path: root/block
2020-03-08Merge tag 'v4.14.170' into 4.14-2.3.x-imxMarcel Ziswiler
This is the 4.14.170 stable release Conflicts: drivers/net/phy/phy_device.c drivers/tty/serial/imx.c include/linux/platform_data/dma-imx-sdma.h net/wireless/util.c
2020-02-07Merge tag 'v4.14.164' into 4.14-2.3.x-imxMarcel Ziswiler
This is the 4.14.164 stable release Conflicts: arch/arm/Kconfig.debug arch/arm/boot/dts/imx7s.dtsi arch/arm/mach-imx/cpuidle-imx6q.c arch/arm/mach-imx/cpuidle-imx6sx.c arch/arm64/kernel/cpu_errata.c arch/arm64/kvm/hyp/tlb.c drivers/crypto/caam/caamalg.c drivers/crypto/mxs-dcp.c drivers/dma/imx-sdma.c drivers/gpio/gpio-vf610.c drivers/gpu/drm/bridge/adv7511/adv7511_drv.c drivers/input/keyboard/imx_keypad.c drivers/input/keyboard/snvs_pwrkey.c drivers/mmc/core/block.c drivers/mmc/core/queue.h drivers/mmc/host/sdhci-esdhc-imx.c drivers/net/can/flexcan.c drivers/net/can/rx-offload.c drivers/net/ethernet/freescale/fec_main.c drivers/net/wireless/ath/ath10k/pci.c drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c drivers/pci/dwc/pci-imx6.c drivers/spi/spi-fsl-lpspi.c drivers/usb/dwc3/gadget.c include/net/tcp.h sound/soc/fsl/Kconfig sound/soc/fsl/fsl_esai.c
2020-01-27block: don't use bio->bi_vcnt to figure out segment numberMing Lei
[ Upstream commit 1a67356e9a4829da2935dd338630a550c59c8489 ] It is wrong to use bio->bi_vcnt to figure out how many segments there are in the bio even though CLONED flag isn't set on this bio, because this bio may be splitted or advanced. So always use bio_segments() in blk_recount_segments(), and it shouldn't cause any performance loss now because the physical segment number is figured out in blk_queue_split() and BIO_SEG_VALID is set meantime since bdced438acd83ad83a6c ("block: setup bi_phys_segments after splitting"). Reviewed-by: Omar Sandoval <osandov@fb.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Fixes: 76d8137a3113 ("blk-merge: recaculate segment if it isn't less than max segments") Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-23block: fix an integer overflow in logical block sizeMikulas Patocka
commit ad6bf88a6c19a39fb3b0045d78ea880325dfcf15 upstream. Logical block size has type unsigned short. That means that it can be at most 32768. However, there are architectures that can run with 64k pages (for example arm64) and on these architectures, it may be possible to create block devices with 64k block size. For exmaple (run this on an architecture with 64k pages): Mount will fail with this error because it tries to read the superblock using 2-sector access: device-mapper: writecache: I/O is not aligned, sector 2, size 1024, block size 65536 EXT4-fs (dm-0): unable to read superblock This patch changes the logical block size from unsigned short to unsigned int to avoid the overflow. Cc: stable@vger.kernel.org Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-12block: fix memleak when __blk_rq_map_user_iov() is failedYang Yingliang
[ Upstream commit 3b7995a98ad76da5597b488fa84aa5a56d43b608 ] When I doing fuzzy test, get the memleak report: BUG: memory leak unreferenced object 0xffff88837af80000 (size 4096): comm "memleak", pid 3557, jiffies 4294817681 (age 112.499s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 20 00 00 00 10 01 00 00 00 00 00 00 01 00 00 00 ............... backtrace: [<000000001c894df8>] bio_alloc_bioset+0x393/0x590 [<000000008b139a3c>] bio_copy_user_iov+0x300/0xcd0 [<00000000a998bd8c>] blk_rq_map_user_iov+0x2f1/0x5f0 [<000000005ceb7f05>] blk_rq_map_user+0xf2/0x160 [<000000006454da92>] sg_common_write.isra.21+0x1094/0x1870 [<00000000064bb208>] sg_write.part.25+0x5d9/0x950 [<000000004fc670f6>] sg_write+0x5f/0x8c [<00000000b0d05c7b>] __vfs_write+0x7c/0x100 [<000000008e177714>] vfs_write+0x1c3/0x500 [<0000000087d23f34>] ksys_write+0xf9/0x200 [<000000002c8dbc9d>] do_syscall_64+0x9f/0x4f0 [<00000000678d8e9a>] entry_SYSCALL_64_after_hwframe+0x49/0xbe If __blk_rq_map_user_iov() is failed in blk_rq_map_user_iov(), the bio(s) which is allocated before this failing will leak. The refcount of the bio(s) is init to 1 and increased to 2 by calling bio_get(), but __blk_rq_unmap_user() only decrease it to 1, so the bio cannot be freed. Fix it by calling blk_rq_unmap_user(). Reviewed-by: Bob Liu <bob.liu@oracle.com> Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-09compat_ioctl: block: handle BLKREPORTZONE/BLKRESETZONEArnd Bergmann
commit 673bdf8ce0a387ef585c13b69a2676096c6edfe9 upstream. These were added to blkdev_ioctl() but not blkdev_compat_ioctl, so add them now. Cc: <stable@vger.kernel.org> # v4.10+ Fixes: 3ed05a987e0f ("blk-zoned: implement ioctls") Reviewed-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-09compat_ioctl: block: handle Persistent ReservationsArnd Bergmann
commit b2c0fcd28772f99236d261509bcd242135677965 upstream. These were added to blkdev_ioctl() in linux-5.5 but not blkdev_compat_ioctl, so add them now. Cc: <stable@vger.kernel.org> # v4.4+ Fixes: bbd3e064362e ("block: add an API for Persistent Reservations") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Fold in followup patch from Arnd with missing pr.h header include. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2019-12-17blk-mq: make sure that line break can be printedMing Lei
commit d2c9be89f8ebe7ebcc97676ac40f8dec1cf9b43a upstream. 8962842ca5ab ("blk-mq: avoid sysfs buffer overflow with too many CPU cores") avoids sysfs buffer overflow, and reserves one character for line break. However, the last snprintf() doesn't get correct 'size' parameter passed in, so fixed it. Fixes: 8962842ca5ab ("blk-mq: avoid sysfs buffer overflow with too many CPU cores") Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17block: fix single range discard mergeMing Lei
