path: root/block
2012-12-06block: Don't access request after it might be freedRoland Dreier
commit 893d290f1d7496db97c9471bc352ad4a11dc8a25 upstream. After we've done __elv_add_request() and __blk_run_queue() in blk_execute_rq_nowait(), the request might finish and be freed immediately. Therefore checking if the type is REQ_TYPE_PM_RESUME isn't safe afterwards, because if it isn't, rq might be gone. Instead, check beforehand and stash the result in a temporary. This fixes crashes in blk_execute_rq_nowait() I get occasionally when running with lots of memory debugging options enabled -- I think this race is usually harmless because the window for rq to be reallocated is so small. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-08-02block: add blk_queue_dead()Tejun Heo
commit 34f6055c80285e4efb3f602a9119db75239744dc upstream. There are a number of QUEUE_FLAG_DEAD tests. Add blk_queue_dead() macro and use it. This patch doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-25scsi: Silence unnecessary warnings about ioctl to partitionJan Kara
commit 6d9359280753d2955f86d6411047516a9431eb51 upstream. Sometimes, warnings about ioctls to partition happen often enough that they form majority of the warnings in the kernel log and users complain. In some cases warnings are about ioctls such as SG_IO so it's not good to get rid of the warnings completely as they can ease debugging of userspace problems when ioctl is refused. Since I have seen warnings from lots of commands, including some proprietary userspace applications, I don't think disallowing the ioctls for processes with CAP_SYS_RAWIO will happen in the near future if ever. So lets just stop warning for processes with CAP_SYS_RAWIO for which ioctl is allowed. CC: Paolo Bonzini <pbonzini@redhat.com> CC: James Bottomley <JBottomley@parallels.com> CC: linux-scsi@vger.kernel.org Acked-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> [bwh: Backported to 3.2: use ENOTTY, not ENOIOCTLCMD] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31block: fix buffer overflow when printing partition UUIDsTejun Heo
commit 05c69d298c96703741cac9a5cbbf6c53bd55a6e2 upstream. 6d1d8050b4bc8 "block, partition: add partition_meta_info to hd_struct" added part_unpack_uuid() which assumes that the passed in buffer has enough space for sprintfing "%pU" - 37 characters including '\0'. Unfortunately, b5af921ec0233 "init: add support for root devices specified by partition UUID" supplied 33 bytes buffer to the function leading to the following panic with stackprotector enabled. Kernel panic - not syncing: stack-protector: Kernel stack corrupted in: ffffffff81b14c7e [<ffffffff815e226b>] panic+0xba/0x1c6 [<ffffffff81b14c7e>] ? printk_all_partitions+0x259/0x26xb [<ffffffff810566bb>] __stack_chk_fail+0x1b/0x20 [<ffffffff81b15c7e>] printk_all_paritions+0x259/0x26xb [<ffffffff81aedfe0>] mount_block_root+0x1bc/0x27f [<ffffffff81aee0fa>] mount_root+0x57/0x5b [<ffffffff81aee23b>] prepare_namespace+0x13d/0x176 [<ffffffff8107eec0>] ? release_tgcred.isra.4+0x330/0x30 [<ffffffff81aedd60>] kernel_init+0x155/0x15a [<ffffffff81087b97>] ? schedule_tail+0x27/0xb0 [<ffffffff815f4d24>] kernel_thread_helper+0x5/0x10 [<ffffffff81aedc0b>] ? start_kernel+0x3c5/0x3c5 [<ffffffff815f4d20>] ? gs_change+0x13/0x13 Increase the buffer size, remove the dangerous part_unpack_uuid() and use snprintf() directly from printk_all_partitions(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Szymon Gruszczynski <sz.gruszczynski@googlemail.com> Cc: Will Drewry <wad@chromium.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-03-19Block: use a freezable workqueue for disk-event pollingAlan Stern
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream. This patch (as1519) fixes a bug in the block layer's disk-events polling. The polling is done by a work routine queued on the system_nrt_wq workqueue. Since that workqueue isn't freezable, the polling continues even in the middle of a system sleep transition. Obviously, polling a suspended drive for media changes and such isn't a good thing to do; in the case of USB mass-storage devices it can lead to real problems requiring device resets and even re-enumeration. The patch fixes things by creating a new system-wide, non-reentrant, freezable workqueue and using it for disk-events polling. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19block: fix __blkdev_get and add_disk race conditionStanislaw Gruszka
