path: root/block
2008-12-13Enforce a minimum SG_IO timeoutLinus Torvalds
commit f2f1fa78a155524b849edf359e42a3001ea652c0 upstream. There's no point in having too short SG_IO timeouts, since if the command does end up timing out, we'll end up through the reset sequence that is several seconds long in order to abort the command that timed out. As a result, shorter timeouts than a few seconds simply do not make sense, as the recovery would be longer than the timeout itself. Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT. Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-20block: fix nr_phys_segments miscalculation bugFUJITA Tomonori
commit 8677142710516d986d932d6f1fba7be8382c1fec upstream backported by Nikanth Karthikesan <knikanth@suse.de> to the 2.6.27.y tree. block: fix nr_phys_segments miscalculation bug This fixes the bug reported by Nikanth Karthikesan <knikanth@suse.de>: http://lkml.org/lkml/2008/10/2/203 The root cause of the bug is that blk_phys_contig_segment miscalculates q->max_segment_size. blk_phys_contig_segment checks: req->biotail->bi_size + next_req->bio->bi_size > q->max_segment_size But blk_recalc_rq_segments might expect that req->biotail and the previous bio in the req are supposed be merged into one segment. blk_recalc_rq_segments might also expect that next_req->bio and the next bio in the next_req are supposed be merged into one segment. In such case, we merge two requests that can't be merged here. Later, blk_rq_map_sg gives more segments than it should. We need to keep track of segment size in blk_recalc_rq_segments and use it to see if two requests can be merged. This patch implements it in the similar way that we used to do for hw merging (virtual merging). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Cc: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-11block: disable sysfs parts of the disk command filterJens Axboe
We still have life time issues with the sysfs command filter kobject, so disable it for 2.6.27 release. We can revisit this and make it work properly for 2.6.28, for 2.6.27 release it's too risky. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-01block: restore original behavior of /proc/partition when there's no partitionTejun Heo
/proc/partitions didn't use to write out the header if there was no partition. However, recent commit 66c64afe changed the behavior. This is nothing major but there's no reason to change user visible behavior without a good rationale. Restore the original behavior. Note that 2.6.28 has clean up changes scheduled which will replace this rather hacky implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-29remove blk_register_filter and blk_unregister_filter in gendiskFUJITA Tomonori
This patch remove blk_register_filter and blk_unregister_filter in gendisk, and adds them to sd.c, sr.c. and ide-cd.c The commit abf5439370491dd6fbb4fe1a7939680d2a9bc9d4 moved cmdfilter from gendisk to request_queue. It turned out that in some subsystems multiple gendisks share a single request_queue. So we get: Using physmap partition information Creating 3 MTD partitions on "physmap-flash": 0x00000000-0x01c00000 : "User FS" 0x01c00000-0x01c40000 : "booter" kobject (8511c410): tried to init an initialized object, something is seriously wrong. Call Trace: [<8036644c>] dump_stack+0x8/0x34 [<8021f050>] kobject_init+0x50/0xcc [<8021fa18>] kobject_init_and_add+0x24/0x58 [<8021d20c>] blk_register_filter+0x4c/0x64 [<8021c194>] add_disk+0x78/0xe0 [<8027d14c>] add_mtd_blktrans_dev+0x254/0x278 [<8027c8f0>] blktrans_notify_add+0x40/0x78 [<80279c00>] add_mtd_device+0xd0/0x150 [<8027b090>] add_mtd_partitions+0x568/0x5d8 [<80285458>] physmap_flash_probe+0x2ac/0x334 [<802644f8>] driver_probe_device+0x12c/0x244 [<8026465c>] __driver_attach+0x4c/0x84 [<80263c64>] bus_for_each_dev+0x58/0xac [<802633ec>] bus_add_driver+0xc4/0x24c [<802648e0>] driver_register+0xcc/0x184 [<80100460>] _stext+0x60/0x1bc In the long term, we need to fix such subsystems but we need a quick fix now. This patch add the command filter support to only sd and sr though it might be useful for other SG_IO users (such as cciss). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reported-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: remove unused ->busy part of the block queue tag mapMatthew Wilcox
It's not used for anything. On top of that, it's racy and can thus trigger a faulty BUG_ON() in __blk_free_tags() on queue exit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: clean up cmdfilter sysfs interfaceAdel Gadllah
This patch changes the interface of the cmd filter to use a +/- notation like: echo -- +0x02 +0x03 -0x08 If neither + or - is given it defaults to + (allow command). Note: The interface was added in 2.6.17-rc1 and is unused and undocumented so far so it's safe to change it. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: jens.axboe@oracle.com Cc: James.Bottomley@hansenpartnership.com Cc: dan.j.williams@intel.com Cc: pjones@redhat.com Cc: viro@zeniv.linux.org.uk Cc: dougg@torque.net Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: rename blk_scsi_cmd_filter to blk_cmd_filterFUJITA Tomonori
