commit c8123f8c9cb517403b51aa41c3c46ff5e10b2c17 upstream.
When mkfs issues a full device discard and the device only
supports discards of a smallish size, we can loop in
blkdev_issue_discard() for a long time. If preempt isn't enabled,
this can turn into a softlock situation and the kernel will
start complaining.
Add an explicit cond_resched() at the end of the loop to avoid
that.
Signed-off-by: Jens Axboe <axboe@fb.com>
commit fff4996b7db7955414ac74386efa5e07fd766b50 upstream.
If blkcg_init_queue fails, blk_alloc_queue_node doesn't call bdi_destroy
to clean up structures allocated by the backing dev.
WARNING: at lib/debugobjects.c:260 debug_print_object+0x85/0xa0()
ODEBUG: free active (active state 0) object type: percpu_counter hint: (null)
Modules linked in: dm_loop dm_mod ip6table_filter ip6_tables uvesafb cfbcopyarea cfbimgblt cfbfillrect fbcon font bitblit fbcon_rotate fbcon_cw fbcon_ud fbcon_ccw softcursor fb fbdev ipt_MASQUERADE iptable_nat nf_nat_ipv4 msr nf_conntrack_ipv4 nf_defrag_ipv4 xt_state ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp llc tun ipv6 cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_ondemand cpufreq_conservative spadfs fuse hid_generic usbhid hid raid0 md_mod dmi_sysfs nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack lm85 hwmon_vid snd_usb_audio snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_hwdep snd_usbmidi_lib snd_rawmidi snd soundcore acpi_cpufreq freq_table mperf sata_svw serverworks kvm_amd ide_core ehci_pci ohci_hcd libata ehci_hcd kvm usbcore tg3 usb_common libphy k10temp pcspkr ptp i2c_piix4 i2c_core evdev microcode hwmon rtc_cmos pps_core e100 skge floppy mii processor button unix
CPU: 0 PID: 2739 Comm: lvchange Tainted: G W
3.10.15-devel #14
Hardware name: empty empty/S3992-E, BIOS 'V1.06 ' 06/09/2009
0000000000000009 ffff88023c3c1ae8 ffffffff813c8fd4 ffff88023c3c1b20
ffffffff810399eb ffff88043d35cd58 ffffffff81651940 ffff88023c3c1bf8
ffffffff82479d90 0000000000000005 ffff88023c3c1b80 ffffffff81039a67
Call Trace:
[<ffffffff813c8fd4>] dump_stack+0x19/0x1b
[<ffffffff810399eb>] warn_slowpath_common+0x6b/0xa0
[<ffffffff81039a67>] warn_slowpath_fmt+0x47/0x50
[<ffffffff8122aaaf>] ? debug_check_no_obj_freed+0xcf/0x250
[<ffffffff81229a15>] debug_print_object+0x85/0xa0
[<ffffffff8122abe3>] debug_check_no_obj_freed+0x203/0x250
[<ffffffff8113c4ac>] kmem_cache_free+0x20c/0x3a0
[<ffffffff811f6709>] blk_alloc_queue_node+0x2a9/0x2c0
[<ffffffff811f672e>] blk_alloc_queue+0xe/0x10
[<ffffffffa04c0093>] dm_create+0x1a3/0x530 [dm_mod]
[<ffffffffa04c6bb0>] ? list_version_get_info+0xe0/0xe0 [dm_mod]
[<ffffffffa04c6c07>] dev_create+0x57/0x2b0 [dm_mod]
[<ffffffffa04c6528>] ctl_ioctl+0x268/0x500 [dm_mod]
[<ffffffff81097662>] ? get_lock_stats+0x22/0x70
[<ffffffffa04c67ce>] dm_ctl_ioctl+0xe/0x20 [dm_mod]
[<ffffffff81161aad>] do_vfs_ioctl+0x2ed/0x520
[<ffffffff8116cfc7>] ? fget_light+0x377/0x4e0
[<ffffffff81161d2b>] SyS_ioctl+0x4b/0x90
[<ffffffff813cff16>] system_call_fastpath+0x1a/0x1f
---[ end trace 4b5ff0d55673d986 ]---
This fix should be backported to stable kernels starting with 2.6.37. Note
that in the kernels prior to 3.5 the affected code is different, but the
bug is still there - bdi_init is called and bdi_destroy isn't.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
[bwh: Backported to 3.2: add bdi_destroy() to the single error path
after the call to bdi_init()]
commit 4912aa6c11e6a5d910264deedbec2075c6f1bb73 upstream.
