[ Upstream commit 25cdb64510644f3e854d502d69c73f21c6df88a9 ]
The WRITE_SAME commands are not present in the blk_default_cmd_filter
write_ok list, and thus are failed with -EPERM when the SG_IO ioctl()
is executed without CAP_SYS_RAWIO capability (e.g., unprivileged users).
[ sg_io() -> blk_fill_sghdr_rq() > blk_verify_command() -> -EPERM ]
The problem can be reproduced with the sg_write_same command
# sg_write_same --num 1 --xferlen 512 /dev/sda
# capsh --drop=cap_sys_rawio -- -c \
'sg_write_same --num 1 --xferlen 512 /dev/sda'
Write same: pass through os error: Operation not permitted
For comparison, the WRITE_VERIFY command does not observe this problem,
since it is in that list:
'sg_write_verify --num 1 --ilen 512 --lba 0 /dev/sda'
So, this patch adds the WRITE_SAME commands to the list, in order
for the SG_IO ioctl to finish successfully:
That case happens to be exercised by QEMU KVM guests with 'scsi-block' devices
(qemu "-device scsi-block" [1], libvirt "<disk type='block' device='lun'>" [2]),
which employs the SG_IO ioctl() and runs as an unprivileged user (libvirt-qemu).
In that scenario, when a filesystem (e.g., ext4) performs its zero-out calls,
which are translated to write-same calls in the guest kernel, and then into
SG_IO ioctls to the host kernel, SCSI I/O errors may be observed in the guest:
[...] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[...] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[...] sd 0:0:0:0: [sda] tag#0 Add. Sense: I/O process terminated
[...] sd 0:0:0:0: [sda] tag#0 CDB: Write Same(10) 41 00 01 04 e0 78 00 00 08 00
[...] blk_update_request: I/O error, dev sda, sector 17096824
Links:
[1] http://git.qemu.org/?p=qemu.git;a=commit;h=336a6915bc7089fb20fea4ba99972ad9a97c5f52
[2] https://libvirt.org/formatdomain.html#elementsDisks (see 'disk' -> 'device')
Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
Signed-off-by: Brahadambal Srinivasan <latha@linux.vnet.ibm.com>
Reported-by: Manjunatha H R <manjuhr1@in.ibm.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit c02ebfdddbafa9a6a0f52fbd715e6bfa229af9d3 upstream.
Commit 0e87e58bf60e ("blk-mq: improve warning for running a queue on the
wrong CPU") attempts to avoid triggering the WARN_ON in
__blk_mq_run_hw_queue when the expected CPU is dead. Problem is, in the
last batch execution before round robin, blk_mq_hctx_next_cpu can
schedule a dead CPU and also update next_cpu to the next alive CPU in
the mask, which will trigger the WARN_ON despite the previous
workaround.
The following patch fixes this scenario by always scheduling the value
in hctx->next_cpu. This changes the moment when we round-robin the CPU
running the hctx, but it really doesn't matter, since it still executes
BLK_MQ_CPU_WORK_BATCH times in a row before switching to another CPU.
Fixes: 0e87e58bf60e ("blk-mq: improve warning for running a queue on the wrong CPU")
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
commit ebc4ff661fbe76781c6b16dfb7b754a5d5073f8e upstream.
cfq_cpd_alloc() which is the cpd_alloc_fn implementation for cfq was
incorrectly hard coding GFP_KERNEL instead of using the mask specified
through the @gfp parameter. This currently doesn't cause any actual
issues because all current callers specify GFP_KERNEL. Fix it.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: e4a9bde9589f ("blkcg: replace blkcg_policy->cpd_size with ->cpd_alloc/free_fn() methods")
commit 128394eff343fc6d2f32172f03e24829539c5835 upstream.
Both damn things interpret userland pointers embedded into the payload;
worse, they are actually traversing those. Leaving aside the bad
API design, this is very much _not_ safe to call with KERNEL_DS.
Bail out early if that happens.
commit bc27c01b5c46d3bfec42c96537c7a3fae0bb2cc4 upstream.
The meaning of the BLK_MQ_S_STOPPED flag is "do not call
.queue_rq()". Hence modify blk_mq_make_request() such that requests
are queued instead of issued if a queue has been stopped.
