path: root/crypto/aegis128-neon.c
2019-08-15crypto: arm64/aegis128 - implement plain NEON versionArd Biesheuvel
Provide a version of the core AES transform to the aegis128 SIMD code that does not rely on the special AES instructions, but uses plain NEON instructions instead. This allows the SIMD version of the aegis128 driver to be used on arm64 systems that do not implement those instructions (which are not mandatory in the architecture), such as the Raspberry Pi 3. Since GCC makes a mess of this when using the tbl/tbx intrinsics to perform the sbox substitution, preload the Sbox into v16..v31 in this case and use inline asm to emit the tbl/tbx instructions. Clang does not support this approach, nor does it require it, since it does a much better job at code generation, so there we use the intrinsics as usual. Cc: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-08-15crypto: aegis128 - provide a SIMD implementation based on NEON intrinsicsArd Biesheuvel
Provide an accelerated implementation of aegis128 by wiring up the SIMD hooks in the generic driver to an implementation based on NEON intrinsics, which can be compiled to both ARM and arm64 code. This results in a performance of 2.2 cycles per byte on Cortex-A53, which is a performance increase of ~11x compared to the generic code. Reviewed-by: Ondrej Mosnacek <omosnace@redhat.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-08-02Revert "crypto: aegis128 - add support for SIMD acceleration"Herbert Xu
This reverts commit ecc8bc81f2fb3976737ef312f824ba6053aa3590 ("crypto: aegis128 - provide a SIMD implementation based on NEON intrinsics") and commit 7cdc0ddbf74a19cecb2f0e9efa2cae9d3c665189 ("crypto: aegis128 - add support for SIMD acceleration"). They cause compile errors on platforms other than ARM because the mechanism to selectively compile the SIMD code is broken. Repoted-by: Heiko Carstens <heiko.carstens@de.ibm.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-07-26crypto: aegis128 - provide a SIMD implementation based on NEON intrinsicsArd Biesheuvel