commit 9f53d2fe815b4011ff930a7b6db98385d45faa68 upstream. The following situation might occur: __blkdev_get: add_disk: register_disk() get_gendisk() disk_block_events() disk->ev == NULL disk_add_events() __disk_unblock_events() disk->ev != NULL --ev->block Then we unblock events, when they are suppose to be blocked. This can trigger events related block/genhd.c warnings, but also can crash in sd_check_events() or other places. I'm able to reproduce crashes with the following scripts (with connected usb dongle as sdb disk). <snip> DEV=/dev/sdb ENABLE=/sys/bus/usb/devices/1-2/bConfigurationValue function stop_me() { for i in `jobs -p` ; do kill $i 2> /dev/null ; done exit } trap stop_me SIGHUP SIGINT SIGTERM for ((i = 0; i < 10; i++)) ; do while true; do fdisk -l $DEV 2>&1 > /dev/null ; done & done while true ; do echo 1 > $ENABLE sleep 1 echo 0 > $ENABLE done </snip> I use the script to verify patch fixing oops in sd_revalidate_disk http://marc.info/?l=linux-scsi&m=132935572512352&w=2 Without Jun'ichi Nomura patch titled "Fix NULL pointer dereference in sd_revalidate_disk" or this one, script easily crash kernel within a few seconds. With both patches applied I do not observe crash. Unfortunately after some time (dozen of minutes), script will hung in: [ 1563.906432] [<c08354f5>] schedule_timeout_uninterruptible+0x15/0x20 [ 1563.906437] [<c04532d5>] msleep+0x15/0x20 [ 1563.906443] [<c05d60b2>] blk_drain_queue+0x32/0xd0 [ 1563.906447] [<c05d6e00>] blk_cleanup_queue+0xd0/0x170 [ 1563.906454] [<c06d278f>] scsi_free_queue+0x3f/0x60 [ 1563.906459] [<c06d7e6e>] __scsi_remove_device+0x6e/0xb0 [ 1563.906463] [<c06d4aff>] scsi_forget_host+0x4f/0x60 [ 1563.906468] [<c06cd84a>] scsi_remove_host+0x5a/0xf0 [ 1563.906482] [<f7f030fb>] quiesce_and_remove_host+0x5b/0xa0 [usb_storage] [ 1563.906490] [<f7f03203>] usb_stor_disconnect+0x13/0x20 [usb_storage] Anyway I think this patch is some step forward. As drawback, I do not teardown on sysfs file create error, because I do not know how to nullify disk->ev (since it can be used). However add_disk error handling practically does not exist too, and things will work without this sysfs file, except events will not be exported to user space. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12bsg: fix sysfs link remove warningStanislaw Gruszka
commit 37b40adf2d1b4a5e51323be73ccf8ddcf3f15dd3 upstream. We create "bsg" link if q->kobj.sd is not NULL, so remove it only when the same condition is true. Fixes: WARNING: at fs/sysfs/inode.c:323 sysfs_hash_and_remove+0x2b/0x77() sysfs: can not remove 'bsg', no directory Call Trace: [<c0429683>] warn_slowpath_common+0x6a/0x7f [<c0537a68>] ? sysfs_hash_and_remove+0x2b/0x77 [<c042970b>] warn_slowpath_fmt+0x2b/0x2f [<c0537a68>] sysfs_hash_and_remove+0x2b/0x77 [<c053969a>] sysfs_remove_link+0x20/0x23 [<c05d88f1>] bsg_unregister_queue+0x40/0x6d [<c0692263>] __scsi_remove_device+0x31/0x9d [<c069149f>] scsi_forget_host+0x41/0x52 [<c0689fa9>] scsi_remove_host+0x71/0xe0 [<f7de5945>] quiesce_and_remove_host+0x51/0x83 [usb_storage] [<f7de5a1e>] usb_stor_disconnect+0x18/0x22 [usb_storage] [<c06c29de>] usb_unbind_interface+0x4e/0x109 [<c067a80f>] __device_release_driver+0x6b/0xa6 [<c067a861>] device_release_driver+0x17/0x22 [<c067a46a>] bus_remove_device+0xd6/0xe6 [<c06785e2>] device_del+0xf2/0x137 [<c06c101f>] usb_disable_device+0x94/0x1a0 Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25block: fail SCSI passthrough ioctls on partition devicesPaolo Bonzini
commit 0bfc96cb77224736dfa35c3c555d37b3646ef35e upstream. [ Changes with respect to 3.3: return -ENOTTY from scsi_verify_blk_ioctl and -ENOIOCTLCMD from sd_compat_ioctl. ] Linux allows executing the SG_IO ioctl on a partition or LVM volume, and will pass the command to the underlying block device. This is well-known, but it is also a large security problem when (via Unix permissions, ACLs, SELinux or a combination thereof) a program or user needs to be granted access only to part of the disk. This patch lets partitions forward a small set of harmless ioctls; others are logged with printk so that we can see which ioctls are actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred. Of course it was being sent to a (partition on a) hard disk, so it would have failed with ENOTTY and the patch isn't changing anything in practice. Still, I'm treating it specially to avoid spamming the logs. In principle, this restriction should include programs running with CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and /dev/sdb, it still should not be able to read/write outside the boundaries of /dev/sda2 independent of the capabilities. However, for now programs with CAP_SYS_RAWIO will still be allowed to send the ioctls. Their actions will still be logged. This patch does not affect the non-libata IDE driver. That driver however already tests for bd != bd->bd_contains before issuing some ioctl; it could be restricted further to forbid these ioctls even for programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> [ Make it also print the command name when warning - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25block: add and use scsi_blk_cmd_ioctlPaolo Bonzini