commit 2a5cf35cd6c56b2924bce103413ad3381bdc31fa upstream. There are actually two kinds of discard merge: - one is the normal discard merge, just like normal read/write request, and call it single-range discard - another is the multi-range discard, queue_max_discard_segments(rq->q) > 1 For the former case, queue_max_discard_segments(rq->q) is 1, and we should handle this kind of discard merge like the normal read/write request. This patch fixes the following kernel panic issue[1], which is caused by not removing the single-range discard request from elevator queue. Guangwu has one raid discard test case, in which this issue is a bit easier to trigger, and I verified that this patch can fix the kernel panic issue in Guangwu's test case. [1] kernel panic log from Jens's report BUG: unable to handle kernel NULL pointer dereference at 0000000000000148 PGD 0 P4D 0. Oops: 0000 [#1] SMP PTI CPU: 37 PID: 763 Comm: kworker/37:1H Not tainted \ 4.20.0-rc3-00649-ge64d9a554a91-dirty #14 Hardware name: Wiwynn \ Leopard-Orv2/Leopard-DDR BW, BIOS LBM08 03/03/2017 Workqueue: kblockd \ blk_mq_run_work_fn RIP: \ 0010:blk_mq_get_driver_tag+0x81/0x120 Code: 24 \ 10 48 89 7c 24 20 74 21 83 fa ff 0f 95 c0 48 8b 4c 24 28 65 48 33 0c 25 28 00 00 00 \ 0f 85 96 00 00 00 48 83 c4 30 5b 5d c3 <48> 8b 87 48 01 00 00 8b 40 04 39 43 20 72 37 \ f6 87 b0 00 00 00 02 RSP: 0018:ffffc90004aabd30 EFLAGS: 00010246 \ RAX: 0000000000000003 RBX: ffff888465ea1300 RCX: ffffc90004aabde8 RDX: 00000000ffffffff RSI: ffffc90004aabde8 RDI: 0000000000000000 RBP: 0000000000000000 R08: ffff888465ea1348 R09: 0000000000000000 R10: 0000000000001000 R11: 00000000ffffffff R12: ffff888465ea1300 R13: 0000000000000000 R14: ffff888465ea1348 R15: ffff888465d10000 FS: 0000000000000000(0000) GS:ffff88846f9c0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000148 CR3: 000000000220a003 CR4: 00000000003606e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Call Trace: blk_mq_dispatch_rq_list+0xec/0x480 ? elv_rb_del+0x11/0x30 blk_mq_do_dispatch_sched+0x6e/0xf0 blk_mq_sched_dispatch_requests+0xfa/0x170 __blk_mq_run_hw_queue+0x5f/0xe0 process_one_work+0x154/0x350 worker_thread+0x46/0x3c0 kthread+0xf5/0x130 ? process_one_work+0x350/0x350 ? kthread_destroy_worker+0x50/0x50 ret_from_fork+0x1f/0x30 Modules linked in: sb_edac x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel \ kvm switchtec irqbypass iTCO_wdt iTCO_vendor_support efivars cdc_ether usbnet mii \ cdc_acm i2c_i801 lpc_ich mfd_core ipmi_si ipmi_devintf ipmi_msghandler acpi_cpufreq \ button sch_fq_codel nfsd nfs_acl lockd grace auth_rpcgss oid_registry sunrpc nvme \ nvme_core fuse sg loop efivarfs autofs4 CR2: 0000000000000148 \ ---[ end trace 340a1fb996df1b9b ]--- RIP: 0010:blk_mq_get_driver_tag+0x81/0x120 Code: 24 10 48 89 7c 24 20 74 21 83 fa ff 0f 95 c0 48 8b 4c 24 28 65 48 33 0c 25 28 \ 00 00 00 0f 85 96 00 00 00 48 83 c4 30 5b 5d c3 <48> 8b 87 48 01 00 00 8b 40 04 39 43 \ 20 72 37 f6 87 b0 00 00 00 02 Fixes: 445251d0f4d329a ("blk-mq: fix discard merge with scheduler attached") Reported-by: Jens Axboe <axboe@kernel.dk> Cc: Guangwu Zhang <guazhang@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jianchao Wang <jianchao.w.wang@oracle.com> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Andre Tomt <andre@tomt.net> Cc: Jack Wang <jack.wang.usish@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17blk-mq: avoid sysfs buffer overflow with too many CPU coresMing Lei
commit 8962842ca5abdcf98e22ab3b2b45a103f0408b95 upstream. It is reported that sysfs buffer overflow can be triggered if the system has too many CPU cores(>841 on 4K PAGE_SIZE) when showing CPUs of hctx via /sys/block/$DEV/mq/$N/cpu_list. Use snprintf to avoid the potential buffer overflow. This version doesn't change the attribute format, and simply stops showing CPU numbers if the buffer is going to overflow. Cc: stable@vger.kernel.org Fixes: 676141e48af7("blk-mq: don't dump CPU -> hw queue map on driver load") Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-01block: fix the DISCARD request mergeJianchao Wang
[ Upstream commit 69840466086d2248898020a08dda52732686c4e6 ] There are two cases when handle DISCARD merge. If max_discard_segments == 1, the bios/requests need to be contiguous to merge. If max_discard_segments > 1, it takes every bio as a range and different range needn't to be contiguous. But now, attempt_merge screws this up. It always consider contiguity for DISCARD for the case max_discard_segments > 1 and cannot merge contiguous DISCARD for the case max_discard_segments == 1, because rq_attempt_discard_merge always returns false in this case. This patch fixes both of the two cases above. Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jianchao Wang <jianchao.w.wang@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-20blok, bfq: do not plug I/O if all queues are weight-raisedPaolo Valente
