path: root/block
2008-02-01block: kill swap_io_context()Jens Axboe
It blindly copies everything in the io_context, including the lock. That doesn't work so well for either lock ordering or lockdep. There seems zero point in swapping io contexts on a request to request merge, so the best point of action is to just remove it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01as-iosched: fix inconsistent ioc->lock contextJens Axboe
Since it's acquired from irq context, all locking must be of the irq safe variant. Most are already inside the queue lock (which already disables interrupts), but the io scheduler rmmod path always has irqs enabled and the put_io_context() path may legally be called with irqs enabled (even if it isn't usually). So fixup those two. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: make elevator lib checkpatch compliantJens Axboe
2008-02-01cfq-iosched: make checkpatch compliantJens Axboe
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-02-01block: new end request handling interface should take unsigned byte countsJens Axboe
No point in passing signed integers as the byte count, they can never be negative. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-30[SCSI] bsg: copy the cmd_type field to the subordinate request for bidiJames Bottomley
This fixes a problem in SCSI where we use the (previously uninitialised) cmd_type via blk_pc_request() to set up the transfer in scsi_init_sgtable(). Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30as-iosched: fix double locking bug in as_merged_requests()Jens Axboe
If the two requests belong to the same io context, we will attempt to lock the same lock twice. But swapping contexts is pointless in that case, so just check for rioc == nioc before doing the double lock and copy. Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Expose hardware sector sizeMartin K. Petersen
Expose hardware sector size in sysfs queue directory. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: ll_rw_blk.c split, add blk-merge.cJens Axboe
2008-01-29block: remove dated (and wrong) comment in blk-core.cJens Axboe
2008-01-29block: get rid of unnecessary forward declarations in blk-core.cJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: split tag and sysfs handling from blk-core.cJens Axboe
Seperates the tag and sysfs handling from ll_rw_blk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: first step of splitting ll_rw_blk, rename itJens Axboe
Then we retain history in blk-core.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Merge branch 'for-2.6.25' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.25' of git://git.kernel.dk/linux-2.6-block: block: implement drain buffers __bio_clone: don't calculate hw/phys segment counts block: allow queue dma_alignment of zero blktrace: Add blktrace ioctls to SCSI generic devices
2008-01-29Merge branch 'blk-end-request' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'blk-end-request' of git://git.kernel.dk/linux-2.6-block: (30 commits) blk_end_request: changing xsysace (take 4) blk_end_request: changing ub (take 4) blk_end_request: cleanup of request completion (take 4) blk_end_request: cleanup 'uptodate' related code (take 4) blk_end_request: remove/unexport end_that_request_* (take 4) blk_end_request: changing scsi (take 4) blk_end_request: add bidi completion interface (take 4) blk_end_request: changing ide-cd (take 4) blk_end_request: add callback feature (take 4) blk_end_request: changing ide normal caller (take 4) blk_end_request: changing cpqarray (take 4) blk_end_request: changing cciss (take 4) blk_end_request: changing ide-scsi (take 4) blk_end_request: changing s390 (take 4) blk_end_request: changing mmc (take 4) blk_end_request: changing i2o_block (take 4) blk_end_request: changing viocd (take 4) blk_end_request: changing xen-blkfront (take 4) blk_end_request: changing viodasd (take 4) blk_end_request: changing sx8 (take 4) ...
2008-01-28cfq-iosched: kill some big inlinesJens Axboe
Use of inlines were a bit over the top, trim them down a bit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28cfq-iosched: relax IOPRIO_CLASS_IDLE restrictionsJens Axboe
Currently you must be root to set idle io prio class on a process. This is due to the fact that the idle class is implemented as a true idle class, meaning that it will not make progress if someone else is requesting disk access. Unfortunately this means that it opens DOS opportunities by locking down file system resources, hence it is root only at the moment. This patch relaxes the idle class a little, by removing the truly idle part (which entals a grace period with associated timer). The modifications make the idle class as close to zero impact as can be done while still guarenteeing progress. This means we can relax the root only criteria as well. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28block: implement drain buffersJames Bottomley
These DMA drain buffer implementations in drivers are pretty horrible to do in terms of manipulating the scatterlist. Plus they're being done at least in drivers/ide and drivers/ata, so we now have code duplication. The one use case for this, as I understand it is AHCI controllers doing PIO mode to mmc devices but translating this to DMA at the controller level. So, what about adding a callback to the block layer that permits the adding of the drain buffer for the problem devices. The idea is that you'd do this in slave_configure after you find one of these devices. The beauty of doing it in the block layer is that it quietly adds the drain buffer to the end of the sg list, so it automatically gets mapped (and unmapped) without anything unusual having to be done to the scatterlist in driver/scsi or drivers/ata and without any alteration to the transfer length. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io_context sharing - anticipatory changesJens Axboe
changes to anticipatory io scheduler for io_context sharing Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28block: cfq: make the io contect sharing locklessJens Axboe
