commit 4d66e5e9b6d720d8463e11d027bd4ad91c8b1318 upstream.
[ INFO: inconsistent lock state ]
4.1.0-rc7+ #217 Tainted: G O
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/6/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
(ext_devt_lock){+.?...}, at: [<ffffffff8143a60c>] blk_free_devt+0x3c/0x70
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff810bf6b1>] __lock_acquire+0x461/0x1e70
[<ffffffff810c1947>] lock_acquire+0xb7/0x290
[<ffffffff818ac3a8>] _raw_spin_lock+0x38/0x50
[<ffffffff8143a07d>] blk_alloc_devt+0x6d/0xd0 <-- take the lock in process context
[<ffffffff810bf64e>] __lock_acquire+0x3fe/0x1e70
[<ffffffff810c00ad>] ? __lock_acquire+0xe5d/0x1e70
[<ffffffff8143a60c>] ? blk_free_devt+0x3c/0x70
[<ffffffff8143a60c>] blk_free_devt+0x3c/0x70 <-- take the lock in softirq
[<ffffffff8143bfec>] part_release+0x1c/0x50
[<ffffffff8158edf6>] device_release+0x36/0xb0
[<ffffffff8145ac2b>] kobject_cleanup+0x7b/0x1a0
[<ffffffff8145aad0>] kobject_put+0x30/0x70
[<ffffffff8158f147>] put_device+0x17/0x20
[<ffffffff8143c29c>] delete_partition_rcu_cb+0x16c/0x180
[<ffffffff8143c130>] ? read_dev_sector+0xa0/0xa0
[<ffffffff810e0e0f>] rcu_process_callbacks+0x2ff/0xa90
[<ffffffff810e0dcf>] ? rcu_process_callbacks+0x2bf/0xa90
[<ffffffff81067e2e>] __do_softirq+0xde/0x600
Neil sees this in his tests and it also triggers on pmem driver unbind
for the libnvdimm tests. This fix is on top of an initial fix by Keith
for incorrect usage of mutex_lock() in this path: 2da78092dda1 "block:
Fix dev_t minor allocation lifetime". Both this and 2da78092dda1 are
candidates for -stable.
Fixes: 2da78092dda1 ("block: Fix dev_t minor allocation lifetime")
Cc: Keith Busch <keith.busch@intel.com>
Reported-by: NeilBrown <neilb@suse.de>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 045c47ca306acf30c740c285a77a4b4bda6be7c5 upstream.
When reading blkio.throttle.io_serviced in a recently created blkio
cgroup, it's possible to race against the creation of a throttle policy,
which delays the allocation of stats_cpu.
Like other functions in the throttle code, just checking for a NULL
stats_cpu prevents the following oops caused by that race.
[ 1117.285199] Unable to handle kernel paging request for data at address 0x7fb4d0020
[ 1117.285252] Faulting instruction address: 0xc0000000003efa2c
[ 1137.733921] Oops: Kernel access of bad area, sig: 11 [#1]
[ 1137.733945] SMP NR_CPUS=2048 NUMA PowerNV
[ 1137.734025] Modules linked in: bridge stp llc kvm_hv kvm binfmt_misc autofs4
[ 1137.734102] CPU: 3 PID: 5302 Comm: blkcgroup Not tainted 3.19.0 #5
[ 1137.734132] task: c000000f1d188b00 ti: c000000f1d210000 task.ti: c000000f1d210000
[ 1137.734167] NIP: c0000000003efa2c LR: c0000000003ef9f0 CTR: c0000000003ef980
[ 1137.734202] REGS: c000000f1d213500 TRAP: 0300 Not tainted (3.19.0)
[ 1137.734230] MSR: 9000000000009032 <SF,HV,EE,ME,IR,DR,RI> CR: 42008884 XER: 20000000
[ 1137.734325] CFAR: 0000000000008458 DAR: 00000007fb4d0020 DSISR: 40000000 SOFTE: 0
GPR00: c0000000003ed3a0 c000000f1d213780 c000000000c59538 0000000000000000
GPR04: 0000000000000800 0000000000000000 0000000000000000 0000000000000000
GPR08: ffffffffffffffff 00000007fb4d0020 00000007fb4d0000 c000000000780808
GPR12: 0000000022000888 c00000000fdc0d80 0000000000000000 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 000001003e120200 c000000f1d5b0cc0 0000000000000200 0000000000000000
GPR24: 0000000000000001 c000000000c269e0 0000000000000020 c000000f1d5b0c80
GPR28: c000000000ca3a08 c000000000ca3dec c000000f1c667e00 c000000f1d213850
[ 1137.734886] NIP [c0000000003efa2c] .tg_prfill_cpu_rwstat+0xac/0x180
[ 1137.734915] LR [c0000000003ef9f0] .tg_prfill_cpu_rwstat+0x70/0x180
[ 1137.734943] Call Trace:
[ 1137.734952] [c000000f1d213780] [d000000005560520] 0xd000000005560520 (unreliable)
[ 1137.734996] [c000000f1d2138a0] [c0000000003ed3a0] .blkcg_print_blkgs+0xe0/0x1a0
[ 1137.735039] [c000000f1d213960] [c0000000003efb50] .tg_print_cpu_rwstat+0x50/0x70
[ 1137.735082] [c000000f1d2139e0] [c000000000104b48] .cgroup_seqfile_show+0x58/0x150
[ 1137.735125] [c000000f1d213a70] [c0000000002749dc] .kernfs_seq_show+0x3c/0x50
[ 1137.735161] [c000000f1d213ae0] [c000000000218630] .seq_read+0xe0/0x510
[ 1137.735197] [c000000f1d213bd0] [c000000000275b04] .kernfs_fop_read+0x164/0x200
[ 1137.735240] [c000000f1d213c80] [c0000000001eb8e0] .__vfs_read+0x30/0x80
[ 1137.735276] [c000000f1d213cf0] [c0000000001eb9c4] .vfs_read+0x94/0x1b0
[ 1137.735312] [c000000f1d213d90] [c0000000001ebb38] .SyS_read+0x58/0x100
[ 1137.735349] [c000000f1d213e30] [c000000000009218] syscall_exit+0x0/0x98
[ 1137.735383] Instruction dump:
[ 1137.735405] 7c6307b4 7f891800 409d00b8 60000000 60420000 3d420004 392a63b0 786a1f24
[ 1137.735471] 7d49502a e93e01c8 7d495214 7d2ad214 <7cead02a> e9090008 e9490010 e9290018
And here is one code that allows to easily reproduce this, although this
has first been found by running docker.
void run(pid_t pid)
int n;
int status;
int fd;
char *buffer;
buffer = memalign(BUFFER_ALIGN, BUFFER_SIZE);
n = snprintf(buffer, BUFFER_SIZE, "%d\n", pid);
fd = open(CGPATH "/test/tasks", O_WRONLY);
write(fd, buffer, n);
close(fd);
if (fork() > 0) {
fd = open("/dev/sda", O_RDONLY | O_DIRECT);
read(fd, buffer, 512);
close(fd);
wait(&status);
} else {
fd = open(CGPATH "/test/blkio.throttle.io_serviced", O_RDONLY);
n = read(fd, buffer, BUFFER_SIZE);
close(fd);
free(buffer);
exit(0);
void test(void)
int status;
mkdir(CGPATH "/test", 0666);
if (fork() > 0)
wait(&status);
else
run(getpid());
rmdir(CGPATH "/test");
int main(int argc, char **argv)
int i;
for (i = 0; i < NR_TESTS; i++)
test();
return 0;
Reported-by: Ricardo Marin Matinata <rmm@br.ibm.com>
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
commit c6ce194325cef342313e3d27620411ce90a89c50 upstream.