[ Upstream commit c8765de0adfcaaf4ffb2d951e07444f00ffa9453 ] To reduce latency for interactive and soft real-time applications, bfq privileges the bfq_queues containing the I/O of these applications. These privileged queues, referred-to as weight-raised queues, get a much higher share of the device throughput w.r.t. non-privileged queues. To preserve this higher share, the I/O of any non-weight-raised queue must be plugged whenever a sync weight-raised queue, while being served, remains temporarily empty. To attain this goal, bfq simply plugs any I/O (from any queue), if a sync weight-raised queue remains empty while in service. Unfortunately, this plugging typically lowers throughput with random I/O, on devices with internal queueing (because it reduces the filling level of the internal queues of the device). This commit addresses this issue by restricting the cases where plugging is performed: if a sync weight-raised queue remains empty while in service, then I/O plugging is performed only if some of the active bfq_queues are *not* weight-raised (which is actually the only circumstance where plugging is needed to preserve the higher share of the throughput of weight-raised queues). This restriction proved able to boost throughput in really many use cases needing only maximum throughput. Signed-off-by: Paolo Valente <paolo.valente@linaro.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-10-05blk-mq: move cancel of requeue_work to the front of blk_exit_queuezhengbin
[ Upstream commit e26cc08265dda37d2acc8394604f220ef412299d ] blk_exit_queue will free elevator_data, while blk_mq_requeue_work will access it. Move cancel of requeue_work to the front of blk_exit_queue to avoid use-after-free. blk_exit_queue blk_mq_requeue_work __elevator_exit blk_mq_run_hw_queues blk_mq_exit_sched blk_mq_run_hw_queue dd_exit_queue blk_mq_hctx_has_pending kfree(elevator_data) blk_mq_sched_has_work dd_has_work Fixes: fbc2a15e3433 ("blk-mq: move cancel of requeue_work into blk_mq_release") Cc: stable@vger.kernel.org Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: zhengbin <zhengbin13@huawei.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31block/bio-integrity: fix a memory leak bugWenwen Wang
[ Upstream commit e7bf90e5afe3aa1d1282c1635a49e17a32c4ecec ] In bio_integrity_prep(), a kernel buffer is allocated through kmalloc() to hold integrity metadata. Later on, the buffer will be attached to the bio structure through bio_integrity_add_page(), which returns the number of bytes of integrity metadata attached. Due to unexpected situations, bio_integrity_add_page() may return 0. As a result, bio_integrity_prep() needs to be terminated with 'false' returned to indicate this error. However, the allocated kernel buffer is not freed on this execution path, leading to a memory leak. To fix this issue, free the allocated buffer before returning from bio_integrity_prep(). Reviewed-by: Ming Lei <ming.lei@redhat.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-21block, bfq: NULL out the bic when it's no longer validDouglas Anderson
commit dbc3117d4ca9e17819ac73501e914b8422686750 upstream. In reboot tests on several devices we were seeing a "use after free" when slub_debug or KASAN was enabled. The kernel complained about: Unable to handle kernel paging request at virtual address 6b6b6c2b ...which is a classic sign of use after free under slub_debug. The stack crawl in kgdb looked like: 0 test_bit (addr=<optimized out>, nr=<optimized out>) 1 bfq_bfqq_busy (bfqq=<optimized out>) 2 bfq_select_queue (bfqd=<optimized out>) 3 __bfq_dispatch_request (hctx=<optimized out>) 4 bfq_dispatch_request (hctx=<optimized out>) 5 0xc056ef00 in blk_mq_do_dispatch_sched (hctx=0xed249440) 6 0xc056f728 in blk_mq_sched_dispatch_requests (hctx=0xed249440) 7 0xc0568d24 in __blk_mq_run_hw_queue (hctx=0xed249440) 8 0xc0568d94 in blk_mq_run_work_fn (work=<optimized out>) 9 0xc024c5c4 in process_one_work (worker=0xec6d4640, work=0xed249480) 10 0xc024cff4 in worker_thread (__worker=0xec6d4640) Digging in kgdb, it could be found that, though bfqq looked fine, bfqq->bic had been freed. Through further digging, I postulated that perhaps it is illegal to access a "bic" (AKA an "icq") after bfq_exit_icq() had been called because the "bic" can be freed at some point in time after this call is made. I confirmed that there certainly were cases where the exact crashing code path would access the "bic" after bfq_exit_icq() had been called. Sspecifically I set the "bfqq->bic" to (void *)0x7 and saw that the bic was 0x7 at the time of the crash. To understand a bit more about why this crash was fairly uncommon (I saw it only once in a few hundred reboots), you can see that much of the time bfq_exit_icq_fbqq() fully frees the bfqq and thus it can't access the ->bic anymore. The only case it doesn't is if bfq_put_queue() sees a reference still held. However, even in the case when bfqq isn't freed, the crash is still rare. Why? I tracked what happened to the "bic" after the exit routine. It doesn't get freed right away. Rather, put_io_context_active() eventually called put_io_context() which queued up freeing on a workqueue. The freeing then actually happened later than that through call_rcu(). Despite all these delays, some extra debugging showed that all the hoops could be jumped through in time and the memory could be freed causing the original crash. Phew! To make a long story short, assuming it truly is illegal to access an icq after the "exit_icq" callback is finished, this patch is needed. Cc: stable@vger.kernel.org Reviewed-by: Paolo Valente <paolo.valente@unimore.it> Signed-off-by: Douglas Anderson <dianders@chromium.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-03block: bio_iov_iter_get_pages: pin more pages for multi-segment IOsMartin Wilck
