[ Upstream commit 14cb2c8a6c5dae57ee3e2da10fa3db2b9087e39e ]
The if-block that sets a successful return value in aix_partition()
uses 'lvip[].pps_per_lv' and 'n[].name' potentially uninitialized.
For example, if 'numlvs' is zero or alloc_lvn() fails, neither is
initialized, but are used anyway if alloc_pvd() succeeds after it.
So, make the alloc_pvd() call conditional on their initialization.
This has been hit when attaching an apparently corrupted/stressed
AIX LUN, misleading the kernel to pr_warn() invalid data and hang.
[...] partition (null) (11 pp's found) is not contiguous
[...] partition (null) (2 pp's found) is not contiguous
[...] partition (null) (3 pp's found) is not contiguous
[...] partition (null) (64 pp's found) is not contiguous
Fixes: 6ceea22bbbc8 ("partitions: add aix lvm partition support files")
Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com>
[ Upstream commit d43fdae7bac2def8c4314b5a49822cb7f08a45f1 ]
Even if properly initialized, the lvname array (i.e., strings)
is read from disk, and might contain corrupt data (e.g., lack
the null terminating character for strings).
So, make sure the partition name string used in pr_warn() has
the null terminating character.
Suggested-by: Daniel J. Axtens <daniel.axtens@canonical.com>
commit e00f4f4d0ff7e13b9115428a245b49108d625f09 upstream.
blkcg allocates some per-cgroup data structures with GFP_NOWAIT and
when that fails falls back to operations which aren't specific to the
cgroup. Occassional failures are expected under pressure and falling
back to non-cgroup operation is the right thing to do.
Unfortunately, I forgot to add __GFP_NOWARN to these allocations and
these expected failures end up creating a lot of noise. Add
__GFP_NOWARN.
Reported-by: Marc MERLIN <marc@merlins.org>
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Jens Axboe <axboe@fb.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit b3193bc0dca9bb69c8ba1ec1a318105c76eb4172 upstream.
In below scenario blkio cgroup does not work as per their assigned
weights :-
1. When the underlying device is nonrotational with a single HW queue
with depth of >= CFQ_HW_QUEUE_MIN
2. When the use case is forming two blkio cgroups cg1(weight 1000) &
cg2(wight 100) and two processes(file1 and file2) doing sync IO in
their respective blkio cgroups.
For above usecase result of fio (without this patch):-
file1: (groupid=0, jobs=1): err= 0: pid=685: Thu Jan 1 19:41:49 1970
write: IOPS=1315, BW=41.1MiB/s (43.1MB/s)(1024MiB/24906msec)
file2: (groupid=0, jobs=1): err= 0: pid=686: Thu Jan 1 19:41:49 1970
write: IOPS=1295, BW=40.5MiB/s (42.5MB/s)(1024MiB/25293msec)
// both the process BW is equal even though they belong to diff.
cgroups with weight of 1000(cg1) and 100(cg2)
In above case (for non rotational NCQ devices),
as soon as the request from cg1 is completed and even
though it is provided with higher set_slice=10, because of CFQ
algorithm when the driver tries to fetch the request, CFQ expires
this group without providing any idle time nor weight priority
and schedules another cfq group (in this case cg2).
And thus both cfq groups(cg1 & cg2) keep alternating to get the
disk time and hence loses the cgroup weight based scheduling.
Below patch gives a chance to cfq algorithm (cfq_arm_slice_timer)
to arm the slice timer in case group_idle is enabled.
In case if group_idle is also not required (including for nonrotational
NCQ drives), we need to explicitly set group_idle = 0 from sysfs for
such cases.
With this patch result of fio(for above usecase) :-
file1: (groupid=0, jobs=1): err= 0: pid=690: Thu Jan 1 00:06:08 1970
write: IOPS=1706, BW=53.3MiB/s (55.9MB/s)(1024MiB/19197msec)
file2: (groupid=0, jobs=1): err= 0: pid=691: Thu Jan 1 00:06:08 1970
write: IOPS=1043, BW=32.6MiB/s (34.2MB/s)(1024MiB/31401msec)
// In this processes BW is as per their respective cgroups weight.
Signed-off-by: Ritesh Harjani <riteshh@codeaurora.org>
[ Upstream commit d6c02a9beb67f13d5f14f23e72fa9981e8b84477 ]
In commit ed996a52c868 ("block: simplify and cleanup bvec pool
handling"), the value of the slab index is incremented by one in
bvec_alloc() after the allocation is done to indicate an index value of
0 does not need to be later freed.
bvec_nr_vecs() was not updated accordingly, and thus returns the wrong
value. Decrement idx before performing the lookup.
Fixes: ed996a52c868 ("block: simplify and cleanup bvec pool handling")
Signed-off-by: Greg Edwards <gedwards@ddn.com>
commit 1dc3039bc87ae7d19a990c3ee71cfd8a9068f428 upstream.
When blk_queue_enter() waits for a queue to unfreeze, or unset the
PREEMPT_ONLY flag, do not allow it to be interrupted by a signal.
The PREEMPT_ONLY flag was introduced later in commit 3a0a529971ec
("block, scsi: Make SCSI quiesce and resume work reliably"). Note the SCSI
device is resumed asynchronously, i.e. after un-freezing userspace tasks.
So that commit exposed the bug as a regression in v4.15. A mysterious
SIGBUS (or -EIO) sometimes happened during the time the device was being
resumed. Most frequently, there was no kernel log message, and we saw Xorg
or Xwayland killed by SIGBUS.[1]
[1] E.g. https://bugzilla.redhat.com/show_bug.cgi?id=1553979
Without this fix, I get an IO error in this test:
# dd if=/dev/sda of=/dev/null iflag=direct & \
while killall -SIGUSR1 dd; do sleep 0.1; done & \
echo mem > /sys/power/state ; \
sleep 5; killall dd # stop after 5 seconds
The interruptible wait was added to blk_queue_enter in
commit 3ef28e83ab15 ("block: generic request_queue reference counting").
Before then, the interruptible wait was only in blk-mq, but I don't think
it could ever have been correct.
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: stable@vger.kernel.org
Signed-off-by: Alan Jenkins <alan.christopher.jenkins@gmail.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 51d638b1f56a0bfd9219800620994794a1a2b219 upstream.
This can be triggered by hot-unplug one cpu.
