path: root/crypto/842.c
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-07crypto: 842 - remove .cra_list initializationJussi Kivilinna
.cra_list initialization is unneeded and have been removed from all other crypto modules except 842. Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01powerpc/crypto: add 842 crypto driverSeth Jennings
This patch add the 842 cryptographic API driver that submits compression requests to the 842 hardware compression accelerator driver (nx-compress). If the hardware accelerator goes offline for any reason (dynamic disable, migration, etc...), this driver will use LZO as a software failover for all future compression requests. For decompression requests, the 842 hardware driver contains a software implementation of the 842 decompressor to support the decompression of data that was compressed before the accelerator went offline. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