[ Upstream commit 17d51b10d7773e4618bcac64648f30f12d4078fb ] bio_iov_iter_get_pages() currently only adds pages for the next non-zero segment from the iov_iter to the bio. That's suboptimal for callers, which typically try to pin as many pages as fit into the bio. This patch converts the current bio_iov_iter_get_pages() into a static helper, and introduces a new helper that allocates as many pages as 1) fit into the bio, 2) are present in the iov_iter, 3) and can be pinned by MM. Error is returned only if zero pages could be pinned. Because of 3), a zero return value doesn't necessarily mean all pages have been pinned. Callers that have to pin every page in the iov_iter must still call this function in a loop (this is currently the case). This change matters most for __blkdev_direct_IO_simple(), which calls bio_iov_iter_get_pages() only once. If it obtains less pages than requested, it returns a "short write" or "short read", and __generic_file_write_iter() falls back to buffered writes, which may lead to data corruption. Fixes: 72ecad22d9f1 ("block: support a full bio worth of IO for simplified bdev direct-io") Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin Wilck <mwilck@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-03block: add a lower-level bio_add_page interfaceChristoph Hellwig
[ Upstream commit 0aa69fd32a5f766e997ca8ab4723c5a1146efa8b ] For the upcoming removal of buffer heads in XFS we need to keep track of the number of outstanding writeback requests per page. For this we need to know if bio_add_page merged a region with the previous bvec or not. Instead of adding additional arguments this refactors bio_add_page to be implemented using three lower level helpers which users like XFS can use directly if they care about the merge decisions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jens Axboe <axboe@kernel.dk> Reviewed-by: Ming Lei <ming.lei@redhat.com> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15block, bfq: increase idling for weight-raised queuesPaolo Valente
[ Upstream commit 778c02a236a8728bb992de10ed1f12c0be5b7b0e ] If a sync bfq_queue has a higher weight than some other queue, and remains temporarily empty while in service, then, to preserve the bandwidth share of the queue, it is necessary to plug I/O dispatching until a new request arrives for the queue. In addition, a timeout needs to be set, to avoid waiting for ever if the process associated with the queue has actually finished its I/O. Even with the above timeout, the device is however not fed with new I/O for a while, if the process has finished its I/O. If this happens often, then throughput drops and latencies grow. For this reason, the timeout is kept rather low: 8 ms is the current default. Unfortunately, such a low value may cause, on the opposite end, a violation of bandwidth guarantees for a process that happens to issue new I/O too late. The higher the system load, the higher the probability that this happens to some process. This is a problem in scenarios where service guarantees matter more than throughput. One important case are weight-raised queues, which need to be granted a very high fraction of the bandwidth. To address this issue, this commit lower-bounds the plugging timeout for weight-raised queues to 20 ms. This simple change provides relevant benefits. For example, on a PLEXTOR PX-256M5S, with which gnome-terminal starts in 0.6 seconds if there is no other I/O in progress, the same applications starts in - 0.8 seconds, instead of 1.2 seconds, if ten files are being read sequentially in parallel - 1 second, instead of 2 seconds, if, in parallel, five files are being read sequentially, and five more files are being written sequentially Tested-by: Holger Hoffstätte <holger@applied-asynchrony.com> Tested-by: Oleksandr Natalenko <oleksandr@natalenko.name> Signed-off-by: Paolo Valente <paolo.valente@linaro.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15blk-mq: move cancel of requeue_work into blk_mq_releaseMing Lei
[ Upstream commit fbc2a15e3433058582e5635aabe48a3011a644a8 ] With holding queue's kobject refcount, it is safe for driver to schedule requeue. However, blk_mq_kick_requeue_list() may be called after blk_sync_queue() is done because of concurrent requeue activities, then requeue work may not be completed when freeing queue, and kernel oops is triggered. So moving the cancel of requeue_work into blk_mq_release() for avoiding race between requeue and freeing queue. Cc: Dongli Zhang <dongli.zhang@oracle.com> Cc: James Smart <james.smart@broadcom.com> Cc: Bart Van Assche <bart.vanassche@wdc.com> Cc: linux-scsi@vger.kernel.org, Cc: Martin K . Petersen <martin.petersen@oracle.com>, Cc: Christoph Hellwig <hch@lst.de>, Cc: James E . J . Bottomley <jejb@linux.vnet.ibm.com>, Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: James Smart <james.smart@broadcom.com> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-31block: sed-opal: fix IOC_OPAL_ENABLE_DISABLE_MBRDavid Kozub
[ Upstream commit 78bf47353b0041865564deeed257a54f047c2fdc ] The implementation of IOC_OPAL_ENABLE_DISABLE_MBR handled the value opal_mbr_data.enable_disable incorrectly: enable_disable is expected to be one of OPAL_MBR_ENABLE(0) or OPAL_MBR_DISABLE(1). enable_disable was passed directly to set_mbr_done and set_mbr_enable_disable where is was interpreted as either OPAL_TRUE(1) or OPAL_FALSE(0). The end result was that calling IOC_OPAL_ENABLE_DISABLE_MBR with OPAL_MBR_ENABLE actually disabled the shadow MBR and vice versa. This patch adds correct conversion from OPAL_MBR_DISABLE/ENABLE to OPAL_FALSE/TRUE. The change affects existing programs using IOC_OPAL_ENABLE_DISABLE_MBR but this is typically used only once when setting up an Opal drive. Acked-by: Jon Derrick <jonathan.derrick@intel.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Scott Bauer <sbauer@plzdonthack.me> Signed-off-by: David Kozub <zub@linux.fjfi.cvut.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-05-14MLK-21526: Revert "block: Unexport elv_register_queue() and ↵Mircea Pop
