path: root/block
2009-04-07Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: branch tracer, intel-iommu: fix build with CONFIG_BRANCH_TRACER=y branch tracer: Fix for enabling branch profiling makes sparse unusable ftrace: Correct a text align for event format output Update /debug/tracing/README tracing/ftrace: alloc the started cpumask for the trace file tracing, x86: remove duplicated #include ftrace: Add check of sched_stopped for probe_sched_wakeup function-graph: add proper initialization for init task tracing/ftrace: fix missing include string.h tracing: fix incorrect return type of ns2usecs() tracing: remove CALLER_ADDR2 from wakeup tracer blktrace: fix pdu_len when tracing packet command requests blktrace: small cleanup in blk_msg_write() blktrace: NUL-terminate user space messages tracing: move scripts/trace/power.pl to scripts/tracing/power.pl
2009-04-07Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: loop: mutex already unlocked in loop_clr_fd() cfq-iosched: don't let idling interfere with plugging block: remove unused REQ_UNPLUG cfq-iosched: kill two unused cfqq flags cfq-iosched: change dispatch logic to deal with single requests at the time mflash: initial support cciss: change to discover first memory BAR cciss: kernel scan thread for MSA2012 cciss: fix residual count for block pc requests block: fix inconsistency in I/O stat accounting code block: elevator quiescing helpers
2009-04-07Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_mv: shorten register names sata_mv: workaround errata SATA#13 sata_mv: cosmetic renames sata_mv: workaround errata SATA#26 sata_mv: workaround errata PCI#7 sata_mv: replace 0x1f with ATA_PIO4 (v2) sata_mv: fix irq mask races sata_mv: revert SoC irq breakage libata: ahci enclosure management bios workaround ata: Add TRIM infrastructure ata_piix: VGN-BX297XP wants the controller power up on suspend libata: Remove some redundant casts from pata_octeon_cf.c pata_artop: typo
2009-04-07cfq-iosched: don't let idling interfere with pluggingJens Axboe
When CFQ is waiting for a new request from a process, currently it'll immediately restart queuing when it sees such a request. This doesn't work very well with streamed IO, since we then end up splitting IO that would otherwise have been merged nicely. For a simple dd test, this causes 10x as many requests to be issued as we should have. Normally this goes unnoticed due to the low overhead of requests at the device side, but some hardware is very sensitive to request sizes and there it can cause big slow downs. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: remove unused REQ_UNPLUGJens Axboe
The request inherits the unplug flag from the bio, but it isn't actually used. The bio flag stops at __make_request(), which tells it to unplug after submission. Passing it on to the request doesn't make any sense. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07cfq-iosched: kill two unused cfqq flagsJens Axboe
We only manipulate the must_dispatch and queue_new flags, they are not tested anymore. So get rid of them. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07cfq-iosched: change dispatch logic to deal with single requests at the timeJens Axboe
The IO scheduler core calls into the IO scheduler dispatch_request hook to move requests from the IO scheduler and into the driver dispatch list. It only does so when the dispatch list is empty. CFQ moves several requests to the dispatch list, which can cause higher latencies if we suddenly have to switch to some important sync IO. Change the logic to move one request at the time instead. This should almost be functionally equivalent to what we did before, except that we now honor 'quantum' as the maximum queue depth at the device side from any single cfqq. If there's just a single active cfqq, we allow up to 4 times the normal quantum. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: fix inconsistency in I/O stat accounting codeJerome Marchand
This forces in_flight to be zero when turning off or on the I/O stat accounting and stops updating I/O stats in attempt_merge() when accounting is turned off. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: elevator quiescing helpersJens Axboe
Simple helper functions to quiesce the request queue. These are currently only used for switching IO schedulers on-the-fly, but we can use them to properly switch IO accounting on and off as well. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-06pata_artop: typoAlan Cox
