path: root/block
2009-04-24cfq-iosched: cache prio_tree root in cfqq->p_rootJens Axboe
Currently we look it up from ->ioprio, but ->ioprio can change if either the process gets its IO priority changed explicitly, or if cfq decides to temporarily boost it. So if we are unlucky, we can end up attempting to remove a node from a different rbtree root than where it was added. Fix this by using ->org_ioprio as the prio_tree index, since that will only change for explicit IO priority settings (not for a boost). Additionally cache the rbtree root inside the cfqq, then we don't have to add code to reinsert the cfqq in the prio_tree if IO priority changes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-24cfq-iosched: fix bug with aliased request and cooperation detectionJens Axboe
cfq_prio_tree_lookup() should return the direct match, yet it always returns zero. Fix that. cfq_prio_tree_add() assumes that we don't get a direct match, while it is very possible that we do. Using O_DIRECT, you can have different cfqq with matching requests, since you don't have the page cache to serialize things for you. Fix this bug by only adding the cfqq if there isn't an existing match. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-24cfq-iosched: clear ->prio_trees[] on cfqd allocJens Axboe
Not strictly needed, but we should make it clear that we init the rbtree roots here. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-24block: fix intermittent dm timeout based oopsHannes Reinecke
Very rarely under stress testing of dm, oopses are occuring as something tampers with an old stack frame. This has been traced back to blk_abort_queue() leaving a timeout_list pointing to the stack. The reason is that sometimes blk_abort_request() won't delete the timer (if the request is marked as complete but before the timer has been removed, a small race window). Fix this by splicing back from the ususally empty list to the q->timeout_list. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-24block: simplify I/O stat accountingJerome Marchand
This simplifies I/O stat accounting switching code and separates it completely from I/O scheduler switch code. Requests are accounted according to the state of their request queue at the time of the request allocation. There is no need anymore to flush the request queue when switching I/O accounting state. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22cfq-iosched: use the default seek distance when there aren't enough seek samplesJeff Moyer
If the cfq io context doesn't have enough samples yet to provide a mean seek distance, then use the default threshold we have for seeky IO instead of defaulting to 0. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22cfq-iosched: make seek_mean converge more quicklyJeff Moyer
Right now, depending on the first sector to which a process issues I/O, the seek time may start out way out of whack. So make sure we start with 0 sectors in seek, instead of the offset of the first request issued. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22block: make blk_abort_queue() ignore non-request based devicesJens Axboe
There's nothing to do for those devices, since the timeout handling is based on requests. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22block: include empty disks in /proc/diskstatsTejun Heo
/proc/diskstats used to show stats for all disks whether they're zero-sized or not and their non-zero partitions. Commit 074a7aca7afa6f230104e8e65eba3420263714a5 accidentally changed the behavior such that it doesn't print out zero sized disks. This patch implements DISK_PITER_INCL_EMPTY_PART0 flag to partition iterator and uses it in diskstats_show() such that empty part0 is shown in /proc/diskstats. Reported and bisectd by Dianel Collins. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Daniel Collins <solemnwarning@solemnwarning.no-ip.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22block: fix queue bounce limit settingTejun Heo
Impact: don't set GFP_DMA in q->bounce_gfp unnecessarily All DMA address limits are expressed in terms of the last addressable unit (byte or page) instead of one plus that. However, when determining bounce_gfp for 64bit machines in blk_queue_bounce_limit(), it compares the specified limit against 0x100000000UL to determine whether it's below 4G ending up falsely setting GFP_DMA in q->bounce_gfp. As DMA zone is very small on x86_64, this makes larger SG_IO transfers very eager to trigger OOM killer. Fix it. While at it, rename the parameter to @dma_mask for clarity and convert comment to proper winged style. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22block: fix SG_IO vector request data length handlingTejun Heo
Impact: fix SG_IO behavior such that it matches the documentation SG_IO howto says that if ->dxfer_len and sum of iovec disagress, the shorter one wins. However, the current implementation returns -EINVAL for such cases. Trim iovc if it's longer than ->dxfer_len. This patch uses iov_*() helpers which take struct iovec * by casting struct sg_iovec * to it. sg_iovec is always identical to iovec and this will be further cleaned up with later patches. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15cfq-iosched: add close cooperator codeJens Axboe