commit 577ebb374c78314ac4617242f509e2f5e7156649 upstream. Introduce a wrapper around scsi_cmd_ioctl that takes a block device. The function will then be enhanced to detect partition block devices and, in that case, subject the ioctls to whitelisting. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-29block: fix blk_queue_end_tag()Dan Williams
Commit 5e081591 "block: warn if tag is greater than real_max_depth" cleaned up blk_queue_end_tag() to warn when the tag is truly invalid (greater than real_max_depth). However, it changed behavior in the tag < max_depth case to not end the request. Leading to triggering of BUG_ON(blk_queued_rq(rq)) in the request completion path: http://marc.info/?l=linux-kernel&m=132204370518629&w=2 In order to allow blk_queue_resize_tags() to shrink the tag space blk_queue_end_tag() must always complete tags with a value less than real_max_depth regardless of the current max_depth. The comment about "handling the shrink case" seems to be what prompted changes in this space, so remove it and BUG on all invalid tags (made even simpler by Matthew's suggestion to use an unsigned compare). Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Tao Ma <boyu.mt@taobao.com> Cc: Matthew Wilcox <matthew@wil.cx> Reported-by: Meelis Roos <mroos@ut.ee> Reported-by: Ed Nadolski <edmund.nadolski@intel.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-21block: re-use existing 'reading' variable instead of checking direction againmajianpeng
Signed-off-by: majianpeng <majianpeng@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-16block, cfq: fix empty queue crash caused by request mergeShaohua Li
All requests of a queue could be merged to other requests of other queue. Such queue will not have request in it, but it's in service tree. This will cause kernel oops. I encounter a BUG_ON() in cfq_dispatch_request() with next patch, but the issue should exist without the patch. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-15block: don't kick empty queue in blk_drain_queue()Tejun Heo
While probing, fd sets up queue, probes hardware and tears down the queue if probing fails. In the process, blk_drain_queue() kicks the queue which failed to finish initialization and fd is unhappy about that. floppy0: no floppy controllers found ------------[ cut here ]------------ WARNING: at drivers/block/floppy.c:2929 do_fd_request+0xbf/0xd0() Hardware name: To Be Filled By O.E.M. VFS: do_fd_request called on non-open device Modules linked in: Pid: 1, comm: swapper Not tainted 3.2.0-rc4-00077-g5983fe2 #2 Call Trace: [<ffffffff81039a6a>] warn_slowpath_common+0x7a/0xb0 [<ffffffff81039b41>] warn_slowpath_fmt+0x41/0x50 [<ffffffff813d657f>] do_fd_request+0xbf/0xd0 [<ffffffff81322b95>] blk_drain_queue+0x65/0x80 [<ffffffff81322c93>] blk_cleanup_queue+0xe3/0x1a0 [<ffffffff818a809d>] floppy_init+0xdeb/0xe28 [<ffffffff818a72b2>] ? daring+0x6b/0x6b [<ffffffff810002af>] do_one_initcall+0x3f/0x170 [<ffffffff81884b34>] kernel_init+0x9d/0x11e [<ffffffff810317c2>] ? schedule_tail+0x22/0xa0 [<ffffffff815dbb14>] kernel_thread_helper+0x4/0x10 [<ffffffff81884a97>] ? start_kernel+0x2be/0x2be [<ffffffff815dbb10>] ? gs_change+0xb/0xb Avoid it by making blk_drain_queue() kick queue iff dispatch queue has something on it. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Ralf Hildebrandt <Ralf.Hildebrandt@charite.de> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Tested-by: Sergei Trofimovich <slyich@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-02cfq-iosched: fix cfq_cic_link() race confitionYasuaki Ishimatsu
cfq_cic_link() has race condition. When some processes which shared ioc issue I/O to same block device simultaneously, cfq_cic_link() returns -EEXIST sometimes. The race condition might stop I/O by following steps: step 1: Process A: Issue an I/O to /dev/sda step 2: Process A: Get an ioc (iocA here) in get_io_context() which does not linked with a cic for the device step 3: Process A: Get a new cic for the device (cicA here) in cfq_alloc_io_context() step 4: Process B: Issue an I/O to /dev/sda step 5: Process B: Get iocA in get_io_context() since process A and B share the same ioc step 6: Process B: Get a new cic for the device (cicB here) in cfq_alloc_io_context() since iocA has not been linked with a cic for the device yet step 7: Process A: Link cicA to iocA in cfq_cic_link() step 8: Process A: Dispatch I/O to driver and finish it step 9: Process B: Try to link cicB to iocA in cfq_cic_link() But it fails with showing "cfq: cic link failed!" kernel message, since iocA has already linked with cicA at step 7. step 10: Process B: Wait for finishig I/O in get_request_wait() The function does not wake up, when there is no I/O to the device. When cfq_cic_link() returns -EEXIST, it means ioc has already linked with cic. So when cfq_cic_link() return -EEXIST, retry cfq_cic_lookup(). Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-30cfq-iosched: free cic_index if blkio_alloc_blkg_stats failsmajianpeng