Reported-by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Ming Lei <tom.leiming@gmail.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
In theory we could map other things, but there's a reason that function
is called "user_iov". Using anything else (like splice can do) just
confuses it.
Reported-and-tested-by: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
If we end up sleeping due to running out of requests, we should
update the hardware and software queues in the map ctx structure.
Otherwise we could end up having rq->mq_ctx point to the pre-sleep
context, and risk corrupting ctx->rq_list since we'll be
grabbing the wrong lock when inserting the request.
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: Chris Mason <clm@fb.com>
Tested-by: Chris Mason <clm@fb.com>
Fixes: 63581af3f31e ("blk-mq: remove non-blocking pass in blk_mq_map_request")
This patch fixes one issue reported by Kent, which can
be triggered in bcachefs over sata disk. Actually it
is a generic issue in block flush vs. blk-tag.
Reported-by: Kent Overstreet <kent.overstreet@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
When bandblocks_set acknowledges a range or badblocks_clear a range,
it's possible all badblocks are acknowledged. We should update
unacked_exist if this occurs.
Signed-off-by: Shaohua Li <shli@fb.com>
Reviewed-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Tested-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Pull block fixes from Jens Axboe:
"A set of fixes that missed the merge window, mostly due to me being
away around that time.
Nothing major here, a mix of nvme cleanups and fixes, and one fix for
the badblocks handling"
* 'for-linus' of git://git.kernel.dk/linux-block:
nvmet: use symbolic constants for CNS values
nvme: use symbolic constants for CNS values
nvme.h: add an enum for cns values
nvme.h: don't use uuid_be
nvme.h: resync with nvme-cli
nvme: Add tertiary number to NVME_VS
nvme : Add sysfs entry for NVMe CMBs when appropriate
nvme: don't schedule multiple resets
nvme: Delete created IO queues on reset
nvme: Stop probing a removed device
badblocks: fix overlapping check for clearing
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc plugins update from Kees Cook:
"This adds a new gcc plugin named "latent_entropy". It is designed to
extract as much possible uncertainty from a running system at boot
time as possible, hoping to capitalize on any possible variation in
CPU operation (due to runtime data differences, hardware differences,
SMP ordering, thermal timing variation, cache behavior, etc).
At the very least, this plugin is a much more comprehensive example
for how to manipulate kernel code using the gcc plugin internals"
* tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
latent_entropy: Mark functions with __latent_entropy
gcc-plugins: Add latent_entropy plugin
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- tracepoints for basic cgroup management operations added
- kernfs and cgroup path formatting functions updated to behave in the
style of strlcpy()
- non-critical bug fixes
* 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
blkcg: Unlock blkcg_pol_mutex only once when cpd == NULL
cgroup: fix error handling regressions in proc_cgroup_show() and cgroup_release_agent()
cpuset: fix error handling regression in proc_cpuset_show()
cgroup: add tracepoints for basic operations
cgroup: make cgroup_path() and friends behave in the style of strlcpy()
kernfs: remove kernfs_path_len()
kernfs: make kernfs_path*() behave in the style of strlcpy()
kernfs: add dummy implementation of kernfs_path_from_node()
Current bad block clear implementation assumes the range to clear
overlaps with at least one bad block already stored. If given range to
clear precedes first bad block in a list, the first entry is incorrectly
updated.
Check not only if stored block end is past clear block end but also if
stored block start is before clear block end.
Signed-off-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Acked-by: NeilBrown <neilb@suse.com>
Make sure that the offset and length arguments that we're using to
construct WRITE SAME and DISCARD requests are actually aligned to the
logical block size. Failure to do this causes other errors in other parts
of the block layer or the SCSI layer because disks don't support partial
logical block writes.
Link: http://lkml.kernel.org/r/147518379026.22791.4437508871355153928.stgit@birch.djwong.org
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Mike Snitzer <snitzer@redhat.com> # tweaked header
Cc: Brian Foster <bfoster@redhat.com>
Patch series "fallocate for block devices", v11.
This is a patchset to fix page cache coherency with BLKZEROOUT and
implement fallocate for block devices.