If we have processes that are working in close proximity to each other on disk, we don't want to idle wait. Instead allow the close process to issue a request, getting better aggregate bandwidth. The anticipatory scheduler has similar checks, noop and deadline do not need it since they don't care about process <-> io mappings. The code for CFQ is a little more involved though, since we split request queues into per-process contexts. This fixes a performance problem with eg dump(8), since it uses several processes in some silly attempt to speed IO up. Even if dump(8) isn't really a valid case (it should be fixed by using CLONE_IO), there are other cases where we see close processes and where idling ends up hurting performance. Credit goes to Jeff Moyer <jmoyer@redhat.com> for writing the initial implementation. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15cfq-iosched: log responsible 'cfqq' in idle timer armJens Axboe
Makes it easier to read the traces. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15cfq-iosched: tweak kick logic a bit moreJens Axboe
We only kick the dispatch for an idling queue, if we think it's a (somewhat) fully merged request. Also allow a kick if we have other busy queues in the system, since we don't want to risk waiting for a potential merge in that case. It's better to get some work done and proceed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15cfq-iosched: no need to save interrupts in cfq_kick_queue()Jens Axboe
It's called from the workqueue handlers from process context, so we always have irqs enabled when entered. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15block: Remove code handling bio_alloc failure with __GFP_WAITNikanth Karthikesan
Remove code handling bio_alloc failure with __GFP_WAIT. GFP_KERNEL implies __GFP_WAIT. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15block: fix SG_IO to return a proper error valueFUJITA Tomonori
blk_rq_unmap_user() returns -EFAULT if a program passes an invalid address to kernel. SG_IO path needs to pass the returned value to user space instead of ignoring it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15cfq-iosched: don't delay queue kick for a merged requestJens Axboe
"Zhang, Yanmin" <yanmin_zhang@linux.intel.com> reports that commit b029195dda0129b427c6e579a3bb3ae752da3a93 introduced a regression of about 50% with sequential threaded read workloads. The test case is: tiotest -k0 -k1 -k3 -f 80 -t 32 which starts 32 threads each reading a 80MB file. Twiddle the kick queue logic so that we do start IO immediately, if it appears to be a fully merged request. We can't really detect that, so just check if the request is bigger than a page or not. The assumption is that since single bio issues will first queue a single request with just one page attached and then later do merges on that, if we already have more than a page worth of data in the request, then the request is most likely good to go. Verified that this doesn't cause a regression with the test case that commit b029195dda0129b427c6e579a3bb3ae752da3a93 was fixing. It does not, we still see maximum sized requests for the queue-then-merge cases. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15as-iosched: get rid of private REQ_SYNC/REQ_ASYNC definesJens Axboe
We can just use the block layer BLK_RW_SYNC/ASYNC defines now. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15cfq-iosched: get rid of private SYNC/ASYNC definesJens Axboe
2009-04-15cfq-iosched: use rw_is_sync() to see if rw flags are sync or notJens Axboe
2009-04-15block: fix bad spelling of quiesceJens Axboe
Credit goes to Andrew Morton for spotting this one. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: branch tracer, intel-iommu: fix build with CONFIG_BRANCH_TRACER=y branch tracer: Fix for enabling branch profiling makes sparse unusable ftrace: Correct a text align for event format output Update /debug/tracing/README tracing/ftrace: alloc the started cpumask for the trace file tracing, x86: remove duplicated #include ftrace: Add check of sched_stopped for probe_sched_wakeup function-graph: add proper initialization for init task tracing/ftrace: fix missing include string.h tracing: fix incorrect return type of ns2usecs() tracing: remove CALLER_ADDR2 from wakeup tracer blktrace: fix pdu_len when tracing packet command requests blktrace: small cleanup in blk_msg_write() blktrace: NUL-terminate user space messages tracing: move scripts/trace/power.pl to scripts/tracing/power.pl
2009-04-07Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: loop: mutex already unlocked in loop_clr_fd() cfq-iosched: don't let idling interfere with plugging block: remove unused REQ_UNPLUG cfq-iosched: kill two unused cfqq flags cfq-iosched: change dispatch logic to deal with single requests at the time mflash: initial support cciss: change to discover first memory BAR cciss: kernel scan thread for MSA2012 cciss: fix residual count for block pc requests block: fix inconsistency in I/O stat accounting code block: elevator quiescing helpers
