commit 71982a409f12c50d011325a4471aa20666bb908d upstream.
/proc/diskstats used to show stats for all disks whether they're
zero-sized or not and their non-zero partitions. Commit
074a7aca7afa6f230104e8e65eba3420263714a5 accidentally changed the
behavior such that it doesn't print out zero sized disks. This patch
implements DISK_PITER_INCL_EMPTY_PART0 flag to partition iterator and
uses it in diskstats_show() such that empty part0 is shown in
/proc/diskstats.
Reported and bisectd by Dianel Collins.
Reported-by: Daniel Collins <solemnwarning@solemnwarning.no-ip.org>
Commit 1e42807918d17e8c93bf14fbb74be84b141334c1 introduced a bug where we
don't get front/back segment sizes in the bio in blk_recount_segments().
Fix this by tracking the back bio as well as the front bio in
__blk_recalc_rq_segments(), this also cleans up the interface by getting
rid of the segment size pointer passing.
Tested-by: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Ingo Molnar <mingo@elte.hu>
blk_recalc_rq_segments() requires a request structure passed in, which
we don't have from blk_recount_segments(). So the latter allocates one on
the stack, using > 400 bytes of stack for that. This can cause us to spill
over one page of stack from ext4 at least:
0) 4560 400 blk_recount_segments+0x43/0x62
1) 4160 32 bio_phys_segments+0x1c/0x24
2) 4128 32 blk_rq_bio_prep+0x2a/0xf9
3) 4096 32 init_request_from_bio+0xf9/0xfe
4) 4064 112 __make_request+0x33c/0x3f6
5) 3952 144 generic_make_request+0x2d1/0x321
6) 3808 64 submit_bio+0xb9/0xc3
7) 3744 48 submit_bh+0xea/0x10e
8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4]
9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4]
10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4]
11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4]
12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4]
13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4]
14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4]
15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4]
16) 1664 32 do_writepages+0x2d/0x3c
17) 1632 144 __writeback_single_inode+0x162/0x2cd
18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b
19) 1392 16 sync_sb_inodes+0xe/0x10
20) 1376 48 writeback_inodes+0x69/0xb3
21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9
22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4
23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393
24) 720 80 generic_file_aio_write+0x6c/0xc8
25) 640 80 ext4_file_write+0xa9/0x137 [ext4]
26) 560 320 do_sync_write+0xf0/0x137
27) 240 48 vfs_write+0xb3/0x13c
28) 192 64 sys_write+0x4c/0x74
29) 128 128 system_call_fastpath+0x16/0x1b
Split the segment counting out into a __blk_recalc_rq_segments() helper
to avoid allocating an onstack request just for checking the physical
segment count.
Add documentation for register_blkdev() function and for the parameters.
Signed-off-by: Márton Németh <nm127@freemail.hu>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
blk_abort_queue() iterates the timeout list and aborts each request on the
list, but if the driver error handling readds a request to the timeout list
during this processing, we could be looping forever. Fix this by splicing
current entries to a local list and run over that list instead.
Hi Tejun,
it looks like your commit:
block: don't depend on consecutive minor space
f331c0296f2a9fee0d396a70598b954062603015
broke a particular case for booting from partitioned md/raid devices.
That is the second time this has been broken recently. The previous
time was fixed by
block: do_mounts - accept root=<non-existant partition>
30f2f0eb4bd2c43d10a8b0d872c6e5ad8f31c9a0
Because the data isn't available when an md device is first created
(we add disks and set it up after creation), the initial partition
scan finds nothing. It is not until the device is opened that
another partition scan happens and finds something.
So at the point where the kernel parameter "root=/dev/md_d0p1" is
being parsed, md_d0 exists, but md_d0p1 does not.
However if we let blk_lookup_devt return the correct device number
even though the device doesn't exist, then the attempt to mount it
will successfully find the partition.
I have tried in the past to find a way to get the partition table to
be read as soon as the array is assembled but that proved impossible
(at the time). I don't remember the details, and could possibly
revisit it. However it would be really nice if blk_lookup_devt
could be adjusted to again accept non existant partitions.
We can't OR shift values, so get rid of BIO_RW_SYNC and use BIO_RW_SYNCIO
and BIO_RW_UNPLUG explicitly. This brings back the behaviour from before
213d9417fec62ef4c3675621b9364a667954d4dd.
When submitting requests via SG_IO, which does a sync io, a
bsg_command is not allocated. So an in-Kernel sense_buffer was not
set. However when calling blk_execute_rq() with no sense buffer
one is provided from the stack. Now bsg at blk_complete_sgv4_hdr_rq()
would check if rq->sense_len and a sense was requested by sg_io_v4
the rq->sense was copy_user() back, but by now it is already mangled
stack memory.