[ INFO: possible circular locking dependency detected ]
4.11.0+ #17 Not tainted
step_after_susp/2640 is trying to acquire lock:
(all_q_mutex){+.+...}, at: [<ffffffffb33f95b8>] blk_mq_queue_reinit_work+0x18/0x110
but task is already holding lock:
(cpu_hotplug.lock){+.+.+.}, at: [<ffffffffb306d04f>] cpu_hotplug_begin+0x7f/0xe0
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (cpu_hotplug.lock){+.+.+.}:
lock_acquire+0x11c/0x230
__mutex_lock+0x92/0x990
mutex_lock_nested+0x1b/0x20
get_online_cpus+0x64/0x80
blk_mq_init_allocated_queue+0x3a0/0x4e0
blk_mq_init_queue+0x3a/0x60
loop_add+0xe5/0x280
loop_init+0x124/0x177
do_one_initcall+0x53/0x1c0
kernel_init_freeable+0x1e3/0x27f
kernel_init+0xe/0x100
ret_from_fork+0x31/0x40
-> #0 (all_q_mutex){+.+...}:
__lock_acquire+0x189a/0x18a0
blk_mq_queue_reinit_dead+0x1c/0x20
cpuhp_invoke_callback+0x1f2/0x810
cpuhp_down_callbacks+0x42/0x80
_cpu_down+0xb2/0xe0
freeze_secondary_cpus+0xb6/0x390
suspend_devices_and_enter+0x3b3/0xa40
pm_suspend+0x129/0x490
state_store+0x82/0xf0
kobj_attr_store+0xf/0x20
sysfs_kf_write+0x45/0x60
kernfs_fop_write+0x135/0x1c0
__vfs_write+0x37/0x160
vfs_write+0xcd/0x1d0
SyS_write+0x58/0xc0
do_syscall_64+0x8f/0x710
return_from_SYSCALL_64+0x0/0x7a
Possible unsafe locking scenario:
CPU0 CPU1
lock(cpu_hotplug.lock);
lock(all_q_mutex);
lock(all_q_mutex);
*** DEADLOCK ***
8 locks held by step_after_susp/2640:
#0: (sb_writers#6){.+.+.+}, at: [<ffffffffb3244aed>] vfs_write+0x1ad/0x1d0
#1: (&of->mutex){+.+.+.}, at: [<ffffffffb32d3a51>] kernfs_fop_write+0x101/0x1c0
#2: (s_active#166){.+.+.+}, at: [<ffffffffb32d3a59>] kernfs_fop_write+0x109/0x1c0
#3: (pm_mutex){+.+...}, at: [<ffffffffb30d2ecd>] pm_suspend+0x21d/0x490
#4: (acpi_scan_lock){+.+.+.}, at: [<ffffffffb34dc3d7>] acpi_scan_lock_acquire+0x17/0x20
#5: (cpu_add_remove_lock){+.+.+.}, at: [<ffffffffb306d6d7>] freeze_secondary_cpus+0x27/0x390
#6: (cpu_hotplug.dep_map){++++++}, at: [<ffffffffb306cfd5>] cpu_hotplug_begin+0x5/0xe0
#7: (cpu_hotplug.lock){+.+.+.}, at: [<ffffffffb306d04f>] cpu_hotplug_begin+0x7f/0xe0
stack backtrace:
CPU: 3 PID: 2640 Comm: step_after_susp Not tainted 4.11.0+ #17
Hardware name: Dell Inc. OptiPlex 7040/0JCTF8, BIOS 1.4.9 09/12/2016
Call Trace:
dump_stack+0x99/0xce
print_circular_bug+0x1fa/0x270
? lock_acquire+0x11c/0x230
? blk_mq_queue_reinit_work+0x18/0x110
? kmem_cache_free+0x2cb/0x330
? anon_transport_class_unregister+0x20/0x20
? blk_mq_queue_reinit_work+0x110/0x110
? mutex_lock_nested+0x1b/0x20
? __flow_cache_shrink+0x160/0x160
_cpu_down+0xb2/0xe0
? rcu_read_lock_sched_held+0x79/0x80
? rcu_sync_lockdep_assert+0x2f/0x60
? __sb_start_write+0xd9/0x1c0
? vfs_write+0x1ad/0x1d0
SyS_write+0x58/0xc0
? trace_hardirqs_on_thunk+0x1a/0x1c
entry_SYSCALL64_slow_path+0x25/0x25
The cpu hotplug path will hold cpu_hotplug.lock and then reinit all exiting
queues for blk mq w/ all_q_mutex, however, blk_mq_init_allocated_queue() will
contend these two locks in the inversion order. This is due to commit eabe06595d62
(blk/mq: Cure cpu hotplug lock inversion), it fixes a cpu hotplug lock inversion
issue because of hotplug rework, however the hotplug rework is still work-in-progress
and lives in a -tip branch and mainline cannot yet trigger that splat. The commit
breaks the linus's tree in the merge window, so this patch reverts the lock order
and avoids to splat linus's tree.
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Thierry Escande <thierry.escande@linaro.org>
[ Upstream commit 8ab0b7dc73e1b3e2987d42554b2bff503f692772 ]
HW queues may be unmapped in some cases, such as blk_mq_update_nr_hw_queues(),
then we need to check it before calling blk_mq_tag_idle(), otherwise
the following kernel oops can be triggered, so fix it by checking if
the hw queue is unmapped since it doesn't make sense to idle the tags
any more after hw queues are unmapped.
[ 440.771298] Workqueue: nvme-wq nvme_rdma_del_ctrl_work [nvme_rdma]
[ 440.779104] task: ffff894bae755ee0 ti: ffff893bf9bc8000 task.ti: ffff893bf9bc8000
[ 440.788359] RIP: 0010:[<ffffffffb730e2b4>] [<ffffffffb730e2b4>] __blk_mq_tag_idle+0x24/0x40
[ 440.798697] RSP: 0018:ffff893bf9bcbd10 EFLAGS: 00010286
[ 440.805538] RAX: 0000000000000000 RBX: ffff895bb131dc00 RCX: 000000000000011f
[ 440.814426] RDX: 00000000ffffffff RSI: 0000000000000120 RDI: ffff895bb131dc00
[ 440.823301] RBP: ffff893bf9bcbd10 R08: 000000000001b860 R09: 4a51d361c00c0000
[ 440.832193] R10: b5907f32b4cc7003 R11: ffffd6cabfb57000 R12: ffff894bafd1e008
[ 440.841091] R13: 0000000000000001 R14: ffff895baf770000 R15: 0000000000000080
[ 440.849988] FS: 0000000000000000(0000) GS:ffff894bbdcc0000(0000) knlGS:0000000000000000
[ 440.859955] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 440.867274] CR2: 0000000000000008 CR3: 000000103d098000 CR4: 00000000001407e0
[ 440.876169] Call Trace:
[ 440.879818] [<ffffffffb7309d68>] blk_mq_exit_hctx+0xd8/0xe0
[ 440.887051] [<ffffffffb730dc40>] blk_mq_free_queue+0xf0/0x160
[ 440.894465] [<ffffffffb72ff679>] blk_cleanup_queue+0xd9/0x150
[ 440.901881] [<ffffffffc08a802b>] nvme_ns_remove+0x5b/0xb0 [nvme_core]
[ 440.910068] [<ffffffffc08a811b>] nvme_remove_namespaces+0x3b/0x60 [nvme_core]
[ 440.919026] [<ffffffffc08b817b>] __nvme_rdma_remove_ctrl+0x2b/0xb0 [nvme_rdma]
[ 440.928079] [<ffffffffc08b8237>] nvme_rdma_del_ctrl_work+0x17/0x20 [nvme_rdma]
[ 440.937126] [<ffffffffb70ab58a>] process_one_work+0x17a/0x440
[ 440.944517] [<ffffffffb70ac3a8>] worker_thread+0x278/0x3c0
[ 440.951607] [<ffffffffb70ac130>] ? manage_workers.isra.24+0x2a0/0x2a0
[ 440.959760] [<ffffffffb70b352f>] kthread+0xcf/0xe0
[ 440.966055] [<ffffffffb70b3460>] ? insert_kthread_work+0x40/0x40
[ 440.973715] [<ffffffffb76d8658>] ret_from_fork+0x58/0x90
[ 440.980586] [<ffffffffb70b3460>] ? insert_kthread_work+0x40/0x40
[ 440.988229] Code: 5b 41 5c 5d c3 66 90 0f 1f 44 00 00 48 8b 87 20 01 00 00 f0 0f ba 77 40 01 19 d2 85 d2 75 08 c3 0f 1f 80 00 00 00 00 55 48 89 e5 <f0> ff 48 08 48 8d 78 10 e8 7f 0f 05 00 5d c3 0f 1f 00 66 2e 0f
[ 441.011620] RIP [<ffffffffb730e2b4>] __blk_mq_tag_idle+0x24/0x40
[ 441.019301] RSP <ffff893bf9bcbd10>
[ 441.024052] CR2: 0000000000000008
Reported-by: Zhang Yi <yizhan@redhat.com>
Tested-by: Zhang Yi <yizhan@redhat.com>
Signed-off-by: Ming Lei <ming.lei@redhat.com>
[ Upstream commit 3116a23bb30272d74ea81baf5d0ee23f602dd15b ]
If bio has no data, such as ones from blkdev_issue_flush(),
then we have nothing to protect.