2009-04-07Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_mv: shorten register names sata_mv: workaround errata SATA#13 sata_mv: cosmetic renames sata_mv: workaround errata SATA#26 sata_mv: workaround errata PCI#7 sata_mv: replace 0x1f with ATA_PIO4 (v2) sata_mv: fix irq mask races sata_mv: revert SoC irq breakage libata: ahci enclosure management bios workaround ata: Add TRIM infrastructure ata_piix: VGN-BX297XP wants the controller power up on suspend libata: Remove some redundant casts from pata_octeon_cf.c pata_artop: typo
2009-04-07cfq-iosched: don't let idling interfere with pluggingJens Axboe
When CFQ is waiting for a new request from a process, currently it'll immediately restart queuing when it sees such a request. This doesn't work very well with streamed IO, since we then end up splitting IO that would otherwise have been merged nicely. For a simple dd test, this causes 10x as many requests to be issued as we should have. Normally this goes unnoticed due to the low overhead of requests at the device side, but some hardware is very sensitive to request sizes and there it can cause big slow downs. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: remove unused REQ_UNPLUGJens Axboe
The request inherits the unplug flag from the bio, but it isn't actually used. The bio flag stops at __make_request(), which tells it to unplug after submission. Passing it on to the request doesn't make any sense. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07cfq-iosched: kill two unused cfqq flagsJens Axboe
We only manipulate the must_dispatch and queue_new flags, they are not tested anymore. So get rid of them. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07cfq-iosched: change dispatch logic to deal with single requests at the timeJens Axboe
The IO scheduler core calls into the IO scheduler dispatch_request hook to move requests from the IO scheduler and into the driver dispatch list. It only does so when the dispatch list is empty. CFQ moves several requests to the dispatch list, which can cause higher latencies if we suddenly have to switch to some important sync IO. Change the logic to move one request at the time instead. This should almost be functionally equivalent to what we did before, except that we now honor 'quantum' as the maximum queue depth at the device side from any single cfqq. If there's just a single active cfqq, we allow up to 4 times the normal quantum. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: fix inconsistency in I/O stat accounting codeJerome Marchand
This forces in_flight to be zero when turning off or on the I/O stat accounting and stops updating I/O stats in attempt_merge() when accounting is turned off. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07block: elevator quiescing helpersJens Axboe
Simple helper functions to quiesce the request queue. These are currently only used for switching IO schedulers on-the-fly, but we can use them to properly switch IO accounting on and off as well. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-06pata_artop: typoAlan Cox
Fix a typo (this was in the original patch but was not merged when the code fixes were for some reason) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-06block: Add flag for telling the IO schedulers NOT to anticipate more IOJens Axboe
By default, CFQ will anticipate more IO from a given io context if the previously completed IO was sync. This used to be fine, since the only sync IO was reads and O_DIRECT writes. But with more "normal" sync writes being used now, we don't want to anticipate for those. Add a bio/request flag that informs the IO scheduler that this is a sync request that we should not idle for. Introduce WRITE_ODIRECT specifically for O_DIRECT writes, and make sure that the other sync writes set this flag. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06block: enabling plugging on SSD devices that don't do queuingJens Axboe
For the older SSD devices that don't do command queuing, we do want to enable plugging to get better merging. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06block: change the request allocation/congestion logic to be sync/async basedJens Axboe
This makes sure that we never wait on async IO for sync requests, instead of doing the split on writes vs reads. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: (36 commits) cpumask: remove cpumask allocation from idle_balance, fix numa, cpumask: move numa_node_id default implementation to topology.h, fix cpumask: remove cpumask allocation from idle_balance x86: cpumask: x86 mmio-mod.c use cpumask_var_t for downed_cpus x86: cpumask: update 32-bit APM not to mug current->cpus_allowed x86: microcode: cleanup x86: cpumask: use work_on_cpu in arch/x86/kernel/microcode_core.c cpumask: fix CONFIG_CPUMASK_OFFSTACK=y cpu hotunplug crash numa, cpumask: move numa_node_id default implementation to topology.h cpumask: convert node_to_cpumask_map[] to cpumask_var_t cpumask: remove x86 cpumask_t uses. cpumask: use cpumask_var_t in uv_flush_tlb_others. cpumask: remove cpumask_t assignment from vector_allocation_domain() cpumask: make Xen use the new operators. cpumask: clean up summit's send_IPI functions cpumask: use new cpumask functions throughout x86 x86: unify cpu_callin_mask/cpu_callout_mask/cpu_initialized_mask/cpu_sibling_setup_mask cpumask: convert struct cpuinfo_x86's llc_shared_map to cpumask_var_t cpumask: convert node_to_cpumask_map[] to cpumask_var_t x86: unify 32 and 64-bit node_to_cpumask_map ...