I have fixed that by forcing a sense_buffer when calling bsg_map_hdr().
The bsg_command->sense is provided in the write/read path like before,
and on-the-stack buffer is provided when doing SG_IO.
I have also fixed a dprintk message to print rq->errors in hex because
of the scsi bit-field use of this member. For other block devices it
does not matter anyway.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Some initial probe requests don't have disk->queue mapped yet, so we
can't rely on a non-NULL queue in blk_queue_io_stat(). Wrap it in
blk_do_io_stat().
This patch adds the ability to pre-empt an ongoing BE timeslice when a RT
request is waiting for the current timeslice to complete. This reduces the
wait time to disk for RT requests from an upper bound of 4 (current value
of cfq_quantum) to 1 disk request.
Applied Jens' suggeested changes to avoid the rb lookup and use !cfq_class_rt()
and retested.
Latency(secs) for the RT task when doing sequential reads from 10G file.
| only RT | RT + BE | RT + BE + this patch
small (512 byte) reads | 143 | 163 | 145
large (1Mb) reads | 142 | 158 | 146
Signed-off-by: Divyesh Shah <dpshah@google.com>
This allows us to turn off disk stat accounting completely, for the cases
where the 0.5-1% reduction in system time is important.
This fixes a "regression" from 2.6.28, where the barrier probes that file
systems may do would trigger additional end request warnings in dmesg.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
For some devices (i.e. CFA ATA) we can't reliably detect whether
the device is of rotational or non-rotational type so we need to
leave the final decision about this setting to the user-space.
As a bonus do a minor CodingStyle fixup in queue_nomerges_store().
Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
It can result in a stuck blktrace system, if --kill is used.
Allow a block device to allocate and register an integrity profile
without providing a template. This allows DM to preallocate a profile
to avoid deadlocks during table reconfiguration.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (57 commits)
jbd2: Fix oops in jbd2_journal_init_inode() on corrupted fs
ext4: Remove "extents" mount option
block: Add Kconfig help which notes that ext4 needs CONFIG_LBD
ext4: Make printk's consistently prefixed with "EXT4-fs: "
ext4: Add sanity checks for the superblock before mounting the filesystem
ext4: Add mount option to set kjournald's I/O priority
jbd2: Submit writes to the journal using WRITE_SYNC
jbd2: Add pid and journal device name to the "kjournald2 starting" message
ext4: Add markers for better debuggability
ext4: Remove code to create the journal inode
ext4: provide function to release metadata pages under memory pressure
ext3: provide function to release metadata pages under memory pressure
add releasepage hooks to block devices which can be used by file systems
ext4: Fix s_dirty_blocks_counter if block allocation failed with nodelalloc
ext4: Init the complete page while building buddy cache
ext4: Don't allow new groups to be added during block allocation
ext4: mark the blocks/inode bitmap beyond end of group as used
ext4: Use new buffer_head flag to check uninit group bitmaps initialization
ext4: Fix the race between read_inode_bitmap() and ext4_new_inode()
ext4: code cleanup
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (45 commits)
[SCSI] qla2xxx: Update version number to 8.03.00-k1.
[SCSI] qla2xxx: Add ISP81XX support.
[SCSI] qla2xxx: Use proper request/response queues with MQ instantiations.
[SCSI] qla2xxx: Correct MQ-chain information retrieval during a firmware dump.
[SCSI] qla2xxx: Collapse EFT/FCE copy procedures during a firmware dump.
[SCSI] qla2xxx: Don't pollute kernel logs with ZIO/RIO status messages.
[SCSI] qla2xxx: Don't fallback to interrupt-polling during re-initialization with MSI-X enabled.
[SCSI] qla2xxx: Remove support for reading/writing HW-event-log.
[SCSI] cxgb3i: add missing include
[SCSI] scsi_lib: fix DID_RESET status problems
[SCSI] fc transport: restore missing dev_loss_tmo callback to LLDD
[SCSI] aha152x_cs: Fix regression that keeps driver from using shared interrupts
[SCSI] sd: Correctly handle 6-byte commands with DIX
[SCSI] sd: DIF: Fix tagging on platforms with signed char
[SCSI] sd: DIF: Show app tag on error
[SCSI] Fix error handling for DIF/DIX
[SCSI] scsi_lib: don't decrement busy counters when inserting commands
[SCSI] libsas: fix test for negative unsigned and typos
[SCSI] a2091, gvp11: kill warn_unused_result warnings
[SCSI] fusion: Move a dereference below a NULL test
Fixed up trivial conflict due to moving the async part of sd_probe
around in the async probes vs using dev_set_name() in naming.
