In commit 975927b942c932,it add blk_rq_pos to sort rq when flushing.
Although this commit was used for the situation which blk_plug handled
multi devices on the same time like md device.
I think there must be some situations like this but only single
device.
So remove the should_sort judgement.
Because the parameter should_sort is only for this purpose,it can delete
should_sort from blk_plug.
CC: Shaohua Li <shli@kernel.org>
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Switch elevator to use the new hashtable implementation. This reduces the
amount of generic unrelated code in the elevator.
This also removes the dymanic allocation of the hash table. The size of the table is
constant so there's no point in paying the price of an extra dereference when accessing
it.
This patch depends on d9b482c ("hashtable: introduce a small and naive
hashtable") which was merged in v3.6.
Unfortunately, at this point, there's no way to make the existing
statistics hierarchical without creating nasty surprises for the
existing users. Just create recursive counterpart of the existing
stats.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
To support hierarchical stats, it's necessary to remember stats from
dead children. Add cfqg->dead_stats and make a dying cfqg transfer
its stats to the parent's dead-stats.
The transfer happens form ->pd_offline_fn() and it is possible that
there are some residual IOs completing afterwards. Currently, we lose
these stats. Given that cgroup removal isn't a very high frequency
operation and the amount of residual IOs on offline are likely to be
nil or small, this shouldn't be a big deal and the complexity needed
to handle residual IOs - another callback and rather elaborate
synchronization to reach and lock the matching q - doesn't seem
justified.
Separate out cfqg_stats_reset() which takes struct cfqg_stats * from
cfq_pd_reset_stats() and move the latter to where other pd methods are
defined. cfqg_stats_reset() will be used to implement hierarchical
stats.
Instead of holding blkcg->lock while walking ->blkg_list and executing
prfill(), RCU walk ->blkg_list and hold the blkg's queue lock while
executing prfill(). This makes prfill() implementations easier as
stats are mostly protected by queue lock.
This will be used to implement hierarchical stats.
RCU free request_queue so that blkcg_gq->q can be dereferenced under
RCU lock. This will be used to implement hierarchical stats.
Implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge().
The former two collect the [rw]stats designated by the target policy
data and offset from the pd's subtree. The latter two add one
[rw]stat to another.
Note that the recursive sum functions require the queue lock to be
held on entry to make blkg online test reliable. This is necessary to
properly handle stats of a dying blkg.
These will be used to implement hierarchical stats.
Hierarchical stats for cfq-iosched will need __blkg_prfill_rwstat().
Export it.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Rename blkg_rwstat_sum() to blkg_rwstat_total(). sum will be used for
summing up stats from multiple blkgs.
Add two blkcg_policy methods, ->online_pd_fn() and ->offline_pd_fn(),
which are invoked as the policy_data gets activated and deactivated
while holding both blkcg and q locks.
Also, add blkcg_gq->online bool, which is set and cleared as the
blkcg_gq gets activated and deactivated. This flag also is toggled
Add pd->plid so that the policy a pd belongs to can be identified
easily. This will be used to implement hierarchical blkg_[rw]stats.
With the previous two patches, all cfqg scheduling decisions are based
on vfraction and ready for hierarchy support. The only thing which
keeps the behavior flat is cfqg_flat_parent() which makes vfraction
calculation consider all non-root cfqgs children of the root cfqg.
Replace it with cfqg_parent() which returns the real parent. This
enables full blkcg hierarchy support for cfq-iosched. For example,
consider the following hierarchy.
root
A:500 B:250
AA:500 AB:1000
For simplicity, let's say all the leaf nodes have active tasks and are
on service tree. For each leaf node, vfraction would be
AA: (500 / 1500) * (500 / 750) =~ 0.2222
AB: (1000 / 1500) * (500 / 750) =~ 0.4444
B: (250 / 750) =~ 0.3333
and vdisktime will be distributed accordingly. For more detail,
please refer to Documentation/block/cfq-iosched.txt.
v2: cfq-iosched.txt updated to describe group scheduling as suggested
by Vivek.
v3: blkio-controller.txt updated.
cfq_group_slice() calculates slice by taking a fraction of
cfq_target_latency according to the ratio of cfqg->weight against
service_tree->total_weight. This currently works only because all
cfqgs are treated to be at the same level.