If you can manage to submit an async write as the first async I/O from
the context of a process with realtime scheduling priority, then a
cfq_queue is allocated, but filed into the wrong async_cfqq bucket. It
ends up in the best effort array, but actually has realtime I/O
scheduling priority set in cfqq->ioprio.
The reason is that cfq_get_queue assumes the default scheduling class and
priority when there is no information present (i.e. when the async cfqq
is created):
static struct cfq_queue *
cfq_get_queue(struct cfq_data *cfqd, bool is_sync, struct cfq_io_cq *cic,
struct bio *bio, gfp_t gfp_mask)
const int ioprio_class = IOPRIO_PRIO_CLASS(cic->ioprio);
const int ioprio = IOPRIO_PRIO_DATA(cic->ioprio);
cic->ioprio starts out as 0, which is "invalid". So, class of 0
(IOPRIO_CLASS_NONE) is passed to cfq_async_queue_prio like so:
async_cfqq = cfq_async_queue_prio(cfqd, ioprio_class, ioprio);
static struct cfq_queue **
cfq_async_queue_prio(struct cfq_data *cfqd, int ioprio_class, int ioprio)
switch (ioprio_class) {
case IOPRIO_CLASS_RT:
return &cfqd->async_cfqq[0][ioprio];
case IOPRIO_CLASS_NONE:
ioprio = IOPRIO_NORM;
/* fall through */
case IOPRIO_CLASS_BE:
return &cfqd->async_cfqq[1][ioprio];
case IOPRIO_CLASS_IDLE:
return &cfqd->async_idle_cfqq;
default:
BUG();
Here, instead of returning a class mapped from the process' scheduling
priority, we get back the bucket associated with IOPRIO_CLASS_BE.
Now, there is no queue allocated there yet, so we create it:
cfqq = cfq_find_alloc_queue(cfqd, is_sync, cic, bio, gfp_mask);
That function ends up doing this:
cfq_init_cfqq(cfqd, cfqq, current->pid, is_sync);
cfq_init_prio_data(cfqq, cic);
cfq_init_cfqq marks the priority as having changed. Then, cfq_init_prio
data does this:
default:
printk(KERN_ERR "cfq: bad prio %x\n", ioprio_class);
* no prio set, inherit CPU scheduling settings
cfqq->ioprio = task_nice_ioprio(tsk);
cfqq->ioprio_class = task_nice_ioclass(tsk);
break;
So we basically have two code paths that treat IOPRIO_CLASS_NONE
differently, which results in an RT async cfqq filed into a best effort
bucket.
Attached is a patch which fixes the problem. I'm not sure how to make
it cleaner. Suggestions would be welcome.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Tested-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
commit 69abaffec7d47a083739b79e3066cb3730eba72e upstream.
Cfq_lookup_create_cfqg() allocates struct blkcg_gq using GFP_ATOMIC.
In cfq_find_alloc_queue() possible allocation failure is not handled.
As a result kernel oopses on NULL pointer dereference when
cfq_link_cfqq_cfqg() calls cfqg_get() for NULL pointer.
Bug was introduced in v3.5 in commit cd1604fab4f9 ("blkcg: factor
out blkio_group creation"). Prior to that commit cfq group lookup
had returned pointer to root group as fallback.
This patch handles this error using existing fallback oom_cfqq.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Fixes: cd1604fab4f9 ("blkcg: factor out blkio_group creation")
commit 5fabcb4c33fe11c7e3afdf805fde26c1a54d0953 upstream.
We can get here from blkdev_ioctl() -> blkpg_ioctl() -> add_partition()
with a user passed in partno value. If we pass in 0x7fffffff, the
new target in disk_expand_part_tbl() overflows the 'int' and we
access beyond the end of ptbl->part[] and even write to it when we
do the rcu_assign_pointer() to assign the new partition.
Reported-by: David Ramos <daramos@stanford.edu>
commit 84ce0f0e94ac97217398b3b69c21c7a62ebeed05 upstream.
When sg_scsi_ioctl() fails to prepare request to submit in
blk_rq_map_kern() we jump to a label where we just end up copying
(luckily zeroed-out) kernel buffer to userspace instead of reporting
error. Fix the problem by jumping to the right label.
CC: Jens Axboe <axboe@kernel.dk>
CC: linux-scsi@vger.kernel.org
Coverity-id: 1226871
Fixed up the, now unused, out label.
commit b8839b8c55f3fdd60dc36abcda7e0266aff7985c upstream.
The math in both blk_stack_limits() and queue_limit_alignment_offset()
assume that a block device's io_min (aka minimum_io_size) is always a
power-of-2. Fix the math such that it works for non-power-of-2 io_min.
This issue (of alignment_offset != 0) became apparent when testing
dm-thinp with a thinp blocksize that matches a RAID6 stripesize of
1280K. Commit fdfb4c8c1 ("dm thin: set minimum_io_size to pool's data
block size") unlocked the potential for alignment_offset != 0 due to
the dm-thin-pool's io_min possibly being a non-power-of-2.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
commit 46f341ffcfb5d8530f7d1e60f3be06cce6661b62 upstream.
Commit 2da78092 changed the locking from a mutex to a spinlock,
so we now longer sleep in this context. But there was a leftover
might_sleep() in there, which now triggers since we do the final
free from an RCU callback. Get rid of it.
Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com>
commit 2da78092dda13f1efd26edbbf99a567776913750 upstream.
Releases the dev_t minor when all references are closed to prevent
another device from acquiring the same major/minor.
Since the partition's release may be invoked from call_rcu's soft-irq
context, the ext_dev_idr's mutex had to be replaced with a spinlock so
as not so sleep.
Signed-off-by: Keith Busch <keith.busch@intel.com>
commit e15693ef18e13e3e6bffe891fe140f18b8ff6d07 upstream.
cfq_group_service_tree_add() is applying new_weight at the beginning of
the function via cfq_update_group_weight().
This actually allows weight to change between adding it to and subtracting
it from children_weight, and triggers WARN_ON_ONCE() in
cfq_group_service_tree_del(), or even causes oops by divide error during
vfr calculation in cfq_group_service_tree_add().