crocode i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support shpchp ioatdma dca be2net sg ses enclosure ext4 mbcache jbd2 sd_mod crc_t10dif ahci megaraid_sas(U) dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 491, comm: scsi_eh_0 Tainted: G W ---------------- 2.6.32-220.13.1.el6.x86_64 #1 IBM -[8722PAX]-/00D1461
RIP: 0010:[<ffffffff8124e424>] [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP: 0018:ffff881057eefd60 EFLAGS: 00010012
RAX: ffff881d99e3e8a8 RBX: ffff881d99e3e780 RCX: ffff881d99e3e8a8
RDX: ffff881d99e3e8a8 RSI: ffff881d99e3e780 RDI: ffff881d99e3e780
RBP: ffff881057eefd80 R08: ffff881057eefe90 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff881057f92338
R13: 0000000000000000 R14: ffff881057f92338 R15: ffff883058188000
FS: 0000000000000000(0000) GS:ffff880040200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006d3ec0 CR3: 000000302cd7d000 CR4: 00000000000406b0
Process scsi_eh_0 (pid: 491, threadinfo ffff881057eee000, task ffff881057e29540)
Stack:
0000000000001057 0000000000000286 ffff8810275efdc0 ffff881057f16000
<0> ffff881057eefdd0 ffffffff81362323 ffff881057eefe20 ffffffff8135f393
<0> ffff881057e29af8 ffff8810275efdc0 ffff881057eefe78 ffff881057eefe90
Call Trace:
[<ffffffff81362323>] __scsi_queue_insert+0xa3/0x150
[<ffffffff8135f393>] ? scsi_eh_ready_devs+0x5e3/0x850
[<ffffffff81362a23>] scsi_queue_insert+0x13/0x20
[<ffffffff8135e4d4>] scsi_eh_flush_done_q+0x104/0x160
[<ffffffff8135fb6b>] scsi_error_handler+0x35b/0x660
[<ffffffff8135f810>] ? scsi_error_handler+0x0/0x660
[<ffffffff810908c6>] kthread+0x96/0xa0
[<ffffffff8100c14a>] child_rip+0xa/0x20
[<ffffffff81090830>] ? kthread+0x0/0xa0
[<ffffffff8100c140>] ? child_rip+0x0/0x20
Code: 00 00 eb d1 4c 8b 2d 3c 8f 97 00 4d 85 ed 74 bf 49 8b 45 00 49 83 c5 08 48 89 de 4c 89 e7 ff d0 49 8b 45 00 48 85 c0 75 eb eb a4 <0f> 0b eb fe 0f 1f 84 00 00 00 00 00 55 48 89 e5 0f 1f 44 00 00
RIP [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP <ffff881057eefd60>
The RIP is this line:
BUG_ON(blk_queued_rq(rq));
After digging through the code, I think there may be a race between the
request completion and the timer handler running.
A timer is started for each request put on the device's queue (see
blk_start_request->blk_add_timer). If the request does not complete
before the timer expires, the timer handler (blk_rq_timed_out_timer)
will mark the request complete atomically:
static inline int blk_mark_rq_complete(struct request *rq)
return test_and_set_bit(REQ_ATOM_COMPLETE, &rq->atomic_flags);
and then call blk_rq_timed_out. The latter function will call
scsi_times_out, which will return one of BLK_EH_HANDLED,
BLK_EH_RESET_TIMER or BLK_EH_NOT_HANDLED. If BLK_EH_RESET_TIMER is
returned, blk_clear_rq_complete is called, and blk_add_timer is again
called to simply wait longer for the request to complete.
Now, if the request happens to complete while this is going on, what
happens? Given that we know the completion handler will bail if it
finds the REQ_ATOM_COMPLETE bit set, we need to focus on the completion
handler running after that bit is cleared. So, from the above
paragraph, after the call to blk_clear_rq_complete. If the completion
sets REQ_ATOM_COMPLETE before the BUG_ON in blk_add_timer, we go boom
there (I haven't seen this in the cores). Next, if we get the
completion before the call to list_add_tail, then the timer will
eventually fire for an old req, which may either be freed or reallocated
(there is evidence that this might be the case). Finally, if the
completion comes in *after* the addition to the timeout list, I think
it's harmless. The request will be removed from the timeout list,
req_atom_complete will be set, and all will be well.
This will only actually explain the coredumps *IF* the request
structure was freed, reallocated *and* queued before the error handler
thread had a chance to process it. That is possible, but it may make
sense to keep digging for another race. I think that if this is what
was happening, we would see other instances of this problem showing up
as null pointer or garbage pointer dereferences, for example when the
request structure was not re-used. It looks like we actually do run
into that situation in other reports.
This patch moves the BUG_ON(test_bit(REQ_ATOM_COMPLETE,
&req->atomic_flags)); from blk_add_timer to the only caller that could
trip over it (blk_start_request). It then inverts the calls to
blk_clear_rq_complete and blk_add_timer in blk_rq_timed_out to address
the race. I've boot tested this patch, but nothing more.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Hannes Reinecke <hare@suse.de>
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream.
Disk names may contain arbitrary strings, so they must not be
interpreted as format strings. It seems that only md allows arbitrary
strings to be used for disk names, but this could allow for a local
memory corruption from uid 0 into ring 0.
CVE-2013-2851
[bwh: Backported to 3.2: adjust device pointer name in nbd.c]
commit c678ef5286ddb5cf70384ad5af286b0afc9b73e1 upstream.
As found by gcc-4.8, the QUEUE_SYSFS_BIT_FNS macro creates functions
that use a value generated by queue_var_store independent of whether
that value was set or not.
block/blk-sysfs.c: In function 'queue_store_nonrot':
block/blk-sysfs.c:244:385: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
Unlike most other such warnings, this one is not a false positive,
writing any non-number string into the sysfs files indeed has
an undefined result, rather than returning an error.
commit ce23bba842aee98092225d9576dba47c82352521 upstream.
idr allocation in blk_alloc_devt() wasn't synchronized against lookup
and removal, and its limit check was off by one - 1 << MINORBITS is
the number of minors allowed, not the maximum allowed minor.
Add locking and rename MAX_EXT_DEVT to NR_EXT_DEVT and fix limit
checking.
Acked-by: Jens Axboe <axboe@kernel.dk>
commit 7b74e912785a11572da43292786ed07ada7e3e0c upstream.
