path: root/block
2008-04-15block: update git url for blktraceJens Axboe
2008-04-10cfq-iosched: do not leak ioc_data across iosched switchesFabio Checconi
When switching scheduler from cfq, cfq_exit_queue() does not clear ioc->ioc_data, leaving a dangling pointer that can deceive the following lookups when the iosched is switched back to cfq. The pattern that can trigger that is the following: - elevator switch from cfq to something else; - module unloading, with elv_unregister() that calls cfq_free_io_context() on ioc freeing the cic (via the .trim op); - module gets reloaded and the elevator switches back to cfq; - reallocation of a cic at the same address as before (with a valid key). To fix it just assign NULL to ioc_data in __cfq_exit_single_io_context(), that is called from the regular exit path and from the elevator switching code. The only path that frees a cic and is not covered is the error handling one, but cic's freed in this way are never cached in ioc_data. Signed-off-by: Fabio Checconi <fabio@gandalf.sssup.it> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-02cfq-iosched: fix rcu freeing of cfq io contextsFabio Checconi
SLAB_DESTROY_BY_RCU is not a direct substitute for normal call_rcu() freeing, since it'll page freeing but NOT object freeing. So change cfq to do the freeing on its own. Signed-off-by: Fabio Checconi <fabio@gandalf.sssup.it> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-02Fix bounce setting for 64-bitAndrea Arcangeli
Looking a bit closer into this regression the reason this can't be right is that dma_addr common default is BLK_BOUNCE_HIGH and most machines have less than 4G. So if you do: if (b_pfn <= (min_t(u64, 0xffffffff, BLK_BOUNCE_HIGH) >> PAGE_SHIFT)) dma = 1 that will translate to: if (BLK_BOUNCE_HIGH <= BLK_BOUNCE_HIGH) dma = 1 So for 99% of hardware this will trigger unnecessary GFP_DMA allocations and isa pooling operations. Also note how the 32bit code still does b_pfn < blk_max_low_pfn. I guess this is what you were looking after. I didn't verify but as far as I can tell, this will stop the regression with isa dma operations at boot for 99% of blkdev/memory combinations out there and I guess this fixes the setups with >4G of ram and 32bit pci cards as well (this also retains symmetry with the 32bit code). Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-12genhd must_check warning fixRoland McGrath
Fixes: block/genhd.c:361: warning: ignoring return value of ‘class_register’, declared with attribute warn_unused_result Signed-off-by: Roland McGrath <roland@redhat.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04block: fix blkdev_issue_flush() not detecting and passing EOPNOTSUPP backJens Axboe
This is important to eg dm, that tries to decide whether to stop using barriers or not. Tested as working by Anders Henke <anders.henke@1und1.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: fix shadowed variable warning in blk-map.cHarvey Harrison
Introduced between 2.6.25-rc2 and -rc3 block/blk-map.c:154:14: warning: symbol 'bio' shadows an earlier one block/blk-map.c:110:13: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: remove extern on function definitionHarvey Harrison
Intoduced between 2.6.25-rc2 and -rc3 block/blk-settings.c:319:12: warning: function 'blk_queue_dma_drain' with external linkage has definition Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04unexport blk_rq_map_user_iovAdrian Bunk
This patch removes the unused export of blk_rq_map_user_iov. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04unexport blk_{get,put}_queueAdrian Bunk
This patch removes the unused exports of blk_{get,put}_queue. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block/genhd.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the needlessly global struct disk_type static - #if 0 the unused genhd_media_change_notify() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04proper prototype for blk_dev_init()Adrian Bunk
This patch adds a proper prototye for blk_dev_init() in block/blk.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block/blk-tag.c should #include "blk.h"Adrian Bunk
Every file should include the headers containing the externs for its global functions (in this case for __blk_queue_free_tags()). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04Fix DMA access of block device in 64-bit kernel on some non-x86 systems with ↵Yang Shi
4GB or upper 4GB memory For some non-x86 systems with 4GB or upper 4GB memory, we need increase the range of addresses that can be used for direct DMA in 64-bit kernel. Signed-off-by: Yang Shi <yang.shi@windriver.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: separate out padding from alignmentTejun Heo
