This adds SG_IO support to SG v4.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
This patch replaces SG v3 in bsg with SG v4 (except for SG_IO).
blk_fill_sghdr_rq doesn't work for SG v4 so verify_command needed to
be exported.
This just kills linux/config.h and dprintk warnings.
This converts block/scsi_ioctl.c use blk_rq_unmap_user new
API. blk_unmap_sghdr_rq is too simple and it might be better to remove
it.
elevator
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
instead of going through all options.
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
With the cfq_queue hash removal, we inadvertently got rid of the
async queue sharing. This was not intentional, in fact CFQ purposely
shares the async queue per priority level to get good merging for
async writes.
So put some logic in cfq_get_queue() to track the shared queues.
Barrier bios are completed twice - once after the barrier write itself
is done and again after the whole sequence is complete.
flush_dry_bio_endio() is for the first completion. It doesn't really
complete the bio. It rewinds bvec and resets bio so that it can be
completed again when the whole barrier sequence is complete.
The bvec rewinding code has the following problems.
1. The rewinding code is wrong because filesystems may pass bvec with
non zero bv_offset.
2. The block layer doesn't guarantee anything about the state of
bvec array on request completion. bv_offset and len are updated
iff __end_that_request_first() completes the bvec partially.
Because of #2, #1 doesn't really matter (nobody cares whether bvec is
re-wound correctly or not) but then again by not doing unwinding at
all, we'll always give back the same bvec to the caller as full bvec
completion doesn't alter bvecs and the final completion is always full
completion.
Drop unnecessary rewinding code.
This is spotted by Neil Brown.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Neil Brown <neilb@suse.de>
Two bugs in there:
- The virt oversize check should use the current bio hardware back
size and the next bio front size, not the same bio. Spotted by
Neil Brown.
- The segment size check should add hw front sizes, not total bio
sizes. Spotted by James Bottomley
Acked-by: James Bottomley <James.Bottomley@SteelEye.com>
Acked-by: NeilBrown <neilb@suse.de>
SCSI marks internal commands with REQ_PREEMPT and push it at the front
of the request queue using blk_execute_rq(). When entering suspended
or frozen state, SCSI devices are quiesced using
scsi_device_quiesce(). In quiesced state, only REQ_PREEMPT requests
are processed. This is how SCSI blocks other requests out while
suspending and resuming. As all internal commands are pushed at the
front of the queue, this usually works.
Unfortunately, this interacts badly with ordered requeueing. To
preserve request order on requeueing (due to busy device, active EH or
other failures), requests are sorted according to ordered sequence on
requeue if IO barrier is in progress.
The following sequence deadlocks.
1. IO barrier sequence issues.
2. Suspend requested. Queue is quiesced with part or all of IO
barrier sequence at the front.
3. During suspending or resuming, SCSI issues internal command which
gets deferred and requeued for some reason. As the command is
issued after the IO barrier in #1, ordered requeueing code puts the
request after IO barrier sequence.
4. The device is ready to process requests again but still is in
quiesced state and the first request of the queue isn't
REQ_PREEMPT, so command processing is deadlocked -
suspending/resuming waits for the issued request to complete while
the request can't be processed till device is put back into
running state by resuming.
This can be fixed by always putting !fs requests at the front when
requeueing.
The following thread reports this deadlock.
http://thread.gmane.org/gmane.linux.kernel/537473
Acked-by: David Greaves <david@dgreaves.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
Send an uevent to user space to indicate that a media change event has
occurred.
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Allow user space to determine if a disk supports Asynchronous Notification of
media changes. This is done by adding a new sysfs file "capability_flags",
which is documented in (insert file name). This sysfs file will export all
disk capabilities flags to user space. We also define a new flag to define
the media change notification capability.
current_io_context() is both static and exported with EXPORT_SYMBOL().
As there are no users outside of ll_rw_blk.c itself, just kill the
export.
Problem reported by Martin Michlmayr <tbm@cyrius.com>
to generic_make_request can use up a lot of space, and we would rather they
didn't.