While adding and removing a lot of disks disks and partitions this
sometimes shows up:
WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted)
Hardware name:
sysfs: cannot create duplicate filename '/dev/block/259:751'
Modules linked in: raid1 autofs4 bnx2fc cnic uio fcoe libfcoe libfc 8021q scsi_transport_fc scsi_tgt garp stp llc sunrpc cpufreq_ondemand powernow_k8 freq_table mperf ipv6 dm_mirror dm_region_hash dm_log power_meter microcode dcdbas serio_raw amd64_edac_mod edac_core edac_mce_amd i2c_piix4 i2c_core k10temp bnx2 sg ixgbe dca mdio ext4 mbcache jbd2 dm_round_robin sr_mod cdrom sd_mod crc_t10dif ata_generic pata_acpi pata_atiixp ahci mptsas mptscsih mptbase scsi_transport_sas dm_multipath dm_mod [last unloaded: scsi_wait_scan]
Pid: 44103, comm: async/16 Not tainted 2.6.32-195.el6.x86_64 #1
Call Trace:
warn_slowpath_common+0x87/0xc0
warn_slowpath_fmt+0x46/0x50
sysfs_do_create_link+0x12b/0x170
sysfs_create_link+0x13/0x20
device_add+0x317/0x650
idr_get_new+0x13/0x50
add_partition+0x21c/0x390
rescan_partitions+0x32b/0x470
sd_open+0x81/0x1f0 [sd_mod]
__blkdev_get+0x1b6/0x3c0
blkdev_get+0x10/0x20
register_disk+0x155/0x170
add_disk+0xa6/0x160
sd_probe_async+0x13b/0x210 [sd_mod]
add_wait_queue+0x46/0x60
async_thread+0x102/0x250
default_wake_function+0x0/0x20
async_thread+0x0/0x250
kthread+0x96/0xa0
child_rip+0xa/0x20
kthread+0x0/0xa0
child_rip+0x0/0x20
This most likely happens because dev_t is freed while the number is
still used and idr_get_new() is not protected on every use. The fix
adds a mutex where it wasn't before and moves the dev_t free function so
it is called after device del.
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
[bwh: Backported to 3.2: adjust filename]
commit 893d290f1d7496db97c9471bc352ad4a11dc8a25 upstream.
After we've done __elv_add_request() and __blk_run_queue() in
blk_execute_rq_nowait(), the request might finish and be freed
immediately. Therefore checking if the type is REQ_TYPE_PM_RESUME
isn't safe afterwards, because if it isn't, rq might be gone.
Instead, check beforehand and stash the result in a temporary.
This fixes crashes in blk_execute_rq_nowait() I get occasionally when
running with lots of memory debugging options enabled -- I think this
race is usually harmless because the window for rq to be reallocated
is so small.
Signed-off-by: Roland Dreier <roland@purestorage.com>
[bwh: Backported to 3.2: adjust context]
commit 34f6055c80285e4efb3f602a9119db75239744dc upstream.
There are a number of QUEUE_FLAG_DEAD tests. Add blk_queue_dead()
macro and use it.
This patch doesn't introduce any functional difference.
commit 6d9359280753d2955f86d6411047516a9431eb51 upstream.
Sometimes, warnings about ioctls to partition happen often enough that they
form majority of the warnings in the kernel log and users complain. In some
cases warnings are about ioctls such as SG_IO so it's not good to get rid of
the warnings completely as they can ease debugging of userspace problems
when ioctl is refused.
Since I have seen warnings from lots of commands, including some proprietary
userspace applications, I don't think disallowing the ioctls for processes
with CAP_SYS_RAWIO will happen in the near future if ever. So lets just
stop warning for processes with CAP_SYS_RAWIO for which ioctl is allowed.
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: James Bottomley <JBottomley@parallels.com>
CC: linux-scsi@vger.kernel.org
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
[bwh: Backported to 3.2: use ENOTTY, not ENOIOCTLCMD]
commit 05c69d298c96703741cac9a5cbbf6c53bd55a6e2 upstream.
6d1d8050b4bc8 "block, partition: add partition_meta_info to hd_struct"
added part_unpack_uuid() which assumes that the passed in buffer has
enough space for sprintfing "%pU" - 37 characters including '\0'.
Unfortunately, b5af921ec0233 "init: add support for root devices
specified by partition UUID" supplied 33 bytes buffer to the function
leading to the following panic with stackprotector enabled.
Kernel panic - not syncing: stack-protector: Kernel stack corrupted in: ffffffff81b14c7e
[<ffffffff815e226b>] panic+0xba/0x1c6
[<ffffffff81b14c7e>] ? printk_all_partitions+0x259/0x26xb
[<ffffffff810566bb>] __stack_chk_fail+0x1b/0x20
[<ffffffff81b15c7e>] printk_all_paritions+0x259/0x26xb
[<ffffffff81aedfe0>] mount_block_root+0x1bc/0x27f
[<ffffffff81aee0fa>] mount_root+0x57/0x5b
[<ffffffff81aee23b>] prepare_namespace+0x13d/0x176
[<ffffffff8107eec0>] ? release_tgcred.isra.4+0x330/0x30
[<ffffffff81aedd60>] kernel_init+0x155/0x15a
[<ffffffff81087b97>] ? schedule_tail+0x27/0xb0
[<ffffffff815f4d24>] kernel_thread_helper+0x5/0x10
[<ffffffff81aedc0b>] ? start_kernel+0x3c5/0x3c5
[<ffffffff815f4d20>] ? gs_change+0x13/0x13
Increase the buffer size, remove the dangerous part_unpack_uuid() and
use snprintf() directly from printk_all_partitions().
Reported-by: Szymon Gruszczynski <sz.gruszczynski@googlemail.com>
Cc: Will Drewry <wad@chromium.org>
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
commit 9f53d2fe815b4011ff930a7b6db98385d45faa68 upstream.
The following situation might occur:
__blkdev_get: add_disk:
register_disk()
get_gendisk()
disk_block_events()
disk->ev == NULL
disk_add_events()
__disk_unblock_events()
disk->ev != NULL
--ev->block
Then we unblock events, when they are suppose to be blocked. This can
trigger events related block/genhd.c warnings, but also can crash in
sd_check_events() or other places.
