path: root/block
2015-07-23block: Do a full clone when splitting discard biosMartin K. Petersen
This fixes a data corruption bug when using discard on top of MD linear, raid0 and raid10 personalities. Commit 20d0189b1012 "block: Introduce new bio_split()" permits sharing the bio_vec between the two resulting bios. That is fine for read/write requests where the bio_vec is immutable. For discards, however, we need to be able to attach a payload and update the bio_vec so the page can get mapped to a scatterlist entry. Therefore the bio_vec can not be shared when splitting discards and we must do a full clone. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Seunguk Shin <seunguk.shin@samsung.com> Tested-by: Seunguk Shin <seunguk.shin@samsung.com> Cc: Seunguk Shin <seunguk.shin@samsung.com> Cc: Jens Axboe <axboe@fb.com> Cc: Kent Overstreet <kent.overstreet@gmail.com> Cc: <stable@vger.kernel.org> # v3.14+ Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-23block: export bio_associate_*() and wbc_account_io()Tejun Heo
bio_associate_blkcg(), bio_associate_current() and wbc_account_io() are used to implement cgroup writeback support for filesystems and thus need to be exported. Export them. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-22blkcg: fix gendisk reference leak in blkg_conf_prep()Tejun Heo
When a blkcg configuration is targeted to a partition rather than a whole device, blkg_conf_prep fails with -EINVAL; unfortunately, it forgets to put the gendisk ref in that case. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-16blk-mq: set default timeout as 30 secondsMing Lei
It is reasonable to set default timeout of request as 30 seconds instead of 30000 ticks, which may be 300 seconds if HZ is 100, for example, some arm64 based systems may choose 100 HZ. Signed-off-by: Ming Lei <ming.lei@canonical.com> Fixes: c76cbbcf4044 ("blk-mq: put blk_queue_rq_timeout together in blk_mq_init_queue()" Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-09blkcg: fix blkcg_policy_data allocation bugTejun Heo
e48453c386f3 ("block, cgroup: implement policy-specific per-blkcg data") updated per-blkcg policy data to be dynamically allocated. When a policy is registered, its policy data aren't created. Instead, when the policy is activated on a queue, the policy data are allocated if there are blkg's (blkcg_gq's) which are attached to a given blkcg. This is buggy. Consider the following scenario. 1. A blkcg is created. No blkg's attached yet. 2. The policy is registered. No policy data is allocated. 3. The policy is activated on a queue. As the above blkcg doesn't have any blkg's, it won't allocate the matching blkcg_policy_data. 4. An IO is issued from the blkcg and blkg is created and the blkcg still doesn't have the matching policy data allocated. With cfq-iosched, this leads to an oops. It also doesn't free policy data on policy unregistration assuming that freeing of all policy data on blkcg destruction should take care of it; however, this also is incorrect. 1. A blkcg has policy data. 2. The policy gets unregistered but the policy data remains. 3. Another policy gets registered on the same slot. 4. Later, the new policy tries to allocate policy data on the previous blkcg but the slot is already occupied and gets skipped. The policy ends up operating on the policy data of the previous policy. There's no reason to manage blkcg_policy_data lazily. The reason we do lazy allocation of blkg's is that the number of all possible blkg's is the product of cgroups and block devices which can reach a surprising level. blkcg_policy_data is contrained by the number of cgroups and shouldn't be a problem. This patch makes blkcg_policy_data to be allocated for all existing blkcg's on policy registration and freed on unregistration and removes blkcg_policy_data handling from policy [de]activation paths. This makes that blkcg_policy_data are created and removed with the policy they belong to and fixes the above described problems. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: e48453c386f3 ("block, cgroup: implement policy-specific per-blkcg data") Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Arianna Avanzini <avanzini.arianna@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-09blkcg: implement all_blkcgs listTejun Heo
Add all_blkcgs list goes through blkcg->all_blkcgs_node and is protected by blkcg_pol_mutex. This will be used to fix blkcg_policy_data allocation bug. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Arianna Avanzini <avanzini.arianna@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-09blkcg: blkcg_css_alloc() should grab blkcg_pol_mutex while iterating ↵Tejun Heo
blkcg_policy[] An entry in blkcg_policy[] is stable while there are non-bypassing in-flight IOs on a request_queue which has the policy activated. This is why most derefs of blkcg_policy[] don't need explicit locking; however, blkcg_css_alloc() isn't invoked from IO path and thus doesn't have this protection and may race policies being added and removed. Fix it by adding explicit blkcg_pol_mutex protection around blkcg_policy[] iteration in blkcg_css_alloc(). Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: e48453c386f3 ("block, cgroup: implement policy-specific per-blkcg data") Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Arianna Avanzini <avanzini.arianna@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-09blkcg: allow blkcg_pol_mutex to be grabbed from cgroup [file] methodsTejun Heo
