path: root/block
2005-12-19[PATCH] block: Cleanup CDROMEJECT ioctlBen Collins
This is just a basic cleanup. No change in functionality. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-21[PATCH] as-iosched: remove state assertion in as_add_request()Jens Axboe
Kill the arq->state poison statement in as_add_request(), it can trigger for perfectly valid code that just reuses a request after io completion instead of freeing it and allocating a new one. We probably should introduce a blk_init_request() to start from scratch, but for now just kill it as we will be removing the as specific poisoning soon. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[BLOCK] new block/ directory comment tidyCoywolf Qi Hunt
Some leftover comments referring to drivers/block that are now block/. They don't add any information we don't already have, so kill them. Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] elevator: elv_latter/former_request updateTejun Heo
With generic dispatch queue update, implicit former/latter request handling using rq->queuelist.prev/next doesn't work as expected anymore. Also, the only iosched dependent on this feature was noop-iosched and it has been reimplemented to have its own latter/former methods. This patch removes implicit former/latter handling. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] noop-iosched: reimplementation of request dispatchingTejun Heo
The original implementation directly used dispatch queue. As new generic dispatch queue imposes stricter rules over ioscheds and dispatch queue usage, this direct use becomes somewhat problematic. This patch reimplements noop-iosched such that it complies to generic iosched model better. Request merging with q->last_merge and rq->queuelist.prev/next work again now. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de
2005-11-12[BLOCK] cfq-iosched: fix slice_left calculationTejun Heo
When cfq slice expires, remainder of slice is calculated and stored in cfqq->slice_left. Current code calculates the opposite of remainder - how many jiffies the cfqq has used past slice end. This patch fixes the bug. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] fix string handling in elv_iosched_storeTejun Heo
elv_iosched_store doesn't terminate string passed from userspace if it's too long. Also, if the written length is zero (probably not possible), it accesses elevator_name[-1]. This patch fixes both bugs. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] Implement elv_drain_elevator for improved switch error detectionTejun Heo
This patch adds request_queue->nr_sorted which keeps the number of requests in the iosched and implement elv_drain_elevator which performs forced dispatching. elv_drain_elevator checks whether iosched actually dispatches all requests it has and prints error message if it doesn't. As buggy forced dispatching can result in wrong barrier operations, I think this extra check is worthwhile. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] cfq-iosched: cfq forced dispatching fixTejun Heo
cfq forced dispatching might not return all requests on the queue. This bug can hang elevator switchinig and corrupt request ordering during flush sequence. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] elevator: run queue in elevator_switchTejun Heo
elevator_dispatch needs to run queue after forced dispatching; otherwise, the queue might stall. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] Document the READ/WRITE splitup of the disk statsJens Axboe
Use the symbolic name where appropriate and add a comment to the disk_stats structure. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] elevator init fixes #2Zachary Amsden
In addition to the first patch, which is probably goodness, I found the cause of my panic - applying this patch fixes it and now I am booting. If the chosen_elevator[] is not found, fall back to noop. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-12[BLOCK] elevator init fixesZachary Amsden
I got a panic in the elevator code, backtrace : Unable to handle kernel NULL pointer dereference at virtual address 00000060 .. EIP is at elevator_put+0x0/0x30 (null elevator_type passed) .. elevator_init+0x38 blk_init_queu_node+0xc9 floppy_init+0xdb do_initcalls+0x23 init+0x10a init+0x0 Clearly if the kmalloc here fails, e->elevator_type is not yet set; this appears to be the correct fix, but I think I probably hit the second case due to a race condition. Someone more familiar with the elevator code should look at this more closely until I can determine if I can reproduce. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-07Merge branch 'block-dir' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
2005-11-04[BLOCK] iosched: fix setting of default io schedulerJens Axboe
With the recent reorg of the io scheduler selection, it unfortunately became possible to select an io scheduler to be the default even if it wasn't builtin. Fix this by requiring the default scheduler to be builtin. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-04[BLOCK] Move all core block layer code to new block/ directoryJens Axboe
drivers/block/ is right now a mix of core and driver parts. Lets move the core parts to a new top level directory. Al will move the fs/ related block parts to block/ next. Signed-off-by: Jens Axboe <axboe@suse.de>