Cc: Jens Axboe <jens.axboe@oracle.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The commit 818827669d85b84241696ffef2de485db46b0b5e (block: make
blk_rq_map_user take a NULL user-space buffer) extended
blk_rq_map_user to accept a NULL user-space buffer with a READ
command. It was necessary to convert sg to use the block layer mapping
API.
This patch extends blk_rq_map_user again for a WRITE command. It is
necessary to convert st and osst drivers to use the block layer
apping API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
This fixes bio_copy_user_iov to properly handle the partial mappings
with struct rq_map_data (which only sg uses for now but st and osst
will shortly). It adds the offset member to struct rq_map_data and
changes blk_rq_map_user to update it so that bio_copy_user_iov can add
an appropriate page frame via bio_add_pc_page().
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/x86/kernel/io_apic.c
Original patch from Nikanth Karthikesan <knikanth@suse.de>
When a queue exits the queue lock is taken and cfq_exit_queue() would free all
the cic's associated with the queue.
But when a task exits, cfq_exit_io_context() gets cic one by one and then
locks the associated queue to call __cfq_exit_single_io_context. It looks like
between getting a cic from the ioc and locking the queue, the queue might have
exited on another cpu.
Fix this by rechecking the cfq_io_context queue key inside the queue lock
again, and not calling into __cfq_exit_single_io_context() if somebody
beat us to it.
We have two seperate config entries for large devices/files. One
is CONFIG_LBD that guards just the devices, the other is CONFIG_LSF
that handles large files. This doesn't make a lot of sense, you typically
want both or none. So get rid of CONFIG_LSF and change CONFIG_LBD wording
to indicate that it covers both.
Acked-by: Jean Delvare <khali@linux-fr.org>
Sparse asked whether these could be static.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
zero is invalid for max_phys_segments, max_hw_segments, and
max_segment_size. It's better to use use min_not_zero instead of
min. min() works though (because the commit 0e435ac makes sure that
these values are set to the default values, non zero, if a queue is
initialized properly).
With this patch, blk_queue_stack_limits does the almost same thing
that dm's combine_restrictions_low() does. I think that it's easy to
remove dm's combine_restrictions_low.
disk_map_sector_rcu() returns a partition from a sector offset,
which we use for IO statistics on a per-partition basis. The
lookup itself is an O(N) list lookup, where N is the number of
partitions. This actually hurts performance quite a bit, even
on the lower end partitions. On higher numbered partitions,
it can get pretty bad.
Solve this by adding a one-hit cache for partition lookup.
This makes the lookup O(1) for the case where we do most IO to
one partition. Even for mixed partition workloads, amortized cost
is pretty close to O(1) since the natural IO batching makes the
one-hit cache last for lots of IOs.
This basically limits the hardware queue depth to 4*quantum at any
point in time, which is 16 with the default settings. As CFQ uses
other means to shrink the hardware queue when necessary in the first
place, there's really no need for this extra heuristic. Additionally,
it ends up hurting performance in some cases.
Just use struct elevator_queue everywhere instead.
We just want to hand the first bits of IO to the device as fast
as possible. Gains a few percent on the IOPS rate.
Empty barrier on write-through (or no cache) w/ ordered tag has no
command to execute and without any command to execute ordered tag is
never issued to the device and the ordering is never achieved. Force
draining for such cases.
Empty barrier required special handling in __elv_next_request() to
complete it without letting the low level driver see it.
With previous changes, barrier code is now flexible enough to skip the
BAR step using the same barrier sequence selection mechanism. Drop
the special handling and mask off q->ordered from start_ordered().
Remove blk_empty_barrier() test which now has no user.
Barrier completion had the following assumptions.
* start_ordered() couldn't finish the whole sequence properly. If all
actions are to be skipped, q->ordseq is set correctly but the actual
completion was never triggered thus hanging the barrier request.
* Drain completion in elv_complete_request() assumed that there's
always at least one request in the queue when drain completes.
Both assumptions are true but these assumptions need to be removed to
improve empty barrier implementation. This patch makes the following
changes.
* Make start_ordered() use blk_ordered_complete_seq() to mark skipped
steps complete and notify __elv_next_request() that it should fetch
the next request if the whole barrier has completed inside
start_ordered().
* Make drain completion path in elv_complete_request() check whether
the queue is empty. Empty queue also indicates drain completion.
* While at it, convert 0/1 return from blk_do_ordered() to false/true.
In all barrier sequences, the barrier write itself was always assumed
to be issued and thus didn't have corresponding control flag. This
patch adds QUEUE_ORDERED_DO_BAR and unify action mask handling in
start_ordered() such that any barrier action can be skipped.