blkcg_pol_mutex primarily protects the blkcg_policy array. It also protects cgroup file type [un]registration during policy addition / removal. This puts blkcg_pol_mutex outside cgroup internal synchronization and in turn makes it impossible to grab from blkcg's cgroup methods as that leads to cyclic dependency. Another problematic dependency arising from this is through cgroup interface file deactivation. Removing a cftype requires removing all files of the type which in turn involves draining all on-going invocations of the file methods. This means that an interface file implementation can't grab blkcg_pol_mutex as draining can lead to AA deadlock. blkcg_reset_stats() is already in this situation. It currently trylocks blkcg_pol_mutex and then unwinds and retries the whole operation on failure, which is cumbersome at best. It has a lengthy comment explaining how cgroup internal synchronization is involved and expected to be updated but as explained above this doesn't need cgroup internal locking to deadlock. It's a self-contained AA deadlock. The described circular dependencies can be easily broken by moving cftype [un]registration out of blkcg_pol_mutex and protect them with an outer mutex. This patch introduces blkcg_pol_register_mutex which wraps entire policy [un]registration including cftype operations and shrinks blkcg_pol_mutex critical section. This also makes the trylock dancing in blkcg_reset_stats() unnecessary. Removed. This patch is necessary for the following blkcg_policy_data allocation bug fixes. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Arianna Avanzini <avanzini.arianna@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-07block/blk-cgroup.c: free per-blkcg data when freeing the blkcgArianna Avanzini
Currently, per-blkcg data is freed each time a policy is deactivated, that is also upon scheduler switch. However, when switching from a scheduler implementing a policy which requires per-blkcg data to another one, that same policy might be active on other devices, and therefore those same per-blkcg data could be still in use. This commit lets per-blkcg data be freed when the blkcg is freed instead of on policy deactivation. Signed-off-by: Arianna Avanzini <avanzini.arianna@gmail.com> Reported-and-tested-by: Michael Kaminsky <kaminsky@cs.cmu.edu> Fixes: e48453c3 ("block, cgroup: implement policy-specific per-blkcg data") Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-07block: use FIELD_SIZEOF to calculate size of a fieldManinder Singh
use FIELD_SIZEOF instead of open coding Signed-off-by: Maninder Singh <maninder1.s@samsung.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-07bio integrity: do not assume bio_integrity_pool exists if bioset existsMike Snitzer
bio_integrity_alloc() and bio_integrity_free() assume that if a bio was allocated from a bioset that that bioset also had its bio_integrity_pool allocated using bioset_integrity_create(). This is a very bad assumption given that bioset_create() and bioset_integrity_create() are completely disjoint. Not all callers of bioset_create() have been trained to also call bioset_integrity_create() -- and they may not care to be. Fix this by falling back to kmalloc'ing 'struct bio_integrity_payload' rather than force all bioset consumers to (wastefully) preallocate a bio_integrity_pool that they very likely won't actually need (given the niche nature of the current block integrity support). Otherwise, a NULL pointer "Kernel BUG" with a trace like the following will be observed (as seen on s390x using zfcp storage) because dm-io doesn't use bioset_integrity_create() when creating its bioset: [ 791.643338] Call Trace: [ 791.643339] ([<00000003df98b848>] 0x3df98b848) [ 791.643341] [<00000000002c5de8>] bio_integrity_alloc+0x48/0xf8 [ 791.643348] [<00000000002c6486>] bio_integrity_prep+0xae/0x2f0 [ 791.643349] [<0000000000371e38>] blk_queue_bio+0x1c8/0x3d8 [ 791.643355] [<000000000036f8d0>] generic_make_request+0xc0/0x100 [ 791.643357] [<000000000036f9b2>] submit_bio+0xa2/0x198 [ 791.643406] [<000003ff801f9774>] dispatch_io+0x15c/0x3b0 [dm_mod] [ 791.643419] [<000003ff801f9b3e>] dm_io+0x176/0x2f0 [dm_mod] [ 791.643423] [<000003ff8074b28a>] do_reads+0x13a/0x1a8 [dm_mirror] [ 791.643425] [<000003ff8074b43a>] do_mirror+0x142/0x298 [dm_mirror] [ 791.643428] [<0000000000154fca>] process_one_work+0x18a/0x3f8 [ 791.643432] [<000000000015598a>] worker_thread+0x132/0x3b0 [ 791.643435] [<000000000015d49a>] kthread+0xd2/0xd8 [ 791.643438] [<00000000005bc0ca>] kernel_thread_starter+0x6/0xc [ 791.643446] [<00000000005bc0c4>] kernel_thread_starter+0x0/0xc Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-27block: fix bogus EFAULT error from SG_IO ioctlPaolo Bonzini