The detailed scenario is as follows:
1. Create blkio cgroups X and Y as a child of X.
Set X's weight to 500 and perform some I/O to apply new_weight.
This X's I/O completes before starting Y's I/O.
2. Y starts I/O and cfq_group_service_tree_add() is called with Y.
3. cfq_group_service_tree_add() walks up the tree during children_weight
calculation and adds parent X's weight (500) to children_weight of root.
children_weight becomes 500.
4. Set X's weight to 1000.
5. X starts I/O and cfq_group_service_tree_add() is called with X.
6. cfq_group_service_tree_add() applies its new_weight (1000).
7. I/O of Y completes and cfq_group_service_tree_del() is called with Y.
8. I/O of X completes and cfq_group_service_tree_del() is called with X.
9. cfq_group_service_tree_del() subtracts X's weight (1000) from
children_weight of root. children_weight becomes -500.
This triggers WARN_ON_ONCE().
10. Set X's weight to 500.
11. X starts I/O and cfq_group_service_tree_add() is called with X.
12. cfq_group_service_tree_add() applies its new_weight (500) and adds it
to children_weight of root. children_weight becomes 0. Calcularion of
vfr triggers oops by divide error.
weight should be updated right before adding it to children_weight.
Reported-by: Ruki Sekiya <sekiya.ruki@lab.ntt.co.jp>
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
commit 2a1b4cf2331d92bc009bf94fa02a24604cdaf24c upstream.
While a queue is being destroyed, all the blkgs are destroyed and its
->root_blkg pointer is set to NULL. If someone else starts to drain
while the queue is in this state, the following oops happens.
NULL pointer dereference at 0000000000000028
IP: [<ffffffff8144e944>] blk_throtl_drain+0x84/0x230
PGD e4a1067 PUD b773067 PMD 0
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: cfq_iosched(-) [last unloaded: cfq_iosched]
CPU: 1 PID: 537 Comm: bash Not tainted 3.16.0-rc3-work+ #2
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff88000e222250 ti: ffff88000efd4000 task.ti: ffff88000efd4000
RIP: 0010:[<ffffffff8144e944>] [<ffffffff8144e944>] blk_throtl_drain+0x84/0x230
RSP: 0018:ffff88000efd7bf0 EFLAGS: 00010046
RAX: 0000000000000000 RBX: ffff880015091450 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88000efd7c10 R08: 0000000000000000 R09: 0000000000000001
R10: ffff88000e222250 R11: 0000000000000000 R12: ffff880015091450
R13: ffff880015092e00 R14: ffff880015091d70 R15: ffff88001508fc28
FS: 00007f1332650740(0000) GS:ffff88001fa80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000028 CR3: 0000000009446000 CR4: 00000000000006e0
Stack:
ffffffff8144e8f6 ffff880015091450 0000000000000000 ffff880015091d80
ffff88000efd7c28 ffffffff8144ae2f ffff880015091450 ffff88000efd7c58
ffffffff81427641 ffff880015091450 ffffffff82401f00 ffff880015091450
Call Trace:
[<ffffffff8144ae2f>] blkcg_drain_queue+0x1f/0x60
[<ffffffff81427641>] __blk_drain_queue+0x71/0x180
[<ffffffff81429b3e>] blk_queue_bypass_start+0x6e/0xb0
[<ffffffff814498b8>] blkcg_deactivate_policy+0x38/0x120
[<ffffffff8144ec44>] blk_throtl_exit+0x34/0x50
[<ffffffff8144aea5>] blkcg_exit_queue+0x35/0x40
[<ffffffff8142d476>] blk_release_queue+0x26/0xd0
[<ffffffff81454968>] kobject_cleanup+0x38/0x70
[<ffffffff81454848>] kobject_put+0x28/0x60
[<ffffffff81427505>] blk_put_queue+0x15/0x20
[<ffffffff817d07bb>] scsi_device_dev_release_usercontext+0x16b/0x1c0
[<ffffffff810bc339>] execute_in_process_context+0x89/0xa0
[<ffffffff817d064c>] scsi_device_dev_release+0x1c/0x20
[<ffffffff817930e2>] device_release+0x32/0xa0
[<ffffffff817934d7>] put_device+0x17/0x20
[<ffffffff817d11b9>] __scsi_remove_device+0xa9/0xe0
[<ffffffff817d121b>] scsi_remove_device+0x2b/0x40
[<ffffffff817d1257>] sdev_store_delete+0x27/0x30
[<ffffffff81792ca8>] dev_attr_store+0x18/0x30
[<ffffffff8126f75e>] sysfs_kf_write+0x3e/0x50
[<ffffffff8126ea87>] kernfs_fop_write+0xe7/0x170
[<ffffffff811f5e9f>] vfs_write+0xaf/0x1d0
[<ffffffff811f69bd>] SyS_write+0x4d/0xc0
[<ffffffff81d24692>] system_call_fastpath+0x16/0x1b
776687bce42b ("block, blk-mq: draining can't be skipped even if
bypass_depth was non-zero") made it easier to trigger this bug by
making blk_queue_bypass_start() drain even when it loses the first
bypass test to blk_cleanup_queue(); however, the bug has always been
there even before the commit as blk_queue_bypass_start() could race
against queue destruction, win the initial bypass test but perform the
actual draining after blk_cleanup_queue() already destroyed all blkgs.
Fix it by skippping calling into policy draining if all the blkgs are
already gone.
Reported-by: Shirish Pargaonkar <spargaonkar@suse.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Reported-by: Jet Chen <jet.chen@intel.com>
Tested-by: Shirish Pargaonkar <spargaonkar@suse.com>
commit 0b462c89e31f7eb6789713437eb551833ee16ff3 upstream.
Stack:
Call Trace:
already gone.
commit d45b3279a5a2252cafcd665bbf2db8c9b31ef783 upstream.
There is no inherent reason why the last put of a tag structure must be
the one for the Scsi_Host, as device model objects can be held for
arbitrary periods. Merge blk_free_tags and __blk_free_tags into a single
funtion that just release a references and get rid of the BUG() when the
host reference wasn't the last.
commit 3b3a1814d1703027f9867d0f5cbbfaf6c7482474 upstream.
This patch provides the compat BLKZEROOUT ioctl. The argument is a pointer
to two uint64_t values, so there is no need to translate it.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit af5040da01ef980670b3741b3e10733ee3e33566 upstream.
trace_block_rq_complete does not take into account that request can
be partially completed, so we can get the following incorrect output
of blkparser:
C R 232 + 240 [0]
C R 240 + 232 [0]
C R 248 + 224 [0]
C R 256 + 216 [0]
but should be:
C R 232 + 8 [0]
C R 240 + 8 [0]
C R 248 + 8 [0]
C R 256 + 8 [0]
Also, the whole output summary statistics of completed requests and
final throughput will be incorrect.
This patch takes into account real completion size of the request and
fixes wrong completion accounting.
