commit 9a00674213a3f00394f4e3221b88f2d21fc05789 upstream.
syzkaller triggered a NULL pointer dereference in crypto_remove_spawns()
via a program that repeatedly and concurrently requests AEADs
"authenc(cmac(des3_ede-asm),pcbc-aes-aesni)" and hashes "cmac(des3_ede)"
through AF_ALG, where the hashes are requested as "untested"
(CRYPTO_ALG_TESTED is set in ->salg_mask but clear in ->salg_feat; this
causes the template to be instantiated for every request).
Although AF_ALG users really shouldn't be able to request an "untested"
algorithm, the NULL pointer dereference is actually caused by a
longstanding race condition where crypto_remove_spawns() can encounter
an instance which has had spawn(s) "grabbed" but hasn't yet been
registered, resulting in ->cra_users still being NULL.
We probably should properly initialize ->cra_users earlier, but that
would require updating many templates individually. For now just fix
the bug in a simple way that can easily be backported: make
crypto_remove_spawns() treat a NULL ->cra_users list as empty.
Reported-by: syzbot <syzkaller@googlegroups.com>
commit d6040764adcb5cb6de1489422411d701c158bb69 upstream.
Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with
the algorithm registration. This fixes qat-dh registration when
driver is restarted
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
This patch adds the helper crypto_inst_setname because the current
helper crypto_alloc_instance2 is no longer useful given that we
now look up the algorithm after we allocate the instance object.
This patch adds the helper crypto_type_has_alg which is meant
to replace crypto_has_alg for new-style crypto types. Rather
than hard-coding type/mask information they're now retrieved
from the crypto_type object.
Simplify crypto_more_spawns() with list_first_entry_or_null()
and list_next_entry().
Signed-off-by: Geliang Tang <geliangtang@163.com>
Currently a number of Crypto API operations may fail when a signal
occurs. This causes nasty problems as the caller of those operations
are often not in a good position to restart the operation.
In fact there is currently no need for those operations to be
interrupted by user signals at all. All we need is for them to
be killable.
This patch replaces the relevant calls of signal_pending with
fatal_signal_pending, and wait_for_completion_interruptible with
wait_for_completion_killable, respectively.
Cc: stable@vger.kernel.org
Currently the task of freeing an instance is given to the crypto
template. However, it has no type information on the instance so
we have to resort to checking type information at runtime.
This patch introduces a free function to crypto_type that will be
used to free an instance. This can then be used to free an instance
in a type-safe manner.
The function __crypto_dequeue_request is completely unused.
This patch ensures that the tfm context always has enough extra
memory to ensure that it is aligned according to cra_alignment.
This patch adds a new primitive crypto_grab_spawn which is meant
to replace crypto_init_spawn and crypto_init_spawn2. Under the
new scheme the user no longer has to worry about reference counting
the alg object before it is subsumed by the spawn.
It is pretty much an exact copy of crypto_grab_aead.
Prior to calling this function spawn->frontend and spawn->inst
must have been set.
The commit 59afdc7b32143528524455039e7557a46b60e4c8 ("crypto:
api - Move module sig ifdef into accessor function") broke the
build when modules are completely disabled because we directly
dereference module->name.
This patch fixes this by using the accessor function module_name.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
All users of fips_enabled should include linux/fips.h directly
instead of getting it through internal.h.
Currently we're hiding mod->sig_ok under an ifdef in open code.
This patch adds a module_sig_ok accessor function and removes that
ifdef.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
This patch adds a crypto_alg_extsize helper that can be used
by algorithm types such as pcompress and shash.
Commit 9c521a200bc3 ("crypto: api - remove instance when test failed")
tried to grab a module reference count before the module was even set.
Worse, it then goes on to free the module reference count after it is
set so you quickly end up with a negative module reference count which
prevents people from using any instances belonging to that module.
This patch moves the module initialisation before the reference
count.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
A cipher instance is added to the list of instances unconditionally
regardless of whether the associated test failed. However, a failed
test implies that during another lookup, the cipher instance will
be added to the list again as it will not be found by the lookup
code.
That means that the list can be filled up with instances whose tests
failed.
Note: tests only fail in reality in FIPS mode when a cipher is not
marked as fips_allowed=1. This can be seen with cmac(des3_ede) that does
not have a fips_allowed=1. When allocating the cipher, the allocation
fails with -ENOENT due to the missing fips_allowed=1 flag (which
causes the testmgr to return EINVAL). Yet, the instance of
cmac(des3_ede) is shown in /proc/crypto. Allocating the cipher again
fails again, but a 2nd instance is listed in /proc/crypto.