This patch prevent bugon like follows:
kfree_debugcheck: out of range ptr ac1fa1d106742a5ah
kernel BUG at mm/slab.c:2773!
invalid opcode: 0000 [#1] SMP
Modules linked in: bcache
CPU: 0 PID: 4428 Comm: xfs_io Tainted: G W 4.11.0-rc4-ext4-00041-g2ef0043-dirty #43
Hardware name: Virtuozzo KVM, BIOS seabios-1.7.5-11.vz7.4 04/01/2014
task: ffff880137786440 task.stack: ffffc90000ba8000
RIP: 0010:kfree_debugcheck+0x25/0x2a
RSP: 0018:ffffc90000babde0 EFLAGS: 00010082
RAX: 0000000000000034 RBX: ac1fa1d106742a5a RCX: 0000000000000007
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88013f3ccb40
RBP: ffffc90000babde8 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000fcb76420 R11: 00000000725172ed R12: 0000000000000282
R13: ffffffff8150e766 R14: ffff88013a145e00 R15: 0000000000000001
FS: 00007fb09384bf40(0000) GS:ffff88013f200000(0000) knlGS:0000000000000000
CR2: 00007fd0172f9e40 CR3: 0000000137fa9000 CR4: 00000000000006f0
Call Trace:
kfree+0xc8/0x1b3
bio_integrity_free+0xc3/0x16b
bio_free+0x25/0x66
bio_put+0x14/0x26
blkdev_issue_flush+0x7a/0x85
blkdev_fsync+0x35/0x42
vfs_fsync_range+0x8e/0x9f
vfs_fsync+0x1c/0x1e
do_fsync+0x31/0x4a
SyS_fsync+0x10/0x14
entry_SYSCALL_64_fastpath+0x1f/0xc2
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
[ Upstream commit fb350e0ad99359768e1e80b4784692031ec340e4 ]
In both elevator_switch_mq() and blk_mq_update_nr_hw_queues(), sched tags
can be allocated, and q->nr_hw_queue is used, and race is inevitable, for
example: blk_mq_init_sched() may trigger use-after-free on hctx, which is
freed in blk_mq_realloc_hw_ctxs() when nr_hw_queues is decreased.
This patch fixes the race be holding q->sysfs_lock.
Reported-by: Yi Zhang <yi.zhang@redhat.com>
Tested-by: Yi Zhang <yi.zhang@redhat.com>
[ Upstream commit 7bd897cfce1eb373892d35d7f73201b0f9b221c4 ]
We don't set an error code on this path. It means that we return NULL
instead of an error pointer and the caller does a NULL dereference.
Fixes: 6d1d8050b4bc ("block, partition: add partition_meta_info to hd_struct")
[ Upstream commit f36ea50ca0043e7b1204feaf1d2ba6bd68c08d36 ]
When formatting NVMe to 512B/4K + T10 DIf/DIX, dd with split op returns
"Input/output error". Looks block layer split the bio after calling
bio_integrity_prep(bio). This patch fixes the issue.
Below is how we debug this issue:
(1)format nvme to 4K block # size with type 2 DIF
(2)dd with block size bigger than 1024k.
oflag=direct
dd: error writing '/dev/nvme0n1': Input/output error
We added some debug code in nvme device driver. It showed us the first
op and the second op have the same bi and pi address. This is not
correct.
1st op: nvme0n1 Op:Wr slba 0x505 length 0x100, PI ctrl=0x1400,
dsmgmt=0x0, AT=0x0 & RT=0x505
Guard 0x00b1, AT 0x0000, RT physical 0x00000505 RT virtual 0x00002828
2nd op: nvme0n1 Op:Wr slba 0x605 length 0x1, PI ctrl=0x1400, dsmgmt=0x0,
AT=0x0 & RT=0x605 ==> This op fails and subsequent 5 retires..
Guard 0x00b1, AT 0x0000, RT physical 0x00000605 RT virtual 0x00002828
With the fix, It showed us both of the first op and the second op have
correct bi and pi address.
1st op: nvme2n1 Op:Wr slba 0x505 length 0x100, PI ctrl=0x1400,
Guard 0x5ccb, AT 0x0000, RT physical 0x00000505 RT virtual
0x00002828
2nd op: nvme2n1 Op:Wr slba 0x605 length 0x1, PI ctrl=0x1400, dsmgmt=0x0,
AT=0x0 & RT=0x605
Guard 0xab4c, AT 0x0000, RT physical 0x00000605 RT virtual
0x00003028
Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
commit bd5c4facf59648581d2f1692dad7b107bf429954 upstream.
I'm getting a slab named "biovec-(1<<(21-12))". It is caused by unintended
expansion of the macro BIO_MAX_PAGES. This patch renames it to biovec-max.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org # v4.14+
commit 5f15684bd5e5ef39d4337988864fec8012471dda upstream.
UFS partitions from newer versions of FreeBSD 10 and 11 use relative
addressing for their subpartitions. But older versions of FreeBSD still
use absolute addressing just like OpenBSD and NetBSD.
Instead of simply testing for a FreeBSD partition, the code needs to
also test if the starting offset of the C subpartition is zero.