As generic_make_request is a void function, and as it is generally not
expected that it will have any effect immediately, it is safe to delay any
call to generic_make_request until there is sufficient stack space
available.
As ->bi_next is reserved for the driver to use, it can have no valid value
when generic_make_request is called, and as __make_request implicitly
assumes it will be NULL (ELEVATOR_BACK_MERGE fork of switch) we can be
certain that all callers set it to NULL. We can therefore safely use
bi_next to link pending requests together, providing we clear it before
making the real call.
So, we choose to allow each thread to only be active in one
generic_make_request at a time. If a subsequent (recursive) call is made,
the bio is linked into a per-thread list, and is handled when the active
call completes.
As the list of pending bios is per-thread, there are no locking issues to
worry about.
I say above that it is "safe to delay any call...". There are, however,
some behaviours of a make_request_fn which would make it unsafe. These
include any behaviour that assumes anything will have changed after a
recursive call to generic_make_request.
These could include:
- waiting for that call to finish and call it's bi_end_io function.
md use to sometimes do this (marking the superblock dirty before
completing a write) but doesn't any more
- inspecting the bio for fields that generic_make_request might
change, such as bi_sector or bi_bdev. It is hard to see a good
reason for this, and I don't think anyone actually does it.
- inspecing the queue to see if, e.g. it is 'full' yet. Again, I
think this is very unlikely to be useful, or to be done.
Signed-off-by: Neil Brown <neilb@suse.de>
Cc: <dm-devel@redhat.com>
Alasdair G Kergon <agk@redhat.com> said:
I can see nothing wrong with this in principle.
For device-mapper at the moment though it's essential that, while the bio
mappings may now get delayed, they still get processed in exactly
the same order as they were passed to generic_make_request().
My main concern is whether the timing changes implicit in this patch
will make the rare data-corrupting races in the existing snapshot code
more likely. (I'm working on a fix for these races, but the unfinished
patch is already several hundred lines long.)
It would be helpful if some people on this mailing list would test
this patch in various scenarios and report back.
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits)
sound: convert "sound" subdirectory to UTF-8
MAINTAINERS: Add cxacru website/mailing list
include files: convert "include" subdirectory to UTF-8
general: convert "kernel" subdirectory to UTF-8
documentation: convert the Documentation directory to UTF-8
Convert the toplevel files CREDITS and MAINTAINERS to UTF-8.
remove broken URLs from net drivers' output
Magic number prefix consistency change to Documentation/magic-number.txt
trivial: s/i_sem /i_mutex/
fix file specification in comments
drivers/base/platform.c: fix small typo in doc
misc doc and kconfig typos
Remove obsolete fat_cvf help text
Fix occurrences of "the the "
Fix minor typoes in kernel/module.c
Kconfig: Remove reference to external mqueue library
Kconfig: A couple of grammatical fixes in arch/i386/Kconfig
Correct comments in genrtc.c to refer to correct /proc file.
Fix more "deprecated" spellos.
Fix "deprecated" typoes.
Fix trivial comment conflict in kernel/relay.c.
Since nonboot CPUs are now disabled after tasks and devices have been
frozen and the CPU hotplug infrastructure is used for this purpose, we need
special CPU hotplug notifications that will help the CPU-hotplug-aware
subsystems distinguish normal CPU hotplug events from CPU hotplug events
related to a system-wide suspend or resume operation in progress. This
patch introduces such notifications and causes them to be used during
suspend and resume transitions. It also changes all of the
CPU-hotplug-aware subsystems to take these notifications into consideration
(for now they are handled in the same way as the corresponding "normal"
ones).
[oleg@tv-sign.ru: cleanups]
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
flush_work(wq, work) doesn't need the first parameter, we can use cwq->wq
(this was possible from the very beginnig, I missed this). So we can unify
flush_work_keventd and flush_work.
Also, rename flush_work() to cancel_work_sync() and fix all callers.
Perhaps this is not the best name, but "flush_work" is really bad.
(akpm: this is why the earlier patches bypassed maintainers)
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Auke Kok <auke-jan.h.kok@intel.com>,
Switch the kblockd flushing from a global flush to a more specific
flush_work().