Signed-off-by: Roman Pen <r.peniaev@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: linux-kernel@vger.kernel.org
commit c8123f8c9cb517403b51aa41c3c46ff5e10b2c17 upstream.
When mkfs issues a full device discard and the device only
supports discards of a smallish size, we can loop in
blkdev_issue_discard() for a long time. If preempt isn't enabled,
this can turn into a softlock situation and the kernel will
start complaining.
Add an explicit cond_resched() at the end of the loop to avoid
that.
commit 556ee818c06f37b2e583af0363e6b16d0e0270de upstream.
request_queue bypassing is used to suppress higher-level function of a
request_queue so that they can be switched, reconfigured and shut
down. A request_queue does the followings while bypassing.
* bypasses elevator and io_cq association and queues requests directly
to the FIFO dispatch queue.
* bypasses block cgroup request_list lookup and always uses the root
request_list.
Once confirmed to be bypassing, specific elevator and block cgroup
policy implementations can assume that nothing is in flight for them
and perform various operations which would be dangerous otherwise.
Such confirmation is acheived by short-circuiting all new requests
directly to the dispatch queue and waiting for all the requests which
were issued before to finish. Unfortunately, while the request
allocating and draining sides were properly handled, we forgot to
actually plug the request dispatch path. Even after bypassing mode is
confirmed, if the attached driver tries to fetch a request and the
dispatch queue is empty, __elv_next_request() would invoke the current
elevator's elevator_dispatch_fn() callback. As all in-flight requests
were drained, the elevator wouldn't contain any request but once
bypass is confirmed we don't even know whether the elevator is even
there. It might be in the process of being switched and half torn
down.
Frank Mayhar reports that this actually happened while switching
elevators, leading to an oops.
Let's fix it by making __elv_next_request() avoid invoking the
elevator_dispatch_fn() callback if the queue is bypassing. It already
avoids invoking the callback if the queue is dying. As a dying queue
is guaranteed to be bypassing, we can simply replace blk_queue_dying()
check with blk_queue_bypass().
Reported-by: Frank Mayhar <fmayhar@google.com>
References: http://lkml.kernel.org/g/1390319905.20232.38.camel@bobble.lax.corp.google.com
Tested-by: Frank Mayhar <fmayhar@google.com>
u64_stats_fetch_retry is only preempt_disable on 32bit UP system. This is not enough to avoid preemption by bh and may read strange 64 bit value.
commit 2c575026fae6e63771bd2a4c1d407214a8096a89 upstream.
Signed-off-by: Hong Zhiguo <zhiguohong@tencent.com>
commit 7c8a3679e3d8e9d92d58f282161760a0e247df97 upstream.
Add locking of q->sysfs_lock into elevator_change() (an exported function)
to ensure it is held to protect q->elevator from elevator_init(), even if
elevator_change() is called from non-sysfs paths.
sysfs path (elv_iosched_store) uses __elevator_change(), non-locking
version, as the lock is already taken by elv_iosched_store().
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit eb1c160b22655fd4ec44be732d6594fd1b1e44f4 upstream.
The soft lockup below happens at the boot time of the system using dm
multipath and the udev rules to switch scheduler.
[ 356.127001] BUG: soft lockup - CPU#3 stuck for 22s! [sh:483]
[ 356.127001] RIP: 0010:[<ffffffff81072a7d>] [<ffffffff81072a7d>] lock_timer_base.isra.35+0x1d/0x50
[ 356.127001] Call Trace:
[ 356.127001] [<ffffffff81073810>] try_to_del_timer_sync+0x20/0x70
[ 356.127001] [<ffffffff8118b08a>] ? kmem_cache_alloc_node_trace+0x20a/0x230
[ 356.127001] [<ffffffff810738b2>] del_timer_sync+0x52/0x60
[ 356.127001] [<ffffffff812ece22>] cfq_exit_queue+0x32/0xf0
[ 356.127001] [<ffffffff812c98df>] elevator_exit+0x2f/0x50
[ 356.127001] [<ffffffff812c9f21>] elevator_change+0xf1/0x1c0
[ 356.127001] [<ffffffff812caa50>] elv_iosched_store+0x20/0x50
[ 356.127001] [<ffffffff812d1d09>] queue_attr_store+0x59/0xb0
[ 356.127001] [<ffffffff812143f6>] sysfs_write_file+0xc6/0x140
[ 356.127001] [<ffffffff811a326d>] vfs_write+0xbd/0x1e0
[ 356.127001] [<ffffffff811a3ca9>] SyS_write+0x49/0xa0
[ 356.127001] [<ffffffff8164e899>] system_call_fastpath+0x16/0x1b
This is caused by a race between md device initialization by multipathd and
shell script to switch the scheduler using sysfs.
- multipathd:
SyS_ioctl -> do_vfs_ioctl -> dm_ctl_ioctl -> ctl_ioctl -> table_load
-> dm_setup_md_queue -> blk_init_allocated_queue -> elevator_init
q->elevator = elevator_alloc(q, e); // not yet initialized
- sh -c 'echo deadline > /sys/$DEVPATH/queue/scheduler':
elevator_switch (in the call trace above)
struct elevator_queue *old = q->elevator;
q->elevator = elevator_alloc(q, new_e);
elevator_exit(old); // lockup! (*)
- multipathd: (cont.)
err = e->ops.elevator_init_fn(q); // init fails; q->elevator is modified
(*) When del_timer_sync() is called, lock_timer_base() will loop infinitely
while timer->base == NULL. In this case, as timer will never initialized,
it results in lockup.
This patch introduces acquisition of q->sysfs_lock around elevator_init()
into blk_init_allocated_queue(), to provide mutual exclusion between
initialization of the q->scheduler and switching of the scheduler.
This should fix this bugzilla:
https://bugzilla.redhat.com/show_bug.cgi?id=902012
commit fff4996b7db7955414ac74386efa5e07fd766b50 upstream.
If blkcg_init_queue fails, blk_alloc_queue_node doesn't call bdi_destroy
to clean up structures allocated by the backing dev.