The first patch is a fix to the existing BLKZEROOUT ioctl to invalidate
the page cache if the zeroing command to the underlying device succeeds.
Without this patch we still have the pagecache coherence bug that's been
in the kernel forever.
The second patch changes the internal block device functions to reject
attempts to discard or zeroout that are not aligned to the logical block
size. Previously, we only checked that the start/len parameters were
512-byte aligned, which caused kernel BUG_ONs for unaligned IOs to 4k-LBA
devices.
The third patch creates an fallocate handler for block devices, wires up
the FALLOC_FL_PUNCH_HOLE flag to zeroing-discard, and connects
FALLOC_FL_ZERO_RANGE to write-same so that we can have a consistent
fallocate interface between files and block devices. It also allows the
combination of PUNCH_HOLE and NO_HIDE_STALE to invoke non-zeroing discard.
Test cases for the new block device fallocate are now in xfstests as
generic/349-351.
This patch (of 3):
Invalidate the page cache (as a regular O_DIRECT write would do) to avoid
returning stale cache contents at a later time.
Link: http://lkml.kernel.org/r/147518378313.22791.16649519283678515021.stgit@birch.djwong.org
The __latent_entropy gcc attribute can be used only on functions and
variables. If it is on a function then the plugin will instrument it for
gathering control-flow entropy. If the attribute is on a variable then
the plugin will initialize it with random contents. The variable must
be an integer, an integer array type or a structure with integer fields.
These specific functions have been selected because they are init
functions (to help gather boot-time entropy), are called at unpredictable
times, or they have variable loops, each of which provide some level of
latent entropy.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
[kees: expanded commit message]
Pull blk-mq CPU hotplug update from Jens Axboe:
"This is the conversion of blk-mq to the new hotplug state machine"
* 'for-4.9/block-smp' of git://git.kernel.dk/linux-block:
blk-mq: fixup "Convert to new hotplug state machine"
blk-mq: Convert to new hotplug state machine
blk-mq/cpu-notif: Convert to new hotplug state machine
Pull blk-mq irq/cpu mapping updates from Jens Axboe:
"This is the block-irq topic branch for 4.9-rc. It's mostly from
Christoph, and it allows drivers to specify their own mappings, and
more importantly, to share the blk-mq mappings with the IRQ affinity
mappings. It's a good step towards making this work better out of the
box"
* 'for-4.9/block-irq' of git://git.kernel.dk/linux-block:
blk_mq: linux/blk-mq.h does not include all the headers it depends on
blk-mq: kill unused blk_mq_create_mq_map()
blk-mq: get rid of the cpumask in struct blk_mq_tags
nvme: remove the post_scan callout
nvme: switch to use pci_alloc_irq_vectors
blk-mq: provide a default queue mapping for PCI device
blk-mq: allow the driver to pass in a queue mapping
blk-mq: remove ->map_queue
blk-mq: only allocate a single mq_map per tag_set
blk-mq: don't redistribute hardware queues on a CPU hotplug event
Pull block layer updates from Jens Axboe:
"This is the main pull request for block layer changes in 4.9.
As mentioned at the last merge window, I've changed things up and now
do just one branch for core block layer changes, and driver changes.
This avoids dependencies between the two branches. Outside of this
main pull request, there are two topical branches coming as well.
This pull request contains:
- A set of fixes, and a conversion to blk-mq, of nbd. From Josef.
- Set of fixes and updates for lightnvm from Matias, Simon, and Arnd.
Followup dependency fix from Geert.
- General fixes from Bart, Baoyou, Guoqing, and Linus W.
- CFQ async write starvation fix from Glauber.
- Add supprot for delayed kick of the requeue list, from Mike.
- Pull out the scalable bitmap code from blk-mq-tag.c and make it
generally available under the name of sbitmap. Only blk-mq-tag uses
it for now, but the blk-mq scheduling bits will use it as well.
From Omar.
- bdev thaw error progagation from Pierre.
- Improve the blk polling statistics, and allow the user to clear
them. From Stephen.
- Set of minor cleanups from Christoph in block/blk-mq.
- Set of cleanups and optimizations from me for block/blk-mq.