Fix a typo (this was in the original patch but was not merged when the code fixes were for some reason) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-06block: Add flag for telling the IO schedulers NOT to anticipate more IOJens Axboe
By default, CFQ will anticipate more IO from a given io context if the previously completed IO was sync. This used to be fine, since the only sync IO was reads and O_DIRECT writes. But with more "normal" sync writes being used now, we don't want to anticipate for those. Add a bio/request flag that informs the IO scheduler that this is a sync request that we should not idle for. Introduce WRITE_ODIRECT specifically for O_DIRECT writes, and make sure that the other sync writes set this flag. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06block: enabling plugging on SSD devices that don't do queuingJens Axboe
For the older SSD devices that don't do command queuing, we do want to enable plugging to get better merging. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06block: change the request allocation/congestion logic to be sync/async basedJens Axboe
This makes sure that we never wait on async IO for sync requests, instead of doing the split on writes vs reads. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: (36 commits) cpumask: remove cpumask allocation from idle_balance, fix numa, cpumask: move numa_node_id default implementation to topology.h, fix cpumask: remove cpumask allocation from idle_balance x86: cpumask: x86 mmio-mod.c use cpumask_var_t for downed_cpus x86: cpumask: update 32-bit APM not to mug current->cpus_allowed x86: microcode: cleanup x86: cpumask: use work_on_cpu in arch/x86/kernel/microcode_core.c cpumask: fix CONFIG_CPUMASK_OFFSTACK=y cpu hotunplug crash numa, cpumask: move numa_node_id default implementation to topology.h cpumask: convert node_to_cpumask_map[] to cpumask_var_t cpumask: remove x86 cpumask_t uses. cpumask: use cpumask_var_t in uv_flush_tlb_others. cpumask: remove cpumask_t assignment from vector_allocation_domain() cpumask: make Xen use the new operators. cpumask: clean up summit's send_IPI functions cpumask: use new cpumask functions throughout x86 x86: unify cpu_callin_mask/cpu_callout_mask/cpu_initialized_mask/cpu_sibling_setup_mask cpumask: convert struct cpuinfo_x86's llc_shared_map to cpumask_var_t cpumask: convert node_to_cpumask_map[] to cpumask_var_t x86: unify 32 and 64-bit node_to_cpumask_map ...
2009-04-03Merge branch 'ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: s390: remove arch specific smp_send_stop() panic: clean up kernel/panic.c panic, smp: provide smp_send_stop() wrapper on UP too panic: decrease oops_in_progress only after having done the panic generic-ipi: eliminate WARN_ON()s during oops/panic generic-ipi: cleanups generic-ipi: remove CSD_FLAG_WAIT generic-ipi: remove kmalloc() generic IPI: simplify barriers and locking
2009-04-03blktrace: fix pdu_len when tracing packet command requestsLi Zefan
Impact: output all of packet commands - not just the first 4 / 8 bytes Since commit d7e3c3249ef23b4617393c69fe464765b4ff1645 ("block: add large command support"), struct request->cmd has been changed from unsinged char cmd[BLK_MAX_CDB] to unsigned char *cmd. v1 -> v2: by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> - make sure rq->cmd_len is always intialized, and then we can use rq->cmd_len instead of BLK_MAX_CDB. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49D4507E.2060602@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-30Merge branch 'linus' into cpumask-for-linusIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c
2009-03-28Merge branch 'percpu-cpumask-x86-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'percpu-cpumask-x86-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (682 commits) percpu: fix spurious alignment WARN in legacy SMP percpu allocator percpu: generalize embedding first chunk setup helper percpu: more flexibility for @dyn_size of pcpu_setup_first_chunk() percpu: make x86 addr <-> pcpu ptr conversion macros generic linker script: define __per_cpu_load on all SMP capable archs x86: UV: remove uv_flush_tlb_others() WARN_ON percpu: finer grained locking to break deadlock and allow atomic free percpu: move fully free chunk reclamation into a work percpu: move chunk area map extension out of area allocation percpu: replace pcpu_realloc() with pcpu_mem_alloc() and pcpu_mem_free() x86, percpu: setup reserved percpu area for x86_64 percpu, module: implement reserved allocation and use it for module percpu variables percpu: add an indirection ptr for chunk page map access x86: make embedding percpu allocator return excessive free space percpu: use negative for auto for pcpu_setup_first_chunk() arguments percpu: improve first chunk initial area map handling percpu: cosmetic renames in pcpu_setup_first_chunk() percpu: clean up percpu constants x86: un-__init fill_pud/pmd/pte x86: remove vestigial fix_ioremap prototypes ... Manually merge conflicts in arch/ia64/kernel/irq_ia64.c