I'm able to reproduce crashes with the following scripts (with
connected usb dongle as sdb disk).
<snip>
DEV=/dev/sdb
ENABLE=/sys/bus/usb/devices/1-2/bConfigurationValue
function stop_me()
for i in `jobs -p` ; do kill $i 2> /dev/null ; done
exit
trap stop_me SIGHUP SIGINT SIGTERM
for ((i = 0; i < 10; i++)) ; do
while true; do fdisk -l $DEV 2>&1 > /dev/null ; done &
done
while true ; do
echo 1 > $ENABLE
sleep 1
echo 0 > $ENABLE
done
</snip>
I use the script to verify patch fixing oops in sd_revalidate_disk
http://marc.info/?l=linux-scsi&m=132935572512352&w=2
Without Jun'ichi Nomura patch titled "Fix NULL pointer dereference in
sd_revalidate_disk" or this one, script easily crash kernel within
a few seconds. With both patches applied I do not observe crash.
Unfortunately after some time (dozen of minutes), script will hung in:
[ 1563.906432] [<c08354f5>] schedule_timeout_uninterruptible+0x15/0x20
[ 1563.906437] [<c04532d5>] msleep+0x15/0x20
[ 1563.906443] [<c05d60b2>] blk_drain_queue+0x32/0xd0
[ 1563.906447] [<c05d6e00>] blk_cleanup_queue+0xd0/0x170
[ 1563.906454] [<c06d278f>] scsi_free_queue+0x3f/0x60
[ 1563.906459] [<c06d7e6e>] __scsi_remove_device+0x6e/0xb0
[ 1563.906463] [<c06d4aff>] scsi_forget_host+0x4f/0x60
[ 1563.906468] [<c06cd84a>] scsi_remove_host+0x5a/0xf0
[ 1563.906482] [<f7f030fb>] quiesce_and_remove_host+0x5b/0xa0 [usb_storage]
[ 1563.906490] [<f7f03203>] usb_stor_disconnect+0x13/0x20 [usb_storage]
Anyway I think this patch is some step forward.
As drawback, I do not teardown on sysfs file create error, because I do
not know how to nullify disk->ev (since it can be used). However add_disk
error handling practically does not exist too, and things will work
without this sysfs file, except events will not be exported to user
space.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 37b40adf2d1b4a5e51323be73ccf8ddcf3f15dd3 upstream.
We create "bsg" link if q->kobj.sd is not NULL, so remove it only
when the same condition is true.
Fixes:
WARNING: at fs/sysfs/inode.c:323 sysfs_hash_and_remove+0x2b/0x77()
sysfs: can not remove 'bsg', no directory
Call Trace:
[<c0429683>] warn_slowpath_common+0x6a/0x7f
[<c0537a68>] ? sysfs_hash_and_remove+0x2b/0x77
[<c042970b>] warn_slowpath_fmt+0x2b/0x2f
[<c0537a68>] sysfs_hash_and_remove+0x2b/0x77
[<c053969a>] sysfs_remove_link+0x20/0x23
[<c05d88f1>] bsg_unregister_queue+0x40/0x6d
[<c0692263>] __scsi_remove_device+0x31/0x9d
[<c069149f>] scsi_forget_host+0x41/0x52
[<c0689fa9>] scsi_remove_host+0x71/0xe0
[<f7de5945>] quiesce_and_remove_host+0x51/0x83 [usb_storage]
[<f7de5a1e>] usb_stor_disconnect+0x18/0x22 [usb_storage]
[<c06c29de>] usb_unbind_interface+0x4e/0x109
[<c067a80f>] __device_release_driver+0x6b/0xa6
[<c067a861>] device_release_driver+0x17/0x22
[<c067a46a>] bus_remove_device+0xd6/0xe6
[<c06785e2>] device_del+0xf2/0x137
[<c06c101f>] usb_disable_device+0x94/0x1a0
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 0bfc96cb77224736dfa35c3c555d37b3646ef35e upstream.
[ Changes with respect to 3.3: return -ENOTTY from scsi_verify_blk_ioctl
and -ENOIOCTLCMD from sd_compat_ioctl. ]
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and
will pass the command to the underlying block device. This is
well-known, but it is also a large security problem when (via Unix
permissions, ACLs, SELinux or a combination thereof) a program or user
needs to be granted access only to part of the disk.
This patch lets partitions forward a small set of harmless ioctls;
others are logged with printk so that we can see which ioctls are
actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred.
Of course it was being sent to a (partition on a) hard disk, so it would
have failed with ENOTTY and the patch isn't changing anything in
practice. Still, I'm treating it specially to avoid spamming the logs.
In principle, this restriction should include programs running with
CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and
/dev/sdb, it still should not be able to read/write outside the
boundaries of /dev/sda2 independent of the capabilities. However, for
now programs with CAP_SYS_RAWIO will still be allowed to send the
ioctls. Their actions will still be logged.
This patch does not affect the non-libata IDE driver. That driver
however already tests for bd != bd->bd_contains before issuing some
ioctl; it could be restricted further to forbid these ioctls even for
programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO.
Cc: linux-scsi@vger.kernel.org
Cc: James Bottomley <JBottomley@parallels.com>
[ Make it also print the command name when warning - Linus ]
commit 577ebb374c78314ac4617242f509e2f5e7156649 upstream.
Introduce a wrapper around scsi_cmd_ioctl that takes a block device.
The function will then be enhanced to detect partition block devices
and, in that case, subject the ioctls to whitelisting.
