path: root/block
2007-05-07KMEM_CACHE(): simplify slab cache creationChristoph Lameter
This patch provides a new macro KMEM_CACHE(<struct>, <flags>) to simplify slab creation. KMEM_CACHE creates a slab with the name of the struct, with the size of the struct and with the alignment of the struct. Additional slab flags may be specified if necessary. Example struct test_slab { int a,b,c; struct list_head; } __cacheline_aligned_in_smp; test_slab_cache = KMEM_CACHE(test_slab, SLAB_PANIC) will create a new slab named "test_slab" of the size sizeof(struct test_slab) and aligned to the alignment of test slab. If it fails then we panic. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits) [SCSI] fusion: fix domain validation loops [SCSI] qla2xxx: fix regression on sparc64 [SCSI] modalias for scsi devices [SCSI] sg: cap reserved_size values at max_sectors [SCSI] BusLogic: stop using check_region [SCSI] tgt: fix rdma transfer bugs [SCSI] aacraid: fix aacraid not finding device [SCSI] aacraid: Correct SMC products in aacraid.txt [SCSI] scsi_error.c: Add EH Start Unit retry [SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test. [SCSI] ipr: Driver version to 2.3.2 [SCSI] ipr: Faster sg list fetch [SCSI] ipr: Return better qc_issue errors [SCSI] ipr: Disrupt device error [SCSI] ipr: Improve async error logging level control [SCSI] ipr: PCI unblock config access fix [SCSI] ipr: Fix for oops following SATA request sense [SCSI] ipr: Log error for SAS dual path switch [SCSI] ipr: Enable logging of debug error data for all devices [SCSI] ipr: Add new PCI-E IDs to device table ...
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-30Merge branch 'cfq' into for-linusJens Axboe
2007-04-30[PATCH] elevator: elv_list_lock does not need irq disablingJens Axboe
It's never grabbed from irq context, so just make it plain spin_lock(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: speedup cic rb lookupJens Axboe
We often lookup the same queue many times in succession, so cache the last looked up queue to avoid browsing the rbtree. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30ll_rw_blk: add io_context private pointerJens Axboe
To be used by as/cfq as they see fit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: get rid of cfqq hashVasily Tarasov
cfq hash is no more necessary. We always can get cfqq from io context. cfq_get_io_context_noalloc() function is introduced, because we don't want to allocate cic on merging and checking may_queue. In order to identify sync queue we've used hash key = CFQ_KEY_ASYNC. Since hash is eliminated we need to use other criterion: sync flag for queue is added. In all places where we dig in rb_tree we're in current context, so no additional locking is required. Advantages of this patch: no additional memory for hash, no seeking in hash, code is cleaner. But it is necessary now to seek cic in per-ioc rbtree, but it is faster: - most processes work only with few devices - most systems have only few block devices - it is a rb-tree Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Changes by me: - Merge into CFQ devel branch - Get rid of cfq_get_io_context_noalloc() - Fix various bugs with dereferencing cic->cfqq[] with offset other than 0 or 1. - Fix bug in cfqq setup, is_sync condition was reversed. - Fix bug where only bio_sync() is used, we need to check for a READ too Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: tighten queue request overlap conditionJens Axboe
For tagged devices, allow overlap of requests if the idle window isn't enabled on the current active queue. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: improve sync vs async workloadsJens Axboe
2007-04-30cfq-iosched: never allow an async queue idlingJens Axboe
We don't enable it by default, don't let it get enabled during runtime. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: get rid of ->dispatch_sliceJens Axboe
We can track it fairly accurately locally, let the slice handling take care of the rest. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: don't pass unused preemption variable aroundJens Axboe
We don't use it anymore in the slice expiry handling. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: get rid of ->cur_rr and ->cfq_listJens Axboe
It's only used for preemption now that the IDLE and RT queues also use the rbtree. If we pass an 'add_front' variable to cfq_service_tree_add(), we can set ->rb_key to 0 to force insertion at the front of the tree. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: slice offset should take ioprio into accountJens Axboe
Use the max_slice-cur_slice as the multipler for the insertion offset. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30[PATCH] cfq-iosched: style cleanups and commentsJens Axboe
2007-04-30cfq-iosched: sort IDLE queues into the rbtreeJens Axboe
