commit b5b9007730ce1d90deaf25d7f678511550744bdc upstream.
This fixes a typo in the CRYPTO_KPP dependency of CRYPTO_ECDH.
Fixes: 3c4b23901a0c ("crypto: ecdh - Add ECDH software support")
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This reverts commit 6145171a6bc0abdc3eca7a4b795ede467d2ba569.
The commit fixes a bug that was only introduced in 4.10, thus is
irrelevant for <=4.9.
[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ]
Since the
commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40
crypto: xts - Convert to skcipher
the XTS mode is based on ECB, so the mode must select
ECB otherwise it can fail to initialize.
Signed-off-by: Milan Broz <gmazyland@gmail.com>
The optimised crc32c implementation depends on VMX (aka. Altivec)
instructions, so the kernel must be built with Altivec support in order
for the crc32c code to build.
Fixes: 6dd7a82cc54e ("crypto: powerpc - Add POWER8 optimised crc32c")
Acked-by: Anton Blanchard <anton@samba.org>
Use the vector polynomial multiply-sum instructions in POWER8 to
speed up crc32c.
This is just over 41x faster than the slice-by-8 method that it
replaces. Measurements on a 4.1 GHz POWER8 show it sustaining
52 GiB/sec.
A simple btrfs write performance test:
dd if=/dev/zero of=/mnt/tmpfile bs=1M count=4096
sync
is over 3.7x faster.
Add the config CRYPTO_SHA512_MB which will enable the computation
using the SHA512 multi-buffer algorithm.
Signed-off-by: Megha Dey <megha.dey@linux.intel.com>
Reviewed-by: Fenghua Yu <fenghua.yu@intel.com>
Reviewed-by: Tim Chen <tim.c.chen@linux.intel.com>
Add the config CRYPTO_SHA256_MB which will enable the computation using the
SHA256 multi-buffer algorithm.
* Implement ECDH under kpp API
* Provide ECC software support for curve P-192 and
P-256.
* Add kpp test for ECDH with data generated by OpenSSL
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
* Implement MPI based Diffie-Hellman under kpp API
* Test provided uses data generad by OpenSSL
Add key-agreement protocol primitives (kpp) API which allows to
implement primitives required by protocols such as DH and ECDH.
The API is composed mainly by the following functions
* set_secret() - It allows the user to set his secret, also
referred to as his private key, along with the parameters
known to both parties involved in the key-agreement session.
* generate_public_key() - It generates the public key to be sent to
the other counterpart involved in the key-agreement session. The
function has to be called after set_params() and set_secret()
* generate_secret() - It generates the shared secret for the session
Other functions such as init() and exit() are provided for allowing
cryptographic hardware to be inizialized properly before use
This patch adds the implementation of SHA3 algorithm
in software and it's based on original implementation
pushed in patch https://lwn.net/Articles/518415/ with
additional changes to match the padding rules specified
in SHA-3 specification.
Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com>
The CTR DRBG derives its random data from the CTR that is encrypted with
AES.
This patch now changes the CTR DRBG implementation such that the
CTR AES mode is employed. This allows the use of steamlined CTR AES
implementation such as ctr-aes-aesni.
Unfortunately there are the following subtile changes we need to apply
when using the CTR AES mode:
- the CTR mode increments the counter after the cipher operation, but
the CTR DRBG requires the increment before the cipher op. Hence, the
crypto_inc is applied to the counter (drbg->V) once it is
recalculated.
- the CTR mode wants to encrypt data, but the CTR DRBG is interested in
the encrypted counter only. The full CTR mode is the XOR of the
encrypted counter with the plaintext data. To access the encrypted
counter, the patch uses a NULL data vector as plaintext to be
"encrypted".
Signed-off-by: Stephan Mueller <smueller@chronox.de>
The pkcs1pad template needs CRYPTO_MANAGER so it needs
to be explicitly selected by CRYPTO_RSA.
Reported-by: Jamie Heilman <jamie@audible.transient.net>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.6:
API:
- Convert remaining crypto_hash users to shash or ahash, also convert
blkcipher/ablkcipher users to skcipher.
- Remove crypto_hash interface.
- Remove crypto_pcomp interface.
- Add crypto engine for async cipher drivers.
- Add akcipher documentation.
- Add skcipher documentation.
Algorithms:
- Rename crypto/crc32 to avoid name clash with lib/crc32.
- Fix bug in keywrap where we zero the wrong pointer.
