by the IO scheduler idling for a given cgroup in anticipation of a better request than the exising ones from other queues/cgroups. All these stats are recorded using start and stop events. When reading these stats, we do not add the delta between the current time and the last start time if we're between the start and stop events. We avoid doing this to make sure that these numbers are always monotonically increasing when read. Since we're using sched_clock() which may use the tsc as its source, it may induce some inconsistency (due to tsc resync across cpus) if we included the current delta. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add io_queued and avg_queue_size statsDivyesh Shah
These stats are useful for getting a feel for the queue depth of the cgroup, i.e., how filled up its queues are at a given instant and over the existence of the cgroup. This ability is useful when debugging problems in the wild as it helps understand the application's IO pattern w/o having to read through the userspace code (coz its tedious or just not available) or w/o the ability to run blktrace (since you may not have root access and/or not want to disturb performance). Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Add io_merged statDivyesh Shah
This includes both the number of bios merged into requests belonging to this cgroup as well as the number of requests merged together. In the past, we've observed different merging behavior across upstream kernels, some by design some actual bugs. This stat helps a lot in debugging such problems when applications report decreased throughput with a new kernel version. This needed adding an extra elevator function to capture bios being merged as I did not want to pollute elevator code with blkiocg knowledge and hence needed the accounting invocation to come from CFQ. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-09blkio: Changes to IO controller additional stats patchesDivyesh Shah
that include some minor fixes and addresses all comments. Changelog: (most based on Vivek Goyal's comments) o renamed blkiocg_reset_write to blkiocg_reset_stats o more clarification in the documentation on io_service_time and io_wait_time o Initialize blkg->stats_lock o rename io_add_stat to blkio_add_stat and declare it static o use bool for direction and sync o derive direction and sync info from existing rq methods o use 12 for major:minor string length o define io_service_time better to cover the NCQ case o add a separate reset_stats interface o make the indexed stats a 2d array to simplify macro and function pointer code o blkio.time now exports in jiffies as before o Added stats description in patch description and Documentation/cgroup/blkio-controller.txt o Prefix all stats functions with blkio and make them static as applicable o replace IO_TYPE_MAX with IO_TYPE_TOTAL o Moved #define constant to top of blk-cgroup.c o Pass dev_t around instead of char * o Add note to documentation file about resetting stats o use BLK_CGROUP_MODULE in addition to BLK_CGROUP config option in #ifdef statements o Avoid struct request specific knowledge in blk-cgroup. blk-cgroup.h now has rq_direction() and rq_sync() functions which are used by CFQ and when using io-controller at a higher level, bio_* functions can be added. Signed-off-by: Divyesh Shah<dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