elv_unregister_queue()" This reverts commit 83d016ac86428dbca8a62d3e4fdc29e3ea39e535. Reverting the patch will solve the issue introduced by MLK-18870 fix The fix is adding the following patch on 4.14 bsp kernel 83d016ac86428("block: Unexport elv_register_queue() and elv_unregister_queue()") The upstream patch that remove the correlation with export elv_register_queue() is not applied on IMX kernel BSP. c100ec49fdd22("dm: fix incomplete request_queue initialization") Having missing patch a compilation issue will be generated if DM is enabled Decision not to cherry-pick the c100ec49fdd22("dm:fix incomplete request_queue initialization") from upstream because the patch adds new DM Crypt functionalities and to revoke the patch that remove the export. Signed-off-by: Mircea Pop <mircea.pop@nxp.com>
2019-04-17block: do not leak memory in bio_copy_user_iov()Jérôme Glisse
commit a3761c3c91209b58b6f33bf69dd8bb8ec0c9d925 upstream. When bio_add_pc_page() fails in bio_copy_user_iov() we should free the page we just allocated otherwise we are leaking it. Cc: linux-block@vger.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: stable@vger.kernel.org Reviewed-by: Chaitanya Kulkarni <chaitanya.kulkarni@wdc.com> Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-20blk-mq: fix a hung issue when fsyncJianchao Wang
[ Upstream commit 85bd6e61f34dffa8ec2dc75ff3c02ee7b2f1cbce ] Florian reported a io hung issue when fsync(). It should be triggered by following race condition. data + post flush a flush blk_flush_complete_seq case REQ_FSEQ_DATA blk_flush_queue_rq issued to driver blk_mq_dispatch_rq_list try to issue a flush req failed due to NON-NCQ command .queue_rq return BLK_STS_DEV_RESOURCE request completion req->end_io // doesn't check RESTART mq_flush_data_end_io case REQ_FSEQ_POSTFLUSH blk_kick_flush do nothing because previous flush has not been completed blk_mq_run_hw_queue insert rq to hctx->dispatch due to RESTART is still set, do nothing To fix this, replace the blk_mq_run_hw_queue in mq_flush_data_end_io with blk_mq_sched_restart to check and clear the RESTART flag. Fixes: bd166ef1 (blk-mq-sched: add framework for MQ capable IO schedulers) Reported-by: Florian Stecker <m19@florianstecker.de> Tested-by: Florian Stecker <m19@florianstecker.de> Signed-off-by: Jianchao Wang <jianchao.w.wang@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-02-12block: bio_check_eod() needs to consider partitionsChristoph Hellwig
bio_check_eod() should check partition size not the whole disk if bio->bi_partno is non-zero. Do this by moving the call to bio_check_eod() into blk_partition_remap(). Based on an earlier patch from Jiufei Xue. Fixes: 74d46992e0d9 ("block: replace bi_bdev with a gendisk pointer and partitions index") Reported-by: Jiufei Xue <jiufei.xue@linux.alibaba.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 52c5e62d4c4beecddc6e1b8045ce1d695fca1ba7)
2019-02-12block: add bdev_read_only() checks to common helpersIlya Dryomov
Similar to blkdev_write_iter(), return -EPERM if the partition is read-only. This covers ioctl(), fallocate() and most in-kernel users but isn't meant to be exhaustive -- everything else will be caught in generic_make_request_checks(), fail with -EIO and can be fixed later. Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit a13553c777375009584741e7d9982e775c4b0744)
2019-02-12block: fail op_is_write() requests to read-only partitionsIlya Dryomov
Regular block device writes go through blkdev_write_iter(), which does bdev_read_only(), while zeroout/discard/etc requests are never checked, both userspace- and kernel-triggered. Add a generic catch-all check to generic_make_request_checks() to actually enforce ioctl(BLKROSET) and set_disk_ro(), which is used by quite a few drivers for things like snapshots, read-only backing files/images, etc. Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 721c7fc701c71f693307d274d2b346a1ecd4a534)
2019-02-12blk-throttle: export io_serviced_recursive, io_service_bytes_recursiveweiping zhang
export these two interface for cgroup-v1. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: weiping zhang <zhangweiping@didichuxing.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 17534c6f2c065ad8e34ff6f013e5afaa90428512)
2019-02-12block: Protect less code with sysfs_lock in blk_{un,}register_queue()Bart Van Assche
The __blk_mq_register_dev(), blk_mq_unregister_dev(), elv_register_queue() and elv_unregister_queue() calls need to be protected with sysfs_lock but other code in these functions not. Hence protect only this code with sysfs_lock. This patch fixes a locking inversion issue in blk_unregister_queue() and also in an error path of blk_register_queue(): it is not allowed to hold sysfs_lock around the kobject_del(&q->kobj) call. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 2c2086afc2b8b974fac32cb028e73dc27bfae442)
2019-02-12block: allow gendisk's request_queue registration to be deferredMike Snitzer