Drivers:
- Support T5/M5, T7/M7 SPARC CPUs in n2 hwrng driver.
- Add PIC32 hwrng driver.
- Support BCM6368 in bcm63xx hwrng driver.
- Pack structs for 32-bit compat users in qat.
- Use crypto engine in omap-aes.
- Add support for sama5d2x SoCs in atmel-sha.
- Make atmel-sha available again.
- Make sahara hashing available again.
- Make ccp hashing available again.
- Make sha1-mb available again.
- Add support for multiple devices in ccp.
- Improve DMA performance in caam.
- Add hashing support to rockchip"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (116 commits)
crypto: qat - remove redundant arbiter configuration
crypto: ux500 - fix checks of error code returned by devm_ioremap_resource()
crypto: atmel - fix checks of error code returned by devm_ioremap_resource()
crypto: qat - Change the definition of icp_qat_uof_regtype
hwrng: exynos - use __maybe_unused to hide pm functions
crypto: ccp - Add abstraction for device-specific calls
crypto: ccp - CCP versioning support
crypto: ccp - Support for multiple CCPs
crypto: ccp - Remove check for x86 family and model
crypto: ccp - memset request context to zero during import
lib/mpi: use "static inline" instead of "extern inline"
lib/mpi: avoid assembler warning
hwrng: bcm63xx - fix non device tree compatibility
crypto: testmgr - allow rfc3686 aes-ctr variants in fips mode.
crypto: qat - The AE id should be less than the maximal AE number
lib/mpi: Endianness fix
crypto: rockchip - add hash support for crypto engine in rk3288
crypto: xts - fix compile errors
crypto: doc - add skcipher API documentation
crypto: doc - update AEAD AD handling
Now block cipher engines need to implement and maintain their own queue/thread
for processing requests, moreover currently helpers provided for only the queue
itself (in crypto_enqueue_request() and crypto_dequeue_request()) but they
don't help with the mechanics of driving the hardware (things like running the
request immediately, DMA map it or providing a thread to process the queue in)
even though a lot of that code really shouldn't vary that much from device to
device.
Thus this patch provides a mechanism for pushing requests to the hardware
as it becomes free that drivers could use. And this framework is patterned
on the SPI code and has worked out well there.
(https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/
drivers/spi/spi.c?id=ffbbdd21329f3e15eeca6df2d4bc11c04d9d91c0)
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
When building the jitterentropy driver by itself, we get a link error
when CRYPTO_RNG is not enabled as well:
crypto/built-in.o: In function `jent_mod_init':
jitterentropy-kcapi.c:(.init.text+0x98): undefined reference to `crypto_register_rng'
crypto/built-in.o: In function `jent_mod_exit':
jitterentropy-kcapi.c:(.exit.text+0x60): undefined reference to `crypto_unregister_rng'
This adds a 'select CRYPTO_RNG' to CRYPTO_JITTERENTROPY to ensure the API
is always there when it's used, not just when DRBG is also enabled.
CRYPTO_DRBG would set it implicitly through CRYPTO_JITTERENTROPY now,
but this leaves it in place to make it explicit what the driver does.
It is unused now, so remove it.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
The ghash and poly1305 hash implementations can be enabled when
CONFIG_CRYPTO_HASH is turned off, causing a link error:
crypto/built-in.o: In function `ghash_mod_init':
(.init.text+0xd0): undefined reference to `crypto_register_shash'
crypto/built-in.o: In function `ghash_mod_exit':
(.exit.text+0xb4): undefined reference to `crypto_unregister_shash'
crypto/built-in.o: In function `poly1305_mod_init':
(.init.text+0xb4): undefined reference to `crypto_register_shash'
crypto/built-in.o: In function `poly1305_mod_exit':
(.exit.text+0x98): undefined reference to `crypto_unregister_shash'
This adds an explicit 'select', like all other hashes have it.
Hook keywrap source code into Kconfig and Makefile
and SHA256
This patch provides the configuration and build support to
include and build the optimized SHA1 and SHA256 update transforms
for the kernel's crypto library.
Originally-by: Chandramouli Narayanan <mouli_7982@yahoo.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- PKCS#7 support added to support signed kexec, also utilized for
module signing. See comments in 3f1e1bea.
