path: root/crypto/cryptd.c
2007-05-31[CRYPTO] cryptd: Fix problem with cryptd and the freezerRafael J. Wysocki
Make sure that cryptd is marked as nonfreezable and does not hold up the freezer. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] cryptd: Add software async crypto daemonHerbert Xu
This patch adds the cryptd module which is a template that takes a synchronous software crypto algorithm and converts it to an asynchronous one by executing it in a kernel thread. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