2009-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (119 commits) [SCSI] scsi_dh_rdac: Retry for NOT_READY check condition [SCSI] mpt2sas: make global symbols unique [SCSI] sd: Make revalidate less chatty [SCSI] sd: Try READ CAPACITY 16 first for SBC-2 devices [SCSI] sd: Refactor sd_read_capacity() [SCSI] mpt2sas v00.100.11.15 [SCSI] mpt2sas: add MPT2SAS_MINOR(221) to miscdevice.h [SCSI] ch: Add scsi type modalias [SCSI] 3w-9xxx: add power management support [SCSI] bsg: add linux/types.h include to bsg.h [SCSI] cxgb3i: fix function descriptions [SCSI] libiscsi: fix possbile null ptr session command cleanup [SCSI] iscsi class: remove host no argument from session creation callout [SCSI] libiscsi: pass session failure a session struct [SCSI] iscsi lib: remove qdepth param from iscsi host allocation [SCSI] iscsi lib: have lib create work queue for transmitting IO [SCSI] iscsi class: fix lock dep warning on logout [SCSI] libiscsi: don't cap queue depth in iscsi modules [SCSI] iscsi_tcp: replace scsi_debug/tcp_debug logging with iscsi conn logging [SCSI] libiscsi_tcp: replace tcp_debug/scsi_debug logging with session/conn logging ...
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26bsg: Remove bogus check against request_queue->max_sectorsBoaz Harrosh
bsg submits REQ_TYPE_BLOCK_PC so the right check is max_hw_sectors. But I've removed this check because right after, bsg proceeds with calling blk_rq_map_user() which does all the right checks. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26block: WARN in __blk_put_request() for potential bio leakBoaz Harrosh
Put a WARN_ON in __blk_put_request if it is about to leak bio(s). This is a serious bug that can happen in error handling code paths. For this to work I have fixed a couple of places in block/ where request->bio != NULL ownership was not honored. And a small cleanup at sg_io() while at it. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24bsg: add support for tail queuingBoaz Harrosh
Currently inherited from sg.c bsg will submit asynchronous request at the head-of-the-queue, (using "at_head" set in the call to blk_execute_rq_nowait()). This is bad in situation where the queues are full, requests will execute out of order, and can cause starvation of the first submitted requests. The sg_io_v4->flags member is used and a bit is allocated to denote the Q_AT_TAIL. Zero is to queue at_head as before, to be compatible with old code at the write/read path. SG_IO code path behavior was changed so to be the same as write/read behavior. SG_IO was very rarely used and breaking compatibility with it is OK at this stage. sg_io_hdr at sg.h also has a flags member and uses 3 bits from the first nibble and one bit from the last nibble. Even though none of these bits are supported by bsg, The second nibble is allocated for use by bsg. Just in case. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: get rid of unused blkdev_free_rq() defineJens Axboe
2009-03-24block: remove various blk_queue_*() setting functions in blk_init_queue_node()Jens Axboe
It calls blk_queue_make_request(), which sets the identical set of limits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-13Merge branch 'x86/core' into core/ipiIngo Molnar
2009-03-13cpumask: use topology_core_cpumask/topology_thread_cpumask instead of ↵Rusty Russell
cpu_core_map/cpu_sibling_map Impact: cleanup This is presumably what those definitions are for, and while all archs define cpu_core_map/cpu_sibling map, that's changing (eg. x86 wants to change it to a pointer). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-13Merge branch 'linus' into core/ipiIngo Molnar
2009-03-12[SCSI] Make scsi.h independent of the rest of the scsi includesJames Bottomley
This allows it to compile and be used on the ps3 platform that wants to use the #define values in scsi.h without actually having CONFIG_SCSI set. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-10Merge branches 'tracing/doc', 'tracing/ftrace', 'tracing/printk' and 'linus' ↵Ingo Molnar
into tracing/core
2009-03-10Merge branches 'x86/apic', 'x86/asm', 'x86/fixmap', 'x86/memtest', 'x86/mm', ↵Ingo Molnar
'x86/urgent', 'linus' and 'core/percpu' into x86/core