** NOTE: this requires linking against the OpenSSL library, which
must be installed, e.g. the openssl-devel on Fedora **
- Smack
- add IPv6 host labeling; ignore labels on kernel threads
- support smack labeling mounts which use binary mount data
- SELinux:
- add ioctl whitelisting (see
http://kernsec.org/files/lss2015/vanderstoep.pdf)
- fix mprotect PROT_EXEC regression caused by mm change
- Seccomp:
- add ptrace options for suspend/resume"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (57 commits)
PKCS#7: Add OIDs for sha224, sha284 and sha512 hash algos and use them
Documentation/Changes: Now need OpenSSL devel packages for module signing
scripts: add extract-cert and sign-file to .gitignore
modsign: Handle signing key in source tree
modsign: Use if_changed rule for extracting cert from module signing key
Move certificate handling to its own directory
sign-file: Fix warning about BIO_reset() return value
PKCS#7: Add MODULE_LICENSE() to test module
Smack - Fix build error with bringup unconfigured
sign-file: Document dependency on OpenSSL devel libraries
PKCS#7: Appropriately restrict authenticated attributes and content type
KEYS: Add a name for PKEY_ID_PKCS7
PKCS#7: Improve and export the X.509 ASN.1 time object decoder
modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYS
extract-cert: Cope with multiple X.509 certificates in a single file
sign-file: Generate CMS message as signature instead of PKCS#7
PKCS#7: Support CMS messages also [RFC5652]
X.509: Change recorded SKID & AKID to not include Subject or Issuer
PKCS#7: Check content type and versions
MAINTAINERS: The keyrings mailing list has moved
This patch adds a missing tristate statement to Kconfig for the
new CRYPTO_NULL2 option.
Fixes: 149a39717dcc ("crypto: aead - Add type-safe geniv init/exit helpers")
Reported-by: Stephan Mueller <smueller@chronox.de>
This patch adds the helpers aead_init_geniv and aead_exit_geniv
which are type-safe and intended the replace the existing geniv
init/exit helpers.
Move certificate handling out of the kernel/ directory and into a certs/
directory to get all the weird stuff in one place and move the generated
signing keys into this directory.
Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
CRYPTO_AUTHENC needs to depend on CRYPTO_NULL as authenc uses
null for copying.
Reported-by: Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Extends the x86_64 Poly1305 authenticator by a function processing four
consecutive Poly1305 blocks in parallel using AVX2 instructions.
For large messages, throughput increases by ~15-45% compared to two
block SSE2:
testing speed of poly1305 (poly1305-simd)
test 0 ( 96 byte blocks, 16 bytes per update, 6 updates): 3809514 opers/sec, 365713411 bytes/sec
test 1 ( 96 byte blocks, 32 bytes per update, 3 updates): 5973423 opers/sec, 573448627 bytes/sec
test 2 ( 96 byte blocks, 96 bytes per update, 1 updates): 9446779 opers/sec, 906890803 bytes/sec
test 3 ( 288 byte blocks, 16 bytes per update, 18 updates): 1364814 opers/sec, 393066691 bytes/sec
test 4 ( 288 byte blocks, 32 bytes per update, 9 updates): 2045780 opers/sec, 589184697 bytes/sec
test 5 ( 288 byte blocks, 288 bytes per update, 1 updates): 3711946 opers/sec, 1069040592 bytes/sec
test 6 ( 1056 byte blocks, 32 bytes per update, 33 updates): 573686 opers/sec, 605812732 bytes/sec
test 7 ( 1056 byte blocks, 1056 bytes per update, 1 updates): 1647802 opers/sec, 1740079440 bytes/sec
test 8 ( 2080 byte blocks, 32 bytes per update, 65 updates): 292970 opers/sec, 609378224 bytes/sec
test 9 ( 2080 byte blocks, 2080 bytes per update, 1 updates): 943229 opers/sec, 1961916528 bytes/sec
test 10 ( 4128 byte blocks, 4128 bytes per update, 1 updates): 494623 opers/sec, 2041804569 bytes/sec
test 11 ( 8224 byte blocks, 8224 bytes per update, 1 updates): 254045 opers/sec, 2089271014 bytes/sec
test 0 ( 96 byte blocks, 16 bytes per update, 6 updates): 3826224 opers/sec, 367317552 bytes/sec
test 1 ( 96 byte blocks, 32 bytes per update, 3 updates): 5948638 opers/sec, 571069267 bytes/sec
test 2 ( 96 byte blocks, 96 bytes per update, 1 updates): 9439110 opers/sec, 906154627 bytes/sec
test 3 ( 288 byte blocks, 16 bytes per update, 18 updates): 1367756 opers/sec, 393913872 bytes/sec
test 4 ( 288 byte blocks, 32 bytes per update, 9 updates): 2056881 opers/sec, 592381958 bytes/sec
test 5 ( 288 byte blocks, 288 bytes per update, 1 updates): 3711153 opers/sec, 1068812179 bytes/sec
test 6 ( 1056 byte blocks, 32 bytes per update, 33 updates): 574940 opers/sec, 607136745 bytes/sec
test 7 ( 1056 byte blocks, 1056 bytes per update, 1 updates): 1948830 opers/sec, 2057964585 bytes/sec
test 8 ( 2080 byte blocks, 32 bytes per update, 65 updates): 293308 opers/sec, 610082096 bytes/sec
test 9 ( 2080 byte blocks, 2080 bytes per update, 1 updates): 1235224 opers/sec, 2569267792 bytes/sec
test 10 ( 4128 byte blocks, 4128 bytes per update, 1 updates): 684405 opers/sec, 2825226316 bytes/sec
test 11 ( 8224 byte blocks, 8224 bytes per update, 1 updates): 367101 opers/sec, 3019039446 bytes/sec
Benchmark results from a Core i5-4670T.