https://bugzilla.kernel.org/show_bug.cgi?id=197733
Signed-off-by: Richard Narron <comet.berkeley@gmail.com>
[ Upstream commit eabe06595d62cfa9278e2cd012df614bc68a7042 ]
By poking at /debug/sched_features I triggered the following splat:
[] WARNING: possible circular locking dependency detected
[] 4.11.0-00873-g964c8b7-dirty #694 Not tainted
[] bash/2109 is trying to acquire lock:
[] (cpu_hotplug_lock.rw_sem){++++++}, at: [<ffffffff8120cb8b>] static_key_slow_dec+0x1b/0x50
[] but task is already holding lock:
[] (&sb->s_type->i_mutex_key#4){+++++.}, at: [<ffffffff81140216>] sched_feat_write+0x86/0x170
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #2 (&sb->s_type->i_mutex_key#4){+++++.}:
[] lock_acquire+0x100/0x210
[] down_write+0x28/0x60
[] start_creating+0x5e/0xf0
[] debugfs_create_dir+0x13/0x110
[] blk_mq_debugfs_register+0x21/0x70
[] blk_mq_register_dev+0x64/0xd0
[] blk_register_queue+0x6a/0x170
[] device_add_disk+0x22d/0x440
[] loop_add+0x1f3/0x280
[] loop_init+0x104/0x142
[] do_one_initcall+0x43/0x180
[] kernel_init_freeable+0x1de/0x266
[] kernel_init+0xe/0x100
[] ret_from_fork+0x31/0x40
[] -> #1 (all_q_mutex){+.+.+.}:
[] __mutex_lock+0x6c/0x960
[] mutex_lock_nested+0x1b/0x20
[] blk_mq_init_allocated_queue+0x37c/0x4e0
[] blk_mq_init_queue+0x3a/0x60
[] loop_add+0xe5/0x280
[] *** DEADLOCK ***
[] 3 locks held by bash/2109:
[] #0: (sb_writers#11){.+.+.+}, at: [<ffffffff81292bcd>] vfs_write+0x17d/0x1a0
[] #1: (debugfs_srcu){......}, at: [<ffffffff8155a90d>] full_proxy_write+0x5d/0xd0
[] #2: (&sb->s_type->i_mutex_key#4){+++++.}, at: [<ffffffff81140216>] sched_feat_write+0x86/0x170
[] stack backtrace:
[] CPU: 9 PID: 2109 Comm: bash Not tainted 4.11.0-00873-g964c8b7-dirty #694
[] Hardware name: Intel Corporation S2600GZ/S2600GZ, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013
[] Call Trace:
[] get_online_cpus+0x2a/0x90
[] static_key_slow_dec+0x1b/0x50
[] static_key_disable+0x20/0x30
[] sched_feat_write+0x131/0x170
[] full_proxy_write+0x97/0xd0
[] __vfs_write+0x28/0x120
[] vfs_write+0xb5/0x1a0
[] SyS_write+0x49/0xa0
[] entry_SYSCALL_64_fastpath+0x23/0xc2
This is because of the cpu hotplug lock rework. Break the chain at #1
by reversing the lock acquisition order. This way i_mutex_key#4 no
longer depends on cpu_hotplug_lock and things are good.
[ Upstream commit 06cceedcca67a93ac7f7aa93bbd9980c7496d14e ]
cgroup could be throttled to a limit but when all cgroups cross high
limit, queue enters a higher state and so the group should be throttled
to a higher limit. It's possible the cgroup is sleeping because of
throttle and other cgroups don't dispatch IO any more. In this case,
nobody can trigger current downgrade/upgrade logic. To fix this issue,
we could either set up a timer to wakeup the cgroup if other cgroups are
idle or make sure this cgroup doesn't sleep too long. Setting up a timer
means we must change the timer very frequently. This patch chooses the
latter. Making cgroup sleep time not too big wouldn't change cgroup
bps/iops, but could make it wakeup more frequently, which isn't a big
issue because throtl_slice * 8 is already quite big.
Signed-off-by: Shaohua Li <shli@fb.com>
commit 9b54d816e00425c3a517514e0d677bb3cec49258 upstream.
If blkg_create fails, new_blkg passed as an argument will
be freed by blkg_create, so there is no need to free it again.
Signed-off-by: Hou Tao <houtao1@huawei.com>
commit 69e0927b3774563c19b5fb32e91d75edc147fb62 upstream.
During stress tests by syzkaller on the sg driver the block layer
infrequently returns EINVAL. Closer inspection shows the block
layer was trying to return ENOMEM (which is much more
understandable) but for some reason overroad that useful error.
Patch below does not show this (unchanged) line:
ret =__blk_rq_map_user_iov(rq, map_data, &i, gfp_mask, copy);
That 'ret' was being overridden when that function failed.
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
[ Upstream commit 39b4954c0a1556f8f7f1fdcf59a227117fcd8a0b ]
MD's rdev_set_badblocks() expects that badblocks_set() returns 1 if
badblocks are disabled, otherwise, rdev_set_badblocks() will record
superblock changes and return success in that case and md will fail to
report an IO error which it should.
This bug has existed since badblocks were introduced in commit
9e0e252a048b ("badblocks: Add core badblock management code").
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Acked-by: Guoqing Jiang <gqjiang@suse.com>
[ Upstream commit 0067d4b020ea07a58540acb2c5fcd3364bf326e0 ]
In case cpu was unplugged, we need to make sure not to assume
that the tags for that cpu are still allocated. so check
for null tags when reinitializing a tagset.
Reported-by: Yi Zhang <yizhan@redhat.com>
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
[ Upstream commit 34d9715ac1edd50285168dd8d80c972739a4f6a4 ]
Once blk_set_queue_dying() is done in blk_cleanup_queue(), we call
blk_freeze_queue() and wait for q->q_usage_counter becoming zero. But
if there are tasks blocked in get_request(), q->q_usage_counter can
never become zero. So we have to wake up all these tasks in
blk_set_queue_dying() first.
Fixes: 3ef28e83ab157997 ("block: generic request_queue reference counting")
[ Upstream commit 737f98cfe7de8df7433a4d846850aa8efa44bd48 ]
Both q->mq_kobj and sw queues' kobjects should have been initialized
once, instead of doing that each add_disk context.
Also this patch removes clearing of ctx in blk_mq_init_cpu_queues()
because percpu allocator fills zero to allocated variable.
This patch fixes one issue[1] reported from Omar.
[1] kernel wearning when doing unbind/bind on one scsi-mq device
[ 19.347924] kobject (ffff8800791ea0b8): tried to init an initialized object, something is seriously wrong.
[ 19.349781] CPU: 1 PID: 84 Comm: kworker/u8:1 Not tainted 4.10.0-rc7-00210-g53f39eeaa263 #34
[ 19.350686] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.1-20161122_114906-anatol 04/01/2014
[ 19.350920] Workqueue: events_unbound async_run_entry_fn
[ 19.350920] Call Trace:
[ 19.350920] dump_stack+0x63/0x83
[ 19.350920] kobject_init+0x77/0x90
[ 19.350920] blk_mq_register_dev+0x40/0x130
[ 19.350920] blk_register_queue+0xb6/0x190
[ 19.350920] device_add_disk+0x1ec/0x4b0
[ 19.350920] sd_probe_async+0x10d/0x1c0 [sd_mod]
[ 19.350920] async_run_entry_fn+0x48/0x150
[ 19.350920] process_one_work+0x1d0/0x480
[ 19.350920] worker_thread+0x48/0x4e0
[ 19.350920] kthread+0x101/0x140
[ 19.350920] ? process_one_work+0x480/0x480
[ 19.350920] ? kthread_create_on_node+0x60/0x60
[ 19.350920] ret_from_fork+0x2c/0x40
Cc: Omar Sandoval <osandov@osandov.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
commit 4e9b6f20828ac880dbc1fa2fdbafae779473d1af upstream.
Make sure that if the timeout timer fires after a queue has been
marked "dying" that the affected requests are finished.
Reported-by: chenxiang (M) <chenxiang66@hisilicon.com>
Fixes: commit 287922eb0b18 ("block: defer timeouts to a workqueue")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Tested-by: chenxiang (M) <chenxiang66@hisilicon.com>
Cc: Keith Busch <keith.busch@intel.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
This reverts commit eb4375e1969c48d454998b2a284c2e6a5dc9eb68 which was
commit f507b54dccfd8000c517d740bc45f20c74532d18 upstream.
Ben reports:
That function doesn't exist here (it was introduced in 4.13).
Instead, this backport has modified bsg_create_job(), creating a
leak. Please revert this on the 3.18, 4.4 and 4.9 stable
branches.
So I'm dropping it from here.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
commit 1cfd0ddd82232804e03f3023f6a58b50dfef0574 upstream.