Commit 5e081591 "block: warn if tag is greater than real_max_depth"
cleaned up blk_queue_end_tag() to warn when the tag is truly invalid
(greater than real_max_depth). However, it changed behavior in the tag <
max_depth case to not end the request. Leading to triggering of
BUG_ON(blk_queued_rq(rq)) in the request completion path:
http://marc.info/?l=linux-kernel&m=132204370518629&w=2
In order to allow blk_queue_resize_tags() to shrink the tag space
blk_queue_end_tag() must always complete tags with a value less than
real_max_depth regardless of the current max_depth. The comment about
"handling the shrink case" seems to be what prompted changes in this
space, so remove it and BUG on all invalid tags (made even simpler by
Matthew's suggestion to use an unsigned compare).
Cc: Tao Ma <boyu.mt@taobao.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Reported-by: Meelis Roos <mroos@ut.ee>
Reported-by: Ed Nadolski <edmund.nadolski@intel.com>
Cc: Tejun Heo <tj@kernel.org>
Signed-off-by: majianpeng <majianpeng@gmail.com>
All requests of a queue could be merged to other requests of other queue.
Such queue will not have request in it, but it's in service tree. This
will cause kernel oops.
I encounter a BUG_ON() in cfq_dispatch_request() with next patch, but the
issue should exist without the patch.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
While probing, fd sets up queue, probes hardware and tears down the
queue if probing fails. In the process, blk_drain_queue() kicks the
queue which failed to finish initialization and fd is unhappy about
that.
floppy0: no floppy controllers found
WARNING: at drivers/block/floppy.c:2929 do_fd_request+0xbf/0xd0()
Hardware name: To Be Filled By O.E.M.
VFS: do_fd_request called on non-open device
Modules linked in:
Pid: 1, comm: swapper Not tainted 3.2.0-rc4-00077-g5983fe2 #2
Call Trace:
[<ffffffff81039a6a>] warn_slowpath_common+0x7a/0xb0
[<ffffffff81039b41>] warn_slowpath_fmt+0x41/0x50
[<ffffffff813d657f>] do_fd_request+0xbf/0xd0
[<ffffffff81322b95>] blk_drain_queue+0x65/0x80
[<ffffffff81322c93>] blk_cleanup_queue+0xe3/0x1a0
[<ffffffff818a809d>] floppy_init+0xdeb/0xe28
[<ffffffff818a72b2>] ? daring+0x6b/0x6b
[<ffffffff810002af>] do_one_initcall+0x3f/0x170
[<ffffffff81884b34>] kernel_init+0x9d/0x11e
[<ffffffff810317c2>] ? schedule_tail+0x22/0xa0
[<ffffffff815dbb14>] kernel_thread_helper+0x4/0x10
[<ffffffff81884a97>] ? start_kernel+0x2be/0x2be
[<ffffffff815dbb10>] ? gs_change+0xb/0xb
Avoid it by making blk_drain_queue() kick queue iff dispatch queue has
something on it.
Reported-by: Ralf Hildebrandt <Ralf.Hildebrandt@charite.de>
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Tested-by: Sergei Trofimovich <slyich@gmail.com>
cfq_cic_link() has race condition. When some processes which shared ioc
issue I/O to same block device simultaneously, cfq_cic_link() returns -EEXIST
sometimes. The race condition might stop I/O by following steps:
step 1: Process A: Issue an I/O to /dev/sda
step 2: Process A: Get an ioc (iocA here) in get_io_context() which does not
linked with a cic for the device
step 3: Process A: Get a new cic for the device (cicA here) in
cfq_alloc_io_context()
step 4: Process B: Issue an I/O to /dev/sda
step 5: Process B: Get iocA in get_io_context() since process A and B share the
same ioc
step 6: Process B: Get a new cic for the device (cicB here) in
cfq_alloc_io_context() since iocA has not been linked with a
cic for the device yet
step 7: Process A: Link cicA to iocA in cfq_cic_link()
step 8: Process A: Dispatch I/O to driver and finish it
step 9: Process B: Try to link cicB to iocA in cfq_cic_link()
But it fails with showing "cfq: cic link failed!" kernel
message, since iocA has already linked with cicA at step 7.
step 10: Process B: Wait for finishig I/O in get_request_wait()
The function does not wake up, when there is no I/O to the
device.
When cfq_cic_link() returns -EEXIST, it means ioc has already linked with cic.
So when cfq_cic_link() return -EEXIST, retry cfq_cic_lookup().
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: stable@kernel.org
If we fail allocating the blkpg stats, we free cfqd and cfgq.
But we need to free the IDA cfqd->cic_index as well.
struct request_queue is allocated with __GFP_ZERO so its "node" field is
zero before initialization. This causes an oops if node 0 is offline in
the page allocator because its zonelists are not initialized. From Dave
Young's dmesg:
SRAT: Node 1 PXM 2 0-d0000000
SRAT: Node 1 PXM 2 100000000-330000000
SRAT: Node 0 PXM 1 330000000-630000000
Initmem setup node 1 0000000000000000-000000000affb000
Built 1 zonelists in Node order, mobility grouping on.
BUG: unable to handle kernel paging request at 0000000000001c08
IP: [<ffffffff8111c355>] __alloc_pages_nodemask+0xb5/0x870
and __alloc_pages_nodemask+0xb5 translates to a NULL pointer on
zonelist->_zonerefs.
The fix is to initialize q->node at the time of allocation so the correct
node is passed to the slab allocator later.
Since blk_init_allocated_queue_node() is no longer needed, merge it with
blk_init_allocated_queue().
[rientjes@google.com: changelog, initializing q->node]
Cc: stable@vger.kernel.org [2.6.37+]
Reported-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Tested-by: Dave Young <dyoung@redhat.com>
After flush plug list, the list has no request, so we need to add a
trace_block_plug().
Reviewed-by: Namhyung Kim <namhyung@gmail.com>
get_request_wait() could sleep and flush the plug list. If the list is
already flushed, don't flush again.