- Various nvme/nvmet/nvmeof fixes from the various folks"
* 'for-4.9/block' of git://git.kernel.dk/linux-block: (54 commits)
fs/block_dev.c: return the right error in thaw_bdev()
nvme: Pass pointers, not dma addresses, to nvme_get/set_features()
nvme/scsi: Remove power management support
nvmet: Make dsm number of ranges zero based
nvmet: Use direct IO for writes
admin-cmd: Added smart-log command support.
nvme-fabrics: Add host_traddr options field to host infrastructure
nvme-fabrics: revise host transport option descriptions
nvme-fabrics: rework nvmf_get_address() for variable options
nbd: use BLK_MQ_F_BLOCKING
blkcg: Annotate blkg_hint correctly
cfq: fix starvation of asynchronous writes
blk-mq: add flag for drivers wanting blocking ->queue_rq()
blk-mq: get rid of manual run of queue with __blk_mq_run_hw_queue()
block: export bio_free_pages to other modules
lightnvm: propagate device_add() error code
lightnvm: expose device geometry through sysfs
lightnvm: control life of nvm_dev in driver
blk-mq: register device instead of disk
Pull CPU hotplug updates from Thomas Gleixner:
"Yet another batch of cpu hotplug core updates and conversions:
- Provide core infrastructure for multi instance drivers so the
drivers do not have to keep custom lists.
- Convert custom lists to the new infrastructure. The block-mq custom
list conversion comes through the block tree and makes the diffstat
tip over to more lines removed than added.
- Handle unbalanced hotplug enable/disable calls more gracefully.
- Remove the obsolete CPU_STARTING/DYING notifier support.
- Convert another batch of notifier users.
The relayfs changes which conflicted with the conversion have been
shipped to me by Andrew.
The remaining lot is targeted for 4.10 so that we finally can remove
the rest of the notifiers"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits)
cpufreq: Fix up conversion to hotplug state machine
blk/mq: Reserve hotplug states for block multiqueue
x86/apic/uv: Convert to hotplug state machine
s390/mm/pfault: Convert to hotplug state machine
mips/loongson/smp: Convert to hotplug state machine
mips/octeon/smp: Convert to hotplug state machine
fault-injection/cpu: Convert to hotplug state machine
padata: Convert to hotplug state machine
cpufreq: Convert to hotplug state machine
ACPI/processor: Convert to hotplug state machine
virtio scsi: Convert to hotplug state machine
oprofile/timer: Convert to hotplug state machine
block/softirq: Convert to hotplug state machine
lib/irq_poll: Convert to hotplug state machine
x86/microcode: Convert to hotplug state machine
sh/SH-X3 SMP: Convert to hotplug state machine
ia64/mca: Convert to hotplug state machine
ARM/OMAP/wakeupgen: Convert to hotplug state machine
ARM/shmobile: Convert to hotplug state machine
arm64/FP/SIMD: Convert to hotplug state machine
Unlocking a mutex twice is wrong. Hence modify blkcg_policy_register()
such that blkcg_pol_mutex is unlocked once if cpd == NULL. This patch
avoids that smatch reports the following error:
block/blk-cgroup.c:1378: blkcg_policy_register() error: double unlock 'mutex:&blkcg_pol_mutex'
Fixes: 06b285bd1125 ("blkcg: fix blkcg_policy_data allocation bug")
Cc: Tejun Heo <tj@kernel.org>
Cc: <stable@vger.kernel.org> # v4.2+
This provides the caller a feedback that a given hctx is not mapped and thus
no command can be sent on it.
Tested-by: Steve Wise <swise@opengridcomputing.com>
While debugging timeouts happening in my application workload (ScyllaDB), I have
observed calls to open() taking a long time, ranging everywhere from 2 seconds -
the first ones that are enough to time out my application - to more than 30
seconds.