Since "block: support large requests in blk_rq_map_user_iov" we
started to call it with partially drained iter; that works fine
on the write side, but reads create a copy of iter for completion
time. And that needs to take the possibility of ->iov_iter != 0
into account...
commit 2b04e8f6bbb196cab4b232af0f8d48ff2c7a8058 upstream.
we need to take care of failure exit as well - pages already
in bio should be dropped by analogue of bio_unmap_pages(),
since their refcounts had been bumped only once per reference
in bio.
commit 95d78c28b5a85bacbc29b8dba7c04babb9b0d467 upstream.
bio_map_user_iov and bio_unmap_user do unbalanced pages refcounting if
IO vector has small consecutive buffers belonging to the same page.
bio_add_pc_page merges them into one, but the page reference is never
dropped.
Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com>
[ Upstream commit c5082b70adfe8e1ea1cf4a8eff92c9f260e364d2 ]
If a GUID Partition Table claims to have more than 2**25 entries, the
calculation of the partition table size in alloc_read_gpt_entries() will
overflow a 32-bit integer and not enough space will be allocated for the
table.
Nothing seems to get written out of bounds, but later efi_partition() will
read up to 32768 bytes from a 128 byte buffer, possibly OOPSing or exposing
information to /proc/partitions and uevents.
The problem exists on both 64-bit and 32-bit platforms.
Fix the overflow and also print a meaningful debug message if the table
size is too large.
Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
The job structure is allocated as part of the request, so we should not
free it in the error path of bsg_prepare_job.
Reviewed-by: Ming Lei <ming.lei@redhat.com>
commit 4ddd56b003f251091a67c15ae3fe4a5c5c5e390a upstream.
Calling blk_start_queue() from interrupt context with the queue
lock held and without disabling IRQs, as the skd driver does, is
safe. This patch avoids that loading the skd driver triggers the
following warning:
WARNING: CPU: 11 PID: 1348 at block/blk-core.c:283 blk_start_queue+0x84/0xa0
RIP: 0010:blk_start_queue+0x84/0xa0
Call Trace:
skd_unquiesce_dev+0x12a/0x1d0 [skd]
skd_complete_internal+0x1e7/0x5a0 [skd]
skd_complete_other+0xc2/0xd0 [skd]
skd_isr_completion_posted.isra.30+0x2a5/0x470 [skd]
skd_isr+0x14f/0x180 [skd]
irq_forced_thread_fn+0x2a/0x70
irq_thread+0x144/0x1a0
kthread+0x125/0x140
ret_from_fork+0x2a/0x40
Fixes: commit a038e2536472 ("[PATCH] blk_start_queue() must be called with irq disabled - add warning")
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Andrew Morton <akpm@osdl.org>
Cc: Hannes Reinecke <hare@suse.de>
commit c005390374957baacbc38eef96ea360559510aa7 upstream.
While pci_irq_get_affinity should never fail for SMP kernel that
implement the affinity mapping, it will always return NULL in the
UP case, so provide a fallback mapping of all queues to CPU 0 in
that case.
Reviewed-by: Omar Sandoval <osandov@fb.com>
commit 223220356d5ebc05ead9a8d697abb0c0a906fc81 upstream.
The code in block/partitions/msdos.c recognizes FreeBSD, OpenBSD
and NetBSD partitions and does a reasonable job picking out OpenBSD
and NetBSD UFS subpartitions.
But for FreeBSD the subpartitions are always "bad".
Kernel: <bsd:bad subpartition - ignored
Though all 3 of these BSD systems use UFS as a file system, only
FreeBSD uses relative start addresses in the subpartition
declarations.
The following patch fixes this for FreeBSD partitions and leaves
the code for OpenBSD and NetBSD intact:
commit 5be6b75610cefd1e21b98a218211922c2feb6e08 upstream.
When adding a cfq_group into the cfq service tree, we use CFQ_IDLE_DELAY
as the delay of cfq_group's vdisktime if there have been other cfq_groups
already.
When cfq is under iops mode, commit 9a7f38c42c2b ("cfq-iosched: Convert
from jiffies to nanoseconds") could result in a large iops delay and
lead to an abnormal io schedule delay for the added cfq_group. To fix
it, we just need to revert to the old CFQ_IDLE_DELAY value: HZ / 5
when iops mode is enabled.
Despite having the same value, the delay of a cfq_queue in idle class
and the delay of cfq_group are different things, so I define two new
macros for the delay of a cfq_group under time-slice mode and iops mode.
Fixes: 9a7f38c42c2b ("cfq-iosched: Convert from jiffies to nanoseconds")
Acked-by: Jan Kara <jack@suse.cz>
commit 2859323e35ab5fc42f351fbda23ab544eaa85945 upstream.
When registering an integrity profile: if the template's interval_exp is
not 0 use it, otherwise use the ilog2() of logical block size of the
provided gendisk.
This fixes a long-standing DM linear target bug where it cannot pass
integrity data to the underlying device if its logical block size
conflicts with the underlying device's logical block size.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
commit 19b7ccf8651df09d274671b53039c672a52ad84d upstream.
Commit 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk")
introduced blk_integrity_revalidate(), which seems to assume ownership
of the stable pages flag and unilaterally clears it if no blk_integrity
profile is registered:
if (bi->profile)
disk->queue->backing_dev_info->capabilities |=
BDI_CAP_STABLE_WRITES;
else
disk->queue->backing_dev_info->capabilities &=
~BDI_CAP_STABLE_WRITES;
It's called from revalidate_disk() and rescan_partitions(), making it
impossible to enable stable pages for drivers that support partitions
and don't use blk_integrity: while the call in revalidate_disk() can be
trivially worked around (see zram, which doesn't support partitions and
hence gets away with zram_revalidate_disk()), rescan_partitions() can
be triggered from userspace at any time. This breaks rbd, where the
ceph messenger is responsible for generating/verifying CRCs.
Since blk_integrity_{un,}register() "must" be used for (un)registering
the integrity profile with the block layer, move BDI_CAP_STABLE_WRITES
setting there. This way drivers that call blk_integrity_register() and
use integrity infrastructure won't interfere with drivers that don't
but still want stable pages.
Fixes: 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk")
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Tested-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[idryomov@gmail.com: backport to < 4.11: bdi is embedded in queue]
commit 36e1f3d107867b25c616c2fd294f5a1c9d4e5d09 upstream.
While stressing memory and IO at the same time we changed SMT settings,
we were able to consistently trigger deadlocks in the mm system, which
froze the entire machine.
I think that under memory stress conditions, the large allocations
performed by blk_mq_init_rq_map may trigger a reclaim, which stalls
waiting on the block layer remmaping completion, thus deadlocking the
system. The trace below was collected after the machine stalled,
waiting for the hotplug event completion.
The simplest fix for this is to make allocations in this path
non-reclaimable, with GFP_NOIO. With this patch, We couldn't hit the
issue anymore.
This should apply on top of Jens's for-next branch cleanly.
Changes since v1:
- Use GFP_NOIO instead of GFP_NOWAIT.