WARNING: at lib/debugobjects.c:260 debug_print_object+0x85/0xa0()
ODEBUG: free active (active state 0) object type: percpu_counter hint: (null)
Modules linked in: dm_loop dm_mod ip6table_filter ip6_tables uvesafb cfbcopyarea cfbimgblt cfbfillrect fbcon font bitblit fbcon_rotate fbcon_cw fbcon_ud fbcon_ccw softcursor fb fbdev ipt_MASQUERADE iptable_nat nf_nat_ipv4 msr nf_conntrack_ipv4 nf_defrag_ipv4 xt_state ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp llc tun ipv6 cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_ondemand cpufreq_conservative spadfs fuse hid_generic usbhid hid raid0 md_mod dmi_sysfs nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack lm85 hwmon_vid snd_usb_audio snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_hwdep snd_usbmidi_lib snd_rawmidi snd soundcore acpi_cpufreq freq_table mperf sata_svw serverworks kvm_amd ide_core ehci_pci ohci_hcd libata ehci_hcd kvm usbcore tg3 usb_common libphy k10temp pcspkr ptp i2c_piix4 i2c_core evdev microcode hwmon rtc_cmos pps_core e100 skge floppy mii processor button unix
CPU: 0 PID: 2739 Comm: lvchange Tainted: G W
3.10.15-devel #14
Hardware name: empty empty/S3992-E, BIOS 'V1.06 ' 06/09/2009
0000000000000009 ffff88023c3c1ae8 ffffffff813c8fd4 ffff88023c3c1b20
ffffffff810399eb ffff88043d35cd58 ffffffff81651940 ffff88023c3c1bf8
ffffffff82479d90 0000000000000005 ffff88023c3c1b80 ffffffff81039a67
Call Trace:
[<ffffffff813c8fd4>] dump_stack+0x19/0x1b
[<ffffffff810399eb>] warn_slowpath_common+0x6b/0xa0
[<ffffffff81039a67>] warn_slowpath_fmt+0x47/0x50
[<ffffffff8122aaaf>] ? debug_check_no_obj_freed+0xcf/0x250
[<ffffffff81229a15>] debug_print_object+0x85/0xa0
[<ffffffff8122abe3>] debug_check_no_obj_freed+0x203/0x250
[<ffffffff8113c4ac>] kmem_cache_free+0x20c/0x3a0
[<ffffffff811f6709>] blk_alloc_queue_node+0x2a9/0x2c0
[<ffffffff811f672e>] blk_alloc_queue+0xe/0x10
[<ffffffffa04c0093>] dm_create+0x1a3/0x530 [dm_mod]
[<ffffffffa04c6bb0>] ? list_version_get_info+0xe0/0xe0 [dm_mod]
[<ffffffffa04c6c07>] dev_create+0x57/0x2b0 [dm_mod]
[<ffffffffa04c6528>] ctl_ioctl+0x268/0x500 [dm_mod]
[<ffffffff81097662>] ? get_lock_stats+0x22/0x70
[<ffffffffa04c67ce>] dm_ctl_ioctl+0xe/0x20 [dm_mod]
[<ffffffff81161aad>] do_vfs_ioctl+0x2ed/0x520
[<ffffffff8116cfc7>] ? fget_light+0x377/0x4e0
[<ffffffff81161d2b>] SyS_ioctl+0x4b/0x90
[<ffffffff813cff16>] system_call_fastpath+0x1a/0x1f
---[ end trace 4b5ff0d55673d986 ]---
This fix should be backported to stable kernels starting with 2.6.37. Note
that in the kernels prior to 3.5 the affected code is different, but the
bug is still there - bdi_init is called and bdi_destroy isn't.
commit d82ae52e68892338068e7559a0c0657193341ce4 upstream.
Without this patch all DM devices will default to BLK_MAX_SEGMENT_SIZE
(65536) even if the underlying device(s) have a larger value -- this is
due to blk_stack_limits() using min_not_zero() when stacking the
max_segment_size limit.
1073741824
before patch:
65536
after patch:
1073741824
Reported-by: Lukasz Flis <l.flis@cyfronet.pl>
commit 4912aa6c11e6a5d910264deedbec2075c6f1bb73 upstream.
crocode i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support shpchp ioatdma dca be2net sg ses enclosure ext4 mbcache jbd2 sd_mod crc_t10dif ahci megaraid_sas(U) dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 491, comm: scsi_eh_0 Tainted: G W ---------------- 2.6.32-220.13.1.el6.x86_64 #1 IBM -[8722PAX]-/00D1461
RIP: 0010:[<ffffffff8124e424>] [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP: 0018:ffff881057eefd60 EFLAGS: 00010012
RAX: ffff881d99e3e8a8 RBX: ffff881d99e3e780 RCX: ffff881d99e3e8a8
RDX: ffff881d99e3e8a8 RSI: ffff881d99e3e780 RDI: ffff881d99e3e780
RBP: ffff881057eefd80 R08: ffff881057eefe90 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff881057f92338
R13: 0000000000000000 R14: ffff881057f92338 R15: ffff883058188000
FS: 0000000000000000(0000) GS:ffff880040200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006d3ec0 CR3: 000000302cd7d000 CR4: 00000000000406b0
Process scsi_eh_0 (pid: 491, threadinfo ffff881057eee000, task ffff881057e29540)
Stack:
0000000000001057 0000000000000286 ffff8810275efdc0 ffff881057f16000
<0> ffff881057eefdd0 ffffffff81362323 ffff881057eefe20 ffffffff8135f393
<0> ffff881057e29af8 ffff8810275efdc0 ffff881057eefe78 ffff881057eefe90
Call Trace:
[<ffffffff81362323>] __scsi_queue_insert+0xa3/0x150
[<ffffffff8135f393>] ? scsi_eh_ready_devs+0x5e3/0x850
[<ffffffff81362a23>] scsi_queue_insert+0x13/0x20
[<ffffffff8135e4d4>] scsi_eh_flush_done_q+0x104/0x160
[<ffffffff8135fb6b>] scsi_error_handler+0x35b/0x660
[<ffffffff8135f810>] ? scsi_error_handler+0x0/0x660
[<ffffffff810908c6>] kthread+0x96/0xa0
[<ffffffff8100c14a>] child_rip+0xa/0x20
[<ffffffff81090830>] ? kthread+0x0/0xa0
[<ffffffff8100c140>] ? child_rip+0x0/0x20
Code: 00 00 eb d1 4c 8b 2d 3c 8f 97 00 4d 85 ed 74 bf 49 8b 45 00 49 83 c5 08 48 89 de 4c 89 e7 ff d0 49 8b 45 00 48 85 c0 75 eb eb a4 <0f> 0b eb fe 0f 1f 84 00 00 00 00 00 55 48 89 e5 0f 1f 44 00 00
RIP [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP <ffff881057eefd60>
The RIP is this line:
BUG_ON(blk_queued_rq(rq));
After digging through the code, I think there may be a race between the
request completion and the timer handler running.
A timer is started for each request put on the device's queue (see
blk_start_request->blk_add_timer). If the request does not complete
before the timer expires, the timer handler (blk_rq_timed_out_timer)
will mark the request complete atomically:
static inline int blk_mark_rq_complete(struct request *rq)
return test_and_set_bit(REQ_ATOM_COMPLETE, &rq->atomic_flags);
and then call blk_rq_timed_out. The latter function will call
scsi_times_out, which will return one of BLK_EH_HANDLED,
BLK_EH_RESET_TIMER or BLK_EH_NOT_HANDLED. If BLK_EH_RESET_TIMER is
returned, blk_clear_rq_complete is called, and blk_add_timer is again
called to simply wait longer for the request to complete.