To prepare for proper hierarchy support, convert cfq_group_slice() to
base the calculation on cfqg->vfraction. As cfqg->vfraction is always
a fraction of 1 and represents the fraction allocated to the cfqg with
hierarchy considered, the slice can be simply calculated by
multiplying cfqg->vfraction to cfq_target_latency (with fixed point
shift factored in).
As vfraction calculation currently treats all non-root cfqgs as
children of the root cfqg, this patch doesn't introduce noticeable
behavior difference.
Currently, cfqg charges are scaled directly according to cfqg->weight.
Regardless of the number of active cfqgs or the amount of active
weights, a given weight value always scales charge the same way. This
works fine as long as all cfqgs are treated equally regardless of
their positions in the hierarchy, which is what cfq currently
implements. It can't work in hierarchical settings because the
interpretation of a given weight value depends on where the weight is
located in the hierarchy.
This patch reimplements cfqg charge scaling so that it can be used to
support hierarchy properly. The scheme is fairly simple and
light-weight.
* When a cfqg is added to the service tree, v(disktime)weight is
calculated. It walks up the tree to root calculating the fraction
it has in the hierarchy. At each level, the fraction can be
calculated as
cfqg->weight / parent->level_weight
By compounding these, the global fraction of vdisktime the cfqg has
claim to - vfraction - can be determined.
* When the cfqg needs to be charged, the charge is scaled inversely
proportionally to the vfraction.
The new scaling scheme uses the same CFQ_SERVICE_SHIFT for fixed point
representation as before; however, the smallest scaling factor is now
1 (ie. 1 << CFQ_SERVICE_SHIFT). This is different from before where 1
was for CFQ_WEIGHT_DEFAULT and higher weight would result in smaller
scaling factor.
While this shifts the global scale of vdisktime a bit, it doesn't
change the relative relationships among cfqgs and the scheduling
result isn't different.
cfq_group_notify_queue_add uses fixed CFQ_IDLE_DELAY when appending
new cfqg to the service tree. The specific value of CFQ_IDLE_DELAY
didn't have any relevance to vdisktime before and is unlikely to cause
any visible behavior difference now especially as the scale shift
isn't that large.
As the new scheme now makes proper distinction between cfqg->weight
and ->leaf_weight, reverse the weight aliasing for root cfqgs. For
root, both weights are now mapped to ->leaf_weight instead of the
other way around.
Because we're still using cfqg_flat_parent(), this patch shouldn't
change the scheduling behavior in any noticeable way.
v2: Beefed up comments on vfraction as requested by Vivek.
To prepare for blkcg hierarchy support, add cfqg->nr_active and
->children_weight. cfqg->nr_active counts the number of active cfqgs
at the cfqg's level and ->children_weight is sum of weights of those
cfqgs. The level covers itself (cfqg->leaf_weight) and immediate
children.
The two values are updated when a cfqg enters and leaves the group
service tree. Unless the hierarchy is very deep, the added overhead
should be negligible.
Currently, the parent is determined using cfqg_flat_parent() which
makes the root cfqg the parent of all other cfqgs. This is to make
the transition to hierarchy-aware scheduling gradual. Scheduling
logic will be converted to use cfqg->children_weight without actually
changing the behavior. When everything is ready,
blkcg_weight_parent() will be replaced with proper parent function.
This patch doesn't introduce any behavior chagne.
v2: s/cfqg->level_weight/cfqg->children_weight/ as per Vivek.
cfq blkcg is about to grow proper hierarchy handling, where a child
blkg's weight would nest inside the parent's. This makes tasks in a
blkg to compete against both tasks in the sibling blkgs and the tasks
of child blkgs.
We're gonna use the existing weight as the group weight which decides
the blkg's weight against its siblings. This patch introduces a new
weight - leaf_weight - which decides the weight of a blkg against the
child blkgs.