Signed-off-by: Martin Willi <martin@strongswan.org>
Implements an x86_64 assembler driver for the Poly1305 authenticator. This
single block variant holds the 130-bit integer in 5 32-bit words, but uses
SSE to do two multiplications/additions in parallel.
When calling updates with small blocks, the overhead for kernel_fpu_begin/
kernel_fpu_end() negates the perfmance gain. We therefore use the
poly1305-generic fallback for small updates.
For large messages, throughput increases by ~5-10% compared to
poly1305-generic:
testing speed of poly1305 (poly1305-generic)
test 0 ( 96 byte blocks, 16 bytes per update, 6 updates): 4080026 opers/sec, 391682496 bytes/sec
test 1 ( 96 byte blocks, 32 bytes per update, 3 updates): 6221094 opers/sec, 597225024 bytes/sec
test 2 ( 96 byte blocks, 96 bytes per update, 1 updates): 9609750 opers/sec, 922536057 bytes/sec
test 3 ( 288 byte blocks, 16 bytes per update, 18 updates): 1459379 opers/sec, 420301267 bytes/sec
test 4 ( 288 byte blocks, 32 bytes per update, 9 updates): 2115179 opers/sec, 609171609 bytes/sec
test 5 ( 288 byte blocks, 288 bytes per update, 1 updates): 3729874 opers/sec, 1074203856 bytes/sec
test 6 ( 1056 byte blocks, 32 bytes per update, 33 updates): 593000 opers/sec, 626208000 bytes/sec
test 7 ( 1056 byte blocks, 1056 bytes per update, 1 updates): 1081536 opers/sec, 1142102332 bytes/sec
test 8 ( 2080 byte blocks, 32 bytes per update, 65 updates): 302077 opers/sec, 628320576 bytes/sec
test 9 ( 2080 byte blocks, 2080 bytes per update, 1 updates): 554384 opers/sec, 1153120176 bytes/sec
test 10 ( 4128 byte blocks, 4128 bytes per update, 1 updates): 278715 opers/sec, 1150536345 bytes/sec
test 11 ( 8224 byte blocks, 8224 bytes per update, 1 updates): 140202 opers/sec, 1153022070 bytes/sec
test 0 ( 96 byte blocks, 16 bytes per update, 6 updates): 3790063 opers/sec, 363846076 bytes/sec
test 1 ( 96 byte blocks, 32 bytes per update, 3 updates): 5913378 opers/sec, 567684355 bytes/sec
test 2 ( 96 byte blocks, 96 bytes per update, 1 updates): 9352574 opers/sec, 897847104 bytes/sec
test 3 ( 288 byte blocks, 16 bytes per update, 18 updates): 1362145 opers/sec, 392297990 bytes/sec
test 4 ( 288 byte blocks, 32 bytes per update, 9 updates): 2007075 opers/sec, 578037628 bytes/sec
test 5 ( 288 byte blocks, 288 bytes per update, 1 updates): 3709811 opers/sec, 1068425798 bytes/sec
test 6 ( 1056 byte blocks, 32 bytes per update, 33 updates): 566272 opers/sec, 597984182 bytes/sec
test 7 ( 1056 byte blocks, 1056 bytes per update, 1 updates): 1111657 opers/sec, 1173910108 bytes/sec
test 8 ( 2080 byte blocks, 32 bytes per update, 65 updates): 288857 opers/sec, 600823808 bytes/sec
test 9 ( 2080 byte blocks, 2080 bytes per update, 1 updates): 590746 opers/sec, 1228751888 bytes/sec
test 10 ( 4128 byte blocks, 4128 bytes per update, 1 updates): 301825 opers/sec, 1245936902 bytes/sec
test 11 ( 8224 byte blocks, 8224 bytes per update, 1 updates): 153075 opers/sec, 1258896201 bytes/sec
Extends the x86_64 ChaCha20 implementation by a function processing eight
ChaCha20 blocks in parallel using AVX2.