Now, if the request happens to complete while this is going on, what
happens? Given that we know the completion handler will bail if it
finds the REQ_ATOM_COMPLETE bit set, we need to focus on the completion
handler running after that bit is cleared. So, from the above
paragraph, after the call to blk_clear_rq_complete. If the completion
sets REQ_ATOM_COMPLETE before the BUG_ON in blk_add_timer, we go boom
there (I haven't seen this in the cores). Next, if we get the
completion before the call to list_add_tail, then the timer will
eventually fire for an old req, which may either be freed or reallocated
(there is evidence that this might be the case). Finally, if the
completion comes in *after* the addition to the timeout list, I think
it's harmless. The request will be removed from the timeout list,
req_atom_complete will be set, and all will be well.
This will only actually explain the coredumps *IF* the request
structure was freed, reallocated *and* queued before the error handler
thread had a chance to process it. That is possible, but it may make
sense to keep digging for another race. I think that if this is what
was happening, we would see other instances of this problem showing up
as null pointer or garbage pointer dereferences, for example when the
request structure was not re-used. It looks like we actually do run
into that situation in other reports.
This patch moves the BUG_ON(test_bit(REQ_ATOM_COMPLETE,
&req->atomic_flags)); from blk_add_timer to the only caller that could
trip over it (blk_start_request). It then inverts the calls to
blk_clear_rq_complete and blk_add_timer in blk_rq_timed_out to address
the race. I've boot tested this patch, but nothing more.
Acked-by: Hannes Reinecke <hare@suse.de>
commit f3cff25f05f2ac29b2ee355e611b0657482f6f1d upstream.
'samples' is 64bit operant, but do_div() second parameter is 32.
do_div silently truncates high 32 bits and calculated result
is invalid.
In case if low 32bit of 'samples' are zeros then do_div() produces
kernel crash.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Cc: Jonghwan Choi <jhbird.choi@gmail.com>
commit d50235b7bc3ee0a0427984d763ea7534149531b4 upstream.
There's a race between elevator switching and normal io operation.
Because the allocation of struct elevator_queue and struct elevator_data
don't in a atomic operation.So there are have chance to use NULL
->elevator_data.
For example:
Thread A: Thread B
blk_queu_bio elevator_switch
spin_lock_irq(q->queue_block) elevator_alloc
elv_merge elevator_init_fn
Because call elevator_alloc, it can't hold queue_lock and the
->elevator_data is NULL.So at the same time, threadA call elv_merge and
nedd some info of elevator_data.So the crash happened.
Move the elevator_alloc into func elevator_init_fn, it make the
operations in a atomic operation.
Using the follow method can easy reproduce this bug
1:dd if=/dev/sdb of=/dev/null
2:while true;do echo noop > scheduler;echo deadline > scheduler;done
The test method also use this method.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream.
Disk names may contain arbitrary strings, so they must not be
interpreted as format strings. It seems that only md allows arbitrary
strings to be used for disk names, but this could allow for a local
memory corruption from uid 0 into ring 0.
CVE-2013-2851
In blk_post_runtime_resume, an autosuspend request will be initiated for
the device. Since we are holding the queue lock, we can't sleep and thus
we should use the async version to initiate an autosuspend, i.e.
pm_request_suspend instead of pm_runtime_suspend, which might sleep.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Pull block core updates from Jens Axboe:
- Major bit is Kents prep work for immutable bio vecs.
- Stable candidate fix for a scheduling-while-atomic in the queue
bypass operation.
- Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging
discard bios.
- Tejuns changes to convert the writeback thread pool to the generic
workqueue mechanism.
- Runtime PM framework, SCSI patches exists on top of these in James'
tree.
- A few random fixes.
* 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits)
relay: move remove_buf_file inside relay_close_buf
partitions/efi.c: replace useless kzalloc's by kmalloc's
fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read()
block: fix max discard sectors limit
blkcg: fix "scheduling while atomic" in blk_queue_bypass_start
Documentation: cfq-iosched: update documentation help for cfq tunables
writeback: expose the bdi_wq workqueue
writeback: replace custom worker pool implementation with unbound workqueue
writeback: remove unused bdi_pending_list
aoe: Fix unitialized var usage
bio-integrity: Add explicit field for owner of bip_buf
block: Add an explicit bio flag for bios that own their bvec
block: Add bio_alloc_pages()
block: Convert some code to bio_for_each_segment_all()
block: Add bio_for_each_segment_all()
bounce: Refactor __blk_queue_bounce to not use bi_io_vec
raid1: use bio_copy_data()
pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage
pktcdvd: use bio_copy_data()
block: Add bio_copy_data()
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio & lguest updates from Rusty Russell:
"Lots of virtio work which wasn't quite ready for last merge window.
Plus I dived into lguest again, reworking the pagetable code so we can
move the switcher page: our fixmaps sometimes take more than 2MB now..."
Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename.
Hopefully correctly resolved.
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits)
caif_virtio: Remove bouncing email addresses
lguest: improve code readability in lg_cpu_start.
virtio-net: fill only rx queues which are being used
lguest: map Switcher below fixmap.
lguest: cache last cpu we ran on.
lguest: map Switcher text whenever we allocate a new pagetable.
lguest: don't share Switcher PTE pages between guests.
lguest: expost switcher_pages array (as lg_switcher_pages).
lguest: extract shadow PTE walking / allocating.
lguest: make check_gpte et. al return bool.
lguest: assume Switcher text is a single page.
lguest: rename switcher_page to switcher_pages.
lguest: remove RESERVE_MEM constant.
lguest: check vaddr not pgd for Switcher protection.
lguest: prepare to make SWITCHER_ADDR a variable.
virtio: console: replace EMFILE with EBUSY for already-open port
virtio-scsi: reset virtqueue affinity when doing cpu hotplug
virtio-scsi: introduce multiqueue support
virtio-scsi: push vq lock/unlock into virtscsi_vq_done
virtio-scsi: pass struct virtio_scsi to virtqueue completion function
In alloc_read_gpt_entries and alloc_read_gpt_header, the kzalloc'ated
zones are either totally overwritten by the following read_lba call,
or freed. As kmalloc is cheaper than kzalloc, use kmalloc.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Cc: Matt Domsch <Matt_Domsch@dell.com>
Cc: Panagiotis Issaris <takis@issaris.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- Fixes and a lot of cleanups. Locking cleanup is finally complete.
cgroup_mutex is no longer exposed to individual controlelrs which
used to cause nasty deadlock issues. Li fixed and cleaned up quite a
bit including long standing ones like racy cgroup_path().
- device cgroup now supports proper hierarchy thanks to Aristeu.
- perf_event cgroup now supports proper hierarchy.
- A new mount option "__DEVEL__sane_behavior" is added. As indicated
by the name, this option is to be used for development only at this
point and generates a warning message when used. Unfortunately,
cgroup interface currently has too many brekages and inconsistencies
to implement a consistent and unified hierarchy on top. The new flag
is used to collect the behavior changes which are necessary to
implement consistent unified hierarchy. It's likely that this flag
won't be used verbatim when it becomes ready but will be enabled
implicitly along with unified hierarchy.