Since I can remember DM has forced the block layer to allow the allocation and initialization of the request_queue to be distinct operations. Reason for this is block/genhd.c:add_disk() has requires that the request_queue (and associated bdi) be tied to the gendisk before add_disk() is called -- because add_disk() also deals with exposing the request_queue via blk_register_queue(). DM's dynamic creation of arbitrary device types (and associated request_queue types) requires the DM device's gendisk be available so that DM table loads can establish a master/slave relationship with subordinate devices that are referenced by loaded DM tables -- using bd_link_disk_holder(). But until these DM tables, and their associated subordinate devices, are known DM cannot know what type of request_queue it needs -- nor what its queue_limits should be. This chicken and egg scenario has created all manner of problems for DM and, at times, the block layer. Summary of changes: - Add device_add_disk_no_queue_reg() and add_disk_no_queue_reg() variant that drivers may use to add a disk without also calling blk_register_queue(). Driver must call blk_register_queue() once its request_queue is fully initialized. - Return early from blk_unregister_queue() if QUEUE_FLAG_REGISTERED is not set. It won't be set if driver used add_disk_no_queue_reg() but driver encounters an error and must del_gendisk() before calling blk_register_queue(). - Export blk_register_queue(). These changes allow DM to use add_disk_no_queue_reg() to anchor its gendisk as the "master" for master/slave relationships DM must establish with subordinate devices referenced in DM tables that get loaded. Once all "slave" devices for a DM device are known its request_queue can be properly initialized and then advertised via sysfs -- important improvement being that no request_queue resource initialization performed by blk_register_queue() is missed for DM devices anymore. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit fa70d2e2c4a0a54ced98260c6a176cc94c876d27)
2019-02-12block: properly protect the 'queue' kobj in blk_unregister_queueMike Snitzer
The original commit e9a823fb34a8b (block: fix warning when I/O elevator is changed as request_queue is being removed) is pretty conflated. "conflated" because the resource being protected by q->sysfs_lock isn't the queue_flags (it is the 'queue' kobj). q->sysfs_lock serializes __elevator_change() (via elv_iosched_store) from racing with blk_unregister_queue(): 1) By holding q->sysfs_lock first, __elevator_change() can complete before a racing blk_unregister_queue(). 2) Conversely, __elevator_change() is testing for QUEUE_FLAG_REGISTERED in case elv_iosched_store() loses the race with blk_unregister_queue(), it needs a way to know the 'queue' kobj isn't there. Expand the scope of blk_unregister_queue()'s q->sysfs_lock use so it is held until after the 'queue' kobj is removed. To do so blk_mq_unregister_dev() must not also take q->sysfs_lock. So rename __blk_mq_unregister_dev() to blk_mq_unregister_dev(). Also, blk_unregister_queue() should use q->queue_lock to protect against any concurrent writes to q->queue_flags -- even though chances are the queue is being cleaned up so no concurrent writes are likely. Fixes: e9a823fb34a8b ("block: fix warning when I/O elevator is changed as request_queue is being removed") Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 667257e8b2988c0183ba23e2bcd6900e87961606)
2019-02-12block: only bdi_unregister() in del_gendisk() if !GENHD_FL_HIDDENMike Snitzer
device_add_disk() will only call bdi_register_owner() if !GENHD_FL_HIDDEN, so it follows that del_gendisk() should only call bdi_unregister() if !GENHD_FL_HIDDEN. Found with code inspection. bdi_unregister() won't do any harm if bdi_register_owner() wasn't used but best to avoid the unnecessary call to bdi_unregister(). Fixes: 8ddcd65325 ("block: introduce GENHD_FL_HIDDEN") Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Ming Lei <ming.lei@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit bc8d062c36e3525e81ea8237ff0ab3264c2317b6)
2019-02-12block: add a poll_fn callback to struct request_queueChristoph Hellwig
That we we can also poll non blk-mq queues. Mostly needed for the NVMe multipath code, but could also be useful elsewhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit ea435e1b9392a33deceaea2a16ebaa3397bead93)
2019-02-12block: introduce GENHD_FL_HIDDENChristoph Hellwig
With this flag a driver can create a gendisk that can be used for I/O submission inside the kernel, but which is not registered as user facing block device. This will be useful for the NVMe multipath implementation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 8ddcd653257c18a669fcb75ee42c37054908e0d6)
2019-02-12block: don't look at the struct device dev_t in disk_devtChristoph Hellwig
The hidden gendisks introduced in the next patch need to keep the dev field in their struct device empty so that udev won't try to create block device nodes for them. To support that rewrite disk_devt to look at the major and first_minor fields in the gendisk itself instead of looking into the struct device. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 517bf3c306bad4fe0da631f90ae2ec40924dee2b)
2019-02-12block: add a blk_steal_bios helperChristoph Hellwig
This helpers allows to bounce steal the uncompleted bios from a request so that they can be reissued on another path. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit ef71de8b15d891b27b8c983a9a8972b11cb4576a)
2019-02-12block: provide a direct_make_request helperChristoph Hellwig
This helper allows reinserting a bio into a new queue without much overhead, but requires all queue limits to be the same for the upper and lower queues, and it does not provide any recursion preventions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Javier González <javier@cnexlabs.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit f421e1d9ade4e1b88183e54425cf50e390d16a7f)
2019-02-12block: Document scheduler modification locking requirementsBart Van Assche