Call Trace:
[c000000f0160aaf0] [c000000f0160ab50] 0xc000000f0160ab50 (unreliable)
[c000000f0160acc0] [c000000000016624] __switch_to+0x2e4/0x430
[c000000f0160ad20] [c000000000b1a880] __schedule+0x310/0x9b0
[c000000f0160ae00] [c000000000b1af68] schedule+0x48/0xc0
[c000000f0160ae30] [c000000000b1b4b0] schedule_preempt_disabled+0x20/0x30
[c000000f0160ae50] [c000000000b1d4fc] __mutex_lock_slowpath+0xec/0x1f0
[c000000f0160aed0] [c000000000b1d678] mutex_lock+0x78/0xa0
[c000000f0160af00] [d000000019413cac] xfs_reclaim_inodes_ag+0x33c/0x380 [xfs]
[c000000f0160b0b0] [d000000019415164] xfs_reclaim_inodes_nr+0x54/0x70 [xfs]
[c000000f0160b0f0] [d0000000194297f8] xfs_fs_free_cached_objects+0x38/0x60 [xfs]
[c000000f0160b120] [c0000000003172c8] super_cache_scan+0x1f8/0x210
[c000000f0160b190] [c00000000026301c] shrink_slab.part.13+0x21c/0x4c0
[c000000f0160b2d0] [c000000000268088] shrink_zone+0x2d8/0x3c0
[c000000f0160b380] [c00000000026834c] do_try_to_free_pages+0x1dc/0x520
[c000000f0160b450] [c00000000026876c] try_to_free_pages+0xdc/0x250
[c000000f0160b4e0] [c000000000251978] __alloc_pages_nodemask+0x868/0x10d0
[c000000f0160b6f0] [c000000000567030] blk_mq_init_rq_map+0x160/0x380
[c000000f0160b7a0] [c00000000056758c] blk_mq_map_swqueue+0x33c/0x360
[c000000f0160b820] [c000000000567904] blk_mq_queue_reinit+0x64/0xb0
[c000000f0160b850] [c00000000056a16c] blk_mq_queue_reinit_notify+0x19c/0x250
[c000000f0160b8a0] [c0000000000f5d38] notifier_call_chain+0x98/0x100
[c000000f0160b8f0] [c0000000000c5fb0] __cpu_notify+0x70/0xe0
[c000000f0160b930] [c0000000000c63c4] notify_prepare+0x44/0xb0
[c000000f0160b9b0] [c0000000000c52f4] cpuhp_invoke_callback+0x84/0x250
[c000000f0160ba10] [c0000000000c570c] cpuhp_up_callbacks+0x5c/0x120
[c000000f0160ba60] [c0000000000c7cb8] _cpu_up+0xf8/0x1d0
[c000000f0160bac0] [c0000000000c7eb0] do_cpu_up+0x120/0x150
[c000000f0160bb40] [c0000000006fe024] cpu_subsys_online+0x64/0xe0
[c000000f0160bb90] [c0000000006f5124] device_online+0xb4/0x120
[c000000f0160bbd0] [c0000000006f5244] online_store+0xb4/0xc0
[c000000f0160bc20] [c0000000006f0a68] dev_attr_store+0x68/0xa0
[c000000f0160bc60] [c0000000003ccc30] sysfs_kf_write+0x80/0xb0
[c000000f0160bca0] [c0000000003cbabc] kernfs_fop_write+0x17c/0x250
[c000000f0160bcf0] [c00000000030fe6c] __vfs_write+0x6c/0x1e0
[c000000f0160bd90] [c000000000311490] vfs_write+0xd0/0x270
[c000000f0160bde0] [c0000000003131fc] SyS_write+0x6c/0x110
[c000000f0160be30] [c000000000009204] system_call+0x38/0xec
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Cc: Brian King <brking@linux.vnet.ibm.com>
Cc: Douglas Miller <dougmill@linux.vnet.ibm.com>
Cc: linux-block@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit f5fe1b51905df7cfe4fdfd85c5fb7bc5b71a094f upstream.
Commit 79bd99596b73 ("blk: improve order of bio handling in generic_make_request()")
changed current->bio_list so that it did not contain *all* of the
queued bios, but only those submitted by the currently running
make_request_fn.
There are two places which walk the list and requeue selected bios,
and others that check if the list is empty. These are no longer
correct.
So redefine current->bio_list to point to an array of two lists, which
contain all queued bios, and adjust various code to test or walk both
lists.
Signed-off-by: NeilBrown <neilb@suse.com>
Fixes: 79bd99596b73 ("blk: improve order of bio handling in generic_make_request()")
Cc: Jack Wang <jinpu.wang@profitbricks.com>
commit 79bd99596b7305ab08109a8bf44a6a4511dbf1cd upstream.
To avoid recursion on the kernel stack when stacked block devices
are in use, generic_make_request() will, when called recursively,
queue new requests for later handling. They will be handled when the
make_request_fn for the current bio completes.
If any bios are submitted by a make_request_fn, these will ultimately
be handled seqeuntially. If the handling of one of those generates
further requests, they will be added to the end of the queue.
This strict first-in-first-out behaviour can lead to deadlocks in
various ways, normally because a request might need to wait for a
previous request to the same device to complete. This can happen when
they share a mempool, and can happen due to interdependencies
particular to the device. Both md and dm have examples where this happens.
These deadlocks can be erradicated by more selective ordering of bios.
Specifically by handling them in depth-first order. That is: when the
handling of one bio generates one or more further bios, they are
handled immediately after the parent, before any siblings of the
parent. That way, when generic_make_request() calls make_request_fn
for some particular device, we can be certain that all previously
submited requests for that device have been completely handled and are
not waiting for anything in the queue of requests maintained in
generic_make_request().
An easy way to achieve this would be to use a last-in-first-out stack
instead of a queue. However this will change the order of consecutive
bios submitted by a make_request_fn, which could have unexpected consequences.
Instead we take a slightly more complex approach.
A fresh queue is created for each call to a make_request_fn. After it completes,
any bios for a different device are placed on the front of the main queue, followed
by any bios for the same device, followed by all bios that were already on
the queue before the make_request_fn was called.
This provides the depth-first approach without reordering bios on the same level.
This, by itself, it not enough to remove all deadlocks. It just makes
it possible for drivers to take the extra step required themselves.
To avoid deadlocks, drivers must never risk waiting for a request
after submitting one to generic_make_request. This includes never
allocing from a mempool twice in the one call to a make_request_fn.
A common pattern in drivers is to call bio_split() in a loop, handling
the first part and then looping around to possibly split the next part.
Instead, a driver that finds it needs to split a bio should queue
(with generic_make_request) the second part, handle the first part,
and then return. The new code in generic_make_request will ensure the
requests to underlying bios are processed first, then the second bio
that was split off. If it splits again, the same process happens. In
each case one bio will be completely handled before the next one is attempted.
With this is place, it should be possible to disable the
punt_bios_to_recover() recovery thread for many block devices, and
eventually it may be possible to remove it completely.
Ref: http://www.spinics.net/lists/raid/msg54680.html
Tested-by: Jinpu Wang <jinpu.wang@profitbricks.com>
Inspired-by: Lars Ellenberg <lars.ellenberg@linbit.com>
commit 95a49603707d982b25d17c5b70e220a05556a2f9 upstream.
When iterating busy requests in timeout handler,
if the STARTED flag of one request isn't set, that means
the request is being processed in block layer or driver, and
isn't submitted to hardware yet.
In current implementation of blk_mq_check_expired(),
if the request queue becomes dying, un-started requests are
handled as being completed/freed immediately. This way is
wrong, and can cause rq corruption or double allocation[1][2],
when doing I/O and removing&resetting NVMe device at the sametime.
This patch fixes several issues reported by Yi Zhang.