The option currently disables some of broken behaviors in cgroup core
and also .use_hierarchy switch in memcg (will be routed through -mm),
which can be used to make very unusual hierarchy where nesting is
partially honored. It will also be used to implement hierarchy
support for blk-throttle which would be impossible otherwise without
introducing a full separate set of control knobs.
This is essentially versioning of interface which isn't very nice but
at this point I can't see any other options which would allow keeping
the interface the same while moving towards hierarchy behavior which
is at least somewhat sane. The planned unified hierarchy is likely
to require some level of adaptation from userland anyway, so I think
it'd be best to take the chance and update the interface such that
it's supportable in the long term.
Maintaining the existing interface does complicate cgroup core but
shouldn't put too much strain on individual controllers and I think
it'd be manageable for the foreseeable future. Maybe we'll be able
to drop it in a decade.
Fix up conflicts (including a semantic one adding a new #include to ppc
that was uncovered by header the file changes) as per Tejun.
* 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits)
cpuset: fix compile warning when CONFIG_SMP=n
cpuset: fix cpu hotplug vs rebuild_sched_domains() race
cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn()
cgroup: restore the call to eventfd->poll()
cgroup: fix use-after-free when umounting cgroupfs
cgroup: fix broken file xattrs
devcg: remove parent_cgroup.
memcg: force use_hierarchy if sane_behavior
cgroup: remove cgrp->top_cgroup
cgroup: introduce sane_behavior mount option
move cgroupfs_root to include/linux/cgroup.h
cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix
cgroup: make cgroup_path() not print double slashes
Revert "cgroup: remove bind() method from cgroup_subsys."
perf: make perf_event cgroup hierarchical
cgroup: implement cgroup_is_descendant()
cgroup: make sure parent won't be destroyed before its children
devcg: remove broken_hierarchy tag
cgroup: remove cgroup_lock_is_held()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg Kroah-Hartman:
"Here's the merge request for the driver core tree for 3.10-rc1
It's pretty small, just a number of driver core and sysfs updates and
fixes, all of which have been in linux-next for a while now.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed conflict in kernel/rtmutex-tester.c, the locking tree had a better
fix for the same sysfs file mode problem.
* tag 'driver-core-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
PM / Runtime: Idle devices asynchronously after probe|release
driver core: handle user namespaces properly with the uid/gid devtmpfs change
driver core: devtmpfs: fix compile failure with CONFIG_UIDGID_STRICT_TYPE_CHECKS
devtmpfs: add base.h include
driver core: add uid and gid to devtmpfs
sysfs: check if one entry has been removed before freeing
sysfs: fix crash_notes_size build warning
sysfs: fix use after free in case of concurrent read/write and readdir
rtmutex-tester: fix mode of sysfs files
Documentation: Add ABI entry for crash_notes and crash_notes_size
sysfs: Add crash_notes_size to export percpu note size
driver core: platform_device.h: fix checkpatch errors and warnings
driver core: platform.c: fix checkpatch errors and warnings
driver core: warn that platform_driver_probe can not use deferred probing
sysfs: use atomic_inc_unless_negative in sysfs_get_active
base: core: WARN() about bogus permissions on device attributes
device: separate all subsys mutexes
This reverts commit 3a366e614d0837d9fc23f78cdb1a1186ebc3387f.
Wanlong Gao reports that it causes a kernel panic on his machine several
minutes after boot. Reverting it removes the panic.
Jens says:
"It's not quite clear why that is yet, so I think we should just revert
the commit for 3.9 final (which I'm assuming is pretty close).
The wifi is crap at the LSF hotel, so sending this email instead of
queueing up a revert and pull request."
Reported-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Requested-by: Jens Axboe <axboe@kernel.dk>
Cc: Tejun Heo <tj@kernel.org>
Now that devtmpfs is caring about uid/gid, we need to use the correct
internal types so users who have USER_NS enabled will have things work
properly for them.
Thanks to Eric for pointing this out, and the patch review.
Reported-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Kay Sievers <kay@vrfy.org>
Cc: Ming Lei <ming.lei@canonical.com>
Since 749fefe677 in v3.7 ("block: lift the initial queue bypass mode
on blk_register_queue() instead of blk_init_allocated_queue()"),
the following warning appears when multipath is used with CONFIG_PREEMPT=y.
This patch moves blk_queue_bypass_start() before radix_tree_preload()
to avoid the sleeping call while preemption is disabled.
BUG: scheduling while atomic: multipath/2460/0x00000002
1 lock held by multipath/2460:
#0: (&md->type_lock){......}, at: [<ffffffffa019fb05>] dm_lock_md_type+0x17/0x19 [dm_mod]
Modules linked in: ...
Pid: 2460, comm: multipath Tainted: G W 3.7.0-rc2 #1
Call Trace:
[<ffffffff810723ae>] __schedule_bug+0x6a/0x78
[<ffffffff81428ba2>] __schedule+0xb4/0x5e0
[<ffffffff814291e6>] schedule+0x64/0x66
[<ffffffff8142773a>] schedule_timeout+0x39/0xf8
[<ffffffff8108ad5f>] ? put_lock_stats+0xe/0x29
[<ffffffff8108ae30>] ? lock_release_holdtime+0xb6/0xbb
[<ffffffff814289e3>] wait_for_common+0x9d/0xee
[<ffffffff8107526c>] ? try_to_wake_up+0x206/0x206
[<ffffffff810c0eb8>] ? kfree_call_rcu+0x1c/0x1c
[<ffffffff81428aec>] wait_for_completion+0x1d/0x1f
[<ffffffff810611f9>] wait_rcu_gp+0x5d/0x7a
[<ffffffff81061216>] ? wait_rcu_gp+0x7a/0x7a
[<ffffffff8106fb18>] ? complete+0x21/0x53
[<ffffffff810c0556>] synchronize_rcu+0x1e/0x20
[<ffffffff811dd903>] blk_queue_bypass_start+0x5d/0x62
[<ffffffff811ee109>] blkcg_activate_policy+0x73/0x270
[<ffffffff81130521>] ? kmem_cache_alloc_node_trace+0xc7/0x108
[<ffffffff811f04b3>] cfq_init_queue+0x80/0x28e
[<ffffffffa01a1600>] ? dm_blk_ioctl+0xa7/0xa7 [dm_mod]
[<ffffffff811d8c41>] elevator_init+0xe1/0x115
[<ffffffff811e229f>] ? blk_queue_make_request+0x54/0x59
[<ffffffff811dd743>] blk_init_allocated_queue+0x8c/0x9e
[<ffffffffa019ffcd>] dm_setup_md_queue+0x36/0xaa [dm_mod]
[<ffffffffa01a60e6>] table_load+0x1bd/0x2c8 [dm_mod]
[<ffffffffa01a7026>] ctl_ioctl+0x1d6/0x236 [dm_mod]
[<ffffffffa01a5f29>] ? table_clear+0xaa/0xaa [dm_mod]
[<ffffffffa01a7099>] dm_ctl_ioctl+0x13/0x17 [dm_mod]
[<ffffffff811479fc>] do_vfs_ioctl+0x3fb/0x441
[<ffffffff811b643c>] ? file_has_perm+0x8a/0x99
[<ffffffff81147aa0>] sys_ioctl+0x5e/0x82
[<ffffffff812010be>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff814310d9>] system_call_fastpath+0x16/0x1b
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: stable@kernel.org
Some drivers want to tell userspace what uid and gid should be used for
their device nodes, so allow that information to percolate through the
driver core to userspace in order to make this happen. This means that
some systems (i.e. Android and friends) will not need to even run a
udev-like daemon for their device node manager and can just rely in
devtmpfs fully, reducing their footprint even more.