The problem seems to happen because XFS may block on pending metadata updates
under certain circumnstances, and that's confirmed with the following backtrace
taken by the offcputime tool (iovisor/bcc):
ffffffffb90c57b1 finish_task_switch
ffffffffb97dffb5 schedule
ffffffffb97e310c schedule_timeout
ffffffffb97e1f12 __down
ffffffffb90ea821 down
ffffffffc046a9dc xfs_buf_lock
ffffffffc046abfb _xfs_buf_find
ffffffffc046ae4a xfs_buf_get_map
ffffffffc046babd xfs_buf_read_map
ffffffffc0499931 xfs_trans_read_buf_map
ffffffffc044a561 xfs_da_read_buf
ffffffffc0451390 xfs_dir3_leaf_read.constprop.16
ffffffffc0452b90 xfs_dir2_leaf_lookup_int
ffffffffc0452e0f xfs_dir2_leaf_lookup
ffffffffc044d9d3 xfs_dir_lookup
ffffffffc047d1d9 xfs_lookup
ffffffffc0479e53 xfs_vn_lookup
ffffffffb925347a path_openat
ffffffffb9254a71 do_filp_open
ffffffffb9242a94 do_sys_open
ffffffffb9242b9e sys_open
ffffffffb97e42b2 entry_SYSCALL_64_fastpath
00007fb0698162ed [unknown]
Inspecting my run with blktrace, I can see that the xfsaild kthread exhibit very
high "Dispatch wait" times, on the dozens of seconds range and consistent with
the open() times I have saw in that run.
Still from the blktrace output, we can after searching a bit, identify the
request that wasn't dispatched:
8,0 11 152 81.092472813 804 A WM 141698288 + 8 <- (8,1) 141696240
8,0 11 153 81.092472889 804 Q WM 141698288 + 8 [xfsaild/sda1]
8,0 11 154 81.092473207 804 G WM 141698288 + 8 [xfsaild/sda1]
8,0 11 206 81.092496118 804 I WM 141698288 + 8 ( 22911) [xfsaild/sda1]
<==== 'I' means Inserted (into the IO scheduler) ===================================>
8,0 0 289372 96.718761435 0 D WM 141698288 + 8 (15626265317) [swapper/0]
<==== Only 15s later the CFQ scheduler dispatches the request ======================>
As we can see above, in this particular example CFQ took 15 seconds to dispatch
this request. Going back to the full trace, we can see that the xfsaild queue
had plenty of opportunity to run, and it was selected as the active queue many
times. It would just always be preempted by something else (example):
8,0 1 0 81.117912979 0 m N cfq1618SN / insert_request
8,0 1 0 81.117913419 0 m N cfq1618SN / add_to_rr
8,0 1 0 81.117914044 0 m N cfq1618SN / preempt
8,0 1 0 81.117914398 0 m N cfq767A / slice expired t=1
8,0 1 0 81.117914755 0 m N cfq767A / resid=40
8,0 1 0 81.117915340 0 m N / served: vt=1948520448 min_vt=1948520448
8,0 1 0 81.117915858 0 m N cfq767A / sl_used=1 disp=0 charge=0 iops=1 sect=0
where cfq767 is the xfsaild queue and cfq1618 corresponds to one of the ScyllaDB
IO dispatchers.
The requests preempting the xfsaild queue are synchronous requests. That's a
characteristic of ScyllaDB workloads, as we only ever issue O_DIRECT requests.
While it can be argued that preempting ASYNC requests in favor of SYNC is part
of the CFQ logic, I don't believe that doing so for 15+ seconds is anyone's
goal.
Moreover, unless I am misunderstanding something, that breaks the expectation
set by the "fifo_expire_async" tunable, which in my system is set to the
default.
Looking at the code, it seems to me that the issue is that after we make
an async queue active, there is no guarantee that it will execute any request.
When the queue itself tests if it cfq_may_dispatch() it can bail if it sees SYNC
requests in flight. An incoming request from another queue can also preempt it
in such situation before we have the chance to execute anything (as seen in the
trace above).
This patch sets the must_dispatch flag if we notice that we have requests
that are already fifo_expired. This flag is always cleared after
cfq_dispatch_request() returns from cfq_dispatch_requests(), so it won't pin
the queue for subsequent requests (unless they are themselves expired)
Care is taken during preempt to still allow rt requests to preempt us
regardless.
Testing my workload with this patch applied produces much better results.