[1]. oops log 1
[ 581.789754] ------------[ cut here ]------------
[ 581.789758] kernel BUG at block/blk-mq.c:374!
[ 581.789760] invalid opcode: 0000 [#1] SMP
[ 581.789761] Modules linked in: vfat fat ipmi_ssif intel_rapl sb_edac
edac_core x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm nvme
irqbypass crct10dif_pclmul nvme_core crc32_pclmul ghash_clmulni_intel
intel_cstate ipmi_si mei_me ipmi_devintf intel_uncore sg ipmi_msghandler
intel_rapl_perf iTCO_wdt mei iTCO_vendor_support mxm_wmi lpc_ich dcdbas shpchp
pcspkr acpi_power_meter wmi nfsd auth_rpcgss nfs_acl lockd dm_multipath grace
sunrpc ip_tables xfs libcrc32c sd_mod mgag200 i2c_algo_bit drm_kms_helper
syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm ahci libahci
crc32c_intel tg3 libata megaraid_sas i2c_core ptp fjes pps_core dm_mirror
dm_region_hash dm_log dm_mod
[ 581.789796] CPU: 1 PID: 1617 Comm: kworker/1:1H Not tainted 4.10.0.bz1420297+ #4
[ 581.789797] Hardware name: Dell Inc. PowerEdge R730xd/072T6D, BIOS 2.2.5 09/06/2016
[ 581.789804] Workqueue: kblockd blk_mq_timeout_work
[ 581.789806] task: ffff8804721c8000 task.stack: ffffc90006ee4000
[ 581.789809] RIP: 0010:blk_mq_end_request+0x58/0x70
[ 581.789810] RSP: 0018:ffffc90006ee7d50 EFLAGS: 00010202
[ 581.789811] RAX: 0000000000000001 RBX: ffff8802e4195340 RCX: ffff88028e2f4b88
[ 581.789812] RDX: 0000000000001000 RSI: 0000000000001000 RDI: 0000000000000000
[ 581.789813] RBP: ffffc90006ee7d60 R08: 0000000000000003 R09: ffff88028e2f4b00
[ 581.789814] R10: 0000000000001000 R11: 0000000000000001 R12: 00000000fffffffb
[ 581.789815] R13: ffff88042abe5780 R14: 000000000000002d R15: ffff88046fbdff80
[ 581.789817] FS: 0000000000000000(0000) GS:ffff88047fc00000(0000) knlGS:0000000000000000
[ 581.789818] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 581.789819] CR2: 00007f64f403a008 CR3: 000000014d078000 CR4: 00000000001406e0
[ 581.789820] Call Trace:
[ 581.789825] blk_mq_check_expired+0x76/0x80
[ 581.789828] bt_iter+0x45/0x50
[ 581.789830] blk_mq_queue_tag_busy_iter+0xdd/0x1f0
[ 581.789832] ? blk_mq_rq_timed_out+0x70/0x70
[ 581.789833] ? blk_mq_rq_timed_out+0x70/0x70
[ 581.789840] ? __switch_to+0x140/0x450
[ 581.789841] blk_mq_timeout_work+0x88/0x170
[ 581.789845] process_one_work+0x165/0x410
[ 581.789847] worker_thread+0x137/0x4c0
[ 581.789851] kthread+0x101/0x140
[ 581.789853] ? rescuer_thread+0x3b0/0x3b0
[ 581.789855] ? kthread_park+0x90/0x90
[ 581.789860] ret_from_fork+0x2c/0x40
[ 581.789861] Code: 48 85 c0 74 0d 44 89 e6 48 89 df ff d0 5b 41 5c 5d c3 48
8b bb 70 01 00 00 48 85 ff 75 0f 48 89 df e8 7d f0 ff ff 5b 41 5c 5d c3 <0f>
0b e8 71 f0 ff ff 90 eb e9 0f 1f 40 00 66 2e 0f 1f 84 00 00
[ 581.789882] RIP: blk_mq_end_request+0x58/0x70 RSP: ffffc90006ee7d50
[ 581.789889] ---[ end trace bcaf03d9a14a0a70 ]---
[2]. oops log2
[ 6984.857362] BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
[ 6984.857372] IP: nvme_queue_rq+0x6e6/0x8cd [nvme]
[ 6984.857373] PGD 0
[ 6984.857374]
[ 6984.857376] Oops: 0000 [#1] SMP
[ 6984.857379] Modules linked in: ipmi_ssif vfat fat intel_rapl sb_edac
irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel ipmi_si iTCO_wdt
iTCO_vendor_support mxm_wmi ipmi_devintf intel_cstate sg dcdbas intel_uncore
mei_me intel_rapl_perf mei pcspkr lpc_ich ipmi_msghandler shpchp
acpi_power_meter wmi nfsd auth_rpcgss dm_multipath nfs_acl lockd grace sunrpc
ip_tables xfs libcrc32c sd_mod mgag200 i2c_algo_bit drm_kms_helper syscopyarea
sysfillrect crc32c_intel sysimgblt fb_sys_fops ttm nvme drm nvme_core ahci
libahci i2c_core tg3 libata ptp megaraid_sas pps_core fjes dm_mirror
[ 6984.857416] CPU: 7 PID: 1635 Comm: kworker/7:1H Not tainted
4.10.0-2.el7.bz1420297.x86_64 #1
[ 6984.857417] Hardware name: Dell Inc. PowerEdge R730xd/072T6D, BIOS 2.2.5 09/06/2016
[ 6984.857427] Workqueue: kblockd blk_mq_run_work_fn
[ 6984.857429] task: ffff880476e3da00 task.stack: ffffc90002e90000
[ 6984.857432] RIP: 0010:nvme_queue_rq+0x6e6/0x8cd [nvme]
[ 6984.857433] RSP: 0018:ffffc90002e93c50 EFLAGS: 00010246
[ 6984.857434] RAX: 0000000000000000 RBX: ffff880275646600 RCX: 0000000000001000
[ 6984.857435] RDX: 0000000000000fff RSI: 00000002fba2a000 RDI: ffff8804734e6950
[ 6984.857436] RBP: ffffc90002e93d30 R08: 0000000000002000 R09: 0000000000001000
[ 6984.857437] R10: 0000000000001000 R11: 0000000000000000 R12: ffff8804741d8000
[ 6984.857438] R13: 0000000000000040 R14: ffff880475649f80 R15: ffff8804734e6780
[ 6984.857439] FS: 0000000000000000(0000) GS:ffff88047fcc0000(0000) knlGS:0000000000000000
[ 6984.857440] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 6984.857442] CR2: 0000000000000010 CR3: 0000000001c09000 CR4: 00000000001406e0
[ 6984.857443] Call Trace:
[ 6984.857451] ? mempool_free+0x2b/0x80
[ 6984.857455] ? bio_free+0x4e/0x60
[ 6984.857459] blk_mq_dispatch_rq_list+0xf5/0x230
[ 6984.857462] blk_mq_process_rq_list+0x133/0x170
[ 6984.857465] __blk_mq_run_hw_queue+0x8c/0xa0
[ 6984.857467] blk_mq_run_work_fn+0x12/0x20
[ 6984.857473] process_one_work+0x165/0x410
[ 6984.857475] worker_thread+0x137/0x4c0
[ 6984.857478] kthread+0x101/0x140
[ 6984.857480] ? rescuer_thread+0x3b0/0x3b0
[ 6984.857481] ? kthread_park+0x90/0x90
[ 6984.857489] ret_from_fork+0x2c/0x40
[ 6984.857490] Code: 8b bd 70 ff ff ff 89 95 50 ff ff ff 89 8d 58 ff ff ff 44
89 95 60 ff ff ff e8 b7 dd 12 e1 8b 95 50 ff ff ff 48 89 85 68 ff ff ff <4c>
8b 48 10 44 8b 58 18 8b 8d 58 ff ff ff 44 8b 95 60 ff ff ff
[ 6984.857511] RIP: nvme_queue_rq+0x6e6/0x8cd [nvme] RSP: ffffc90002e93c50
[ 6984.857512] CR2: 0000000000000010
[ 6984.895359] ---[ end trace 2d7ceb528432bf83 ]---
Tested-by: Yi Zhang <yizhan@redhat.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
[ Upstream commit 25cdb64510644f3e854d502d69c73f21c6df88a9 ]
The WRITE_SAME commands are not present in the blk_default_cmd_filter
write_ok list, and thus are failed with -EPERM when the SG_IO ioctl()
is executed without CAP_SYS_RAWIO capability (e.g., unprivileged users).