Signed-off-by: Kay Sievers <kay@vrfy.org>
This reverts commit 8761a3dc1f07b163414e2215a2cadbb4cfe2a107.
There are situations where the destruction path is called
with the bdev->bd_mutex already held, which then deadlocks in
loop_clr_fd(). The normal partition cleanup does a trylock()
on the mutex, but it'd be nice to have a more bullet proof
method in loop. So punt this more involved fix to the next
merge window, and just back out this buggy fix for now.
As found by gcc-4.8, the QUEUE_SYSFS_BIT_FNS macro creates functions
that use a value generated by queue_var_store independent of whether
that value was set or not.
block/blk-sysfs.c: In function 'queue_store_nonrot':
block/blk-sysfs.c:244:385: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
Unlike most other such warnings, this one is not a false positive,
writing any non-number string into the sysfs files indeed has
an undefined result, rather than returning an error.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq into for-3.10/core
Tejun writes:
This is the pull request for the earlier patchset[1] with the same
name. It's only three patches (the first one was committed to
workqueue tree) but the merge strategy is a bit involved due to the
dependencies.
* Because the conversion needs features from wq/for-3.10,
block/for-3.10/core is based on rc3, and wq/for-3.10 has conflicts
with rc3, I pulled mainline (rc5) into wq/for-3.10 to prevent those
workqueue conflicts from flaring up in block tree.
* Resolving the issue that Jan and Dave raised about debugging
requires arch-wide changes. The patchset is being worked on[2] but
it'll have to go through -mm after these changes show up in -next,
and not included in this pull request.
The three commits are located in the following git branch.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq.git writeback-workqueue
Pulling it into block/for-3.10/core produces a conflict in
drivers/md/raid5.c between the following two commits.
e3620a3ad5 ("MD RAID5: Avoid accessing gendisk or queue structs when not available")
2f6db2a707 ("raid5: use bio_reset()")
The conflict is trivial - one removes an "if ()" conditional while the
other removes "rbi->bi_next = NULL" right above it. We just need to
remove both. The merged branch is available at
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq.git block-test-merge
so that you can use it for verification. The test merge commit has
proper merge description.
While these changes are a bit of pain to route, they make code simpler
and even have, while minute, measureable performance gain[3] even on a
workload which isn't particularly favorable to showing the benefits of
this conversion.
Fixed up the conflict.
drivers/md/raid5.c
for-3.10/core
This contains Kents prep work for the immutable bio_vecs.
Just a little convenience macro - main reason to add it now is preparing
for immutable bio vecs, it'll reduce the size of the patch that puts
bi_sector/bi_size/bi_idx into a struct bvec_iter.
CC: Lars Ellenberg <drbd-dev@lists.linbit.com>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Alasdair Kergon <agk@redhat.com>
CC: dm-devel@redhat.com
CC: Neil Brown <neilb@suse.de>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
CC: linux-s390@vger.kernel.org
CC: Chris Mason <chris.mason@fusionio.com>
CC: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Converts it to use bio_advance(), simplifying it quite a bit in the
process.
Note that req_bio_endio() now always calls bio_advance() - which means
it always loops over the biovec, not just on partial completions. Don't
expect it to affect performance, but worth noting.
Tested it by forcing partial updates, and dumping before and after on
various bio/bvec fields when doing a partial update.
When a request is added:
If device is suspended or is suspending and the request is not a
PM request, resume the device.
When the last request finishes:
Call pm_runtime_mark_last_busy().
When pick a request:
If device is resuming/suspending, then only PM request is allowed
to go.
The idea and API is designed by Alan Stern and described here:
http://marc.info/?l=linux-scsi&m=133727953625963&w=2
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Add runtime pm helper functions:
void blk_pm_runtime_init(struct request_queue *q, struct device *dev)
- Initialization function for drivers to call.
int blk_pre_runtime_suspend(struct request_queue *q)
- If any requests are in the queue, mark last busy and return -EBUSY.
Otherwise set q->rpm_status to RPM_SUSPENDING and return 0.
void blk_post_runtime_suspend(struct request_queue *q, int err)
- If the suspend succeeded then set q->rpm_status to RPM_SUSPENDED.
Otherwise set it to RPM_ACTIVE and mark last busy.
void blk_pre_runtime_resume(struct request_queue *q)
- Set q->rpm_status to RPM_RESUMING.
void blk_post_runtime_resume(struct request_queue *q, int err)
- If the resume succeeded then set q->rpm_status to RPM_ACTIVE
and call __blk_run_queue, then mark last busy and autosuspend.
Otherwise set q->rpm_status to RPM_SUSPENDED.
Fixed code indent should use tabs where possible.
Signed-off-by: Alice Ferrazzi <alice.ferrazzi@gmail.com>
Any partitions added by user space to the loop device were being
left in place after detaching the loop device. This was because
the detach path issued a BLKRRPART to clean up partitions if
LO_FLAGS_PARTSCAN was set, meaning that the partitions were auto
scanned on attach. Replace this BLKRRPART with code that
unconditionally cleans up partitions on detach instead.
Signed-off-by: Phillip Susi <psusi@ubuntu.com>
Modified by Jens to export delete_partition().
This is useful in places that recycle the same scatterlist multiple
times, and do not want to incur the cost of sg_init_table every
time in hot paths.
Acked-by: Jens Axboe <axboe@kernel.dk>
rename() will change dentry->d_name. The result of this race can
be worse than seeing partially rewritten name, but we might access
a stale pointer because rename() will re-allocate memory to hold
a longer name.
As accessing dentry->name must be protected by dentry->d_lock or
parent inode's i_mutex, while on the other hand cgroup-path() can
be called with some irq-safe spinlocks held, we can't generate
cgroup path using dentry->d_name.
Alternatively we make a copy of dentry->d_name and save it in
cgrp->name when a cgroup is created, and update cgrp->name at
rename().
v5: use flexible array instead of zero-size array.
v4: - allocate root_cgroup_name and all root_cgroup->name points to it.
- add cgroup_name() wrapper.
v3: use kfree_rcu() instead of synchronize_rcu() in user-visible path.
v2: make cgrp->name RCU safe.
Signed-off-by: Li Zefan <lizefan@huawei.com>