Same treatment as the RT conversion, just put the sorted idle branch at the end of the tree. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: sort RT queues into the rbtreeJens Axboe
Currently CFQ does a linked insert into the current list for RT queues. We can just factor the class into the rb insertion, and then we don't have to treat RT queues in a special way. It's faster, too. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30[PATCH] cfq-iosched: speed up rbtree handlingJens Axboe
For cases where the rbtree is mainly used for sorting and min retrieval, a nice speedup of the rbtree code is to maintain a cache of the leftmost node in the tree. Also spotted in the CFS CPU scheduler code. Improved by Alan D. Brunelle <Alan.Brunelle@hp.com> by updating the leftmost hint in cfq_rb_first() if it isn't set, instead of only updating it on insert. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: rework the whole round-robin list conceptJens Axboe
Drawing on some inspiration from the CFS CPU scheduler design, overhaul the pending cfq_queue concept list management. Currently CFQ uses a doubly linked list per priority level for sorting and service uses. Kill those lists and maintain an rbtree of cfq_queue's, sorted by when to service them. This unfortunately means that the ionice levels aren't as strong anymore, will work on improving those later. We only scale the slice time now, not the number of times we service. This means that latency is better (for all priority levels), but that the distinction between the highest and lower levels aren't as big. The diffstat speaks for itself. cfq-iosched.c | 363 +++++++++++++++++--------------------------------- 1 file changed, 125 insertions(+), 238 deletions(-) Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: minor updatesJens Axboe
- Move the queue_new flag clear to when the queue is selected - Only select the non-first queue in cfq_get_best_queue(), if there's a substantial difference between the best and first. - Get rid of ->busy_rr - Only select a close cooperator, if the current queue is known to take a while to "think". Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: development updateJens Axboe
- Implement logic for detecting cooperating processes, so we choose the best available queue whenever possible. - Improve residual slice time accounting. - Remove dead code: we no longer see async requests coming in on sync queues. That part was removed a long time ago. That means that we can also remove the difference between cfq_cfqq_sync() and cfq_cfqq_class_sync(), they are now indentical. And we can kill the on_dispatch array, just make it a counter. - Allow a process to go into the current list, if it hasn't been serviced in this scheduler tick yet. Possible future improvements including caching the cfqq lookup in cfq_close_cooperator(), so we don't have to look it up twice. cfq_get_best_queue() should just use that last decision instead of doing it again. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-30cfq-iosched: improve preemption for cooperating tasksJens Axboe
When testing the syslet async io approach, I discovered that CFQ sometimes didn't perform as well as expected. cfq_should_preempt() needs to better check for cooperating tasks, so fix that by allowing preemption of an equal priority queue if the recently queued request is as good a candidate for IO as the one we are currently waiting for. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-04-25cfq-iosched: fix alias + front merge bugJens Axboe
There's a really rare and obscure bug in CFQ, that causes a crash in cfq_dispatch_insert() due to rq == NULL. One example of the resulting oops is seen here: http://lkml.org/lkml/2007/4/15/41 Neil correctly diagnosed the situation for how this can happen: if two concurrent requests with the exact same sector number (due to direct IO or aliasing between MD and the raw device access), the alias handling will add the request to the sortlist, but next_rq remains NULL. Read the more complete analysis at: http://lkml.org/lkml/2007/4/25/57 This looks like it requires md to trigger, even though it should potentially be possible to due with O_DIRECT (at least if you edit the kernel and doctor some of the unplug calls). The fix is to move the ->next_rq update to when we add a request to the rbtree. Then we remove the possibility for a request to exist in the rbtree code, but not have ->next_rq correctly updated. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20cfq-iosched: fix sequential write regressionJens Axboe