If we fail allocating the blkpg stats, we free cfqd and cfgq. But we need to free the IDA cfqd->cic_index as well. Signed-off-by: majianpeng <majianpeng@gmail.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-23block: initialize request_queue's numa node duringMike Snitzer
struct request_queue is allocated with __GFP_ZERO so its "node" field is zero before initialization. This causes an oops if node 0 is offline in the page allocator because its zonelists are not initialized. From Dave Young's dmesg: SRAT: Node 1 PXM 2 0-d0000000 SRAT: Node 1 PXM 2 100000000-330000000 SRAT: Node 0 PXM 1 330000000-630000000 Initmem setup node 1 0000000000000000-000000000affb000 ... Built 1 zonelists in Node order, mobility grouping on. ... BUG: unable to handle kernel paging request at 0000000000001c08 IP: [<ffffffff8111c355>] __alloc_pages_nodemask+0xb5/0x870 and __alloc_pages_nodemask+0xb5 translates to a NULL pointer on zonelist->_zonerefs. The fix is to initialize q->node at the time of allocation so the correct node is passed to the slab allocator later. Since blk_init_allocated_queue_node() is no longer needed, merge it with blk_init_allocated_queue(). [rientjes@google.com: changelog, initializing q->node] Cc: stable@vger.kernel.org [2.6.37+] Reported-by: Dave Young <dyoung@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: David Rientjes <rientjes@google.com> Tested-by: Dave Young <dyoung@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-16block: add missed trace_block_plugShaohua Li
After flush plug list, the list has no request, so we need to add a trace_block_plug(). Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-16block: avoid unnecessary plug list flushShaohua Li
get_request_wait() could sleep and flush the plug list. If the list is already flushed, don't flush again. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-13block: Always check length of all iov entries in blk_rq_map_user_iov()Ben Hutchings
Even after commit 5478755616ae2ef1ce144dded589b62b2a50d575 ("block: check for proper length of iov entries earlier ...") we still won't check for zero-length entries after an unaligned entry. Remove the break-statement, so all entries are checked. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-10block: Revert "[SCSI] genhd: add a new attribute "alias" in gendisk"Tejun Heo
This reverts commit a72c5e5eb738033938ab30d6a634b74d1d060f10. The commit introduced alias for block devices which is intended to be used during logging although actual usage hasn't been committed yet. This approach adds very limited benefit (raw log might be easier to follow) which can be trivially implemented in userland but has a lot of problems. It is much worse than netif renames because it doesn't rename the actual device but just adds conveninence name which isn't used universally or enforced. Everything internal including device lookup and sysfs still uses the internal name and nothing prevents two devices from using conflicting alias - ie. sda can have sdb as its alias. This has been nacked by people working on device driver core, block layer and kernel-userland interface and shouldn't have been upstreamed. Revert it. http://thread.gmane.org/gmane.linux.kernel/1155104 http://thread.gmane.org/gmane.linux.scsi/68632 http://thread.gmane.org/gmane.linux.scsi/69776 Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Nao Nishijima <nao.nishijima.xt@hitachi.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-04Merge branch 'for-3.2/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.2/drivers' of git://git.kernel.dk/linux-block: (30 commits) virtio-blk: use ida to allocate disk index hpsa: add small delay when using PCI Power Management to reset for kump cciss: add small delay when using PCI Power Management to reset for kump xen/blkback: Fix two races in the handling of barrier requests. xen/blkback: Check for proper operation. xen/blkback: Fix the inhibition to map pages when discarding sector ranges. xen/blkback: Report VBD_WSECT (wr_sect) properly. xen/blkback: Support 'feature-barrier' aka old-style BARRIER requests. xen-blkfront: plug device number leak in xlblk_init() error path xen-blkfront: If no barrier or flush is supported, use invalid operation. xen-blkback: use kzalloc() in favor of kmalloc()+memset() xen-blkback: fixed indentation and comments xen-blkfront: fix a deadlock while handling discard response xen-blkfront: Handle discard requests. xen-blkback: Implement discard requests ('feature-discard') xen-blkfront: add BLKIF_OP_DISCARD and discard request struct drivers/block/loop.c: remove unnecessary bdev argument from loop_clr_fd() drivers/block/loop.c: emit uevent on auto release drivers/block/cpqarray.c: use pci_dev->revision loop: always allow userspace partitions and optionally support automatic scanning ... Fic up trivial header file includsion conflict in drivers/block/loop.c