Whenever blk_fill_sghdr_rq fails, its errno code is ignored and changed to EFAULT. This can cause very confusing errors: $ sg_persist -k /dev/sda persistent reservation in: pass through os error: Bad address The fix is trivial, just propagate the return value from blk_fill_sghdr_rq. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-26Merge tag 'dm-4.2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: "Apologies for not pressing this request-based DM partial completion issue further, it was an oversight on my part. We'll have to get it fixed up properly and revisit for a future release. - Revert block and DM core changes the removed request-based DM's ability to handle partial request completions -- otherwise with the current SCSI LLDs these changes could lead to silent data corruption. - Fix two DM version bumps that were missing from the initial 4.2 DM pull request (enabled userspace lvm2 to know certain changes have been made)" * tag 'dm-4.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm cache policy smq: fix "default" version to be 1.4.0 dm: bump the ioctl version to 4.32.0 Revert "block, dm: don't copy bios for request clones" Revert "dm: do not allocate any mempools for blk-mq request-based DM"
2015-06-26Revert "block, dm: don't copy bios for request clones"Mike Snitzer
This reverts commit 5f1b670d0bef508a5554d92525f5f6d00d640b38. Justification for revert as reported in this dm-devel post: https://www.redhat.com/archives/dm-devel/2015-June/msg00160.html this change should not be pushed to mainline yet. Firstly, Christoph has a newer version of the patch that fixes silent data corruption problem: https://www.redhat.com/archives/dm-devel/2015-May/msg00229.html And the new version still depends on LLDDs to always complete requests to the end when error happens, while block API doesn't enforce such a requirement. If the assumption is ever broken, the inconsistency between request and bio (e.g. rq->__sector and rq->bio) will cause silent data corruption: https://www.redhat.com/archives/dm-devel/2015-June/msg00022.html Reported-by: Junichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-06-25Merge branch 'for-4.2/writeback' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull cgroup writeback support from Jens Axboe: "This is the big pull request for adding cgroup writeback support. This code has been in development for a long time, and it has been simmering in for-next for a good chunk of this cycle too. This is one of those problems that has been talked about for at least half a decade, finally there's a solution and code to go with it. Also see last weeks writeup on LWN: http://lwn.net/Articles/648292/" * 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits) writeback, blkio: add documentation for cgroup writeback support vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB writeback: do foreign inode detection iff cgroup writeback is enabled v9fs: fix error handling in v9fs_session_init() bdi: fix wrong error return value in cgwb_create() buffer: remove unusued 'ret' variable writeback: disassociate inodes from dying bdi_writebacks writeback: implement foreign cgroup inode bdi_writeback switching writeback: add lockdep annotation to inode_to_wb() writeback: use unlocked_inode_to_wb transaction in inode_congested() writeback: implement unlocked_inode_to_wb transaction and use it for stat updates writeback: implement [locked_]inode_to_wb_and_lock_list() writeback: implement foreign cgroup inode detection writeback: make writeback_control track the inode being written back writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb() mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use writeback: implement memcg writeback domain based throttling writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes writeback: implement memcg wb_domain writeback: update wb_over_bg_thresh() to use wb_domain aware operations ...
2015-06-25Merge branch 'for-4.2/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO update from Jens Axboe: "Nothing really major in here, mostly a collection of smaller optimizations and cleanups, mixed with various fixes. In more detail, this contains: - Addition of policy specific data to blkcg for block cgroups. From Arianna Avanzini. - Various cleanups around command types from Christoph. - Cleanup of the suspend block I/O path from Christoph. - Plugging updates from Shaohua and Jeff Moyer, for blk-mq. - Eliminating atomic inc/dec of both remaining IO count and reference count in a bio. From me. - Fixes for SG gap and chunk size support for data-less (discards) IO, so we can merge these better. From me. - Small restructuring of blk-mq shared tag support, freeing drivers from iterating hardware queues. From Keith Busch. - A few cfq-iosched tweaks, from Tahsin Erdogan and me. Makes the IOPS mode the default for non-rotational storage" * 'for-4.2/core' of git://git.kernel.dk/linux-block: (35 commits) cfq-iosched: fix other locations where blkcg_to_cfqgd() can return NULL cfq-iosched: fix sysfs oops when attempting to read unconfigured weights cfq-iosched: move group scheduling functions under ifdef cfq-iosched: fix the setting of IOPS mode on SSDs blktrace: Add blktrace.c to BLOCK LAYER in MAINTAINERS file block, cgroup: implement policy-specific per-blkcg data block: Make CFQ default to IOPS mode on SSDs block: add blk_set_queue_dying() to blkdev.h blk-mq: Shared tag enhancements block: don't honor chunk sizes for data-less IO block: only honor SG gap prevention for merges that contain data block: fix returnvar.cocci warnings block, dm: don't copy bios for request clones block: remove management of bi_remaining when restoring original bi_end_io block: replace trylock with mutex_lock in blkdev_reread_part() block: export blkdev_reread_part() and __blkdev_reread_part() suspend: simplify block I/O handling block: collapse bio bit space block: remove unused BIO_RW_BLOCK and BIO_EOF flags block: remove BIO_EOPNOTSUPP ...
