path: root/certs/system_keyring.c
2018-09-09Replace magic for trusting the secondary keyring with #defineYannik Sembritzki
commit 817aef260037f33ee0f44c17fe341323d3aebd6d upstream. Replace the use of a magic number that indicates that verify_*_signature() should use the secondary keyring with a symbol. Signed-off-by: Yannik Sembritzki <yannik@sembritzki.me> Signed-off-by: David Howells <dhowells@redhat.com> Cc: keyrings@vger.kernel.org Cc: linux-security-module@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-11certs: Add a secondary system keyring that can be added to dynamicallyDavid Howells
Add a secondary system keyring that can be added to by root whilst the system is running - provided the key being added is vouched for by a key built into the kernel or already added to the secondary keyring. Rename .system_keyring to .builtin_trusted_keys to distinguish it more obviously from the new keyring (called .secondary_trusted_keys). The new keyring needs to be enabled with CONFIG_SECONDARY_TRUSTED_KEYRING. If the secondary keyring is enabled, a link is created from that to .builtin_trusted_keys so that the the latter will automatically be searched too if the secondary keyring is searched. Signed-off-by: David Howells <dhowells@redhat.com>
2016-04-11KEYS: Remove KEY_FLAG_TRUSTED and KEY_ALLOC_TRUSTEDDavid Howells
Remove KEY_FLAG_TRUSTED and KEY_ALLOC_TRUSTED as they're no longer meaningful. Also we can drop the trusted flag from the preparse structure. Given this, we no longer need to pass the key flags through to restrict_link(). Further, we can now get rid of keyring_restrict_trusted_only() also. Signed-off-by: David Howells <dhowells@redhat.com>
2016-04-11KEYS: Move the point of trust determination to __key_link()David Howells
Move the point at which a key is determined to be trustworthy to __key_link() so that we use the contents of the keyring being linked in to to determine whether the key being linked in is trusted or not. What is 'trusted' then becomes a matter of what's in the keyring. Currently, the test is done when the key is parsed, but given that at that point we can only sensibly refer to the contents of the system trusted keyring, we can only use that as the basis for working out the trustworthiness of a new key. With this change, a trusted keyring is a set of keys that once the trusted-only flag is set cannot be added to except by verification through one of the contained keys. Further, adding a key into a trusted keyring, whilst it might grant trustworthiness in the context of that keyring, does not automatically grant trustworthiness in the context of a second keyring to which it could be secondarily linked. To accomplish this, the authentication data associated with the key source must now be retained. For an X.509 cert, this means the contents of the AuthorityKeyIdentifier and the signature data. If system keyrings are disabled then restrict_link_by_builtin_trusted() resolves to restrict_link_reject(). The integrity digital signature code still works correctly with this as it was previously using KEY_FLAG_TRUSTED_ONLY, which doesn't permit anything to be added if there is no system keyring against which trust can be determined. Signed-off-by: David Howells <dhowells@redhat.com>
2016-04-11KEYS: Add a facility to restrict new links into a keyringDavid Howells
Add a facility whereby proposed new links to be added to a keyring can be vetted, permitting them to be rejected if necessary. This can be used to block public keys from which the signature cannot be verified or for which the signature verification fails. It could also be used to provide blacklisting. This affects operations like add_key(), KEYCTL_LINK and KEYCTL_INSTANTIATE. To this end: (1) A function pointer is added to the key struct that, if set, points to the vetting function. This is called as: int (*restrict_link)(struct key *keyring, const struct key_type *key_type, unsigned long key_flags, const union key_payload *key_payload), where 'keyring' will be the keyring being added to, key_type and key_payload will describe the key being added and key_flags[*] can be AND'ed with KEY_FLAG_TRUSTED. [*] This parameter will be removed in a later patch when KEY_FLAG_TRUSTED is removed. The function should return 0 to allow the link to take place or an error (typically -ENOKEY, -ENOPKG or -EKEYREJECTED) to reject the link. The pointer should not be set directly, but rather should be set through keyring_alloc(). Note that if called during add_key(), preparse is called before this method, but a key isn't actually allocated until after this function is called. (2) KEY_ALLOC_BYPASS_RESTRICTION is added. This can be passed to key_create_or_update() or key_instantiate_and_link() to bypass the restriction check. (3) KEY_FLAG_TRUSTED_ONLY is removed. The entire contents of a keyring with this restriction emplaced can be considered 'trustworthy' by virtue of being in the keyring when that keyring is consulted. (4) key_alloc() and keyring_alloc() take an extra argument that will be used to set restrict_link in the new key. This ensures that the pointer is set before the key is published, thus preventing a window of unrestrictedness. Normally this argument will be NULL. (5) As a temporary affair, keyring_restrict_trusted_only() is added. It should be passed to keyring_alloc() as the extra argument instead of setting KEY_FLAG_TRUSTED_ONLY on a keyring. This will be replaced in a later patch with functions that look in the appropriate places for authoritative keys. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2016-04-06PKCS#7: Make trust determination dependent on contents of trust keyringDavid Howells
Make the determination of the trustworthiness of a key dependent on whether a key that can verify it is present in the supplied ring of trusted keys rather than whether or not the verifying key has KEY_FLAG_TRUSTED set. verify_pkcs7_signature() will return -ENOKEY if the PKCS#7 message trust chain cannot be verified. Signed-off-by: David Howells <dhowells@redhat.com>
2016-04-06KEYS: Generalise system_verify_data() to provide access to internal contentDavid Howells
Generalise system_verify_data() to provide access to internal content through a callback. This allows all the PKCS#7 stuff to be hidden inside this function and removed from the PE file parser and the PKCS#7 test key. If external content is not required, NULL should be passed as data to the function. If the callback is not required, that can be set to NULL. The function is now called verify_pkcs7_signature() to contrast with verify_pefile_signature() and the definitions of both have been moved into linux/verification.h along with the key_being_used_for enum. Signed-off-by: David Howells <dhowells@redhat.com>
2016-02-09KEYS: Add an alloc flag to convey the builtinness of a keyDavid Howells
Add KEY_ALLOC_BUILT_IN to convey that a key should have KEY_FLAG_BUILTIN set rather than setting it after the fact. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-08-14Move certificate handling to its own directoryDavid Howells
Move certificate handling out of the kernel/ directory and into a certs/ directory to get all the weird stuff in one place and move the generated signing keys into this directory. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