Even after commit 5478755616ae2ef1ce144dded589b62b2a50d575
("block: check for proper length of iov entries earlier ...")
we still won't check for zero-length entries after an unaligned
entry. Remove the break-statement, so all entries are checked.
This reverts commit a72c5e5eb738033938ab30d6a634b74d1d060f10.
The commit introduced alias for block devices which is intended to be
used during logging although actual usage hasn't been committed yet.
This approach adds very limited benefit (raw log might be easier to
follow) which can be trivially implemented in userland but has a lot
of problems.
It is much worse than netif renames because it doesn't rename the
actual device but just adds conveninence name which isn't used
universally or enforced. Everything internal including device lookup
and sysfs still uses the internal name and nothing prevents two
devices from using conflicting alias - ie. sda can have sdb as its
alias.
This has been nacked by people working on device driver core, block
layer and kernel-userland interface and shouldn't have been
upstreamed. Revert it.
http://thread.gmane.org/gmane.linux.kernel/1155104
http://thread.gmane.org/gmane.linux.scsi/68632
http://thread.gmane.org/gmane.linux.scsi/69776
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Nao Nishijima <nao.nishijima.xt@hitachi.com>
Cc: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
* 'for-3.2/drivers' of git://git.kernel.dk/linux-block: (30 commits)
virtio-blk: use ida to allocate disk index
hpsa: add small delay when using PCI Power Management to reset for kump
cciss: add small delay when using PCI Power Management to reset for kump
xen/blkback: Fix two races in the handling of barrier requests.
xen/blkback: Check for proper operation.
xen/blkback: Fix the inhibition to map pages when discarding sector ranges.
xen/blkback: Report VBD_WSECT (wr_sect) properly.
xen/blkback: Support 'feature-barrier' aka old-style BARRIER requests.
xen-blkfront: plug device number leak in xlblk_init() error path
xen-blkfront: If no barrier or flush is supported, use invalid operation.
xen-blkback: use kzalloc() in favor of kmalloc()+memset()
xen-blkback: fixed indentation and comments
xen-blkfront: fix a deadlock while handling discard response
xen-blkfront: Handle discard requests.
xen-blkback: Implement discard requests ('feature-discard')
xen-blkfront: add BLKIF_OP_DISCARD and discard request struct
drivers/block/loop.c: remove unnecessary bdev argument from loop_clr_fd()
drivers/block/loop.c: emit uevent on auto release
drivers/block/cpqarray.c: use pci_dev->revision
loop: always allow userspace partitions and optionally support automatic scanning
Fic up trivial header file includsion conflict in drivers/block/loop.c
* 'for-3.2/core' of git://git.kernel.dk/linux-block: (29 commits)
block: don't call blk_drain_queue() if elevator is not up
blk-throttle: use queue_is_locked() instead of lockdep_is_held()
blk-throttle: Take blkcg->lock while traversing blkcg->policy_list
blk-throttle: Free up policy node associated with deleted rule
block: warn if tag is greater than real_max_depth.
block: make gendisk hold a reference to its queue
blk-flush: move the queue kick into
blk-flush: fix invalid BUG_ON in blk_insert_flush
block: Remove the control of complete cpu from bio.
block: fix a typo in the blk-cgroup.h file
block: initialize the bounce pool if high memory may be added later
block: fix request_queue lifetime handling by making blk_queue_cleanup() properly shutdown
block: drop @tsk from attempt_plug_merge() and explain sync rules
block: make get_request[_wait]() fail if queue is dead
block: reorganize throtl_get_tg() and blk_throtl_bio()
block: reorganize queue draining
block: drop unnecessary blk_get/put_queue() in scsi_cmd_ioctl() and blk_get_tg()
block: pass around REQ_* flags instead of broken down booleans during request alloc/free
block: move blk_throtl prototypes to block/blk.h
block: fix genhd refcounting in blkio_policy_parse_and_set()
Fix up trivial conflicts due to "mddev_t" -> "struct mddev" conversion
and making the request functions be of type "void" instead of "int" in
- drivers/md/{faulty.c,linear.c,md.c,md.h,multipath.c,raid0.c,raid1.c,raid10.c,raid5.c}
- drivers/staging/zram/zram_drv.c
blk_cleanup_queue() may be called before elevator is set up on a
queue which triggers the following oops.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8125a69c>] elv_drain_elevator+0x1c/0x70
Pid: 830, comm: kworker/0:2 Not tainted 3.1.0-next-20111025_64+ #1590
Bochs Bochs
RIP: 0010:[<ffffffff8125a69c>] [<ffffffff8125a69c>] elv_drain_elevator+0x1c/0x70
Call Trace:
[<ffffffff8125da92>] blk_drain_queue+0x42/0x70
[<ffffffff8125db90>] blk_cleanup_queue+0xd0/0x1c0
[<ffffffff81469640>] md_free+0x50/0x70
[<ffffffff8126f43b>] kobject_release+0x8b/0x1d0
[<ffffffff81270d56>] kref_put+0x36/0xa0
[<ffffffff8126f2b7>] kobject_put+0x27/0x60
[<ffffffff814693af>] mddev_delayed_delete+0x2f/0x40
[<ffffffff81083450>] process_one_work+0x100/0x3b0
[<ffffffff8108527f>] worker_thread+0x15f/0x3a0
[<ffffffff81089937>] kthread+0x87/0x90
[<ffffffff81621834>] kernel_thread_helper+0x4/0x10
Fix it by making blk_cleanup_queue() check whether q->elevator is set
up before invoking blk_drain_queue.
Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz>
This file isn't using full modular functionality, and hence
can be "downgraded" to just using the export.h header.