The io context sharing introduced a per-ioc spinlock, that would protect the cfq io context lookup. That is a regression from the original, since we never needed any locking there because the ioc/cic were process private. The cic lookup is changed from an rbtree construct to a radix tree, which we can then use RCU to make the reader side lockless. That is the performance critical path, modifying the radix tree is only done on process creation (when that process first does IO, actually) and on process exit (if that process has done IO). As it so happens, radix trees are also much faster for this type of lookup where the key is a pointer. It's a very sparse tree. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io_context sharing - cfq changesNikanth Karthikesan
changes in the cfq for io_context sharing Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io context sharing: preliminary supportJens Axboe
Detach task state from ioc, instead keep track of how many processes are accessing the ioc. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28ioprio: move io priority from task_struct to io_contextJens Axboe
This is where it belongs and then it doesn't take up space for a process that doesn't do IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: cleanup of request completion (take 4)Kiyoshi Ueda
This patch merges complete_request() into end_that_request_last() for cleanup. complete_request() was introduced by earlier part of this patch-set, not to break the existing users of end_that_request_last(). Since all users are converted to blk_end_request interfaces and end_that_request_last() is no longer exported, the code can be merged to end_that_request_last(). Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: cleanup 'uptodate' related code (take 4)Kiyoshi Ueda
This patch converts 'uptodate' arguments of no longer exported interfaces, end_that_request_first/last, to 'error', and removes internal conversions for it in blk_end_request interfaces. Also, this patch removes no longer needed end_io_error(). Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: remove/unexport end_that_request_* (take 4)Kiyoshi Ueda
This patch removes the following functions: o end_that_request_first() o end_that_request_chunk() and stops exporting the functions below: o end_that_request_last() Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: add bidi completion interface (take 4)Kiyoshi Ueda
This patch adds a variant of the interface, blk_end_bidi_request(), which completes a bidi request. Bidi request must be completed as a whole, both rq and rq->next_rq at once. So the interface has 2 arguments for completion size. As for ->end_io, only rq->end_io is called (rq->next_rq->end_io is not called). So if special completion handling is needed, the handler must be set to rq->end_io. And the handler must take care of freeing next_rq too, since the interface doesn't care of it if rq->end_io is not NULL. Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: add callback feature (take 4)Kiyoshi Ueda
This patch adds a variant of the interface, blk_end_request_callback(), which has driver callback feature. Drivers may need to do special works between end_that_request_first() and end_that_request_last(). For such drivers, blk_end_request_callback() allows it to pass a callback function which is called between end_that_request_first() and end_that_request_last(). This interface is only for fallback of other blk_end_request interfaces. Drivers should avoid their tricky behaviors and use other interfaces as much as possible. Currently, only one driver, ide-cd, needs this interface. So this interface should/will be removed, after the driver removes such tricky behaviors. o ide-cd (cdrom_newpc_intr()) In PIO mode, cdrom_newpc_intr() needs to defer end_that_request_last() until the device clears DRQ_STAT and raises an interrupt after end_that_request_first(). So end_that_request_first() and end_that_request_last() are called separately in cdrom_newpc_intr(). This means blk_end_request_callback() has to return without completing request even if no leftover in the request. To satisfy the requirement, callback function has return value so that drivers can tell blk_end_request_callback() to return without completing request. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: changing block layer core (take 4)Kiyoshi Ueda
This patch converts core parts of block layer to use blk_end_request interfaces. Related 'uptodate' arguments are converted to 'error'. 'dequeue' argument was originally introduced for end_dequeued_request(), where no attempt should be made to dequeue the request as it's already dequeued. However, it's not necessary as it can be checked with list_empty(&rq->queuelist). (Dequeued request has empty list and queued request doesn't.) And it has been done in blk_end_request interfaces. As a result of this patch, end_queued_request() and end_dequeued_request() become identical. A future patch will merge and rename them and change users of those functions. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: add/export functions to get request size (take 4)Kiyoshi Ueda
This patch adds/exports functions to get the size of request in bytes. They are useful because blk_end_request interfaces take bytes as a completed I/O size instead of sectors. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: add new request completion interface (take 4)Kiyoshi Ueda