From the application side I see no timeouts, and the open() latency histogram
generated by systemtap looks much better, with the worst outlier at 131ms:
Latency histogram of xfs_buf_lock acquisition (microseconds):
value |-------------------------------------------------- count
0 | 11
1 |@@@@ 161
2 |@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 1966
4 |@ 54
8 | 36
16 | 7
32 | 0
64 | 0
1024 | 0
2048 | 0
4096 | 1
8192 | 1
16384 | 2
32768 | 0
65536 | 0
131072 | 1
262144 | 0
524288 | 0
Signed-off-by: Glauber Costa <glauber@scylladb.com>
CC: Jens Axboe <axboe@kernel.dk>
CC: linux-block@vger.kernel.org
CC: linux-kernel@vger.kernel.org
The "blk_mq_queue_reinit_dead()" just cleared the cpumask instead doing
a copy. Since we might never had an online callback we could end up with
a ZERO mask which in turn leads to crash as test robot demonstarted.
Fixes: 65d5291eee66 ("blk-mq: Convert to new hotplug state machine")
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
If a driver sets BLK_MQ_F_BLOCKING, it is allowed to block in its
->queue_rq() handler. For that case, blk-mq ensures that we always
calls it from a safe context.
Tested-by: Josef Bacik <jbacik@fb.com>
bt_get already does a non-blocking pass as well as running the queue
when scheduling internally, no need to duplicate it.
Two cases:
1) blk_mq_alloc_request() needlessly re-runs the queue, after
calling into the tag allocation without NOWAIT set. We don't
need to do that.
2) blk_mq_map_request() should just use blk_mq_run_hw_queue() with
the async flag set to false.
Install the callbacks via the state machine so we can phase out the cpu
hotplug notifiers mess.
Cc: linux-block@vger.kernel.org
Cc: rt@linutronix.de
Cc: Christoph Hellwing <hch@lst.de>
Link: http://lkml.kernel.org/r/20160919212601.180033814@linutronix.de
Replace the block-mq notifier list management with the multi instance
facility in the cpu hotplug state machine.
bio_free_pages is introduced in commit 1dfa0f68c040
("block: add a helper to free bio bounce buffer pages"),
we can reuse the func in other modules after it was
imported.
Cc: Jens Axboe <axboe@fb.com>
Cc: Shaohua Li <shli@fb.com>
Signed-off-by: Guoqing Jiang <gqjiang@suse.com>
Acked-by: Kent Overstreet <kent.overstreet@gmail.com>
Enable devices without a gendisk instance to register itself with blk-mq
and expose the associated multi-queue sysfs entries.
Signed-off-by: Matias Bjørling <m@bjorling.me>
Right now, if slice is expired, we start a new slice. If a bio is
queued, we keep on extending slice by throtle_slice interval (100ms).
This worked well as long as pending timer function got executed with-in
few milli seconds of scheduled time. But looks like with recent changes
in timer subsystem, slack can be much longer depending on the expiry time
of the scheduled timer.
commit 500462a9de65 ("timers: Switch to a non-cascading wheel")
This means, by the time timer function gets executed, it is possible the
delay from scheduled time is more than 100ms. That means current code
will conclude that existing slice has expired and a new one needs to
be started. New slice will be 100ms by default and that will not be
sufficient to meet rate requirement of group given the bio size and
bio will not be dispatched and we will start a new timer function to
wait. And when that timer expires, same process will repeat and we
will wait again and this can easily be an infinite loop.
Solve this issue by starting a new slice only if throttle gropup is
empty. If it is not empty, that means there should be an active slice
going on. Ideally it should not be expired but given the slack, it is
possible that it has expired.
Reported-by: Hou Tao <houtao1@huawei.com>
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Install the callbacks via the state machine.
Link: http://lkml.kernel.org/r/20160906170457.32393-9-bigeasy@linutronix.de
and building block/blk-mq-pci.o should depend on CONFIG_BLOCK
Fixes: 973c4e372c8f ("blk-mq: provide a default queue mapping for PCI device")
In order to get good cache behavior from a sbitmap, we want each CPU to
stick to its own cacheline(s) as much as possible. This might happen
naturally as the bitmap gets filled up and the alloc_hint values spread
out, but we really want this behavior from the start. blk-mq apparently
intended to do this, but the code to do this was never wired up. Get rid
of the dead code and make it part of the sbitmap library.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Again, there's no point in passing this in every time. Make it part of
struct sbitmap_queue and clean up the API.