2009-03-06block: fix missing bio back/front segment size setting in blk_recount_segments()Jens Axboe
Commit 1e42807918d17e8c93bf14fbb74be84b141334c1 introduced a bug where we don't get front/back segment sizes in the bio in blk_recount_segments(). Fix this by tracking the back bio as well as the front bio in __blk_recalc_rq_segments(), this also cleans up the interface by getting rid of the segment size pointer passing. Tested-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-04Merge branch 'x86/core' into core/percpuIngo Molnar
2009-02-27Merge branches 'tracing/ftrace' and 'linus' into tracing/coreIngo Molnar
2009-02-26block: reduce stack footprint of blk_recount_segments()Jens Axboe
blk_recalc_rq_segments() requires a request structure passed in, which we don't have from blk_recount_segments(). So the latter allocates one on the stack, using > 400 bytes of stack for that. This can cause us to spill over one page of stack from ext4 at least: 0) 4560 400 blk_recount_segments+0x43/0x62 1) 4160 32 bio_phys_segments+0x1c/0x24 2) 4128 32 blk_rq_bio_prep+0x2a/0xf9 3) 4096 32 init_request_from_bio+0xf9/0xfe 4) 4064 112 __make_request+0x33c/0x3f6 5) 3952 144 generic_make_request+0x2d1/0x321 6) 3808 64 submit_bio+0xb9/0xc3 7) 3744 48 submit_bh+0xea/0x10e 8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4] 9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4] 10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4] 11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4] 12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4] 13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4] 14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4] 15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4] 16) 1664 32 do_writepages+0x2d/0x3c 17) 1632 144 __writeback_single_inode+0x162/0x2cd 18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b 19) 1392 16 sync_sb_inodes+0xe/0x10 20) 1376 48 writeback_inodes+0x69/0xb3 21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9 22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4 23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393 24) 720 80 generic_file_aio_write+0x6c/0xc8 25) 640 80 ext4_file_write+0xa9/0x137 [ext4] 26) 560 320 do_sync_write+0xf0/0x137 27) 240 48 vfs_write+0xb3/0x13c 28) 192 64 sys_write+0x4c/0x74 29) 128 128 system_call_fastpath+0x16/0x1b Split the segment counting out into a __blk_recalc_rq_segments() helper to avoid allocating an onstack request just for checking the physical segment count. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-26block: add documentation for register_blkdev()Márton Németh
Add documentation for register_blkdev() function and for the parameters. Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-25generic-ipi: remove CSD_FLAG_WAITPeter Zijlstra
Oleg noticed that we don't strictly need CSD_FLAG_WAIT, rework the code so that we can use CSD_FLAG_LOCK for both purposes. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-24Merge branch 'tj-percpu' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into core/percpu Conflicts: arch/x86/include/asm/pgtable.h
2009-02-20alloc_percpu: add align argument to __alloc_percpu.Rusty Russell
This prepares for a real __alloc_percpu, by adding an alignment argument. Only one place uses __alloc_percpu directly, and that's for a string. tj: af_inet also uses __alloc_percpu(), update it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Jens Axboe <axboe@kernel.dk>
2009-02-19Merge branch 'linus' into tracing/blktraceIngo Molnar
Conflicts: block/blktrace.c Semantic merge: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-18block: fix deadlock in blk_abort_queue() for drivers that readd to timeout listHannes Reinecke
blk_abort_queue() iterates the timeout list and aborts each request on the list, but if the driver error handling readds a request to the timeout list during this processing, we could be looping forever. Fix this by splicing current entries to a local list and run over that list instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-18block: fix booting from partitioned md arrayNeil Brown