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
2015-06-20cfq-iosched: fix other locations where blkcg_to_cfqgd() can return NULLJens Axboe
Commit 9470e4a693db only covered the initial bug report, there are other spots in CFQ where we need to check that we actually have a valid cfq_group_data structure. Fixes: e48453c3 ("block, cgroup: implement policy-specific per-blkcg data") Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-19cfq-iosched: fix sysfs oops when attempting to read unconfigured weightsJens Axboe
If none of the devices in the system are using CFQ, then attempting to read: /sys/fs/cgroup/blkio/blkio.leaf_weight will results in a NULL dereference. Check for a valid cfq_group_data struct before attempting to dereference it. Reported-by: Andrey Wagin <avagin@gmail.com> Fixes: e48453c3 ("block, cgroup: implement policy-specific per-blkcg data") Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-19cfq-iosched: move group scheduling functions under ifdefJens Axboe
If CFQ_GROUP_IOSCHED is not set, the compiler produces the following warning: CC block/cfq-iosched.o linux/block/cfq-iosched.c:469:2: warning: 'cpd_to_cfqgd' defined but not used [-Wunused-function] *cpd_to_cfqgd(struct blkcg_policy_data *cpd) ^ In reality, two other lookup functions aren't used either if CFQ_GROUP_IOSCHED isn't set. Move all three under one of the CFQ_GROUP_IOSCHED sections in the code. Reported-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-11block: fix ext_dev_lock lockdep reportDan Williams
================================= [ INFO: inconsistent lock state ] 4.1.0-rc7+ #217 Tainted: G O --------------------------------- inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. swapper/6/0 [HC0[0]:SC1[1]:HE1:SE0] takes: (ext_devt_lock){+.?...}, at: [<ffffffff8143a60c>] blk_free_devt+0x3c/0x70 {SOFTIRQ-ON-W} state was registered at: [<ffffffff810bf6b1>] __lock_acquire+0x461/0x1e70 [<ffffffff810c1947>] lock_acquire+0xb7/0x290 [<ffffffff818ac3a8>] _raw_spin_lock+0x38/0x50 [<ffffffff8143a07d>] blk_alloc_devt+0x6d/0xd0 <-- take the lock in process context [..] [<ffffffff810bf64e>] __lock_acquire+0x3fe/0x1e70 [<ffffffff810c00ad>] ? __lock_acquire+0xe5d/0x1e70 [<ffffffff810c1947>] lock_acquire+0xb7/0x290 [<ffffffff8143a60c>] ? blk_free_devt+0x3c/0x70 [<ffffffff818ac3a8>] _raw_spin_lock+0x38/0x50 [<ffffffff8143a60c>] ? blk_free_devt+0x3c/0x70 [<ffffffff8143a60c>] blk_free_devt+0x3c/0x70 <-- take the lock in softirq [<ffffffff8143bfec>] part_release+0x1c/0x50 [<ffffffff8158edf6>] device_release+0x36/0xb0 [<ffffffff8145ac2b>] kobject_cleanup+0x7b/0x1a0 [<ffffffff8145aad0>] kobject_put+0x30/0x70 [<ffffffff8158f147>] put_device+0x17/0x20 [<ffffffff8143c29c>] delete_partition_rcu_cb+0x16c/0x180 [<ffffffff8143c130>] ? read_dev_sector+0xa0/0xa0 [<ffffffff810e0e0f>] rcu_process_callbacks+0x2ff/0xa90 [<ffffffff810e0dcf>] ? rcu_process_callbacks+0x2bf/0xa90 [<ffffffff81067e2e>] __do_softirq+0xde/0x600 Neil sees this in his tests and it also triggers on pmem driver unbind for the libnvdimm tests. This fix is on top of an initial fix by Keith for incorrect usage of mutex_lock() in this path: 2da78092dda1 "block: Fix dev_t minor allocation lifetime". Both this and 2da78092dda1 are candidates for -stable. Fixes: 2da78092dda1 ("block: Fix dev_t minor allocation lifetime") Cc: <stable@vger.kernel.org> Cc: Keith Busch <keith.busch@intel.com> Reported-by: NeilBrown <neilb@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-10cfq-iosched: fix the setting of IOPS mode on SSDsJens Axboe
A previous commit wanted to make CFQ default to IOPS mode on non-rotational storage, however it did so when the queue was initialized and the non-rotational flag is only set later on in the probe. Add an elevator hook that gets called off the add_disk() path, at that point we know that feature probing has finished, and we can reliably check for the various flags that drivers can set. Fixes: 41c0126b ("block: Make CFQ default to IOPS mode on SSDs") Tested-by: Romain Francoise <romain@orebokech.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-09blk-mq: free hctx->ctxs in queue's release handlerMing Lei
Now blk_cleanup_queue() can be called before calling del_gendisk()[1], inside which hctx->ctxs is touched from blk_mq_unregister_hctx(), but the variable has been freed by blk_cleanup_queue() at that time. So this patch moves freeing of hctx->ctxs into queue's release handler for fixing the oops reported by Stefan. [1], 6cd18e711dd8075 (block: destroy bdi before blockdev is unregistered) Reported-by: Stefan Seyfried <stefan.seyfried@googlemail.com> Cc: NeilBrown <neilb@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: stable@vger.kernel.org (v4.0) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-07block, cgroup: implement policy-specific per-blkcg dataArianna Avanzini