For large messages, throughput increases by ~55-70% compared to four block
SSSE3:
testing speed of chacha20 (chacha20-simd) encryption
test 0 (256 bit key, 16 byte blocks): 42249230 operations in 10 seconds (675987680 bytes)
test 1 (256 bit key, 64 byte blocks): 46441641 operations in 10 seconds (2972265024 bytes)
test 2 (256 bit key, 256 byte blocks): 33028112 operations in 10 seconds (8455196672 bytes)
test 3 (256 bit key, 1024 byte blocks): 11568759 operations in 10 seconds (11846409216 bytes)
test 4 (256 bit key, 8192 byte blocks): 1448761 operations in 10 seconds (11868250112 bytes)
test 0 (256 bit key, 16 byte blocks): 41999675 operations in 10 seconds (671994800 bytes)
test 1 (256 bit key, 64 byte blocks): 45805908 operations in 10 seconds (2931578112 bytes)
test 2 (256 bit key, 256 byte blocks): 32814947 operations in 10 seconds (8400626432 bytes)
test 3 (256 bit key, 1024 byte blocks): 19777167 operations in 10 seconds (20251819008 bytes)
test 4 (256 bit key, 8192 byte blocks): 2279321 operations in 10 seconds (18672197632 bytes)
Implements an x86_64 assembler driver for the ChaCha20 stream cipher. This
single block variant works on a single state matrix using SSE instructions.
It requires SSSE3 due the use of pshufb for efficient 8/16-bit rotate
operations.
For large messages, throughput increases by ~65% compared to
chacha20-generic:
testing speed of chacha20 (chacha20-generic) encryption
test 0 (256 bit key, 16 byte blocks): 45089207 operations in 10 seconds (721427312 bytes)
test 1 (256 bit key, 64 byte blocks): 43839521 operations in 10 seconds (2805729344 bytes)
test 2 (256 bit key, 256 byte blocks): 12702056 operations in 10 seconds (3251726336 bytes)
test 3 (256 bit key, 1024 byte blocks): 3371173 operations in 10 seconds (3452081152 bytes)
test 4 (256 bit key, 8192 byte blocks): 422468 operations in 10 seconds (3460857856 bytes)
test 0 (256 bit key, 16 byte blocks): 43141886 operations in 10 seconds (690270176 bytes)
test 1 (256 bit key, 64 byte blocks): 46845874 operations in 10 seconds (2998135936 bytes)
test 2 (256 bit key, 256 byte blocks): 18458512 operations in 10 seconds (4725379072 bytes)
test 3 (256 bit key, 1024 byte blocks): 5360533 operations in 10 seconds (5489185792 bytes)
test 4 (256 bit key, 8192 byte blocks): 692846 operations in 10 seconds (5675794432 bytes)
Should be CRYPTO_AKCIPHER instead of AKCIPHER
Reported-by: Andreas Ruprecht <andreas.ruprecht@fau.de>
New test vectors for RSA algorithm.
Add a new rsa generic SW implementation.
This implements only cryptographic primitives.
Added select on ASN1.
Add Public Key Encryption API.
Made CRYPTO_AKCIPHER invisible like other type config options.
The hash-based DRBG variants all use sha256 so we need to add a
select on it.
This patch creates a new invisible Kconfig option CRYPTO_RNG_DEFAULT
that simply selects the DRBG. This new option is then selected
by the IV generators.
As this is required by many IPsec algorithms, let's set the default
to m.
This AEAD uses a chacha20 ablkcipher and a poly1305 ahash to construct the
ChaCha20-Poly1305 AEAD as defined in RFC7539. It supports both synchronous and
asynchronous operations, even if we currently have no async chacha20 or poly1305
drivers.