Block layer alignment was used for two different purposes - memory alignment and padding. This causes problems in lower layers because drivers which only require memory alignment ends up with adjusted rq->data_len. Separate out padding such that padding occurs iff driver explicitly requests it. Tomo: restorethe code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa according to padding alignment. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: restore the meaning of rq->data_len to the true data lengthFUJITA Tomonori
The meaning of rq->data_len was changed to the length of an allocated buffer from the true data length. It breaks SG_IO friends and bsg. This patch restores the meaning of rq->data_len to the true data length and adds rq->extra_len to store an extended length (due to drain buffer and padding). This patch also removes the code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa. The commit adjusts bio according to memory alignment (queue_dma_alignment). However, memory alignment is NOT padding alignment. This adjustment also breaks SG_IO friends and bsg. Padding alignment needs to be fixed in a proper way (by a separate patch). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-03-04block: fix kernel-docbook parameters and filesRandy Dunlap
kernel-doc for block/: - add missing parameters - fix one function's parameter list (remove blank line) - add 2 source files to docbook for non-exported kernel-doc functions Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: clear drain buffer if draining for write commandTejun Heo
Clear drain buffer before chaining if the command in question is a write. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: implement request_queue->dma_drain_neededTejun Heo
Draining shouldn't be done for commands where overflow may indicate data integrity issues. Add dma_drain_needed callback to request_queue. Drain buffer is appened iff this function returns non-zero. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: add request->raw_data_lenTejun Heo
With padding and draining moved into it, block layer now may extend requests as directed by queue parameters, so now a request has two sizes - the original request size and the extended size which matches the size of area pointed to by bios and later by sgs. The latter size is what lower layers are primarily interested in when allocating, filling up DMA tables and setting up the controller. Both padding and draining extend the data area to accomodate controller characteristics. As any controller which speaks SCSI can handle underflows, feeding larger data area is safe. So, this patch makes the primary data length field, request->data_len, indicate the size of full data area and add a separate length field, request->raw_data_len, for the unmodified request size. The latter is used to report to higher layer (userland) and where the original request size should be fed to the controller or device. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: update bio according to DMA alignment paddingTejun Heo
DMA start address and transfer size alignment for PC requests are achieved using bio_copy_user() instead of bio_map_user(). This works because bio_copy_user() always uses full pages and block DMA alignment isn't allowed to go over PAGE_SIZE. However, the implementation didn't update the last bio of the request to make this padding visible to lower layers. This patch makes blk_rq_map_user() extend the last bio such that it includes the padding area and the size of area pointed to by the request is properly aligned. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19elevator: make elevator_get() attempt to load the appropriate moduleJens Axboe
Currently we fail if someone requests a valid io scheduler, but it's modular and not currently loaded. That can happen from a driver init asking for a different scheduler, or online switching through sysfs as requested by a user. This patch makes elevator_get() request_module() to attempt to load the appropriate module, instead of requiring that done manually. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19cfq-iosched: add hlist for browsing parallel to the radix treeJens Axboe
It's cumbersome to browse a radix tree from start to finish, especially since we modify keys when a process exits. So add a hlist for the single purpose of browsing over all known cfq_io_contexts, used for exit, io prio change, etc. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=9948 Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: make blk_rq_map_user() clear ->bio if it unmaps itJens Axboe
That way the interface is symmetric, and calling blk_rq_unmap_user() on the request wont oops. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19make blk_settings_init() staticAdrian Bunk
blk_settings_init() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-19make blk_ioc_init() staticAdrian Bunk
blk_ioc_init() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-19make blk-core.c:request_cachep static againAdrian Bunk
request_cachep needlessly became global. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-08Enhanced partition statistics: remove old partition statisticsJerome Marchand