The patch simply de-registers the instance when the testing failed.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
We currently initialise the crypto_alg ref count in the function
__crypto_register_alg. As one of the callers of that function
crypto_register_instance needs to obtain a ref count before it
calls __crypto_register_alg, we need to move the initialisation
out of there.
Since both callers of __crypto_register_alg call crypto_check_alg,
this is the logical place to perform the initialisation.
Acked-by: Stephan Mueller <smueller@chronox.de>
This patch makes crypto_unregister_instance take a crypto_instance
instead of a crypto_alg. This allows us to remove a duplicate
CRYPTO_ALG_INSTANCE check in crypto_unregister_instance.
There are multiple problems in crypto_unregister_instance:
1) The cra_refcnt BUG_ON check is racy and can cause crashes.
2) The cra_refcnt check shouldn't exist at all.
3) There is no reference on tmpl to protect the tmpl->free call.
This patch rewrites the function using crypto_remove_spawn which
now morphs into crypto_remove_instance.
Fixed style error identified by checkpatch.
WARNING: Missing a blank line after declarations
+ int err = crypto_remove_alg(&inst->alg, &users);
+ BUG_ON(err);
Signed-off-by: Joshua I. James <joshua@cybercrimetech.com>
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
Per further discussion with NIST, the requirements for FIPS state that
we only need to panic the system on failed kernel module signature checks
for crypto subsystem modules. This moves the fips-mode-only module
signature check out of the generic module loading code, into the crypto
subsystem, at points where we can catch both algorithm module loads and
mode module loads. At the same time, make CONFIG_CRYPTO_FIPS dependent on
CONFIG_MODULE_SIG, as this is entirely necessary for FIPS mode.
v2: remove extraneous blank line, perform checks in static inline
function, drop no longer necessary fips.h include.
CC: "David S. Miller" <davem@davemloft.net>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Stephan Mueller <stephan.mueller@atsec.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
The template lookup interface does not provide a way to use format
strings, so make sure that the interface cannot be abused accidentally.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: <stable@vger.kernel.org>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Replace PTR_ERR followed by ERR_PTR by ERR_CAST, to be more concise.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression err,x;
- err = PTR_ERR(x);
if (IS_ERR(x))
- return ERR_PTR(err);
+ return ERR_CAST(x);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
It has been observed that sometimes the crypto allocation code
will get stuck for 60 seconds or multiples thereof. This is
usually caused by an algorithm failing to pass the self-test.
If an algorithm fails to be constructed, we will immediately notify
all larval waiters. However, if it succeeds in construction, but
then fails the self-test, we won't notify anyone at all.
This patch fixes this by merging the notification in the case
where the algorithm fails to be constructed with that of the
the case where it pases the self-test. This way regardless of
what happens, we'll give the larval waiters an answer.
Hardware crypto engines frequently need to register a selection of
different algorithms with the core. Simplify their code slightly,
especially the error handling, by providing functions to register a
number of algorithms in a single call.
We leak the crypto instance when we unregister an instance with
crypto_del_alg(). Therefore we introduce crypto_unregister_instance()
to unlink the crypto instance from the template's instances list and
to free the recources of the instance properly.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
The upcomming crypto usrerspace configuration api needs
to remove the spawns on top on an algorithm, so export
crypto_remove_final.
crypto_remove_spawns.
The upcomming crypto user configuration api needs to identify
crypto instances. This patch adds a flag that is set if the
algorithm is an instance that is build from templates.
We don't check "frontend" consistently in crypto_init_spawn2(). We
check it at the start of the function but then we dereference it
unconditionally in the parameter list when we call crypto_init_spawn().