These files were getting <linux/module.h> via an implicit include
path, but we want to crush those out of existence since they cost
time during compiles of processing thousands of lines of headers
for no reason. Give them the lightweight header that just contains
the EXPORT_SYMBOL infrastructure.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (204 commits)
[SCSI] qla4xxx: export address/port of connection (fix udev disk names)
[SCSI] ipr: Fix BUG on adapter dump timeout
[SCSI] megaraid_sas: Fix instance access in megasas_reset_timer
[SCSI] hpsa: change confusing message to be more clear
[SCSI] iscsi class: fix vlan configuration
[SCSI] qla4xxx: fix data alignment and use nl helpers
[SCSI] iscsi class: fix link local mispelling
[SCSI] iscsi class: Replace iscsi_get_next_target_id with IDA
[SCSI] aacraid: use lower snprintf() limit
[SCSI] lpfc 8.3.27: Change driver version to 8.3.27
[SCSI] lpfc 8.3.27: T10 additions for SLI4
[SCSI] lpfc 8.3.27: Fix queue allocation failure recovery
[SCSI] lpfc 8.3.27: Change algorithm for getting physical port name
[SCSI] lpfc 8.3.27: Changed worst case mailbox timeout
[SCSI] lpfc 8.3.27: Miscellanous logic and interface fixes
[SCSI] megaraid_sas: Changelog and version update
[SCSI] megaraid_sas: Add driver workaround for PERC5/1068 kdump kernel panic
[SCSI] megaraid_sas: Add multiple MSI-X vector/multiple reply queue support
[SCSI] megaraid_sas: Add support for MegaRAID 9360/9380 12GB/s controllers
[SCSI] megaraid_sas: Clear FUSION_IN_RESET before enabling interrupts
We can't use the latter if !CONFIG_LOCKDEP.
Reported-by: Sedat Dilek <sedat.dilek@googlemail.com>
blkcg->policy_list is protected by blkcg->lock. Its not rcu protected
list. So even for readers, they need to take blkcg->lock. There are
few functions which were reading the list without taking lock. Fix it.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
If a rule is being deleted, free up associated policy node. Otherwise
that memory is leaked.
In case tag depth is reduced, it is max_depth not real_max_depth.
So we should allow a request with tag >= max_depth, but for a
tag >= real_max_depth, there really should be some problem.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
The following command sequence triggers an oops.
# mount /dev/sdb1 /mnt
# echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete
# umount /mnt
general protection fault: 0000 [#1] PREEMPT SMP
CPU 2
Modules linked in:
Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs
RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60
Call Trace:
[<ffffffff810d2845>] lock_acquire+0x95/0x140
[<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50
[<ffffffff811573bc>] bdi_lock_two+0x5c/0x70
[<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0
[<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0
[<ffffffff811c4010>] __blkdev_put+0x160/0x1d0
[<ffffffff811c40df>] blkdev_put+0x5f/0x190
[<ffffffff8118f18d>] kill_block_super+0x4d/0x80
[<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70
[<ffffffff8119003a>] deactivate_super+0x4a/0x70
[<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130
[<ffffffff811acf2e>] sys_umount+0x7e/0x3a0
[<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b
This is because bdev holds on to disk but disk doesn't pin the
associated queue. If a SCSI device is removed while the device is
still open, the sdev puts the base reference to the queue on release.
When the bdev is finally released, the associated queue is already
gone along with the bdi and bdev_inode_switch_bdi() ends up
dereferencing already freed bdi.
Even if it were not for this bug, disk not holding onto the associated
queue is very unusual and error-prone.
Fix it by making add_disk() take an extra reference to its queue and
put it on disk_release() and ensuring that disk and its fops owner are
put in that order after all accesses to the disk and queue are
complete.
A dm-multipath user reported[1] a problem when trying to boot
a kernel with commit 4853abaae7e4a2af938115ce9071ef8684fb7af4
(block: fix flush machinery for stacking drivers with differring
flush flags) applied. It turns out that an empty flush request
can be sent into blk_insert_flush. When the BUG_ON was fixed
to allow for this, I/O on the underlying device would stall. The
reason is that blk_insert_cloned_request does not kick the queue.
In the aforementioned commit, I had added a special case to
kick the queue if data was sent down but the queue flags did
not require a flush. A better solution is to push the queue
kick up into blk_insert_cloned_request.
This patch, along with a follow-on which fixes the BUG_ON, fixes
the issue reported.
[1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html
Reported-by: Christophe Saout <christophe@saout.de>
Stable note: 3.1
A user reported a regression due to commit
4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush
machinery for stacking drivers with differring flush flags).
Part of the problem is that blk_insert_flush required a
single bio be attached to the request. In reality, having
no attached bio is also a valid case, as can be observed with
an empty flush.
Stable note: 3.1
bio originally has the functionality to set the complete cpu, but
it is broken.
Chirstoph said that "This code is unused, and from the all the
discussions lately pretty obviously broken. The only thing keeping
it serves is creating more confusion and possibly more bugs."
And Jens replied with "We can kill bio_set_completion_cpu(). I'm fine
with leaving cpu control to the request based drivers, they are the
only ones that can toggle the setting anyway".
So this patch tries to remove all the work of controling complete cpu
from a bio.
Cc: Shaohua Li <shaohua.li@intel.com>
byptes -> bytes.
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
properly shutdown
request_queue is refcounted but actually depdends on lifetime
management from the queue owner - on blk_cleanup_queue(), block layer
expects that there's no request passing through request_queue and no
new one will.
This is fundamentally broken. The queue owner (e.g. SCSI layer)
doesn't have a way to know whether there are other active users before
calling blk_cleanup_queue() and other users (e.g. bsg) don't have any
guarantee that the queue is and would stay valid while it's holding a
reference.