The block IO (blkio) controller enables the block layer to provide service guarantees in a hierarchical fashion. Specifically, service guarantees are provided by registered request-accounting policies. As of now, a proportional-share and a throttling policy are available. They are implemented, respectively, by the CFQ I/O scheduler and the blk-throttle subsystem. Unfortunately, as for adding new policies, the current implementation of the block IO controller is only halfway ready to allow new policies to be plugged in. This commit provides a solution to make the block IO controller fully ready to handle new policies. In what follows, we first describe briefly the current state, and then list the changes made by this commit. The throttling policy does not need any per-cgroup information to perform its task. In contrast, the proportional share policy uses, for each cgroup, both the weight assigned by the user to the cgroup, and a set of dynamically- computed weights, one for each device. The first, user-defined weight is stored in the blkcg data structure: the block IO controller allocates a private blkcg data structure for each cgroup in the blkio cgroups hierarchy (regardless of which policy is active). In other words, the block IO controller internally mirrors the blkio cgroups with private blkcg data structures. On the other hand, for each cgroup and device, the corresponding dynamically- computed weight is maintained in the following, different way. For each device, the block IO controller keeps a private blkcg_gq structure for each cgroup in blkio. In other words, block IO also keeps one private mirror copy of the blkio cgroups hierarchy for each device, made of blkcg_gq structures. Each blkcg_gq structure keeps per-policy information in a generic array of dynamically-allocated 'dedicated' data structures, one for each registered policy (so currently the array contains two elements). To be inserted into the generic array, each dedicated data structure embeds a generic blkg_policy_data structure. Consider now the array contained in the blkcg_gq structure corresponding to a given pair of cgroup and device: one of the elements of the array contains the dedicated data structure for the proportional-share policy, and this dedicated data structure contains the dynamically-computed weight for that pair of cgroup and device. The generic strategy adopted for storing per-policy data in blkcg_gq structures is already capable of handling new policies, whereas the one adopted with blkcg structures is not, because per-policy data are hard-coded in the blkcg structures themselves (currently only data related to the proportional- share policy). This commit addresses the above issues through the following changes: . It generalizes blkcg structures so that per-policy data are stored in the same way as in blkcg_gq structures. Specifically, it lets also the blkcg structure store per-policy data in a generic array of dynamically-allocated dedicated data structures. We will refer to these data structures as blkcg dedicated data structures, to distinguish them from the dedicated data structures inserted in the generic arrays kept by blkcg_gq structures. To allow blkcg dedicated data structures to be inserted in the generic array inside a blkcg structure, this commit also introduces a new blkcg_policy_data structure, which is the equivalent of blkg_policy_data for blkcg dedicated data structures. . It adds to the blkcg_policy structure, i.e., to the descriptor of a policy, a cpd_size field and a cpd_init field, to be initialized by the policy with, respectively, the size of the blkcg dedicated data structures, and the address of a constructor function for blkcg dedicated data structures. . It moves the CFQ-specific fields embedded in the blkcg data structure (i.e., the fields related to the proportional-share policy), into a new blkcg dedicated data structure called cfq_group_data. Signed-off-by: Paolo Valente <paolo.valente@unimore.it> Signed-off-by: Arianna Avanzini <avanzini.arianna@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-05block: Make CFQ default to IOPS mode on SSDsTahsin Erdogan
CFQ idling causes reduced IOPS throughput on non-rotational disks. Since disk head seeking is not applicable to SSDs, it doesn't really help performance by anticipating future near-by IO requests. By turning off idling (and switching to IOPS mode), we allow other processes to dispatch IO requests down to the driver and so increase IO throughput. Following FIO benchmark results were taken on a cloud SSD offering with idling on and off: Idling iops avg-lat(ms) stddev bw ------------------------------------------------------ On 7054 90.107 38.697 28217KB/s Off 29255 21.836 11.730 117022KB/s fio --name=temp --size=100G --time_based --ioengine=libaio \ --randrepeat=0 --direct=1 --invalidate=1 --verify=0 \ --verify_fatal=0 --rw=randread --blocksize=4k --group_reporting=1 \ --filename=/dev/sdb --runtime=10 --iodepth=64 --numjobs=10 And the following is from a local SSD run: Idling iops avg-lat(ms) stddev bw ------------------------------------------------------ On 19320 33.043 14.068 77281KB/s Off 21626 29.465 12.662 86507KB/s fio --name=temp --size=5G --time_based --ioengine=libaio \ --randrepeat=0 --direct=1 --invalidate=1 --verify=0 \ --verify_fatal=0 --rw=randread --blocksize=4k --group_reporting=1 \ --filename=/fio_data --runtime=10 --iodepth=64 --numjobs=10 Reviewed-by: Nauman Rafique <nauman@google.com> Signed-off-by: Tahsin Erdogan <tahsin@google.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback, blkcg: propagate non-root blkcg congestion stateTejun Heo
Now that bdi layer can handle per-blkcg bdi_writeback_congested state, blk_{set|clear}_congested() can propagate non-root blkcg congestion state to them. This can be easily achieved by disabling the root_rl tests in blk_{set|clear}_congested(). Note that we still need those tests when !CONFIG_CGROUP_WRITEBACK as otherwise we'll end up flipping root blkcg wb's congestion state for events happening on other blkcgs. v2: Updated for bdi_writeback_congested. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback, blkcg: restructure blk_{set|clear}_queue_congested()Tejun Heo