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
Poly1305 is a fast message authenticator designed by Daniel J. Bernstein.
It is further defined in RFC7539 as a building block for the ChaCha20-Poly1305
AEAD for use in IETF protocols.
This is a portable C implementation of the algorithm without architecture
specific optimizations, based on public domain code by Daniel J. Bernstein and
Andrew Moon.
ChaCha20 is a high speed 256-bit key size stream cipher algorithm designed by
Daniel J. Bernstein. It is further specified in RFC7539 for use in IETF
protocols as a building block for the ChaCha20-Poly1305 AEAD.
This is a portable C implementation without any architecture specific
optimizations. It uses a 16-byte IV, which includes the 12-byte ChaCha20 nonce
prepended by the initial block counter. Some algorithms require an explicit
counter value, for example the mentioned AEAD construction.
This reverts commit f858c7bcca8c20761a20593439fe998b4b67e86b as
the algif_aead interface has been switched over to the new AEAD
interface.
Merge the crypto tree for 4.1 to pull in the changeset that disables
algif_aead.
The CPU Jitter RNG provides a source of good entropy by
collecting CPU executing time jitter. The entropy in the CPU
execution time jitter is magnified by the CPU Jitter Random
Number Generator. The CPU Jitter Random Number Generator uses
the CPU execution timing jitter to generate a bit stream
which complies with different statistical measurements that
determine the bit stream is random.
The CPU Jitter Random Number Generator delivers entropy which
follows information theoretical requirements. Based on these
studies and the implementation, the caller can assume that
one bit of data extracted from the CPU Jitter Random Number
Generator holds one bit of entropy.
The CPU Jitter Random Number Generator provides a decentralized
source of entropy, i.e. every caller can operate on a private
state of the entropy pool.
The RNG does not have any dependencies on any other service
in the kernel. The RNG only needs a high-resolution time
stamp.
Further design details, the cryptographic assessment and
large array of test results are documented at
http://www.chronox.de/jent.html.
CC: Andreas Steffen <andreas.steffen@strongswan.org>
CC: Theodore Ts'o <tytso@mit.edu>
CC: Sandy Harris <sandyinchina@gmail.com>
The newly added AEAD user-space isn't quite ready for prime time
just yet. In particular it is conflicting with the AEAD single
SG list interface change so this patch disables it now.
Once the SG list stuff is completely done we can then renable
this interface.
This patch adds a new AEAD IV generator echainiv. It is intended
to replace the existing skcipher IV generator eseqiv.
If the underlying AEAD algorithm is using the old AEAD interface,
then echainiv will simply use its IV generator.
Otherwise, echainiv will encrypt a counter just like eseqiv but
it'll first xor it against a previously stored IV similar to
chainiv.
This patch converts the seqiv IV generator to work with the new
AEAD interface where IV generators are just normal AEAD algorithms.
Full backwards compatibility is paramount at this point since
no users have yet switched over to the new interface. Nor can
they switch to the new interface until IV generation is fully
supported by it.
So this means we are adding two versions of seqiv alongside the
existing one. The first one is the one that will be used when
the underlying AEAD algorithm has switched over to the new AEAD
interface. The second one handles the current case where the
underlying AEAD algorithm still uses the old interface.
Both versions export themselves through the new AEAD interface.
Change the crypto 842 compression alg to use the software 842 compression
and decompression library. Add the crypto driver_name as "842-generic".
Remove the fallback to LZO compression.
Previously, this crypto compression alg attemped 842 compression using
PowerPC hardware, and fell back to LZO compression and decompression if
the 842 PowerPC hardware was unavailable or failed. This should not
fall back to any other compression method, however; users of this crypto
compression alg can fallback if desired, and transparent fallback tricks
callers into thinking they are getting 842 compression when they actually
get LZO compression - the failure of the 842 hardware should not be
transparent to the caller.
The crypto compression alg for a hardware device also should not be located
in crypto/ so this is now a software-only implementation that uses the 842
software compression/decompression library.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
This patch fix a spelling typo in crypto/Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
This moves all Kconfig symbols defined in crypto/Kconfig that depend
on CONFIG_ARM to a dedicated Kconfig file in arch/arm/crypto, which is
where the code that implements those features resides as well.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Enable user to select OCTEON SHA1/256/512 modules.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Integrate the module into the kernel config tree.
Signed-off-by: Markus Stockhausen <stockhausen@collogia.de>
