When allocation is bigger than L2 size it is more optimal to
flush or writeback whole L2 instead of doing maintenance
for each allocated page.
bug 983964
Change-Id: Ibb3609be71621ff9ab75bea9146bfe7578f9315a
Signed-off-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-on: http://git-master/r/127835
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Framebuffer console init failed issue will be fixed by:
http://git-master/r/#change,107866
So we should enable framebuffer console now.
Bug 996992
Bug 941073
Change-Id: I6841248fad406f4a00055062691f5794145c030a
Signed-off-by: Mark Zhang <markz@nvidia.com>
Reviewed-on: http://git-master/r/124805
Reviewed-by: Peer Chen <pchen@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Allen Martin <amartin@nvidia.com>
The dm "crypt" target is needed for encrypted /var support.
Additionally, since the expected hash alg will be sha256, built it in,
and ready future support for sha512 as a module.
BUG=chromium-os:22172
TEST=build, boot amd64-generic, verify target listed in "dmsetup targets"
Reviewed-on: https://gerrit.chromium.org/gerrit/15548
Tested-by: Kees Cook <keescook@chromium.org>
Commit-Ready: Kees Cook <keescook@chromium.org>
(cherry-picked from commit 50180f134a6e23be3ce763524b6b5193d848c0f7)
Modified to use:
chromeos/config/config.common.chromeos
instead of:
chromeos/config/base.config
Change-Id: Iac31f59f340f52a7017948fd5add3d316d38a123
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Reviewed-on: http://git-master/r/117151
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Renormalize split configs based on current TOT k3.1 kernel and
remove DEBUG_LL to clean up the kernel log a bit.
BUG=None
TEST=Verified generated config doesn't prompt.
Change-Id: Ib13e633742a2c4e0060629d145e0571e7a7d5241
Reviewed-on: http://git-master/r/116136
Update split configs to enable the brcmfmac driver for wifi. Also
renormalize the split configs.
BUG=1007114
TEST=Using 6/20/2012 nightly image I was able to browse the web
using wifi
Change-Id: Ia810032861cf1015c3a0127cfa07f865a05e9028
Reviewed-on: http://git-master/r/111335
Reviewed-by: Wei Ni <wni@nvidia.com>
The ChromeOS build environment expects to build the kernel using a splitconfig.
This change adds the scripts and configs required to satisfy this requirement.
Right now the chromeos-tegra3 config is the only supported configuration using
the splitconfigs.
Change-Id: I21ac515261a03bdbe1c79bbd6cd02a6e34c82ef9
Reviewed-on: http://git-master/r/103683
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