We have a 10-15% performance regression for sequential writes on TCQ/NCQ enabled drives in 2.6.21-rcX after the CFQ update went in. It has been reported by Valerie Clement <valerie.clement@bull.net> and the Intel testing folks. The regression is because of CFQ's now more aggressive queue control, limiting the depth available to the device. This patches fixes that regression by allowing a greater depth when only one queue is busy. It has been tested to not impact sync-vs-async workloads too much - we still do a lot better than 2.6.20. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-17[SCSI] sg: cap reserved_size values at max_sectorsAlan Stern
This patch (as857) modifies the SG_GET_RESERVED_SIZE and SG_SET_RESERVED_SIZE ioctls in the sg driver, capping the values at the device's request_queue's max_sectors value. This will permit cdrecord to obtain a legal value for the maximum transfer length, fixing Bugzilla #7026. The patch also caps the initial reserved_size value. There's no reason to have a reserved buffer larger than max_sectors, since it would be impossible to use the extra space. The corresponding ioctls in the block layer are modified similarly, and the initial value for the reserved_size is set as large as possible. This will effectively make it default to max_sectors. Note that the actual value is meaningless anyway, since block devices don't have a reserved buffer. Finally, the BLKSECTGET ioctl is added to sg, so that there will be a uniform way for users to determine the actual max_sectors value for any raw SCSI transport. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-04[PATCH] remove protection of LANANA-reserved majorsAndrew Morton
Revert all this. It can cause device-mapper to receive a different major from earlier kernels and it turns out that the Amanda backup program (via GNU tar, apparently) checks major numbers on files when performing incremental backups. Which is a bit broken of Amanda (or tar), but this feature isn't important enough to justify the churn. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27make elv_register() output atomicThibaut VARENE
Booting 2.6.21-rc3-g45592145 I noticed the following on one of my machines in the bootlog: io scheduler noop registered<6>Time: jiffies clocksource has been installed. io scheduler deadline registered (default) Looking at block/elevator.c, it appears that elv_register() uses two consecutive printks in a non-atomic way, leading to the above glitch. The attached trivial patch fixes this issue, by using a single printk. Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-03-27block: blk_max_pfn is somtimes wrongVasily Tarasov
There is a small problem in handling page bounce. At the moment blk_max_pfn equals max_pfn, which is in fact not maximum possible _number_ of a page frame, but the _amount_ of page frames. For example for the 32bit x86 node with 4Gb RAM, max_pfn = 0x100000, but not 0xFFFF. request_queue structure has a member q->bounce_pfn and queue needs bounce pages for the pages _above_ this limit. This routine is handled by blk_queue_bounce(), where the following check is produced: if (q->bounce_pfn >= blk_max_pfn) return; Assume, that a driver has set q->bounce_pfn to 0xFFFF, but blk_max_pfn equals 0x10000. In such situation the check above fails and for each bio we always fall down for iterating over pages tied to the bio. I want to notice, that for quite a big range of device drivers (ide, md, ...) such problem doesn't happen because they use BLK_BOUNCE_ANY for bounce_pfn. BLK_BOUNCE_ANY is defined as blk_max_pfn << PAGE_SHIFT, and then the check above doesn't fail. But for other drivers, which obtain reuired value from drivers, it fails. For example sata_nv uses ATA_DMA_MASK or dev->dma_mask. I propose to use (max_pfn - 1) for blk_max_pfn. And the same for blk_max_low_pfn. The patch also cleanses some checks related with bounce_pfn. Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-20[PATCH] lockdep: annotate BLKPG_DEL_PARTITIONPeter Zijlstra
>============================================= >[ INFO: possible recursive locking detected ] >2.6.19-1.2909.fc7 #1 >--------------------------------------------- >anaconda/587 is trying to acquire lock: > (&bdev->bd_mutex){--..}, at: [<c05fb380>] mutex_lock+0x21/0x24 > >but task is already holding lock: > (&bdev->bd_mutex){--..}, at: [<c05fb380>] mutex_lock+0x21/0x24 > >other info that might help us debug this: >1 lock held by anaconda/587: > #0: (&bdev->bd_mutex){--..}, at: [<c05fb380>] mutex_lock+0x21/0x24 > >stack backtrace: > [<c0405812>] show_trace_log_lvl+0x1a/0x2f > [<c0405db2>] show_trace+0x12/0x14 > [<c0405e36>] dump_stack+0x16/0x18 > [<c043bd84>] __lock_acquire+0x116/0xa09 > [<c043c960>] lock_acquire+0x56/0x6f > [<c05fb1fa>] __mutex_lock_slowpath+0xe5/0x24a > [<c05fb380>] mutex_lock+0x21/0x24 > [<c04d82fb>] blkdev_ioctl+0x600/0x76d > [<c04946b1>] block_ioctl+0x1b/0x1f > [<c047ed5a>] do_ioctl+0x22/0x68 > [<c047eff2>] vfs_ioctl+0x252/0x265 > [<c047f04e>] sys_ioctl+0x49/0x63 > [<c0404070>] syscall_call+0x7/0xb Annotate BLKPG_DEL_PARTITION's bd_mutex locking and add a little comment clarifying the bd_mutex locking, because I confused myself and initially thought the lock order was wrong too. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] rework reserved major handlingAndrew Morton