This patch adds 2 new interfaces for request completion: o blk_end_request() : called without queue lock o __blk_end_request() : called with queue lock held blk_end_request takes 'error' as an argument instead of 'uptodate', which current end_that_request_* take. The meanings of values are below and the value is used when bio is completed. 0 : success < 0 : error Some device drivers call some generic functions below between end_that_request_{first/chunk} and end_that_request_last(). o add_disk_randomness() o blk_queue_end_tag() o blkdev_dequeue_request() These are called in the blk_end_request interfaces as a part of generic request completion. So all device drivers become to call above functions. To decide whether to call blkdev_dequeue_request(), blk_end_request uses list_empty(&rq->queuelist) (blk_queued_rq() macro is added for it). So drivers must re-initialize it using list_init() or so before calling blk_end_request if drivers use it for its specific purpose. (Currently, there is no driver which completes request without re-initializing the queuelist after used it. So rq->queuelist can be used for the purpose above.) "Normal" drivers can be converted to use blk_end_request() in a standard way shown below. a) end_that_request_{chunk/first} spin_lock_irqsave() (add_disk_randomness(), blk_queue_end_tag(), blkdev_dequeue_request()) end_that_request_last() spin_unlock_irqrestore() => blk_end_request() b) spin_lock_irqsave() end_that_request_{chunk/first} (add_disk_randomness(), blk_queue_end_tag(), blkdev_dequeue_request()) end_that_request_last() spin_unlock_irqrestore() => spin_lock_irqsave() __blk_end_request() spin_unlock_irqsave() c) spin_lock_irqsave() (add_disk_randomness(), blk_queue_end_tag(), blkdev_dequeue_request()) end_that_request_last() spin_unlock_irqrestore() => blk_end_request() or spin_lock_irqsave() __blk_end_request() spin_unlock_irqrestore() Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blktrace: Add blktrace ioctls to SCSI generic devicesChristof Schmitt
Since the SCSI layer uses the request queues from the block layer, blktrace can also be used to trace the requests to all SCSI devices (like SCSI tape drives), not only disks. The only missing part is the ioctl interface to start and stop tracing. This patch adds the SETUP, START, STOP and TEARDOWN ioctls from blktrace to the sg device files. With this change, blktrace can be used for SCSI devices like for disks, e.g.: blktrace -d /dev/sg1 -o - | blkparse -i - Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-24Kobject: rename kobject_init_ng() to kobject_init()Greg Kroah-Hartman
Now that the old kobject_init() function is gone, rename kobject_init_ng() to kobject_init() to clean up the namespace. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: rename kobject_add_ng() to kobject_add()Greg Kroah-Hartman
Now that the old kobject_add() function is gone, rename kobject_add_ng() to kobject_add() to clean up the namespace. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: convert block/ll_rw_blk.c to use kobject_init/add_ng()Greg Kroah-Hartman
This converts the code to use the new kobject functions, cleaning up the logic in doing so. Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: convert block/elevator.c to use kobject_init/add_ng()Greg Kroah-Hartman
2008-01-24Driver core: convert block from raw kobjects to core devicesKay Sievers
This moves the block devices to /sys/class/block. It will create a flat list of all block devices, with the disks and partitions in one directory. For compatibility /sys/block is created and contains symlinks to the disks. /sys/class/block |-- sda -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda |-- sda1 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda1 |-- sda10 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda10 |-- sda5 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda5 |-- sda6 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda6 |-- sda7 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda7 |-- sda8 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda8 |-- sda9 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda9 `-- sr0 -> ../../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 /sys/block/ |-- sda -> ../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda `-- sr0 -> ../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert block_subsys to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename block_subsys to block_kset to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-11[SCSI] block: Introduce new blk_queue_update_dma_alignment interfaceJames Bottomley
The purpose of this is to allow stacked alignment settings, with the ultimate queue alignment being set to the largest alignment requirement in the stack. The reason for this is so that the SCSI mid-layer can relax the default alignment requirements (which are basically causing a lot of superfluous copying to go on in the SG_IO interface) while allowing transports, devices or HBAs to add stricter limits if they need them. Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas, bsg: pass errors through correctlyJames Bottomley
Currently in BSG, errors returned in req->errors aren't passed back to the calling programme (either via SG_IO or via read/write). Fix this, while preserving the SCSI convention of returning status in req->errors. Now update libsas to return errors correctly instead of to ignore them. Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11blktrace: kill the unneeded initcallJens Axboe
It just inits the mutex, we can do that with DEFINE_MUTEX() instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-11block: fix blktrace timestampsIngo Molnar
David Dillow reported broken blktrace timestamps. The reason is cpu_clock() which is not a global time source. Fix bkltrace timestamps by using ktime_get() like the networking code does for packet timestamps. This also removes a whole lot of complexity from bkltrace.c and shrinks the code by 500 bytes: text data bss dec hex filename 2888 124 44 3056 bf0 blktrace.o.before 2390 116 44 2550 9f6 blktrace.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-12-18block: let elv_register() return voidAdrian Bunk
elv_register() always returns 0, and there isn't anything it does where it should return an error (the only error condition is so grave that it's handled with a BUG_ON). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-12-18as-iosched: fix write batch start pointAaron Carroll
New write batches currently start from where the last one completed. We have no idea where the head is after switching batches, so this makes little sense. Instead, start the next batch from the request with the earliest deadline in the hope that we avoid a deadline expiry later on. Signed-off-by: Aaron Carroll <aaronc@gelato.unsw.edu.au> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-12-18as-iosched: fix incorrect commentsAaron Carroll
Two comments refer to deadlines applying to reads only. This is not the case. Signed-off-by: Aaron Carroll <aaronc@gelato.unsw.edu.au> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