This patch does not change any functionality. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 14a23498ba97683c6790b1bcd8b2cdfe9ad99797)
2019-02-12block: Unexport elv_register_queue() and elv_unregister_queue()Bart Van Assche
These two functions are only called from inside the block layer so unexport them. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> (cherry picked from commit 83d016ac86428dbca8a62d3e4fdc29e3ea39e535)
2019-02-12MLK-11444 ata: imx: cmd buf corruption errata bug fixRichard Zhu
errata: When a read command returns less data than specified in the PRDs (for example, there are two PRDs for this command, but the device returns a number of bytes which is less than in the first PRD), the second PRD of this command is not read out of the PRD FIFO, causing the next command to use this PRD erroneously. workaround - forces sg_tablesize = 1 - modified the sg_io function in block/scsi_ioctl.c to use a 64k buffer allocated with dma_alloc_coherent during the probe in ahci_imx - In order to fix the scsi/sata hang, when CD_ROM and HDD are accessed simultaneously after the workaround is applied. Do not go to sleep in scsi_eh_handler, when there is host failed. Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
2018-12-29block: fix infinite loop if the device loses discard capabilityMikulas Patocka
[ Upstream commit b88aef36b87c9787a4db724923ec4f57dfd513f3 ] If __blkdev_issue_discard is in progress and a device mapper device is reloaded with a table that doesn't support discard, q->limits.max_discard_sectors is set to zero. This results in infinite loop in __blkdev_issue_discard. This patch checks if max_discard_sectors is zero and aborts with -EOPNOTSUPP. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Tested-by: Zdenek Kabelac <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-29block: break discard submissions into the user defined sizeJens Axboe
[ Upstream commit af097f5d199e2aa3ab3ef777f0716e487b8f7b08 ] Don't build discards bigger than what the user asked for, if the user decided to limit the size by writing to 'discard_max_bytes'. Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-21elevator: lookup mq vs non-mq elevatorsJens Axboe
[ Upstream commit 2527d99789e248576ac8081530cd4fd88730f8c7 ] If an IO scheduler is selected via elevator= and it doesn't match the driver in question wrt blk-mq support, then we fail to boot. The elevator= parameter is deprecated and only supported for non-mq devices. Augment the elevator lookup API so that we pass in if we're looking for an mq capable scheduler or not, so that we only ever return a valid type for the queue in question. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=196695 Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-21SCSI: fix queue cleanup race before queue initialization is doneMing Lei
commit 8dc765d438f1e42b3e8227b3b09fad7d73f4ec9a upstream. c2856ae2f315d ("blk-mq: quiesce queue before freeing queue") has already fixed this race, however the implied synchronize_rcu() in blk_mq_quiesce_queue() can slow down LUN probe a lot, so caused performance regression. Then 1311326cf4755c7 ("blk-mq: avoid to synchronize rcu inside blk_cleanup_queue()") tried to quiesce queue for avoiding unnecessary synchronize_rcu() only when queue initialization is done, because it is usual to see lots of inexistent LUNs which need to be probed. However, turns out it isn't safe to quiesce queue only when queue initialization is done. Because when one SCSI command is completed, the user of sending command can be waken up immediately, then the scsi device may be removed, meantime the run queue in scsi_end_request() is still in-progress, so kernel panic can be caused. In Red Hat QE lab, there are several reports about this kind of kernel panic triggered during kernel booting. This patch tries to address the issue by grabing one queue usage counter during freeing one request and the following run queue. Fixes: 1311326cf4755c7 ("blk-mq: avoid to synchronize rcu inside blk_cleanup_queue()") Cc: Andrew Jones <drjones@redhat.com> Cc: Bart Van Assche <bart.vanassche@wdc.com> Cc: linux-scsi@vger.kernel.org Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Cc: James E.J. Bottomley <jejb@linux.vnet.ibm.com> Cc: stable <stable@vger.kernel.org> Cc: jianchao.wang <jianchao.w.wang@oracle.com> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13block, bfq: correctly charge and reset entity service in all casesPaolo Valente
[ Upstream commit cbeb869a3d1110450186b738199963c5e68c2a71 ] BFQ schedules entities (which represent either per-process queues or groups of queues) as a function of their timestamps. In particular, as a function of their (virtual) finish times. The finish time of an entity is computed as a function of the budget assigned to the entity, assuming, tentatively, that the entity, once in service, will receive an amount of service equal to its budget. Then, when the entity is expired because it finishes to be served, this finish time is updated as a function of the actual service received by the entity. This allows the entity to be correctly charged with only the service received, and then to be correctly re-scheduled. Yet an entity may receive service also while not being the entity in service (in the scheduling environment of its parent entity), for several reasons. If the entity remains with no backlog while receiving this 'unofficial' service, then it is expired. Also on such an expiration, the finish time of the entity should be updated to account for only the service actually received by the entity. Unfortunately, such an update is not performed for an entity expiring without being the entity in service. In a similar vein, the service counter of the entity in service is reset when the entity is expired, to be ready to be used for next service cycle. This reset too should be performed also in case an entity is expired because it remains empty after receiving service while not being the entity in service. But in this case the reset is not performed. This commit performs the above update of the finish time and reset of the service received, also for an entity expiring while not being the entity in service. Signed-off-by: Paolo Valente <paolo.valente@linaro.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-13blk-mq: I/O and timer unplugs are inverted in blktraceIlya Dryomov