Several people have reported failures in dynamic major device number handling due to the recent changes in there to avoid handing out the local/experimental majors. Rolf reports that this is due to a gcc-4.1.0 bug. The patch refactors that code a lot in an attempt to provoke the compiler into behaving. Cc: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17update I/O sched Kconfig help texts - CFQ is now default, not AS.Jesper Juhl
Change I/O scheduler description to correctly show CFQ as being the default scheduler and not the anticipatory scheduler that previously was default. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] register_blkdev(): don't hand out the LOCAL/EXPERIMENTAL majorsAndrew Morton
As pointed out in http://bugzilla.kernel.org/show_bug.cgi?id=7922, dynamic blockdev major allocation can hand out majors which LANANA has defined as being for local/experimental use. Cc: Torben Mathiasen <device@lanana.org> Cc: Greg KH <greg@kroah.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tomas Klas <tomas.klas@mepatek.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11cfq-iosched: improve continue or break logic in cfq_dispatchJens Axboe
This improves performance considerably for sync requests when you have command queuing enabled. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: remove the implicit queue kicking in slice expireJens Axboe
We only really need it for a process going away, so move it to those locations. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: check whether a queue timed out in accountingJens Axboe
Makes it more fair for the residual slice count. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: tweak the FIFO checkingJens Axboe
We currently check the FIFO once per slice. Optimize that a bit and only do it as the first thing for a new slice, so we don't end up doing a single request and then seek to the FIFO requests. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: don't pass in queue for cfq_arm_slice_timer()Jens Axboe
It must always be the active queue, otherwise it's a bug. So just use the active_queue, don't pass it in explicitly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: account for slice over/under timeJens Axboe
If a slice uses less than it is entitled to (or perhaps more), include that in the decision on how much time to give it the next time it gets serviced. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: defer slice activation to first request being activeJens Axboe
This better matches what time the queue is actually spending doing IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11[PATCH] cfq-iosched: use last service point as the fairness criteriaJens Axboe
Right now we use slice_start, which gives async queues an unfair advantage. Chance that to service_last, and base the resorter on that. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: document the cfqq flagsJens Axboe
2007-02-11[PATCH] cfq-iosched: move on_rr check into cfq_resort_rr_list()Jens Axboe
Move the on_rr check into cfq_resort_rr_list(), every call site needs to check it anyway. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11cfq-iosched: remove cfq_io_context last_queueJens Axboe
It hasn't been used for a while, kill it off and remove the old if 0 code chunk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11elevator: don't sort reads between writesJens Axboe
Don't allow elv_dispatch_sort() to mix reads and writes together, it's rarely a good idea. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-11elevator: abstract out the activate and deactivate functionsJens Axboe
2007-02-11Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Update defconfig. [SPARC64]: Add PCI MSI support on Niagara. [SPARC64] IRQ: Use irq_desc->chip_data instead of irq_desc->handler_data [SPARC64]: Add obppath sysfs attribute for SBUS and PCI devices. [PARTITION]: Add whole_disk attribute.
2007-02-11[PATCH] Relay: add CPU hotplug supportMathieu Desnoyers
Mathieu originally needed to add this for tracing Xen, but it's something that's needed for any application that can be tracing while cpus are added. unplug isn't supported by this patch. The thought was that at minumum a new buffer needs to be added when a cpu comes up, but it wasn't worth the effort to remove buffers on cpu down since they'd be freed soon anyway when the channel was closed. [zanussi@us.ibm.com: avoid lock_cpu_hotplug deadlock] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