Technically, the cmd_filter would be applied to other protocols though it's unlikely to happen. Putting SCSI stuff to request_queue is kinda layer violation. So let's rename it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: move cmdfilter from gendisk to request_queueFUJITA Tomonori
cmd_filter works only for the block layer SG_IO with SCSI block devices. It breaks scsi/sg.c, bsg, and the block layer SG_IO with SCSI character devices (such as st). We hit a kernel crash with them. The problem is that cmd_filter code accesses to gendisk (having struct blk_scsi_cmd_filter) via inode->i_bdev->bd_disk. It works for only SCSI block device files. With character device files, inode->i_bdev leads you to struct cdev. inode->i_bdev->bd_disk->blk_scsi_cmd_filter isn't safe. SCSI ULDs don't expose gendisk; they keep it private. bsg needs to be independent on any protocols. We shouldn't change ULDs to expose their gendisk. This patch moves struct blk_scsi_cmd_filter from gendisk to request_queue, a common object, which eveyone can access to. The user interface doesn't change; users can change the filters via /sys/block/. gendisk has a pointer to request_queue so the cmd_filter code accesses to struct blk_scsi_cmd_filter. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-21block: drop references taken by class_find_device()Kay Sievers
Otherwise we leak references, which is not a good thing to do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21block: fix partial read() of /proc/{partitions,diskstats}Kay Sievers
The proc files get truncated if they do not fit into the buffer with a single read(). We need to move the seq_file index from the callback of class_find_device() to the caller of class_find_device(), to keep its value across multiple invocations of the callback. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] scsi_transport_spi: fix oops in revalidate [SCSI] ses: fix VPD inquiry overrun [SCSI] block: Fix miscalculation of sg_io timeout in CDROM_SEND_PACKET handler. [SCSI] hptiop: add more PCI device IDs
2008-08-01block: add a blk_plug_device_unlocked() that grabs the queue lockJens Axboe
blk_plug_device() must be called with the queue lock held, so callers often just grab and release the lock for that purpose. Add a helper that does just that. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-30[SCSI] block: Fix miscalculation of sg_io timeout in CDROM_SEND_PACKET handler.Tim Wright
It seems cdrwtool in the udftools has been unusable on "modern" kernels for some time. A Google search reveals many people with the same issue but no solution (cdrwtool fails to format the disk). After spending some time tracking down the issue, it comes down to the following: The udftools still use the older CDROM_SEND_PACKET interface to send things like FORMAT_UNIT through to the drive. They should really be updated, but that's another story. Since most distros are using libata now, the cd or dvd burner appears as a SCSI device, and we wind up in block/scsi_ioctl.c. Here, the code tries to take the "struct cdrom_generic_command" and translate it and stuff it into a "struct sg_io_hdr" structure so it can pass it to the modern sg_io() routine instead. Unfortunately, there is one error, or rather an omission in the translation. The timeout that is passed in in the "struct cdrom_generic_command" is in HZ=100 units, and this is modified and correctly converted to jiffies by use of clock_t_to_jiffies(). However, a little further down, this cgc.timeout value in jiffies is simply copied into the sg_io_hdr timeout, which should be in milliseconds. Since most modern x86 kernels seems to be getting build with HZ=250, the timeout that is passed to sg_io and eventually converted to the timeout_per_command member of the scsi_cmnd structure is now four times too small. Since cdrwtool tries to set the timeout to one hour for the FORMAT_UNIT command, and it takes about 20 minutes to format a 4x CDRW, the SCSI error-handler kicks in after the FORMAT_UNIT completes because it took longer than the incorrectly-calculated timeout. [jejb: fix up whitespace] Signed-off-by: Tim Wright <timw@splhi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26Use WARN() in block/Arjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26block/blk-map.c: use the new object_is_on_stack() helperFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25block/ioctl.c and fs/partition/check.c: check value returned by add_partition()Abdel Benamrouche