2011-11-04Merge branch 'for-3.2/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.2/core' of git://git.kernel.dk/linux-block: (29 commits) block: don't call blk_drain_queue() if elevator is not up blk-throttle: use queue_is_locked() instead of lockdep_is_held() blk-throttle: Take blkcg->lock while traversing blkcg->policy_list blk-throttle: Free up policy node associated with deleted rule block: warn if tag is greater than real_max_depth. block: make gendisk hold a reference to its queue blk-flush: move the queue kick into blk-flush: fix invalid BUG_ON in blk_insert_flush block: Remove the control of complete cpu from bio. block: fix a typo in the blk-cgroup.h file block: initialize the bounce pool if high memory may be added later block: fix request_queue lifetime handling by making blk_queue_cleanup() properly shutdown block: drop @tsk from attempt_plug_merge() and explain sync rules block: make get_request[_wait]() fail if queue is dead block: reorganize throtl_get_tg() and blk_throtl_bio() block: reorganize queue draining block: drop unnecessary blk_get/put_queue() in scsi_cmd_ioctl() and blk_get_tg() block: pass around REQ_* flags instead of broken down booleans during request alloc/free block: move blk_throtl prototypes to block/blk.h block: fix genhd refcounting in blkio_policy_parse_and_set() ... Fix up trivial conflicts due to "mddev_t" -> "struct mddev" conversion and making the request functions be of type "void" instead of "int" in - drivers/md/{faulty.c,linear.c,md.c,md.h,multipath.c,raid0.c,raid1.c,raid10.c,raid5.c} - drivers/staging/zram/zram_drv.c
2011-11-03block: don't call blk_drain_queue() if elevator is not upTejun Heo
blk_cleanup_queue() may be called before elevator is set up on a queue which triggers the following oops. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8125a69c>] elv_drain_elevator+0x1c/0x70 ... Pid: 830, comm: kworker/0:2 Not tainted 3.1.0-next-20111025_64+ #1590 Bochs Bochs RIP: 0010:[<ffffffff8125a69c>] [<ffffffff8125a69c>] elv_drain_elevator+0x1c/0x70 ... Call Trace: [<ffffffff8125da92>] blk_drain_queue+0x42/0x70 [<ffffffff8125db90>] blk_cleanup_queue+0xd0/0x1c0 [<ffffffff81469640>] md_free+0x50/0x70 [<ffffffff8126f43b>] kobject_release+0x8b/0x1d0 [<ffffffff81270d56>] kref_put+0x36/0xa0 [<ffffffff8126f2b7>] kobject_put+0x27/0x60 [<ffffffff814693af>] mddev_delayed_delete+0x2f/0x40 [<ffffffff81083450>] process_one_work+0x100/0x3b0 [<ffffffff8108527f>] worker_thread+0x15f/0x3a0 [<ffffffff81089937>] kthread+0x87/0x90 [<ffffffff81621834>] kernel_thread_helper+0x4/0x10 Fix it by making blk_cleanup_queue() check whether q->elevator is set up before invoking blk_drain_queue. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-31block: Change module.h -> export.h in bsg-lib.cPaul Gortmaker
This file isn't using full modular functionality, and hence can be "downgraded" to just using the export.h header. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31block: add export.h to files using EXPORT_SYMBOL/THIS_MODULE macrosPaul Gortmaker
These files were getting <linux/module.h> via an implicit include path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give them the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (204 commits) [SCSI] qla4xxx: export address/port of connection (fix udev disk names) [SCSI] ipr: Fix BUG on adapter dump timeout [SCSI] megaraid_sas: Fix instance access in megasas_reset_timer [SCSI] hpsa: change confusing message to be more clear [SCSI] iscsi class: fix vlan configuration [SCSI] qla4xxx: fix data alignment and use nl helpers [SCSI] iscsi class: fix link local mispelling [SCSI] iscsi class: Replace iscsi_get_next_target_id with IDA [SCSI] aacraid: use lower snprintf() limit [SCSI] lpfc 8.3.27: Change driver version to 8.3.27 [SCSI] lpfc 8.3.27: T10 additions for SLI4 [SCSI] lpfc 8.3.27: Fix queue allocation failure recovery [SCSI] lpfc 8.3.27: Change algorithm for getting physical port name [SCSI] lpfc 8.3.27: Changed worst case mailbox timeout [SCSI] lpfc 8.3.27: Miscellanous logic and interface fixes [SCSI] megaraid_sas: Changelog and version update [SCSI] megaraid_sas: Add driver workaround for PERC5/1068 kdump kernel panic [SCSI] megaraid_sas: Add multiple MSI-X vector/multiple reply queue support [SCSI] megaraid_sas: Add support for MegaRAID 9360/9380 12GB/s controllers [SCSI] megaraid_sas: Clear FUSION_IN_RESET before enabling interrupts ...