It's named leaf_weight because another way to look at it is that each
internal blkg nodes have a hidden child leaf node which contains all
its tasks and leaf_weight is the weight of the leaf node and handled
the same as the weight of the child blkgs.
This patch only adds leaf_weight fields and exposes it to userland.
The new weight isn't actually used anywhere yet. Note that
cfq-iosched currently offcially supports only single level hierarchy
and root blkgs compete with the first level blkgs - ie. root weight is
basically being used as leaf_weight. For root blkgs, the two weights
are kept in sync for backward compatibility.
v2: cfqd->root_group->leaf_weight initialization was missing from
cfq_init_queue() causing divide by zero when
!CONFIG_CFQ_GROUP_SCHED. Fix it. Reported by Fengguang.
Cc: Fengguang Wu <fengguang.wu@intel.com>
Currently a child blkg (blkcg_gq) can be created even if its parent
doesn't exist. ie. Given a blkg, it's not guaranteed that its
ancestors will exist. This makes it difficult to implement proper
hierarchy support for blkcg policies.
Always create blkgs recursively and make a child blkg hold a reference
to its parent. blkg->parent is added so that finding the parent is
easy. blkcg_parent() is also added in the process.
This change can be visible to userland. e.g. while issuing IO in a
nested cgroup didn't affect the ancestors at all, now it will
initialize all ancestor blkgs and zero stats for the request_queue
will always appear on them. While this is userland visible, this
shouldn't cause any functional difference.
* Rename out_* labels to err_*.
* Do ERR_PTR() conversion once in the error return path.
This patch is cosmetic and to prepare for the hierarchy support.
Reorganize such that
* __blkg_lookup() takes bool param @update_hint to determine whether
to update hint.
* __blkg_lookup_create() no longer performs lookup before trying to
create. Renamed to blkg_create().
* blkg_lookup_create() now performs lookup and then invokes
blkg_create() if lookup fails.
* root_blkg creation in blkcg_activate_policy() updated accordingly.
Note that blkcg_activate_policy() no longer updates lookup hint if
root_blkg already exists.
Except for the last lookup hint bit which is immaterial, this is pure
reorganization and doesn't introduce any visible behavior change.
This is to prepare for proper hierarchy support.
blkg_alloc() was mistakenly checking blkcg_policy_enabled() twice.
The latter test should have been on whether pol->pd_init_fn() exists.
This doesn't cause actual problems because both blkcg policies
implement pol->pd_init_fn(). Fix it.
Currently we attach a character "S" or "A" to the cfqq<pid>, to represent
whether queues is sync or async. Add one more character "N" to represent
whether it is sync-noidle queue or sync queue. So now three different
type of queues will look as follows.
cfq1234S --> sync queus
cfq1234SN --> sync noidle queue
cfq1234A --> Async queue
Previously S/A classification was being printed only if group scheduling
was enabled. This patch also makes sure that this classification is
displayed even if group idling is disabled.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Use of local varibale "n" seems to be unnecessary. Remove it. This brings
it inline with function __cfq_group_st_add(), which is also doing the
similar operation of adding a group to a rb tree.
No functionality change here.
choose_service_tree() selects/sets both wl_class and wl_type. Rename it to
choose_wl_class_and_type() to make it very clear.
cfq_choose_wl() only selects and sets wl_type. It is easy to confuse
it with choose_st(). So rename it to cfq_choose_wl_type() to make
it clear what does it do.
Just renaming. No functionality change.
At quite a few places we use the keyword "service_tree". At some places,
especially local variables, I have abbreviated it to "st".
Also at couple of places moved binary operator "+" from beginning of line
to end of previous line, as per Tejun's feedback.
v2:
Reverted most of the service tree name change based on Jeff Moyer's feedback.
Some more renaming. Again making the code uniform w.r.t use of
wl_class/class to represent IO class (RT, BE, IDLE) and using
wl_type/type to represent subclass (SYNC, SYNC-IDLE, ASYNC).
At places this patch shortens the string "workload" to "wl".
Renamed "saved_workload" to "saved_wl_type". Renamed
"saved_serving_class" to "saved_wl_class".