(akpm: bypassed maintainers, sorry. There are other patches which depend on
this)
Cc: "Maciej W. Rozycki" <macro@linux-mips.org>
Cc: Jens Axboe <axboe@suse.de>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Display all possible partitions when the root filesystem is not mounted.
This helps to track spell'o's and missing drivers.
Updated to work with newer kernels.
Example output:
VFS: Cannot open root device "foobar" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
0800 8388608 sda driver: sd
0801 192748 sda1
0802 8193150 sda2
0810 4194304 sdb driver: sd
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[akpm@linux-foundation.org: cleanups, fix printk warnings]
Cc: Dave Gilbert <linux@treblig.org>
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
* 'for-2.6.22' of git://git.kernel.dk/data/git/linux-2.6-block:
[PATCH] ll_rw_blk: fix missing bounce in blk_rq_map_kern()
[PATCH] splice: always call into page_cache_readahead()
[PATCH] splice(): fix interaction with readahead
Fix units mismatch (jiffies vs msecs) in as-iosched.c, spotted by Xiaoning
Ding <dingxn@cse.ohio-state.edu>.
Signed-off-by: Nick Piggin <npiggin@suse.de>
I think we might just need the blk_map_kern users now. For the async
execute I added the bounce code already and the block SG_IO has it
atleady. I think the blk_map_kern bounce code got dropped because we
thought the correct gfp_t would be passed in. But I think all we need is
the patch below and all the paths are take care of. The patch is not
tested. Patch was made against scsi-misc.
The last place that is sending non sg commands may just be md/dm-emc.c
but that is is just waiting on alasdair to take some patches that fix
that and a bunch of junk in there including adding bounce support. If
the patch below is ok though and dm-emc finally gets converted then it
will have sg and bonce buffer support.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
This patch provides a new macro
KMEM_CACHE(<struct>, <flags>)
to simplify slab creation. KMEM_CACHE creates a slab with the name of the
struct, with the size of the struct and with the alignment of the struct.
Additional slab flags may be specified if necessary.
Example
struct test_slab {
int a,b,c;
struct list_head;
} __cacheline_aligned_in_smp;
test_slab_cache = KMEM_CACHE(test_slab, SLAB_PANIC)
will create a new slab named "test_slab" of the size sizeof(struct
test_slab) and aligned to the alignment of test slab. If it fails then we
panic.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't
been used in 6 years (so akpm says).
find * -name \*.[ch] | xargs grep -l invalidate_bdev |
while read file; do
quilt add $file;
sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file;
done
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits)
[SCSI] fusion: fix domain validation loops
[SCSI] qla2xxx: fix regression on sparc64
[SCSI] modalias for scsi devices
[SCSI] sg: cap reserved_size values at max_sectors
[SCSI] BusLogic: stop using check_region
[SCSI] tgt: fix rdma transfer bugs
[SCSI] aacraid: fix aacraid not finding device
[SCSI] aacraid: Correct SMC products in aacraid.txt
[SCSI] scsi_error.c: Add EH Start Unit retry
[SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test.
[SCSI] ipr: Driver version to 2.3.2
[SCSI] ipr: Faster sg list fetch
[SCSI] ipr: Return better qc_issue errors
[SCSI] ipr: Disrupt device error
[SCSI] ipr: Improve async error logging level control
[SCSI] ipr: PCI unblock config access fix
[SCSI] ipr: Fix for oops following SATA request sense
[SCSI] ipr: Log error for SAS dual path switch
[SCSI] ipr: Enable logging of debug error data for all devices
[SCSI] ipr: Add new PCI-E IDs to device table
We need to work on cleaning up the relationship between kobjects, ksets and
ktypes. The removal of 'struct subsystem' is the first step of this,
especially as it is not really needed at all.
Thanks to Kay for fixing the bugs in this patch.
It's never grabbed from irq context, so just make it plain spin_lock().
We often lookup the same queue many times in succession, so cache
the last looked up queue to avoid browsing the rbtree.