Now that add_partition() has been aught to propagate errors, let's check them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Abdel Benamrouche <draconux@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21block: make /proc/partitions and /proc/diskstats use class_find_device()Greg Kroah-Hartman
Use the proper class iterator function instead of mucking around in the internals of the class structures. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21block: move header for /proc/partitions to seq_startGreg Kroah-Hartman
The seq_start call is the better place for the header for the file, that way we don't have to be mucking in the class structure to try to figure out if this is the first partition or not. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21block: make proc files seq_start use the class_find_device()Greg Kroah-Hartman
2008-07-21block: make /proc/diskstats only build if CONFIG_PROC_FS is enabledRandy Dunlap
These functions are only needed if CONFIG_PROC_FS is enabled, so save the space when it is not. This also makes it easier for a patch later in this series to work properly if CONFIG_PROC_FS is not enabled. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21block: make blk_lookup_devt use the class iterator functionGreg Kroah-Hartman
2008-07-21block: make printk_partition use the class iterator functionGreg Kroah-Hartman
2008-07-21block: fix compiler warning in genhd.cGreg Kroah-Hartman
Warn if something really bad happens if we can't create this link. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: block: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysfs: add /sys/dev/{char,block} to lookup sysfs path by major:minorDan Williams
Why?: There are occasions where userspace would like to access sysfs attributes for a device but it may not know how sysfs has named the device or the path. For example what is the sysfs path for /dev/disk/by-id/ata-ST3160827AS_5MT004CK? With this change a call to stat(2) returns the major:minor then userspace can see that /sys/dev/block/8:32 links to /sys/block/sdc. What are the alternatives?: 1/ Add an ioctl to return the path: Doable, but sysfs is meant to reduce the need to proliferate ioctl interfaces into the kernel, so this seems counter productive. 2/ Use udev to create these symlinks: Also doable, but it adds a udev dependency to utilities that might be running in a limited environment like an initramfs. 3/ Do a full-tree search of sysfs. [kay.sievers@vrfy.org: fix duplicate registrations] [kay.sievers@vrfy.org: cleanup suggestions] Cc: Neil Brown <neilb@suse.de> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Reviewed-by: SL Baur <steve@xemacs.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Mark Lord <lkml@rtr.ca> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits) [SCSI] scsi_dh: fix kconfig related build errors [SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of [SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h [SCSI] make struct scsi_{host,target}_type static [SCSI] fix locking in host use of blk_plug_device() [SCSI] zfcp: Cleanup external header file [SCSI] zfcp: Cleanup code in zfcp_erp.c [SCSI] zfcp: zfcp_fsf cleanup. [SCSI] zfcp: consolidate sysfs things into one file. [SCSI] zfcp: Cleanup of code in zfcp_aux.c [SCSI] zfcp: Cleanup of code in zfcp_scsi.c [SCSI] zfcp: Move status accessors from zfcp to SCSI include file. [SCSI] zfcp: Small QDIO cleanups [SCSI] zfcp: Adapter reopen for large number of unsolicited status [SCSI] zfcp: Fix error checking for ELS ADISC requests [SCSI] zfcp: wait until adapter is finished with ERP during auto-port [SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver [SCSI] sg: Add target reset support [SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC [SCSI] sd: Move scsi_disk() accessor function to sd.h ...
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (80 commits) ide-floppy: fix unfortunate function naming ide-tape: unify idetape_create_read/write_cmd ide: add ide_pc_intr() helper ide-{floppy,scsi}: read Status Register before stopping DMA engine ide-scsi: add more debugging to idescsi_pc_intr() ide-scsi: use pc->callback ide-floppy: add more debugging to idefloppy_pc_intr() ide-tape: always log debug info in idetape_pc_intr() if debugging is enabled ide-tape: add ide_tape_io_buffers() helper ide-tape: factor out DSC handling from idetape_pc_intr() ide-{floppy,tape}: move checking of ->failed_pc to ->callback ide: add ide_issue_pc() helper ide: add PC_FLAG_DRQ_INTERRUPT pc flag ide-scsi: move idescsi_map_sg() call out from idescsi_issue_pc() ide: add ide_transfer_pc() helper ide-scsi: set drive->scsi flag for devices handled by the driver ide-{cd,floppy,tape}: remove checking for drive->scsi ide: add PC_FLAG_ZIP_DRIVE pc flag ide-tape: factor out waiting for good ireason from idetape_transfer_pc() ide-tape: set PC_FLAG_DMA_IN_PROGRESS flag in idetape_transfer_pc() ...