For uniformity with "saved_wl_*" variables, renamed "serving_class"
to "serving_wl_class" and renamed "serving_type" to "serving_wl_type".
Again, just trying to improve upon code uniformity and improve
readability. No functional change.
v2:
- Restored the usage of keyword "service" based on Jeff Moyer's feedback.
Currently CFQ has three IO classes, RT, BE and IDLE. At many a places we
are calling workloads belonging to these classes as "prio". This gets
very confusing as one starts to associate it with ioprio.
So this patch just does bunch of renaming so that reading code becomes
easier. All reference to RT, BE and IDLE workload are done using keyword
"class" and all references to subclass, SYNC, SYNC-IDLE, ASYNC are made
using keyword "type".
This makes me feel much better while I am reading the code. There is no
functionality change due to this patch.
Acked-by: Tejun Heo <tj@kernel.org>
Remove a race condition which causes a warning in disk_clear_events. This
is a race between disk_clear_events() and disk_flush_events().
ev->clearing will be altered by disk_flush_events() even though we are
blocking event checking through disk_flush_events(). If this happens
after ev->clearing was cleared for disk_clear_events(), this can cause the
WARN_ON_ONCE() in that function to be triggered.
This change also has disk_clear_events() not go through a workqueue.
Since we have to wait for the work to complete, we should just call the
function directly. Also, since this work cannot be put on a freezable
workqueue, it will have to contend with increased demand, so calling the
function directly avoids this.
[akpm@linux-foundation.org: fix spello in comment]
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Cc: Mandeep Singh Baines <msb@chromium.org>
In disk_clear_events, do not put work on system_nrt_freezable_wq.
Instead, put it on system_nrt_wq.
There is a race between probing a usb and suspending the device. Since
probing a usb calls disk_clear_events, which puts work on a frozen
workqueue, probing cannot finish after the workqueue is frozen. However,
suspending cannot finish until the usb probe is finished, so we get a
deadlock, causing the system to reboot.
The way to reproduce this bug is to wake up from suspend with a usb
storage device plugged in, or plugging in a usb storage device right
before suspend. The window of time is on the order of time it takes to
probe the usb device. As long as the workqueues are frozen before the
call to add_disk within sd_probe_async finishes, there will be a deadlock
(which calls blkdev_get, sd_open, check_disk_change, then
disk_clear_events). This is not difficult to reproduce after figuring out
the timings.
[akpm@linux-foundation.org: fix up comment]
Reviewed-by: Mandeep Singh Baines <msb@chromium.org>
Merge misc patches from Andrew Morton:
"Incoming:
- lots of misc stuff
- backlight tree updates
- lib/ updates
- Oleg's percpu-rwsem changes
- checkpatch
- rtc
- aoe
- more checkpoint/restart support
I still have a pile of MM stuff pending - Pekka should be merging
later today after which that is good to go. A number of other things
are twiddling thumbs awaiting maintainer merges."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits)
scatterlist: don't BUG when we can trivially return a proper error.
docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output
fs, fanotify: add @mflags field to fanotify output
docs: add documentation about /proc/<pid>/fdinfo/<fd> output
fs, notify: add procfs fdinfo helper
fs, exportfs: add exportfs_encode_inode_fh() helper
fs, exportfs: escape nil dereference if no s_export_op present
fs, epoll: add procfs fdinfo helper
fs, eventfd: add procfs fdinfo helper
procfs: add ability to plug in auxiliary fdinfo providers
tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test
breakpoint selftests: print failure status instead of cause make error
kcmp selftests: print fail status instead of cause make error
kcmp selftests: make run_tests fix
mem-hotplug selftests: print failure status instead of cause make error
cpu-hotplug selftests: print failure status instead of cause make error
mqueue selftests: print failure status instead of cause make error
vm selftests: print failure status instead of cause make error
ubifs: use prandom_bytes
mtd: nandsim: use prandom_bytes
Currently only block_dev and uprobes use percpu_rw_semaphore,
add the config option selected by BLOCK || UPROBES.