Removes the now unused old partition statistic code. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-08Enhanced partition statistics: procfsJerome Marchand
Reports enhanced partition statistics in /proc/diskstats. Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
2008-02-08Enhanced partition statistics: update partition statiticsJerome Marchand
Updates the enhanced partition statistics in generic block layer besides the disk statistics. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-08block: fixup rq_init() a bitJens Axboe
Rearrange fields in cache order and initialize some fields that we didn't previously init. Remove init of ->completion_data, it's part of a union with ->hash. Luckily clearing the rb node is the same as setting it to null! Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: kill swap_io_context()Jens Axboe
It blindly copies everything in the io_context, including the lock. That doesn't work so well for either lock ordering or lockdep. There seems zero point in swapping io contexts on a request to request merge, so the best point of action is to just remove it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01as-iosched: fix inconsistent ioc->lock contextJens Axboe
Since it's acquired from irq context, all locking must be of the irq safe variant. Most are already inside the queue lock (which already disables interrupts), but the io scheduler rmmod path always has irqs enabled and the put_io_context() path may legally be called with irqs enabled (even if it isn't usually). So fixup those two. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: make elevator lib checkpatch compliantJens Axboe
2008-02-01cfq-iosched: make checkpatch compliantJens Axboe
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-02-01block: new end request handling interface should take unsigned byte countsJens Axboe
No point in passing signed integers as the byte count, they can never be negative. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-30[SCSI] bsg: copy the cmd_type field to the subordinate request for bidiJames Bottomley
This fixes a problem in SCSI where we use the (previously uninitialised) cmd_type via blk_pc_request() to set up the transfer in scsi_init_sgtable(). Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30as-iosched: fix double locking bug in as_merged_requests()Jens Axboe
If the two requests belong to the same io context, we will attempt to lock the same lock twice. But swapping contexts is pointless in that case, so just check for rioc == nioc before doing the double lock and copy. Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Expose hardware sector sizeMartin K. Petersen
Expose hardware sector size in sysfs queue directory. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: ll_rw_blk.c split, add blk-merge.cJens Axboe
2008-01-29block: remove dated (and wrong) comment in blk-core.cJens Axboe
2008-01-29block: get rid of unnecessary forward declarations in blk-core.cJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: split tag and sysfs handling from blk-core.cJens Axboe
Seperates the tag and sysfs handling from ll_rw_blk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: first step of splitting ll_rw_blk, rename itJens Axboe
Then we retain history in blk-core.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Merge branch 'for-2.6.25' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.25' of git://git.kernel.dk/linux-2.6-block: block: implement drain buffers __bio_clone: don't calculate hw/phys segment counts block: allow queue dma_alignment of zero blktrace: Add blktrace ioctls to SCSI generic devices
2008-01-29Merge branch 'blk-end-request' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'blk-end-request' of git://git.kernel.dk/linux-2.6-block: (30 commits) blk_end_request: changing xsysace (take 4) blk_end_request: changing ub (take 4) blk_end_request: cleanup of request completion (take 4) blk_end_request: cleanup 'uptodate' related code (take 4) blk_end_request: remove/unexport end_that_request_* (take 4) blk_end_request: changing scsi (take 4) blk_end_request: add bidi completion interface (take 4) blk_end_request: changing ide-cd (take 4) blk_end_request: add callback feature (take 4) blk_end_request: changing ide normal caller (take 4) blk_end_request: changing cpqarray (take 4) blk_end_request: changing cciss (take 4) blk_end_request: changing ide-scsi (take 4) blk_end_request: changing s390 (take 4) blk_end_request: changing mmc (take 4) blk_end_request: changing i2o_block (take 4) blk_end_request: changing viocd (take 4) blk_end_request: changing xen-blkfront (take 4) blk_end_request: changing viodasd (take 4) blk_end_request: changing sx8 (take 4) ...
2008-01-28cfq-iosched: kill some big inlinesJens Axboe
Use of inlines were a bit over the top, trim them down a bit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