With delay added in blk_queue_bio() before queue_lock is grabbed, the
following oops can be easily triggered when a device is removed with
in-flight IOs.
sd 0:0:1:0: [sdb] Stopping disk
ata1.01: disabled
CPU 2
Modules linked in:
Pid: 648, comm: test_rawio Not tainted 3.1.0-rc3-work+ #56 Bochs Bochs
RIP: 0010:[<ffffffff8137d651>] [<ffffffff8137d651>] elv_rqhash_find+0x61/0x100
Process test_rawio (pid: 648, threadinfo ffff880019efa000, task ffff880019ef8a80)
Call Trace:
[<ffffffff8137d774>] elv_merge+0x84/0xe0
[<ffffffff81385b54>] blk_queue_bio+0xf4/0x400
[<ffffffff813838ea>] generic_make_request+0xca/0x100
[<ffffffff81383994>] submit_bio+0x74/0x100
[<ffffffff811c53ec>] dio_bio_submit+0xbc/0xc0
[<ffffffff811c610e>] __blockdev_direct_IO+0x92e/0xb40
[<ffffffff811c39f7>] blkdev_direct_IO+0x57/0x60
[<ffffffff8113b1c5>] generic_file_aio_read+0x6d5/0x760
[<ffffffff8118c1ca>] do_sync_read+0xda/0x120
[<ffffffff8118ce55>] vfs_read+0xc5/0x180
[<ffffffff8118cfaa>] sys_pread64+0x9a/0xb0
[<ffffffff81afaf6b>] system_call_fastpath+0x16/0x1b
This happens because blk_queue_cleanup() destroys the queue and
elevator whether IOs are in progress or not and DEAD tests are
sprinkled in the request processing path without proper
synchronization.
Similar problem exists for blk-throtl. On queue cleanup, blk-throtl
is shutdown whether it has requests in it or not. Depending on
timing, it either oopses or throttled bios are lost putting tasks
which are waiting for bio completion into eternal D state.
The way it should work is having the usual clear distinction between
shutdown and release. Shutdown drains all currently pending requests,
marks the queue dead, and performs partial teardown of the now
unnecessary part of the queue. Even after shutdown is complete,
reference holders are still allowed to issue requests to the queue
although they will be immmediately failed. The rest of teardown
happens on release.
This patch makes the following changes to make blk_queue_cleanup()
behave as proper shutdown.
* QUEUE_FLAG_DEAD is now set while holding both q->exit_mutex and
queue_lock.
* Unsynchronized DEAD check in generic_make_request_checks() removed.
This couldn't make any meaningful difference as the queue could die
after the check.
* blk_drain_queue() updated such that it can drain all requests and is
now called during cleanup.
* blk_throtl updated such that it checks DEAD on grabbing queue_lock,
drains all throttled bios during cleanup and free td when queue is
released.
Cc: Vivek Goyal <vgoyal@redhat.com>
attempt_plug_merge() accesses elevator without holding queue_lock and
may call into ->elevator_bio_merge_fn(). The elvator is guaranteed to
be valid because it's accessed iff the plugged list has requests and
elevator is never exited with live requests, so as long as the
elevator method can deal with unlocked access, this is safe.
Explain the sync rules around attempt_plug_merge() and drop the
unnecessary @tsk parameter.
This patch doesn't introduce any functional change.
Currently get_request[_wait]() allocates request whether queue is dead
or not. This patch makes get_request[_wait]() return NULL if @q is
dead. blk_queue_bio() is updated to fail the submitted bio if request
allocation fails. While at it, add docbook comments for
get_request[_wait]().
Note that the current code has rather unclear (there are spurious DEAD
tests scattered around) assumption that the owner of a queue
guarantees that no request travels block layer if the queue is dead
and this patch in itself doesn't change much; however, this will allow
fixing the broken assumption in the next patch.
blk_throtl_bio() and throtl_get_tg() have rather unusual interface.
* throtl_get_tg() returns pointer to a valid tg or ERR_PTR(-ENODEV),
and drops queue_lock in the latter case. Different locking context
depending on return value is error-prone and DEAD state is scheduled
to be protected by queue_lock anyway. Move DEAD check inside
queue_lock and return valid tg or NULL.
* blk_throtl_bio() indicates return status both with its return value
and in/out param **@bio. The former is used to indicate whether
queue is found to be dead during throtl processing. The latter
whether the bio is throttled.
There's no point in returning DEAD check result from
blk_throtl_bio(). The queue can die after blk_throtl_bio() is
finished but before make_request_fn() grabs queue lock.
Make it take *@bio instead and return boolean result indicating
whether the request is throttled or not.
This patch doesn't cause any visible functional difference.
Reorganize queue draining related code in preparation of queue exit
changes.
* Factor out actual draining from elv_quiesce_start() to
blk_drain_queue().
* Make elv_quiesce_start/end() responsible for their own locking.
* Replace open-coded ELVSWITCH clearing in elevator_switch() with
elv_quiesce_end().
blk_get/put_queue() in scsi_cmd_ioctl() and throtl_get_tg() are
completely bogus. The caller must have a reference to the queue on
entry and taking an extra reference doesn't change anything.
For scsi_cmd_ioctl(), the only effect is that it ends up checking
QUEUE_FLAG_DEAD on entry; however, this is bogus as queue can die
right after blk_get_queue(). Dead queue should be and is handled in
request issue path (it's somewhat broken now but that's a separate
problem and doesn't affect this one much).
throtl_get_tg() incorrectly assumes that q is rcu freed. Also, it
doesn't check return value of blk_get_queue(). If the queue is
already dead, it ends up doing an extra put.
Drop them.