Cc: Anton Arapov <anton@redhat.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Pull block driver update from Jens Axboe:
"Now that the core bits are in, here are the driver bits for 3.8. The
branch contains:
- A huge pile of drbd bits that were dumped from the 3.7 merge
window. Following that, it was both made perfectly clear that
there is going to be no more over-the-wall pulls and how the
situation on individual pulls can be improved.
- A few cleanups from Akinobu Mita for drbd and cciss.
- Queue improvement for loop from Lukas. This grew into adding a
generic interface for waiting/checking an even with a specific
lock, allowing this to be pulled out of md and now loop and drbd is
also using it.
- A few fixes for xen back/front block driver from Roger Pau Monne.
- Partition improvements from Stephen Warren, allowing partiion UUID
to be used as an identifier."
* 'for-3.8/drivers' of git://git.kernel.dk/linux-block: (609 commits)
drbd: update Kconfig to match current dependencies
drbd: Fix drbdsetup wait-connect, wait-sync etc... commands
drbd: close race between drbd_set_role and drbd_connect
drbd: respect no-md-barriers setting also when changed online via disk-options
drbd: Remove obsolete check
drbd: fixup after wait_even_lock_irq() addition to generic code
loop: Limit the number of requests in the bio list
wait: add wait_event_lock_irq() interface
xen-blkfront: free allocated page
xen-blkback: move free persistent grants code
block: partition: msdos: provide UUIDs for partitions
init: reduce PARTUUID min length to 1 from 36
block: store partition_meta_info.uuid as a string
cciss: use check_signature()
cciss: cleanup bitops usage
drbd: use copy_highpage
drbd: if the replication link breaks during handshake, keep retrying
drbd: check return of kmalloc in receive_uuids
drbd: Broadcast sync progress no more often than once per second
drbd: don't try to clear bits once the disk has failed
Pull block layer core updates from Jens Axboe:
"Here are the core block IO bits for 3.8. The branch contains:
- The final version of the surprise device removal fixups from Bart.
- Don't hide EFI partitions under advanced partition types. It's
fairly wide spread these days. This is especially dangerous for
systems that have both msdos and efi partition tables, where you
want to keep them in sync.
- Cleanup of using -1 instead of the proper NUMA_NO_NODE
- Export control of bdi flusher thread CPU mask and default to using
the home node (if known) from Jeff.
- Export unplug tracepoint for MD.
- Core improvements from Shaohua. Reinstate the recursive merge, as
the original bug has been fixed. Add plugging for discard and also
fix a problem handling non pow-of-2 discard limits.
There's a trivial merge in block/blk-exec.c due to a fix that went
into 3.7-rc at a later point than -rc4 where this is based."
* 'for-3.8/core' of git://git.kernel.dk/linux-block:
block: export block_unplug tracepoint
block: add plug for blkdev_issue_discard
block: discard granularity might not be power of 2
deadline: Allow 0ms deadline latency, increase the read speed
partitions: enable EFI/GPT support by default
bsg: Remove unused function bsg_goose_queue()
block: Make blk_cleanup_queue() wait until request_fn finished
block: Avoid scheduling delayed work on a dead queue
block: Avoid that request_fn is invoked on a dead queue
block: Let blk_drain_queue() caller obtain the queue lock
block: Rename queue dead flag
bdi: add a user-tunable cpu_list for the bdi flusher threads
block: use NUMA_NO_NODE instead of -1
block: recursive merge requests
block CFQ: avoid moving request to different queue
This allows stacked devices (like md/raid5) to provide blktrace
tracing, including unplug events.
Signed-off-by: NeilBrown <neilb@suse.de>
Last post of this patch appears lost, so I resend this.
Now discard merge works, add plug for blkdev_issue_discard. This will help
discard request merge especially for raid0 case. In raid0, a big discard
request is split to small requests, and if correct plug is added, such small
requests can be merged in low layer.
Signed-off-by: Shaohua Li <shli@fusionio.com>
In MD raid case, discard granularity might not be power of 2, for example, a
4-disk raid5 has 3*chunk_size discard granularity. Correct the calculation for
such cases.