blk_{set|clear}_queue_congested() take @q and set or clear, respectively, the congestion state of its bdi's root wb. Because bdi used to be able to handle congestion state only on the root wb, the callers of those functions tested whether the congestion is on the root blkcg and skipped if not. This is cumbersome and makes implementation of per cgroup bdi_writeback congestion state propagation difficult. This patch renames blk_{set|clear}_queue_congested() to blk_{set|clear}_congested(), and makes them take request_list instead of request_queue and test whether the specified request_list is the root one before updating bdi_writeback congestion state. This makes the tests in the callers unnecessary and simplifies them. As there are no external users of these functions, the definitions are moved from include/linux/blkdev.h to block/blk-core.c. This patch doesn't introduce any noticeable behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback, blkcg: associate each blkcg_gq with the corresponding ↵Tejun Heo
bdi_writeback_congested A blkg (blkcg_gq) can be congested and decongested independently from other blkgs on the same request_queue. Accordingly, for cgroup writeback support, the congestion status at bdi (backing_dev_info) should be split and updated separately from matching blkg's. This patch prepares by adding blkg->wb_congested and associating a blkg with its matching per-blkcg bdi_writeback_congested on creation. v2: Updated to associate bdi_writeback_congested instead of bdi_writeback. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback: make backing_dev_info host cgroup-specific bdi_writebacksTejun Heo
For the planned cgroup writeback support, on each bdi (backing_dev_info), each memcg will be served by a separate wb (bdi_writeback). This patch updates bdi so that a bdi can host multiple wbs (bdi_writebacks). On the default hierarchy, blkcg implicitly enables memcg. This allows using memcg's page ownership for attributing writeback IOs, and every memcg - blkcg combination can be served by its own wb by assigning a dedicated wb to each memcg. This means that there may be multiple wb's of a bdi mapped to the same blkcg. As congested state is per blkcg - bdi combination, those wb's should share the same congested state. This is achieved by tracking congested state via bdi_writeback_congested structs which are keyed by blkcg. bdi->wb remains unchanged and will keep serving the root cgroup. cgwb's (cgroup wb's) for non-root cgroups are created on-demand or looked up while dirtying an inode according to the memcg of the page being dirtied or current task. Each cgwb is indexed on bdi->cgwb_tree by its memcg id. Once an inode is associated with its wb, it can be retrieved using inode_to_wb(). Currently, none of the filesystems has FS_CGROUP_WRITEBACK and all pages will keep being associated with bdi->wb. v3: inode_attach_wb() in account_page_dirtied() moved inside mapping_cap_account_dirty() block where it's known to be !NULL. Also, an unnecessary NULL check before kfree() removed. Both detected by the kbuild bot. v2: Updated so that wb association is per inode and wb is per memcg rather than blkcg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: kbuild test robot <fengguang.wu@intel.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback: add {CONFIG|BDI_CAP|FS}_CGROUP_WRITEBACKTejun Heo
cgroup writeback requires support from both bdi and filesystem sides. Add BDI_CAP_CGROUP_WRITEBACK and FS_CGROUP_WRITEBACK to indicate support and enable BDI_CAP_CGROUP_WRITEBACK on block based bdi's by default. Also, define CONFIG_CGROUP_WRITEBACK which is enabled if both MEMCG and BLK_CGROUP are enabled. inode_cgwb_enabled() which determines whether a given inode's both bdi and fs support cgroup writeback is added. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback: separate out include/linux/backing-dev-defs.hTejun Heo
With the planned cgroup writeback support, backing-dev related declarations will be more widely used across block and cgroup; unfortunately, including backing-dev.h from include/linux/blkdev.h makes cyclic include dependency quite likely. This patch separates out backing-dev-defs.h which only has the essential definitions and updates blkdev.h to include it. c files which need access to more backing-dev details now include backing-dev.h directly. This takes backing-dev.h off the common include dependency chain making it a lot easier to use it across block and cgroup. v2: fs/fat build failure fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02writeback: move backing_dev_info->state into bdi_writebackTejun Heo
Currently, a bdi (backing_dev_info) embeds single wb (bdi_writeback) and the role of the separation is unclear. For cgroup support for writeback IOs, a bdi will be updated to host multiple wb's where each wb serves writeback IOs of a different cgroup on the bdi. To achieve that, a wb should carry all states necessary for servicing writeback IOs for a cgroup independently. This patch moves bdi->state into wb. * enum bdi_state is renamed to wb_state and the prefix of all enums is changed from BDI_ to WB_. * Explicit zeroing of bdi->state is removed without adding zeoring of wb->state as the whole data structure is zeroed on init anyway. * As there's still only one bdi_writeback per backing_dev_info, all uses of bdi->state are mechanically replaced with bdi->wb.state introducing no behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: drbd-dev@lists.linbit.com Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02blkcg: implement bio_associate_blkcg()Tejun Heo