2009-04-03Merge branch 'ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: s390: remove arch specific smp_send_stop() panic: clean up kernel/panic.c panic, smp: provide smp_send_stop() wrapper on UP too panic: decrease oops_in_progress only after having done the panic generic-ipi: eliminate WARN_ON()s during oops/panic generic-ipi: cleanups generic-ipi: remove CSD_FLAG_WAIT generic-ipi: remove kmalloc() generic IPI: simplify barriers and locking
2009-04-03blktrace: fix pdu_len when tracing packet command requestsLi Zefan
Impact: output all of packet commands - not just the first 4 / 8 bytes Since commit d7e3c3249ef23b4617393c69fe464765b4ff1645 ("block: add large command support"), struct request->cmd has been changed from unsinged char cmd[BLK_MAX_CDB] to unsigned char *cmd. v1 -> v2: by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> - make sure rq->cmd_len is always intialized, and then we can use rq->cmd_len instead of BLK_MAX_CDB. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49D4507E.2060602@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-30Merge branch 'linus' into cpumask-for-linusIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c
2009-03-28Merge branch 'percpu-cpumask-x86-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'percpu-cpumask-x86-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (682 commits) percpu: fix spurious alignment WARN in legacy SMP percpu allocator percpu: generalize embedding first chunk setup helper percpu: more flexibility for @dyn_size of pcpu_setup_first_chunk() percpu: make x86 addr <-> pcpu ptr conversion macros generic linker script: define __per_cpu_load on all SMP capable archs x86: UV: remove uv_flush_tlb_others() WARN_ON percpu: finer grained locking to break deadlock and allow atomic free percpu: move fully free chunk reclamation into a work percpu: move chunk area map extension out of area allocation percpu: replace pcpu_realloc() with pcpu_mem_alloc() and pcpu_mem_free() x86, percpu: setup reserved percpu area for x86_64 percpu, module: implement reserved allocation and use it for module percpu variables percpu: add an indirection ptr for chunk page map access x86: make embedding percpu allocator return excessive free space percpu: use negative for auto for pcpu_setup_first_chunk() arguments percpu: improve first chunk initial area map handling percpu: cosmetic renames in pcpu_setup_first_chunk() percpu: clean up percpu constants x86: un-__init fill_pud/pmd/pte x86: remove vestigial fix_ioremap prototypes ... Manually merge conflicts in arch/ia64/kernel/irq_ia64.c
2009-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (119 commits) [SCSI] scsi_dh_rdac: Retry for NOT_READY check condition [SCSI] mpt2sas: make global symbols unique [SCSI] sd: Make revalidate less chatty [SCSI] sd: Try READ CAPACITY 16 first for SBC-2 devices [SCSI] sd: Refactor sd_read_capacity() [SCSI] mpt2sas v00.100.11.15 [SCSI] mpt2sas: add MPT2SAS_MINOR(221) to miscdevice.h [SCSI] ch: Add scsi type modalias [SCSI] 3w-9xxx: add power management support [SCSI] bsg: add linux/types.h include to bsg.h [SCSI] cxgb3i: fix function descriptions [SCSI] libiscsi: fix possbile null ptr session command cleanup [SCSI] iscsi class: remove host no argument from session creation callout [SCSI] libiscsi: pass session failure a session struct [SCSI] iscsi lib: remove qdepth param from iscsi host allocation [SCSI] iscsi lib: have lib create work queue for transmitting IO [SCSI] iscsi class: fix lock dep warning on logout [SCSI] libiscsi: don't cap queue depth in iscsi modules [SCSI] iscsi_tcp: replace scsi_debug/tcp_debug logging with iscsi conn logging [SCSI] libiscsi_tcp: replace tcp_debug/scsi_debug logging with session/conn logging ...
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26bsg: Remove bogus check against request_queue->max_sectorsBoaz Harrosh
bsg submits REQ_TYPE_BLOCK_PC so the right check is max_hw_sectors. But I've removed this check because right after, bsg proceeds with calling blk_rq_map_user() which does all the right checks. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26block: WARN in __blk_put_request() for potential bio leakBoaz Harrosh
Put a WARN_ON in __blk_put_request if it is about to leak bio(s). This is a serious bug that can happen in error handling code paths. For this to work I have fixed a couple of places in block/ where request->bio != NULL ownership was not honored. And a small cleanup at sg_io() while at it. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24bsg: add support for tail queuingBoaz Harrosh
Currently inherited from sg.c bsg will submit asynchronous request at the head-of-the-queue, (using "at_head" set in the call to blk_execute_rq_nowait()). This is bad in situation where the queues are full, requests will execute out of order, and can cause starvation of the first submitted requests. The sg_io_v4->flags member is used and a bit is allocated to denote the Q_AT_TAIL. Zero is to queue at_head as before, to be compatible with old code at the write/read path. SG_IO code path behavior was changed so to be the same as write/read behavior. SG_IO was very rarely used and breaking compatibility with it is OK at this stage. sg_io_hdr at sg.h also has a flags member and uses 3 bits from the first nibble and one bit from the last nibble. Even though none of these bits are supported by bsg, The second nibble is allocated for use by bsg. Just in case. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: get rid of unused blkdev_free_rq() defineJens Axboe
2009-03-24block: remove various blk_queue_*() setting functions in blk_init_queue_node()Jens Axboe
It calls blk_queue_make_request(), which sets the identical set of limits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-13Merge branch 'x86/core' into core/ipiIngo Molnar
