path: root/crypto/compress.c
2016-10-21crypto: api - Remove no-op exit_ops codeEric Biggers
crypto_exit_cipher_ops() and crypto_exit_compress_ops() are no-ops and have been for a long time, so remove them. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-16crypto: compress - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-07[CRYPTO] api: Remove deprecated interfaceHerbert Xu
This patch removes the old cipher interface and related code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] api: Added cra_init/cra_exitHerbert Xu
This patch adds the hooks cra_init/cra_exit which are called during a tfm's construction and destruction respectively. This will be used by the instances to allocate child tfm's. For now this lets us get rid of the coa_init/coa_exit functions which are used for exactly that purpose (unlike the dia_init function which is called for each transaction). In fact the coa_exit path is currently buggy as it may get called twice when an error is encountered during initialisation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] api: Fixed incorrect passing of context instead of tfmMichal Ludvig
Fix a few omissions in passing TFM instead of CTX to algorithms. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