Currently, a bio can only be associated with the io_context and blkcg of %current using bio_associate_current(). This is too restrictive for cgroup writeback support. Implement bio_associate_blkcg() which associates a bio with the specified blkcg. bio_associate_blkcg() leaves the io_context unassociated. bio_associate_current() is updated so that it considers a bio as already associated if it has a blkcg_css, instead of an io_context, associated with it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02cgroup, block: implement task_get_css() and use it in bio_associate_current()Tejun Heo
bio_associate_current() currently open codes task_css() and css_tryget_online() to find and pin $current's blkcg css. Abstract it into task_get_css() which is implemented from cgroup side. As a task is always associated with an online css for every subsystem except while the css_set update is propagating, task_get_css() retries till css_tryget_online() succeeds. This is a cleanup and shouldn't lead to noticeable behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02blkcg: add blkcg_root_cssTejun Heo
Add global constant blkcg_root_css which points to &blkcg_root.css. This will be used by cgroup writeback support. If blkcg is disabled, it's defined as ERR_PTR(-EINVAL). v2: The declarations moved to include/linux/blk-cgroup.h as suggested by Vivek. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02blkcg: always create the blkcg_gq for the root blkcgTejun Heo
Currently, blkcg does a minor optimization where the root blkcg is created when the first blkcg policy is activated on a queue and destroyed on the deactivation of the last. On systems where blkcg is configured but not used, this saves one blkcg_gq struct per queue. On systems where blkcg is actually used, there's no difference. The only case where this can lead to any meaninful, albeit still minute, save in memory consumption is when all blkcg policies are deactivated after being widely used in the system, which is a hihgly unlikely scenario. The conditional existence of root blkcg_gq has already created several bugs in blkcg and became an issue once again for the new per-cgroup wb_congested mechanism for cgroup writeback support leading to a NULL dereference when no blkcg policy is active. This is really not worth bothering with. This patch makes blkcg always allocate and link the root blkcg_gq and release it only on queue destruction. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02blkcg: move block/blk-cgroup.h to include/linux/blk-cgroup.hTejun Heo
cgroup aware writeback support will require exposing some of blkcg details. In preprataion, move block/blk-cgroup.h to include/linux/blk-cgroup.h. This patch is pure file move. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02Merge branch 'linus' into sched/core, to resolve conflictIngo Molnar
Conflicts: arch/sparc/include/asm/topology_64.h Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-01blk-mq: Shared tag enhancementsKeith Busch
Storage controllers may expose multiple block devices that share hardware resources managed by blk-mq. This patch enhances the shared tags so a low-level driver can access the shared resources not tied to the unshared h/w contexts. This way the LLD can dynamically add and delete disks and request queues without having to track all the request_queue hctx's to iterate outstanding tags. Signed-off-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-29block: only honor SG gap prevention for merges that contain dataJens Axboe
We can safely merge anything that wont generate an SG list entry, so if the bio is data-less (discard), don't look at potential SG gaps. Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-29Merge remote-tracking branch 'jens/for-4.2/core' into dm-4.2Mike Snitzer
2015-05-28block: discard bdi_unregister() in favour of bdi_destroy()NeilBrown
bdi_unregister() now contains very little functionality. It contains a "WARN_ON" if bdi->dev is NULL. This warning is of no real consequence as bdi->dev isn't needed by anything else in the function, and it triggers if blk_cleanup_queue() -> bdi_destroy() is called before bdi_unregister, which happens since Commit: 6cd18e711dd8 ("block: destroy bdi before blockdev is unregistered.") So this isn't wanted. It also calls bdi_set_min_ratio(). This needs to be called after writes through the bdi have all been flushed, and before the bdi is destroyed. Calling it early is better than calling it late as it frees up a global resource. Calling it immediately after bdi_wb_shutdown() in bdi_destroy() perfectly fits these requirements. So bdi_unregister() can be discarded with the important content moved to bdi_destroy(), as can the writeback_bdi_unregister event which is already not used. Reported-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org (v4.0) Fixes: c4db59d31e39 ("fs: don't reassign dirty inodes to default_backing_dev_info") Fixes: 6cd18e711dd8 ("block: destroy bdi before blockdev is unregistered.") Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Dan Williams <dan.j.williams@intel.com> Tested-by: Nicholas Moulin <nicholas.w.moulin@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-27sched/topology: Rename topology_thread_cpumask() to topology_sibling_cpumask()Bartosz Golaszewski
Rename topology_thread_cpumask() to topology_sibling_cpumask() for more consistency with scheduler code. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Benoit Cousson <bcousson@baylibre.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jean Delvare <jdelvare@suse.de> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Viresh Kumar <viresh.kumar@linaro.org> Link: http://lkml.kernel.org/r/1432645896-12588-2-git-send-email-bgolaszewski@baylibre.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-22block, dm: don't copy bios for request clonesChristoph Hellwig