To be used by as/cfq as they see fit.
cfq hash is no more necessary. We always can get cfqq from io context.
cfq_get_io_context_noalloc() function is introduced, because we don't
want to allocate cic on merging and checking may_queue. In order to
identify sync queue we've used hash key = CFQ_KEY_ASYNC. Since hash is
eliminated we need to use other criterion: sync flag for queue is added.
In all places where we dig in rb_tree we're in current context, so no
additional locking is required.
Advantages of this patch: no additional memory for hash, no seeking in
hash, code is cleaner. But it is necessary now to seek cic in per-ioc
rbtree, but it is faster:
- most processes work only with few devices
- most systems have only few block devices
- it is a rb-tree
Signed-off-by: Vasily Tarasov <vtaras@openvz.org>
Changes by me:
- Merge into CFQ devel branch
- Get rid of cfq_get_io_context_noalloc()
- Fix various bugs with dereferencing cic->cfqq[] with offset other
than 0 or 1.
- Fix bug in cfqq setup, is_sync condition was reversed.
- Fix bug where only bio_sync() is used, we need to check for a READ too
For tagged devices, allow overlap of requests if the idle window
isn't enabled on the current active queue.
We don't enable it by default, don't let it get enabled during
runtime.
We can track it fairly accurately locally, let the slice handling
take care of the rest.
We don't use it anymore in the slice expiry handling.
It's only used for preemption now that the IDLE and RT queues also
use the rbtree. If we pass an 'add_front' variable to
cfq_service_tree_add(), we can set ->rb_key to 0 to force insertion
at the front of the tree.
Use the max_slice-cur_slice as the multipler for the insertion offset.
Same treatment as the RT conversion, just put the sorted idle
branch at the end of the tree.
Currently CFQ does a linked insert into the current list for RT
queues. We can just factor the class into the rb insertion,
and then we don't have to treat RT queues in a special way. It's
faster, too.
For cases where the rbtree is mainly used for sorting and min retrieval,
a nice speedup of the rbtree code is to maintain a cache of the leftmost
node in the tree.
Also spotted in the CFS CPU scheduler code.
Improved by Alan D. Brunelle <Alan.Brunelle@hp.com> by updating the
leftmost hint in cfq_rb_first() if it isn't set, instead of only
updating it on insert.
Drawing on some inspiration from the CFS CPU scheduler design, overhaul
the pending cfq_queue concept list management. Currently CFQ uses a
doubly linked list per priority level for sorting and service uses.
Kill those lists and maintain an rbtree of cfq_queue's, sorted by when
to service them.
This unfortunately means that the ionice levels aren't as strong
anymore, will work on improving those later. We only scale the slice
time now, not the number of times we service. This means that latency
is better (for all priority levels), but that the distinction between
the highest and lower levels aren't as big.
The diffstat speaks for itself.
cfq-iosched.c | 363 +++++++++++++++++---------------------------------
1 file changed, 125 insertions(+), 238 deletions(-)
- Move the queue_new flag clear to when the queue is selected
- Only select the non-first queue in cfq_get_best_queue(), if there's
a substantial difference between the best and first.
- Get rid of ->busy_rr
- Only select a close cooperator, if the current queue is known to take
a while to "think".
- Implement logic for detecting cooperating processes, so we
choose the best available queue whenever possible.
- Improve residual slice time accounting.
- Remove dead code: we no longer see async requests coming in on
sync queues. That part was removed a long time ago. That means
that we can also remove the difference between cfq_cfqq_sync()
and cfq_cfqq_class_sync(), they are now indentical. And we can
kill the on_dispatch array, just make it a counter.
- Allow a process to go into the current list, if it hasn't been
serviced in this scheduler tick yet.
Possible future improvements including caching the cfqq lookup
in cfq_close_cooperator(), so we don't have to look it up twice.
cfq_get_best_queue() should just use that last decision instead
of doing it again.
When testing the syslet async io approach, I discovered that CFQ
sometimes didn't perform as well as expected. cfq_should_preempt()
needs to better check for cooperating tasks, so fix that by allowing
preemption of an equal priority queue if the recently queued request
is as good a candidate for IO as the one we are currently waiting for.