This patch doesn't introduce any visible behavior changes.
* Because barrier mode can be changed dynamically, whether barrier is
supported or not can be determined only when actually issuing the
barrier and there is no point in checking it earlier. Drop barrier
support check in generic_make_request() and __make_request(), and
update comment around the support check in blk_do_ordered().
* There is no reason to check discard support in both
generic_make_request() and __make_request(). Drop the check in
__make_request(). While at it, move error action block to the end
of the function and add unlikely() to q existence test.
* Barrier request, be it empty or not, is never passed to low level
driver and thus it's meaningless to try to copy back req->sector to
bio->bi_sector on error. In addition, the notion of failed sector
doesn't make any sense for empty barrier to begin with. Drop the
code block from __end_that_request_first().
Separate out ordering type (drain,) and action masks (preflush,
postflush, fua) from visible ordering mode selectors
(QUEUE_ORDERED_*). Ordering types are now named QUEUE_ORDERED_BY_*
while action masks are named QUEUE_ORDERED_DO_*.
This change is necessary to add QUEUE_ORDERED_DO_BAR and make it
optional to improve empty barrier implementation.
After many improvements on kblockd_flush_work, it is now identical to
cancel_work_sync, so a direct call to cancel_work_sync is suggested.
The only difference is that cancel_work_sync is a GPL symbol,
so no non-GPL modules anymore.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Allow the scsi request REQ_QUIET flag to be propagated to the buffer
file system layer. The basic ideas is to pass the flag from the scsi
request to the bio (block IO) and then to the buffer layer. The buffer
layer can then suppress needless printks.
This patch declutters the kernel log by removed the 40-50 (per lun)
buffer io error messages seen during a boot in my multipath setup . It
is a good chance any real errors will be missed in the "noise" it the
logs without this patch.
During boot I see blocks of messages like
__ratelimit: 211 callbacks suppressed
Buffer I/O error on device sdm, logical block 5242879
Buffer I/O error on device sdm, logical block 5242847
Buffer I/O error on device sdm, logical block 1
Buffer I/O error on device sdm, logical block 5242878
Buffer I/O error on device sdm, logical block 5242872
in my logs.
My disk environment is multipath fiber channel using the SCSI_DH_RDAC
code and multipathd. This topology includes an "active" and "ghost"
path for each lun. IO's to the "ghost" path will never complete and the
SCSI layer, via the scsi device handler rdac code, quick returns the IOs
to theses paths and sets the REQ_QUIET scsi flag to suppress the scsi
layer messages.
I am wanting to extend the QUIET behavior to include the buffer file
system layer to deal with these errors as well. I have been running this
patch for a while now on several boxes without issue. A few runs of
bonnie++ show no noticeable difference in performance in my setup.
Thanks for John Stultz for the quiet_error finalization.
Submitted-by: Keith Mannthey <kmannth@us.ibm.com>
There's no need to take queue_lock or kernel_lock when modifying
bdi->ra_pages. So remove them. Also remove out of date comment for
queue_max_sectors_store().
Signed-off-by: Wu Fengguang <wfg@linux.intel.com>
There is no argument named @tags in blk_init_tags,
remove its' comment.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Convert the timeout ioctl scalling to use the clock_t functions
which are much more accurate with some USER_HZ vs HZ combinations.
Signed-off-by: Milton Miller <miltonm@bga.com>
For sync IO, we'll often do them serialized. This means we'll be touching
the queue timer for every IO, as opposed to only occasionally like we
do for queued IO. Instead of deleting the timer when the last request
is removed, just let continue running. If a new request comes up soon
we then don't have to readd the timer again. If no new requests arrive,
the timer will expire without side effect later.
This improves high iops sync IO by ~1%.
Now the rq->deadline can't be zero if the request is in the
timeout_list, so there is no need to have next_set. There is no need to
access a request's deadline field if blk_rq_timed_out is called on it.
Signed-off-by: Malahal Naineni <malahal@us.ibm.com>
cpu_coregroup_map returned a cpumask_t: it's going away.
(Note, the sched part of this patch won't apply meaningfully to the
sched tree, but I'm posting it to show the goal).
Signed-off-by: Mike Travis <travis@sgi.com>
into tracing/core
include/linux/ftrace.h
There's no point in having too short SG_IO timeouts, since if the
command does end up timing out, we'll end up through the reset sequence
that is several seconds long in order to abort the command that timed
out.
As a result, shorter timeouts than a few seconds simply do not make
sense, as the recovery would be longer than the timeout itself.
Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT.
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Jeff Garzik <jeff@garzik.org>