I looked at the places that call crypto_init_spawn2() and "frontend" is
always a valid pointer so I removed the check for null.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (102 commits)
crypto: sha-s390 - Fix warnings in import function
crypto: vmac - New hash algorithm for intel_txt support
crypto: api - Do not displace newly registered algorithms
crypto: ansi_cprng - Fix module initialization
crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctx
crypto: fips - Depend on ansi_cprng
crypto: blkcipher - Do not use eseqiv on stream ciphers
crypto: ctr - Use chainiv on raw counter mode
Revert crypto: fips - Select CPRNG
crypto: rng - Fix typo
crypto: talitos - add support for 36 bit addressing
crypto: talitos - align locks on cache lines
crypto: talitos - simplify hmac data size calculation
crypto: mv_cesa - Add support for Orion5X crypto engine
crypto: cryptd - Add support to access underlaying shash
crypto: gcm - Use GHASH digest algorithm
crypto: ghash - Add GHASH digest algorithm for GCM
crypto: authenc - Convert to ahash
crypto: api - Fix aligned ctx helper
crypto: hmac - Prehash ipad/opad
We have a mechanism where newly registered algorithms of a higher
priority can displace existing instances that use a different
implementation of the same algorithm with a lower priority.
Unfortunately the same mechanism can cause a newly registered
algorithm to displace itself if it depends on an existing version
of the same algorithm.
This patch fixes this by keeping all algorithms that the newly
reigstered algorithm depends on, thus protecting them from being
removed.
As struct skcipher_givcrypt_request includes struct crypto_request
at a non-zero offset, testing for NULL after converting the pointer
returned by crypto_dequeue_request does not work. This can result
in IPsec crashes when the queue is depleted.
This patch fixes it by doing the pointer conversion only when the
return value is non-NULL. In particular, we create a new function
__crypto_dequeue_request that does the pointer conversion.
Reported-by: Brad Bosch <bradbosch@comcast.net>
This patch allows crypto_drop_spawn to be called on spawns that
have not been initialised or have failed initialisation. This
fixes potential crashes during initialisation without adding
special case code.
This patch adds the helper crypto_attr_alg2 which is similar to
crypto_attr_alg but takes an extra frontend argument. This is
intended to be used by new style algorithm types such as shash.
This patch modifies the spawn infrastructure to support new style
algorithms like shash. In particular, this means storing the
frontend type in the spawn and using crypto_create_tfm to allocate
the tfm.
This patch adds a new argument to crypto_alloc_instance which
sets aside some space before the instance for use by algorithms
such as shash that place type-specific data before crypto_alg.
For compatibility the function has been renamed so that existing
users aren't affected.
When we complete a test we'll notify everyone waiting on it, drop
the mutex, and then remove the test larval (after reacquiring the
mutex). If one of the notified parties tries to register another
algorithm with the same driver name prior to the removal of the
test larval, they will fail with EEXIST as only one algorithm of
a given name can be tested at any time.
This broke the initialisation of aead and givcipher algorithms as
they will register two algorithms with the same driver name, in
sequence.
This patch fixes the problem by marking the larval as dead before
we drop the mutex, and also ignoring all dead or dying algorithms
on the registration path.
Tested-by: Andreas Steffen <andreas.steffen@strongswan.org>
This patch makes use of the new testing infrastructure by requiring
algorithms to pass a run-time test before they're made available to
users.
Since the only user of __crypto_alg_lookup is doing exactly what
crypto_alg_lookup does, we can now the latter in lieu of the former.
This patch adds a new helper crypto_attr_alg_name which is basically the
first half of crypto_attr_alg. That is, it returns an algorithm name
parameter as a string without looking it up. The caller can then look it
up immediately or defer it until later.
With the addition of more stream ciphers we need to curb the proliferation
of ad-hoc xor functions. This patch creates a generic pair of functions,
crypto_inc and crypto_xor which does big-endian increment and exclusive or,
respectively.
For optimum performance, they both use u32 operations so alignment must be
as that of u32 even though the arguments are of type u8 *.
As it is crypto_remove_spawn may try to unregister an instance which is
yet to be registered. This patch fixes this by checking whether the
instance has been registered before attempting to remove it.
It also removes a bogus cra_destroy check in crypto_register_instance as
1) it's outside the mutex;
2) we have a check in __crypto_register_alg already.
This patch adds a comment to explain why we compare the cra_driver_name of
the algorithm being registered against the cra_name of a larval as opposed
to the cra_driver_name of the larval.
In fact larvals have only one name, cra_name which is the name that was
requested by the user. The test here is simply trying to find out whether
the algorithm being registered can or can not satisfy the larval.
Previously we assumed for convenience that the block size is a multiple of
the algorithm's required alignment. With the pending addition of CTR this
will no longer be the case as the block size will be 1 due to it being a
stream cipher. However, the alignment requirement will be that of the
underlying implementation which will most likely be greater than 1.