2011-10-25blk-throttle: use queue_is_locked() instead of lockdep_is_held()Jens Axboe
We can't use the latter if !CONFIG_LOCKDEP. Reported-by: Sedat Dilek <sedat.dilek@googlemail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-25blk-throttle: Take blkcg->lock while traversing blkcg->policy_listVivek Goyal
blkcg->policy_list is protected by blkcg->lock. Its not rcu protected list. So even for readers, they need to take blkcg->lock. There are few functions which were reading the list without taking lock. Fix it. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-25blk-throttle: Free up policy node associated with deleted ruleVivek Goyal
If a rule is being deleted, free up associated policy node. Otherwise that memory is leaked. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-25block: warn if tag is greater than real_max_depth.Tao Ma
In case tag depth is reduced, it is max_depth not real_max_depth. So we should allow a request with tag >= max_depth, but for a tag >= real_max_depth, there really should be some problem. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24Merge branch 'for-linus' into for-3.2/coreJens Axboe
2011-10-24block: make gendisk hold a reference to its queueTejun Heo
The following command sequence triggers an oops. # mount /dev/sdb1 /mnt # echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete # umount /mnt general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60 ... Call Trace: [<ffffffff810d2845>] lock_acquire+0x95/0x140 [<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50 [<ffffffff811573bc>] bdi_lock_two+0x5c/0x70 [<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0 [<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0 [<ffffffff811c4010>] __blkdev_put+0x160/0x1d0 [<ffffffff811c40df>] blkdev_put+0x5f/0x190 [<ffffffff8118f18d>] kill_block_super+0x4d/0x80 [<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70 [<ffffffff8119003a>] deactivate_super+0x4a/0x70 [<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130 [<ffffffff811acf2e>] sys_umount+0x7e/0x3a0 [<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b This is because bdev holds on to disk but disk doesn't pin the associated queue. If a SCSI device is removed while the device is still open, the sdev puts the base reference to the queue on release. When the bdev is finally released, the associated queue is already gone along with the bdi and bdev_inode_switch_bdi() ends up dereferencing already freed bdi. Even if it were not for this bug, disk not holding onto the associated queue is very unusual and error-prone. Fix it by making add_disk() take an extra reference to its queue and put it on disk_release() and ensuring that disk and its fops owner are put in that order after all accesses to the disk and queue are complete. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24blk-flush: move the queue kick intoJeff Moyer
A dm-multipath user reported[1] a problem when trying to boot a kernel with commit 4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush machinery for stacking drivers with differring flush flags) applied. It turns out that an empty flush request can be sent into blk_insert_flush. When the BUG_ON was fixed to allow for this, I/O on the underlying device would stall. The reason is that blk_insert_cloned_request does not kick the queue. In the aforementioned commit, I had added a special case to kick the queue if data was sent down but the queue flags did not require a flush. A better solution is to push the queue kick up into blk_insert_cloned_request. This patch, along with a follow-on which fixes the BUG_ON, fixes the issue reported. [1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html Reported-by: Christophe Saout <christophe@saout.de> Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Stable note: 3.1 Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24blk-flush: fix invalid BUG_ON in blk_insert_flushJeff Moyer
A user reported a regression due to commit 4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush machinery for stacking drivers with differring flush flags). Part of the problem is that blk_insert_flush required a single bio be attached to the request. In reality, having no attached bio is also a valid case, as can be observed with an empty flush. [1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html Reported-by: Christophe Saout <christophe@saout.de> Signed-off-by: Jeff Moyer <jmoyer@redhat.com Acked-by: Tejun Heo <tj@kernel.org> Stable note: 3.1 Cc: stable@vger.kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24block: Remove the control of complete cpu from bio.Tao Ma
bio originally has the functionality to set the complete cpu, but it is broken. Chirstoph said that "This code is unused, and from the all the discussions lately pretty obviously broken. The only thing keeping it serves is creating more confusion and possibly more bugs." And Jens replied with "We can kill bio_set_completion_cpu(). I'm fine with leaving cpu control to the request based drivers, they are the only ones that can toggle the setting anyway". So this patch tries to remove all the work of controling complete cpu from a bio. Cc: Shaohua Li <shaohua.li@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24block: fix a typo in the blk-cgroup.h fileJie Liu
byptes -> bytes. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: fix request_queue lifetime handling by making blk_queue_cleanup() ↵Tejun Heo