[ sg_io() -> blk_fill_sghdr_rq() > blk_verify_command() -> -EPERM ]
The problem can be reproduced with the sg_write_same command
# sg_write_same --num 1 --xferlen 512 /dev/sda
# capsh --drop=cap_sys_rawio -- -c \
'sg_write_same --num 1 --xferlen 512 /dev/sda'
Write same: pass through os error: Operation not permitted
For comparison, the WRITE_VERIFY command does not observe this problem,
since it is in that list:
'sg_write_verify --num 1 --ilen 512 --lba 0 /dev/sda'
So, this patch adds the WRITE_SAME commands to the list, in order
for the SG_IO ioctl to finish successfully:
That case happens to be exercised by QEMU KVM guests with 'scsi-block' devices
(qemu "-device scsi-block" [1], libvirt "<disk type='block' device='lun'>" [2]),
which employs the SG_IO ioctl() and runs as an unprivileged user (libvirt-qemu).
In that scenario, when a filesystem (e.g., ext4) performs its zero-out calls,
which are translated to write-same calls in the guest kernel, and then into
SG_IO ioctls to the host kernel, SCSI I/O errors may be observed in the guest:
[...] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[...] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[...] sd 0:0:0:0: [sda] tag#0 Add. Sense: I/O process terminated
[...] sd 0:0:0:0: [sda] tag#0 CDB: Write Same(10) 41 00 01 04 e0 78 00 00 08 00
[...] blk_update_request: I/O error, dev sda, sector 17096824
Links:
[1] http://git.qemu.org/?p=qemu.git;a=commit;h=336a6915bc7089fb20fea4ba99972ad9a97c5f52
[2] https://libvirt.org/formatdomain.html#elementsDisks (see 'disk' -> 'device')
Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
Signed-off-by: Brahadambal Srinivasan <latha@linux.vnet.ibm.com>
Reported-by: Manjunatha H R <manjuhr1@in.ibm.com>
commit c02ebfdddbafa9a6a0f52fbd715e6bfa229af9d3 upstream.
Commit 0e87e58bf60e ("blk-mq: improve warning for running a queue on the
wrong CPU") attempts to avoid triggering the WARN_ON in
__blk_mq_run_hw_queue when the expected CPU is dead. Problem is, in the
last batch execution before round robin, blk_mq_hctx_next_cpu can
schedule a dead CPU and also update next_cpu to the next alive CPU in
the mask, which will trigger the WARN_ON despite the previous
workaround.
The following patch fixes this scenario by always scheduling the value
in hctx->next_cpu. This changes the moment when we round-robin the CPU
running the hctx, but it really doesn't matter, since it still executes
BLK_MQ_CPU_WORK_BATCH times in a row before switching to another CPU.
Fixes: 0e87e58bf60e ("blk-mq: improve warning for running a queue on the wrong CPU")
commit ebc4ff661fbe76781c6b16dfb7b754a5d5073f8e upstream.
cfq_cpd_alloc() which is the cpd_alloc_fn implementation for cfq was
incorrectly hard coding GFP_KERNEL instead of using the mask specified
through the @gfp parameter. This currently doesn't cause any actual
issues because all current callers specify GFP_KERNEL. Fix it.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: e4a9bde9589f ("blkcg: replace blkcg_policy->cpd_size with ->cpd_alloc/free_fn() methods")
commit 128394eff343fc6d2f32172f03e24829539c5835 upstream.
Both damn things interpret userland pointers embedded into the payload;
worse, they are actually traversing those. Leaving aside the bad
API design, this is very much _not_ safe to call with KERNEL_DS.
Bail out early if that happens.
commit bc27c01b5c46d3bfec42c96537c7a3fae0bb2cc4 upstream.
The meaning of the BLK_MQ_S_STOPPED flag is "do not call
.queue_rq()". Hence modify blk_mq_make_request() such that requests
are queued instead of issued if a queue has been stopped.
Reported-by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Ming Lei <tom.leiming@gmail.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
In theory we could map other things, but there's a reason that function
is called "user_iov". Using anything else (like splice can do) just
confuses it.
Reported-and-tested-by: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
If we end up sleeping due to running out of requests, we should
update the hardware and software queues in the map ctx structure.
Otherwise we could end up having rq->mq_ctx point to the pre-sleep
context, and risk corrupting ctx->rq_list since we'll be
grabbing the wrong lock when inserting the request.
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: Chris Mason <clm@fb.com>
Tested-by: Chris Mason <clm@fb.com>
Fixes: 63581af3f31e ("blk-mq: remove non-blocking pass in blk_mq_map_request")
This patch fixes one issue reported by Kent, which can
be triggered in bcachefs over sata disk. Actually it
is a generic issue in block flush vs. blk-tag.
Reported-by: Kent Overstreet <kent.overstreet@gmail.com>
When bandblocks_set acknowledges a range or badblocks_clear a range,
it's possible all badblocks are acknowledged. We should update
unacked_exist if this occurs.
Reviewed-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Tested-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Pull block fixes from Jens Axboe:
"A set of fixes that missed the merge window, mostly due to me being
away around that time.
Nothing major here, a mix of nvme cleanups and fixes, and one fix for
the badblocks handling"
* 'for-linus' of git://git.kernel.dk/linux-block:
nvmet: use symbolic constants for CNS values
nvme: use symbolic constants for CNS values
nvme.h: add an enum for cns values
nvme.h: don't use uuid_be
nvme.h: resync with nvme-cli
nvme: Add tertiary number to NVME_VS
nvme : Add sysfs entry for NVMe CMBs when appropriate
nvme: don't schedule multiple resets
nvme: Delete created IO queues on reset
nvme: Stop probing a removed device
badblocks: fix overlapping check for clearing
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc plugins update from Kees Cook:
"This adds a new gcc plugin named "latent_entropy". It is designed to
extract as much possible uncertainty from a running system at boot
time as possible, hoping to capitalize on any possible variation in
CPU operation (due to runtime data differences, hardware differences,
SMP ordering, thermal timing variation, cache behavior, etc).
At the very least, this plugin is a much more comprehensive example
for how to manipulate kernel code using the gcc plugin internals"
* tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
latent_entropy: Mark functions with __latent_entropy
gcc-plugins: Add latent_entropy plugin