Hi Tejun, it looks like your commit: block: don't depend on consecutive minor space f331c0296f2a9fee0d396a70598b954062603015 broke a particular case for booting from partitioned md/raid devices. That is the second time this has been broken recently. The previous time was fixed by block: do_mounts - accept root=<non-existant partition> 30f2f0eb4bd2c43d10a8b0d872c6e5ad8f31c9a0 Because the data isn't available when an md device is first created (we add disks and set it up after creation), the initial partition scan finds nothing. It is not until the device is opened that another partition scan happens and finds something. So at the point where the kernel parameter "root=/dev/md_d0p1" is being parsed, md_d0 exists, but md_d0p1 does not. However if we let blk_lookup_devt return the correct device number even though the device doesn't exist, then the attempt to mount it will successfully find the partition. I have tried in the past to find a way to get the partition table to be read as soon as the array is assembled but that proved impossible (at the time). I don't remember the details, and could possibly revisit it. However it would be really nice if blk_lookup_devt could be adjusted to again accept non existant partitions. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-18block: fix bad definition of BIO_RW_SYNCJens Axboe
We can't OR shift values, so get rid of BIO_RW_SYNC and use BIO_RW_SYNCIO and BIO_RW_UNPLUG explicitly. This brings back the behaviour from before 213d9417fec62ef4c3675621b9364a667954d4dd. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-18bsg: Fix sense buffer bug in SG_IOBoaz Harrosh
When submitting requests via SG_IO, which does a sync io, a bsg_command is not allocated. So an in-Kernel sense_buffer was not set. However when calling blk_execute_rq() with no sense buffer one is provided from the stack. Now bsg at blk_complete_sgv4_hdr_rq() would check if rq->sense_len and a sense was requested by sg_io_v4 the rq->sense was copy_user() back, but by now it is already mangled stack memory. I have fixed that by forcing a sense_buffer when calling bsg_map_hdr(). The bsg_command->sense is provided in the write/read path like before, and on-the-stack buffer is provided when doing SG_IO. I have also fixed a dprintk message to print rq->errors in hex because of the scsi bit-field use of this member. For other block devices it does not matter anyway. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-09tracing/blktrace: move the tracing file to kernel/traceFrederic Weisbecker
Impact: cleanup Move blktrace.c to kernel/trace, also move its config entry. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06trace: Call tracing_reset_online_cpus before tracer->init()Arnaldo Carvalho de Melo
Impact: cleanup To make it easy for ftrace plugin writers, as this was open coded in the existing plugins Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06tracing: Introduce trace_buffer_{lock_reserve,unlock_commit}Arnaldo Carvalho de Melo
Impact: new API These new functions do what previously was being open coded, reducing the number of details ftrace plugin writers have to worry about. It also standardizes the handling of stacktrace, userstacktrace and other trace options we may introduce in the future. With this patch, for instance, the blk tracer (and some others already in the tree) can use the "userstacktrace" /d/tracing/trace_options facility. $ codiff /tmp/vmlinux.before /tmp/vmlinux.after linux-2.6-tip/kernel/trace/trace.c: trace_vprintk | -5 trace_graph_return | -22 trace_graph_entry | -26 trace_function | -45 __ftrace_trace_stack | -27 ftrace_trace_userstack | -29 tracing_sched_switch_trace | -66 tracing_stop | +1 trace_seq_to_user | -1 ftrace_trace_special | -63 ftrace_special | +1 tracing_sched_wakeup_trace | -70 tracing_reset_online_cpus | -1 13 functions changed, 2 bytes added, 355 bytes removed, diff: -353 linux-2.6-tip/block/blktrace.c: __blk_add_trace | -58 1 function changed, 58 bytes removed, diff: -58 linux-2.6-tip/kernel/trace/trace.c: trace_buffer_lock_reserve | +88 trace_buffer_unlock_commit | +86 2 functions changed, 174 bytes added, diff: +174 /tmp/vmlinux.after: 16 functions changed, 176 bytes added, 413 bytes removed, diff: -237 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06ring_buffer: remove unused flags parameterArnaldo Carvalho de Melo
Impact: API change, cleanup >From ring_buffer_{lock_reserve,unlock_commit}. $ codiff /tmp/vmlinux.before /tmp/vmlinux.after linux-2.6-tip/kernel/trace/trace.c: trace_vprintk | -14 trace_graph_return | -14 trace_graph_entry | -10 trace_function | -8 __ftrace_trace_stack | -8 ftrace_trace_userstack | -8 tracing_sched_switch_trace | -8 ftrace_trace_special | -12 tracing_sched_wakeup_trace | -8 9 functions changed, 90 bytes removed, diff: -90 linux-2.6-tip/block/blktrace.c: __blk_add_trace | -1 1 function changed, 1 bytes removed, diff: -1 /tmp/vmlinux.after: 10 functions changed, 91 bytes removed, diff: -91 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