properly shutdown request_queue is refcounted but actually depdends on lifetime management from the queue owner - on blk_cleanup_queue(), block layer expects that there's no request passing through request_queue and no new one will. This is fundamentally broken. The queue owner (e.g. SCSI layer) doesn't have a way to know whether there are other active users before calling blk_cleanup_queue() and other users (e.g. bsg) don't have any guarantee that the queue is and would stay valid while it's holding a reference. With delay added in blk_queue_bio() before queue_lock is grabbed, the following oops can be easily triggered when a device is removed with in-flight IOs. sd 0:0:1:0: [sdb] Stopping disk ata1.01: disabled general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: Pid: 648, comm: test_rawio Not tainted 3.1.0-rc3-work+ #56 Bochs Bochs RIP: 0010:[<ffffffff8137d651>] [<ffffffff8137d651>] elv_rqhash_find+0x61/0x100 ... Process test_rawio (pid: 648, threadinfo ffff880019efa000, task ffff880019ef8a80) ... Call Trace: [<ffffffff8137d774>] elv_merge+0x84/0xe0 [<ffffffff81385b54>] blk_queue_bio+0xf4/0x400 [<ffffffff813838ea>] generic_make_request+0xca/0x100 [<ffffffff81383994>] submit_bio+0x74/0x100 [<ffffffff811c53ec>] dio_bio_submit+0xbc/0xc0 [<ffffffff811c610e>] __blockdev_direct_IO+0x92e/0xb40 [<ffffffff811c39f7>] blkdev_direct_IO+0x57/0x60 [<ffffffff8113b1c5>] generic_file_aio_read+0x6d5/0x760 [<ffffffff8118c1ca>] do_sync_read+0xda/0x120 [<ffffffff8118ce55>] vfs_read+0xc5/0x180 [<ffffffff8118cfaa>] sys_pread64+0x9a/0xb0 [<ffffffff81afaf6b>] system_call_fastpath+0x16/0x1b This happens because blk_queue_cleanup() destroys the queue and elevator whether IOs are in progress or not and DEAD tests are sprinkled in the request processing path without proper synchronization. Similar problem exists for blk-throtl. On queue cleanup, blk-throtl is shutdown whether it has requests in it or not. Depending on timing, it either oopses or throttled bios are lost putting tasks which are waiting for bio completion into eternal D state. The way it should work is having the usual clear distinction between shutdown and release. Shutdown drains all currently pending requests, marks the queue dead, and performs partial teardown of the now unnecessary part of the queue. Even after shutdown is complete, reference holders are still allowed to issue requests to the queue although they will be immmediately failed. The rest of teardown happens on release. This patch makes the following changes to make blk_queue_cleanup() behave as proper shutdown. * QUEUE_FLAG_DEAD is now set while holding both q->exit_mutex and queue_lock. * Unsynchronized DEAD check in generic_make_request_checks() removed. This couldn't make any meaningful difference as the queue could die after the check. * blk_drain_queue() updated such that it can drain all requests and is now called during cleanup. * blk_throtl updated such that it checks DEAD on grabbing queue_lock, drains all throttled bios during cleanup and free td when queue is released. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: drop @tsk from attempt_plug_merge() and explain sync rulesTejun Heo
attempt_plug_merge() accesses elevator without holding queue_lock and may call into ->elevator_bio_merge_fn(). The elvator is guaranteed to be valid because it's accessed iff the plugged list has requests and elevator is never exited with live requests, so as long as the elevator method can deal with unlocked access, this is safe. Explain the sync rules around attempt_plug_merge() and drop the unnecessary @tsk parameter. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: make get_request[_wait]() fail if queue is deadTejun Heo
Currently get_request[_wait]() allocates request whether queue is dead or not. This patch makes get_request[_wait]() return NULL if @q is dead. blk_queue_bio() is updated to fail the submitted bio if request allocation fails. While at it, add docbook comments for get_request[_wait](). Note that the current code has rather unclear (there are spurious DEAD tests scattered around) assumption that the owner of a queue guarantees that no request travels block layer if the queue is dead and this patch in itself doesn't change much; however, this will allow fixing the broken assumption in the next patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: reorganize throtl_get_tg() and blk_throtl_bio()Tejun Heo
blk_throtl_bio() and throtl_get_tg() have rather unusual interface. * throtl_get_tg() returns pointer to a valid tg or ERR_PTR(-ENODEV), and drops queue_lock in the latter case. Different locking context depending on return value is error-prone and DEAD state is scheduled to be protected by queue_lock anyway. Move DEAD check inside queue_lock and return valid tg or NULL. * blk_throtl_bio() indicates return status both with its return value and in/out param **@bio. The former is used to indicate whether queue is found to be dead during throtl processing. The latter whether the bio is throttled. There's no point in returning DEAD check result from blk_throtl_bio(). The queue can die after blk_throtl_bio() is finished but before make_request_fn() grabs queue lock. Make it take *@bio instead and return boolean result indicating whether the request is throttled or not. This patch doesn't cause any visible functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: reorganize queue drainingTejun Heo