Reported-by: Neil Brown <neilb@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup changes from Tejun Heo:
"A lot of activities on cgroup side. The big changes are focused on
making cgroup hierarchy handling saner.
- cgroup_rmdir() had peculiar semantics - it allowed cgroup
destruction to be vetoed by individual controllers and tried to
drain refcnt synchronously. The vetoing never worked properly and
caused good deal of contortions in cgroup. memcg was the last
reamining user. Michal Hocko removed the usage and cgroup_rmdir()
path has been simplified significantly. This was done in a
separate branch so that the memcg people can base further memcg
changes on top.
- The above allowed cleaning up cgroup lifecycle management and
implementation of generic cgroup iterators which are used to
improve hierarchy support.
- cgroup_freezer updated to allow migration in and out of a frozen
cgroup and handle hierarchy. If a cgroup is frozen, all descendant
cgroups are frozen.
- netcls_cgroup and netprio_cgroup updated to handle hierarchy
properly.
- Various fixes and cleanups.
- Two merge commits. One to pull in memcg and rmdir cleanups (needed
to build iterators). The other pulled in cgroup/for-3.7-fixes for
device_cgroup fixes so that further device_cgroup patches can be
stacked on top."
Fixed up a trivial conflict in mm/memcontrol.c as per Tejun (due to
commit bea8c150a7 ("memcg: fix hotplugged memory zone oops") in master
touching code close to commit 2ef37d3fe4 ("memcg: Simplify
mem_cgroup_force_empty_list error handling") in for-3.8)
* 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (65 commits)
cgroup: update Documentation/cgroups/00-INDEX
cgroup_rm_file: don't delete the uncreated files
cgroup: remove subsystem files when remounting cgroup
cgroup: use cgroup_addrm_files() in cgroup_clear_directory()
cgroup: warn about broken hierarchies only after css_online
cgroup: list_del_init() on removed events
cgroup: fix lockdep warning for event_control
cgroup: move list add after list head initilization
netprio_cgroup: allow nesting and inherit config on cgroup creation
netprio_cgroup: implement netprio[_set]_prio() helpers
netprio_cgroup: use cgroup->id instead of cgroup_netprio_state->prioidx
netprio_cgroup: reimplement priomap expansion
netprio_cgroup: shorten variable names in extend_netdev_table()
netprio_cgroup: simplify write_priomap()
netcls_cgroup: move config inheritance to ->css_online() and remove .broken_hierarchy marking
cgroup: remove obsolete guarantee from cgroup_task_migrate.
cgroup: add cgroup->id
cgroup, cpuset: remove cgroup_subsys->post_clone()
cgroup: s/CGRP_CLONE_CHILDREN/CGRP_CPUSET_CLONE_CHILDREN/
cgroup: rename ->create/post_create/pre_destroy/destroy() to ->css_alloc/online/offline/free()
Change a timer compare from after to after-equals, thus allowing
0 timeout and making deadline schedule FIFO.
Signed-off-by: xiaobing tu <xiaobing.tu@intel.com>
The Kconfig currently enables MSDOS partitions by default because they
are assumed to be essential, but it's necessary to enable "advanced
partition selection" in order to get GPT support. IMO GPT partitions
are becoming common enought to deserve the same treatment MSDOS
partitions get.
(Side note: I got bit by a disk that had MSDOS and GPT partition
tables, but for some reason the MSDOS table was different from the
GPT one. I was stupid enought to disable "advanced partition
selection" in my .config, which disabled GPT partitioning and made
my btrfs pool unbootable because it couldn't find the partitions)
Signed-off-by: Diego Calleja <diegocg@gmail.com>
The function bsg_goose_queue() does not have any in-tree callers,
so let's remove it.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Some request_fn implementations, e.g. scsi_request_fn(), unlock
the queue lock internally. This may result in multiple threads
executing request_fn for the same queue simultaneously. Keep
track of the number of active request_fn calls and make sure that
blk_cleanup_queue() waits until all active request_fn invocations
have finished. A block driver may start cleaning up resources
needed by its request_fn as soon as blk_cleanup_queue() finished,
so blk_cleanup_queue() must wait for all outstanding request_fn
invocations to finish.