Allocating your own per-cpu allocation hint separately makes for an
awkward API. Instead, allocate the per-cpu hint as part of the struct
sbitmap_queue. There's no point for a struct sbitmap_queue without the
cache, but you can still use a bare struct sbitmap.
This is a generally useful data structure, so make it available to
anyone else who might want to use it. It's also a nice cleanup
separating the allocation logic from the rest of the tag handling logic.
The code is behind a new Kconfig option, CONFIG_SBITMAP, which is only
selected by CONFIG_BLOCK for now.
This should be a complete noop functionality-wise.
We currently account a '0' dispatch, and anything above that still falls
below the range set by BLK_MQ_MAX_DISPATCH_ORDER. If we dispatch more,
we don't account it.
Change the last bucket to be inclusive of anything above the range we
track, and have the sysfs file reflect that by including a '+' in the
output:
$ cat /sys/block/nvme0n1/mq/0/dispatched
0 1006
1 20229
2 1
4 0
8 0
16 0
32+ 0
Reviewed-by: Omar Sandoval <osandov@fb.com>
Fixes 1b157939f92a ("blk-mq: get rid of the cpumask in struct blk_mq_tags")
Unused now that NVMe sets up irq affinity before calling into blk-mq.
Reviewed-by: Keith Busch <keith.busch@intel.com>
This allows drivers specify their own queue mapping by overriding the
setup-time function that builds the mq_map. This can be used for
example to build the map based on the MSI-X vector mapping provided
by the core interrupt layer for PCI devices.
All drivers use the default, so provide an inline version of it. If we
ever need other queue mapping we can add an optional method back,
although supporting will also require major changes to the queue setup
code.
This provides better code generation, and better debugability as well.
The mapping is identical for all queues in a tag_set, so stop wasting
memory for building multiple. Note that for now I've kept the mq_map
pointer in the request_queue, but we'll need to investigate if we can
remove it without suffering too much from the additional pointer chasing.
The same would apply to the mq_ops pointer as well.
Currently blk-mq will totally remap hardware context when a CPU hotplug
even happened, which causes major havoc for drivers, as they are never
told about this remapping. E.g. any carefully sorted out CPU affinity
will just be completely messed up.
The rebuild also doesn't really help for the common case of cpu
hotplug, which is soft onlining / offlining of cpus - in this case we
should just leave the queue and irq mapping as is. If it actually
worked it would have helped in the case of physical cpu hotplug,
although for that we'd need a way to actually notify the driver.
Note that drivers may already be able to accommodate such a topology
change on their own, e.g. using the reset_controller sysfs file in NVMe
will cause the driver to get things right for this case.
With the rebuild removed we will simplify retain the queue mapping for
a soft offlined CPU that will work when it comes back online, and will
map any newly onlined CPU to queue 0 until the driver initiates
a rebuild of the queue map.
blk_mq_delay_kick_requeue_list() provides the ability to kick the
q->requeue_list after a specified time. To do this the request_queue's
'requeue_work' member was changed to a delayed_work.
blk_mq_delay_kick_requeue_list() allows DM to defer processing requeued
requests while it doesn't make sense to immediately requeue them
(e.g. when all paths in a DM multipath have failed).
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit e1defc4ff0cf57aca6c5e3ff99fa503f5943c1f1
"block: Do away with the notion of hardsect_size"
removed the notion of "hardware sector size" from
the kernel in favor of logical block size, but
references remain in comments and documentation.
Update the remaining sites mentioning hardsect.
Allow the io_poll statistics to be zeroed to make for easier logging
of polling event.
Signed-off-by: Stephen Bates <sbates@raithlin.com>
Acked-by: Christoph Hellwig <hch@lst.de>
In order to help determine the effectiveness of polling in a running
system it is usful to determine the ratio of how often the poll
function is called vs how often the completion is checked. For this
reason we add a poll_considered variable and add it to the sysfs entry
for io_poll.