commit 587562d0c7cd6861f4f90a2eb811cccb1a376f5f upstream. trace_block_unplug() takes true for explicit unplugs and false for implicit unplugs. schedule() unplugs are implicit and should be reported as timer unplugs. While correct in the legacy code, this has been inverted in blk-mq since 4.11. Cc: stable@vger.kernel.org Fixes: bd166ef183c2 ("blk-mq-sched: add framework for MQ capable IO schedulers") Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-26blk-mq: avoid to synchronize rcu inside blk_cleanup_queue()Ming Lei
[ Upstream commit 1311326cf4755c7ffefd20f576144ecf46d9906b ] SCSI probing may synchronously create and destroy a lot of request_queues for non-existent devices. Any synchronize_rcu() in queue creation or destroy path may introduce long latency during booting, see detailed description in comment of blk_register_queue(). This patch removes one synchronize_rcu() inside blk_cleanup_queue() for this case, commit c2856ae2f315d75(blk-mq: quiesce queue before freeing queue) needs synchronize_rcu() for implementing blk_mq_quiesce_queue(), but when queue isn't initialized, it isn't necessary to do that since only pass-through requests are involved, no original issue in scsi_execute() at all. Without this patch and previous one, it may take more 20+ seconds for virtio-scsi to complete disk probe. With the two patches, the time becomes less than 100ms. Fixes: c2856ae2f315d75 ("blk-mq: quiesce queue before freeing queue") Reported-by: Andrew Jones <drjones@redhat.com> Cc: Omar Sandoval <osandov@fb.com> Cc: Bart Van Assche <bart.vanassche@wdc.com> Cc: linux-scsi@vger.kernel.org Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Tested-by: Andrew Jones <drjones@redhat.com> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-26blk-mq: only attempt to merge bio if there is rq in sw queueMing Lei
[ Upstream commit b04f50ab8a74129b3041a2836c33c916be3c6667 ] Only attempt to merge bio iff the ctx->rq_list isn't empty, because: 1) for high-performance SSD, most of times dispatch may succeed, then there may be nothing left in ctx->rq_list, so don't try to merge over sw queue if it is empty, then we can save one acquiring of ctx->lock 2) we can't expect good merge performance on per-cpu sw queue, and missing one merge on sw queue won't be a big deal since tasks can be scheduled from one CPU to another. Cc: Laurence Oberman <loberman@redhat.com> Cc: Omar Sandoval <osandov@fb.com> Cc: Bart Van Assche <bart.vanassche@wdc.com> Tested-by: Kashyap Desai <kashyap.desai@broadcom.com> Reported-by: Kashyap Desai <kashyap.desai@broadcom.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-26block: allow max_discard_segments to be stackedMike Snitzer
[ Upstream commit 42c9cdfe1e11e083dceb0f0c4977b758cf7403b9 ] Set max_discard_segments to USHRT_MAX in blk_set_stacking_limits() so that blk_stack_limits() can stack up this limit for stacked devices. before: $ cat /sys/block/nvme0n1/queue/max_discard_segments 256 $ cat /sys/block/dm-0/queue/max_discard_segments 1 after: $ cat /sys/block/nvme0n1/queue/max_discard_segments 256 $ cat /sys/block/dm-0/queue/max_discard_segments 256 Fixes: 1e739730c5b9e ("block: optionally merge discontiguous discard bios into a single request") Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19partitions/aix: fix usage of uninitialized lv_info and lvname structuresMauricio Faria de Oliveira
[ Upstream commit 14cb2c8a6c5dae57ee3e2da10fa3db2b9087e39e ] The if-block that sets a successful return value in aix_partition() uses 'lvip[].pps_per_lv' and 'n[].name' potentially uninitialized. For example, if 'numlvs' is zero or alloc_lvn() fails, neither is initialized, but are used anyway if alloc_pvd() succeeds after it. So, make the alloc_pvd() call conditional on their initialization. This has been hit when attaching an apparently corrupted/stressed AIX LUN, misleading the kernel to pr_warn() invalid data and hang. [...] partition (null) (11 pp's found) is not contiguous [...] partition (null) (2 pp's found) is not contiguous [...] partition (null) (3 pp's found) is not contiguous [...] partition (null) (64 pp's found) is not contiguous Fixes: 6ceea22bbbc8 ("partitions: add aix lvm partition support files") Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19partitions/aix: append null character to print data from diskMauricio Faria de Oliveira
[ Upstream commit d43fdae7bac2def8c4314b5a49822cb7f08a45f1 ] Even if properly initialized, the lvname array (i.e., strings) is read from disk, and might contain corrupt data (e.g., lack the null terminating character for strings). So, make sure the partition name string used in pr_warn() has the null terminating character. Fixes: 6ceea22bbbc8 ("partitions: add aix lvm partition support files") Suggested-by: Daniel J. Axtens <daniel.axtens@canonical.com> Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