Reported-by: Chanho Min <chanho.min@lge.com>
Cc: James Bottomley <JBottomley@Parallels.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Running a queue must continue after it has been marked dying until
it has been marked dead. So the function blk_run_queue_async() must
not schedule delayed work after blk_cleanup_queue() has marked a queue
dead. Hence add a test for that queue state in blk_run_queue_async()
and make sure that queue_unplugged() invokes that function with the
queue lock held. This avoids that the queue state can change after
it has been tested and before mod_delayed_work() is invoked. Drop
the queue dying test in queue_unplugged() since it is now
superfluous: __blk_run_queue() already tests whether or not the
queue is dead.
A block driver may start cleaning up resources needed by its
request_fn as soon as blk_cleanup_queue() finished, so request_fn
must not be invoked after draining finished. This is important
when blk_run_queue() is invoked without any requests in progress.
As an example, if blk_drain_queue() and scsi_run_queue() run in
parallel, blk_drain_queue() may have finished all requests after
scsi_run_queue() has taken a SCSI device off the starved list but
before that last function has had a chance to run the queue.
Cc: Chanho Min <chanho.min@lge.com>
Let the caller of blk_drain_queue() obtain the queue lock to improve
readability of the patch called "Avoid that request_fn is invoked on
a dead queue".
QUEUE_FLAG_DEAD is used to indicate that queuing new requests must
stop. After this flag has been set queue draining starts. However,
during the queue draining phase it is still safe to invoke the
queue's request_fn, so QUEUE_FLAG_DYING is a better name for this
flag.
This patch has been generated by running the following command
over the kernel source tree:
git grep -lEw 'blk_queue_dead|QUEUE_FLAG_DEAD' |
xargs sed -i.tmp -e 's/blk_queue_dead/blk_queue_dying/g' \
-e 's/QUEUE_FLAG_DEAD/QUEUE_FLAG_DYING/g'; \
sed -i.tmp -e "s/QUEUE_FLAG_DYING$(printf \\t)*5/QUEUE_FLAG_DYING$(printf \\t)5/g" \
include/linux/blkdev.h; \
sed -i.tmp -e 's/ DEAD/ DYING/g' -e 's/dead queue/a dying queue/' \
-e 's/Dead queue/A dying queue/' block/blk-core.c
After we've done __elv_add_request() and __blk_run_queue() in
blk_execute_rq_nowait(), the request might finish and be freed
immediately. Therefore checking if the type is REQ_TYPE_PM_RESUME
isn't safe afterwards, because if it isn't, rq might be gone.
Instead, check beforehand and stash the result in a temporary.
This fixes crashes in blk_execute_rq_nowait() I get occasionally when
running with lots of memory debugging options enabled -- I think this
race is usually harmless because the window for rq to be reallocated
is so small.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Cc: stable@kernel.org
The MSDOS/MBR partition table includes a 32-bit unique ID, often referred
to as the NT disk signature. When combined with a partition number within
the table, this can form a unique ID similar in concept to EFI/GPT's
partition UUID. Constructing and recording this value in struct
partition_meta_info allows MSDOS partitions to be referred to on the
kernel command-line using the following syntax:
root=PARTUUID=0002dd75-01
Cc: Tejun Heo <tj@kernel.org>
Cc: Will Drewry <wad@chromium.org>
Cc: Kay Sievers <kay.sievers@vrfy.org>
This will allow other types of UUID to be stored here, aside from true
UUIDs. This also simplifies code that uses this field, since it's usually
constructed from a, used as a, or compared to other, strings.
Note: A simplistic approach here would be to set uuid_str[36]=0 whenever a
/PARTNROFF option was found to be present. However, this modifies the
input string, and causes subsequent calls to devt_from_partuuid() not to
see the /PARTNROFF option, which causes different results. In order to
avoid misleading future maintainers, this parameter is marked const.
Rename cgroup_subsys css lifetime related callbacks to better describe
what their roles are. Also, update documentation.
Acked-by: Li Zefan <lizefan@huawei.com>
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
Modified by me to cover blk_init_queue() as well.