Currently dm-multipath has to clone the bios for every request sent to the lower devices, which wastes cpu cycles and ties down memory. This patch instead adds a new REQ_CLONE flag that instructs req_bio_endio to not complete bios attached to a request, which we set on clone requests similar to bios in a flush sequence. With this change I/O errors on a path failure only get propagated to dm-multipath, which can then either resubmit the I/O or complete the bios on the original request. I've done some basic testing of this on a Linux target with ALUA support, and it survives path failures during I/O nicely. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-22block: remove management of bi_remaining when restoring original bi_end_ioMike Snitzer
Commit c4cf5261 ("bio: skip atomic inc/dec of ->bi_remaining for non-chains") regressed all existing callers that followed this pattern: 1) saving a bio's original bi_end_io 2) wiring up an intermediate bi_end_io 3) restoring the original bi_end_io from intermediate bi_end_io 4) calling bio_endio() to execute the restored original bi_end_io The regression was due to BIO_CHAIN only ever getting set if bio_inc_remaining() is called. For the above pattern it isn't set until step 3 above (step 2 would've needed to establish BIO_CHAIN). As such the first bio_endio(), in step 2 above, never decremented __bi_remaining before calling the intermediate bi_end_io -- leaving __bi_remaining with the value 1 instead of 0. When bio_inc_remaining() occurred during step 3 it brought it to a value of 2. When the second bio_endio() was called, in step 4 above, it should've called the original bi_end_io but it didn't because there was an extra reference that wasn't dropped (due to atomic operations being optimized away since BIO_CHAIN wasn't set upfront). Fix this issue by removing the __bi_remaining management complexity for all callers that use the above pattern -- bio_chain() is the only interface that _needs_ to be concerned with __bi_remaining. For the above pattern callers just expect the bi_end_io they set to get called! Remove bio_endio_nodec() and also remove all bio_inc_remaining() calls that aren't associated with the bio_chain() interface. Also, the bio_inc_remaining() interface has been moved local to bio.c. Fixes: c4cf5261 ("bio: skip atomic inc/dec of ->bi_remaining for non-chains") Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-20block: replace trylock with mutex_lock in blkdev_reread_part()Ming Lei
The only possible problem of using mutex_lock() instead of trylock is about deadlock. If there aren't any locks held before calling blkdev_reread_part(), deadlock can't be caused by this conversion. If there are locks held before calling blkdev_reread_part(), and if these locks arn't required in open, close handler and I/O path, deadlock shouldn't be caused too. Both user space's ioctl(BLKRRPART) and md_setup_drive() from init/do_mounts_md.c belongs to the 1st case, so the conversion is safe for the two cases. For loop, the previous patches in this pathset has fixed the ABBA lock dependency, so the conversion is OK. For nbd, tx_lock is held when calling the function: - both open and release won't hold the lock - when blkdev_reread_part() is run, I/O thread has been stopped already, so tx_lock won't be acquired in I/O path at that time. - so the conversion won't cause deadlock for nbd For dasd, both dasd_open(), dasd_release() and request function don't acquire any mutex/semphone, so the conversion should be safe. Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Jarod Wilson <jarod@redhat.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-20block: export blkdev_reread_part() and __blkdev_reread_part()Jarod Wilson
This patch exports blkdev_reread_part() for block drivers, also introduce __blkdev_reread_part(). For some drivers, such as loop, reread of partitions can be run from the release path, and bd_mutex may already be held prior to calling ioctl_by_bdev(bdev, BLKRRPART, 0), so introduce __blkdev_reread_part for use in such cases. CC: Christoph Hellwig <hch@lst.de> CC: Jens Axboe <axboe@kernel.dk> CC: Tejun Heo <tj@kernel.org> CC: Alexander Viro <viro@zeniv.linux.org.uk> CC: Markus Pargmann <mpa@pengutronix.de> CC: Stefan Weinhuber <wein@de.ibm.com> CC: Stefan Haberland <stefan.haberland@de.ibm.com> CC: Sebastian Ott <sebott@linux.vnet.ibm.com> CC: Fabian Frederick <fabf@skynet.be> CC: Ming Lei <ming.lei@canonical.com> CC: David Herrmann <dh.herrmann@gmail.com> CC: Andrew Morton <akpm@linux-foundation.org> CC: Peter Zijlstra <peterz@infradead.org> CC: nbd-general@lists.sourceforge.net CC: linux-s390@vger.kernel.org Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-19block: remove unused BIO_RW_BLOCK and BIO_EOF flagsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-19block: remove BIO_EOPNOTSUPPChristoph Hellwig
Since the big barrier rewrite/removal in 2007 we never fail FLUSH or FUA requests, which means we can remove the magic BIO_EOPNOTSUPP flag to help propagating those to the buffer_head layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-19block: use an atomic_t for mq_freeze_depthChristoph Hellwig
lockdep gets unhappy about the not disabling irqs when using the queue_lock around it. Instead of trying to fix that up just switch to an atomic_t and get rid of the lock. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