2008-07-15block: unexport blk_end_sync_rqFUJITA Tomonori
All the users of blk_end_sync_rq has gone (they are converted to use blk_execute_rq). This unexports blk_end_sync_rq. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15block: remove the checking for NULL queue in blk_put_requestFUJITA Tomonori
Some uses blk_put_request asymmetrically, that is, they uses it with requests that not allocated by blk_get_request. As a result, blk_put_request has a hack to catch a NULL request_queue. Now such callers are fixed (they use blk_get_request properly). So we can safely remove the hack in blk_put_request. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15block: handle blk_pm_resume_request() requests in blk_execute_rq_nowait()Bartlomiej Zolnierkiewicz
For blk_pm_resume_request() requests (which are used only by IDE subsystem currently) the queue is stopped so we need to call ->request_fn explicitly. Thanks to: - Rafael for reporting/bisecting the bug - Borislav/Rafael for testing the fix This is a preparation for converting IDE to use blk_execute_rq(). Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-14Merge branch 'core/softirq' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/softirq' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softirq: remove irqs_disabled warning from local_bh_enable softirq: remove initialization of static per-cpu variable Remove argument from open_softirq which is always NULL
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-14Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (37 commits) splice: fix generic_file_splice_read() race with page invalidation ramfs: enable splice write drivers/block/pktcdvd.c: avoid useless memset cdrom: revert commit 22a9189 (cdrom: use kmalloced buffers instead of buffers on stack) scsi: sr avoids useless buffer allocation block: blk_rq_map_kern uses the bounce buffers for stack buffers block: add blk_queue_update_dma_pad DAC960: push down BKL pktcdvd: push BKL down into driver paride: push ioctl down into driver block: use get_unaligned_* helpers block: extend queue_flag bitops block: request_module(): use format string Add bvec_merge_data to handle stacked devices and ->merge_bvec() block: integrity flags can't use bit ops on unsigned short cmdfilter: extend default read filter sg: fix odd style (extra parenthesis) introduced by cmd filter patch block: add bounce support to blk_rq_map_user_iov cfq-iosched: get rid of enable_idle being unused warning allow userspace to modify scsi command filter on per device basis ...
2008-07-12[SCSI] bsg: fix oops on removeJames Bottomley
If you do a modremove of any sas driver, you run into an oops on shutdown when the host is removed (coming from the host bsg device). The root cause seems to be that there's a use after free of the bsg_class_device: In bsg_kref_release_function, this is used (to do a put_device(bcg->parent) after bcg->release has been called. In sas (and possibly many other things) bcd->release frees the queue which contains the bsg_class_device, so we get a put_device on unreferenced memory. Fix this by taking a copy of the pointer to the parent before releasing bsg. Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] bsg: fix bsg_mutex hang with device removalFUJITA Tomonori
We don't need to hold bsg_mutex during bsg_complete_all_commands(). It leads to a problem that we block bsg_unregister_queue during bsg_complete_all_commands (untill all the outstanding commands complete). Thanks to Pete Wyckoff for finding the bug and testing the patch. The detailed bug report is: http://marc.info/?l=linux-scsi&m=121182137132145&w=2 Tested-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-04block: blk_rq_map_kern uses the bounce buffers for stack buffersFUJITA Tomonori
blk_rq_map_kern is used for kernel internal I/Os. Some callers use this function with stack buffers but DMA to/from the stack buffers leads to memory corruption on a non-coherent platform. This patch make blk_rq_map_kern uses the bounce buffers if a caller passes a stack buffer (on the all platforms for simplicity). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-04block: add blk_queue_update_dma_padFUJITA Tomonori
This adds blk_queue_update_dma_pad to prevent LLDs from overwriting the dma pad mask wrongly (we added blk_queue_update_dma_alignment due to the same reason). This also converts libata to use blk_queue_update_dma_pad instead of blk_queue_dma_pad. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: extend queue_flag bitopsJens Axboe
Add test_and_clear and test_and_set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: request_module(): use format stringmaximilian attems
Avoid bad things happening if the module has a printk control string in its name. Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: integrity flags can't use bit ops on unsigned shortJens Axboe
Just use normal open coded bit operations instead, they need not be atomic. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03cmdfilter: extend default read filterAdel Gadllah
This patch adds the commands that the former sg filter allowed for read access to the cmdfilter to keep userspace apps that rely on them working. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: add bounce support to blk_rq_map_user_iovFUJITA Tomonori
blk_rq_map_user_iov can't handle the bounce buffer (it means that the bio_map_user_iov path doesn't work with a LLD that needs GFP_DMA). This patch fixes blk_rq_map_user_iov to support the bounce buffer. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03cfq-iosched: get rid of enable_idle being unused warningJens Axboe
2008-07-03allow userspace to modify scsi command filter on per device basisAdel Gadllah
This patch exports the per-gendisk command filter to user space through sysfs, so it can be changed by the system administrator. All users of the old cmd filter have been converted to use the new one. Original patch from Peter Jones. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: integrity checkpatch cleanupsJens Axboe
> 80 char lines and that sort of thing. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: export "ro" attributeKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03Added in user-injected messages into blk tracesAlan D. Brunelle
This allows a user to annotate the blk trace stream: writing a suitable message to {/sys/kernel/debug}/block/<dsf>/msg will have it propagated into the trace stream. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
