commit 7e77bdebff5cb1e9876c561f69710b9ab8fa1f7e upstream.
If a request is backlogged, it's complete() handler will get called
twice: once with -EINPROGRESS, and once with the final error code.
af_alg's complete handler, unlike other users, does not handle the
-EINPROGRESS but instead always completes the completion that recvmsg()
is waiting on. This can lead to a return to user space while the
request is still pending in the driver. If userspace closes the sockets
before the requests are handled by the driver, this will lead to
use-after-frees (and potential crashes) in the kernel due to the tfm
having been freed.
The crashes can be easily reproduced (for example) by reducing the max
queue length in cryptod.c and running the following (from
http://www.chronox.de/libkcapi.html) on AES-NI capable hardware:
$ while true; do kcapi -x 1 -e -c '__ecb-aes-aesni' \
-k 00000000000000000000000000000000 \
-p 00000000000000000000000000000000 >/dev/null & done
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
commit 4c63f83c2c2e16a13ce274ee678e28246bd33645 upstream.
Th AF_ALG socket was missing a security label (e.g. SELinux)
which means that socket was in "unlabeled" state.
This was recently demonstrated in the cryptsetup package
(cryptsetup v1.6.5 and later.)
See https://bugzilla.redhat.com/show_bug.cgi?id=1115120
This patch clones the sock's label from the parent sock
and resolves the issue (similar to AF_BLUETOOTH protocol family).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
Acked-by: Paul Moore <paul@paul-moore.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Change data type to fix warning:
crypto/af_alg.c:35: warning: initialization from incompatible pointer type
Signed-off-by: Miloslav Trmač <mitr@redhat.com>
This patch creates the backbone of the user-space interface for
the Crypto API, through a new socket family AF_ALG.
Each session corresponds to one or more connections obtained from
that socket. The number depends on the number of inputs/outputs
of that particular type of operation. For most types there will
be a s ingle connection/file descriptor that is used for both input
and output. AEAD is one of the few that require two inputs.
Each algorithm type will provide its own implementation that plugs
into af_alg. They're keyed using a string such as "skcipher" or
"hash".
IOW this patch only contains the boring bits that is required
to hold everything together.
Thakns to Miloslav Trmac for reviewing this and contributing
fixes and improvements.
Tested-by: Martin Willi <martin@strongswan.org>