Reorganize queue draining related code in preparation of queue exit changes. * Factor out actual draining from elv_quiesce_start() to blk_drain_queue(). * Make elv_quiesce_start/end() responsible for their own locking. * Replace open-coded ELVSWITCH clearing in elevator_switch() with elv_quiesce_end(). This patch doesn't cause any visible functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: drop unnecessary blk_get/put_queue() in scsi_cmd_ioctl() and blk_get_tg()Tejun Heo
blk_get/put_queue() in scsi_cmd_ioctl() and throtl_get_tg() are completely bogus. The caller must have a reference to the queue on entry and taking an extra reference doesn't change anything. For scsi_cmd_ioctl(), the only effect is that it ends up checking QUEUE_FLAG_DEAD on entry; however, this is bogus as queue can die right after blk_get_queue(). Dead queue should be and is handled in request issue path (it's somewhat broken now but that's a separate problem and doesn't affect this one much). throtl_get_tg() incorrectly assumes that q is rcu freed. Also, it doesn't check return value of blk_get_queue(). If the queue is already dead, it ends up doing an extra put. Drop them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: pass around REQ_* flags instead of broken down booleans during ↵Tejun Heo
request alloc/free blk_alloc_request() and freed_request() take different combinations of REQ_* @flags, @priv and @is_sync when @flags is superset of the latter two. Make them take @flags only. This cleans up the code a bit and will ease updating allocation related REQ_* flags. This patch doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: move blk_throtl prototypes to block/blk.hTejun Heo
blk_throtl interface is block internal and there's no reason to have them in linux/blkdev.h. Move them to block/blk.h. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: fix genhd refcounting in blkio_policy_parse_and_set()Tejun Heo
blkio_policy_parse_and_set() calls blkio_check_dev_num() to check whether the given dev_t is valid. blkio_check_dev_num() uses get_gendisk() for verification but never puts the returned genhd leaking the reference. This patch collapses blkio_check_dev_num() into its caller and updates it such that the genhd is put before returning. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19block: make gendisk hold a reference to its queueTejun Heo
The following command sequence triggers an oops. # mount /dev/sdb1 /mnt # echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete # umount /mnt general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60 ... Call Trace: [<ffffffff810d2845>] lock_acquire+0x95/0x140 [<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50 [<ffffffff811573bc>] bdi_lock_two+0x5c/0x70 [<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0 [<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0 [<ffffffff811c4010>] __blkdev_put+0x160/0x1d0 [<ffffffff811c40df>] blkdev_put+0x5f/0x190 [<ffffffff8118f18d>] kill_block_super+0x4d/0x80 [<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70 [<ffffffff8119003a>] deactivate_super+0x4a/0x70 [<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130 [<ffffffff811acf2e>] sys_umount+0x7e/0x3a0 [<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b This is because bdev holds on to disk but disk doesn't pin the associated queue. If a SCSI device is removed while the device is still open, the sdev puts the base reference to the queue on release. When the bdev is finally released, the associated queue is already gone along with the bdi and bdev_inode_switch_bdi() ends up dereferencing already freed bdi. Even if it were not for this bug, disk not holding onto the associated queue is very unusual and error-prone. Fix it by making add_disk() take an extra reference to its queue and put it on disk_release() and ensuring that disk and its fops owner are put in that order after all accesses to the disk and queue are complete. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-19Merge branch 'v3.1-rc10' into for-3.2/coreJens Axboe
Conflicts: block/blk-core.c include/linux/blkdev.h Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-09-28block: Free queue resources at blk_release_queue()Hannes Reinecke
A kernel crash is observed when a mounted ext3/ext4 filesystem is physically removed. The problem is that blk_cleanup_queue() frees up some resources eg by calling elevator_exit(), which are not checked for in normal operation. So we should rather move these calls to the destructor function blk_release_queue() as at that point all remaining references are gone. However, in doing so we have to ensure that any externally supplied queue_lock is disconnected as the driver might free up the lock after the call of blk_cleanup_queue(), Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-09-21blk-cgroup: be able to remove the record of unplugged deviceWanlong Gao
The bug is we're not able to remove the device from blkio cgroup's per-device control files if it gets unplugged. To reproduce the bug: # mount -t cgroup -o blkio xxx /cgroup # cd /cgroup # echo "8:0 1000" > blkio.throttle.read_bps_device # unplug the device # cat blkio.throttle.read_bps_device 8:0 1000 # echo "8:0 0" > blkio.throttle.read_bps_device -bash: echo: write error: No such device After patching, the device removal will succeed. Thanks for the comments of Paul, Zefan, and Vivek. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
