path: root/crypto/crypto_user.c
2015-06-22crypto: user - Add CRYPTO_MSG_DELRNGHerbert Xu
This patch adds a new crypto_user command that allows the admin to delete the crypto system RNG. Note that this can only be done if the RNG is currently not in use. The next time it is used a new system RNG will be allocated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: akcipher - add PKE APITadeusz Struk
Add Public Key Encryption API. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Made CRYPTO_AKCIPHER invisible like other type config options. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-08crypto: user - Fix crypto_alg_match raceHerbert Xu
The function crypto_alg_match returns an algorithm without taking any references on it. This means that the algorithm can be freed at any time, therefore all users of crypto_alg_match are buggy. This patch fixes this by taking a reference count on the algorithm to prevent such races. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-03crypto: api - Change crypto_unregister_instance argument typeHerbert Xu
This patch makes crypto_unregister_instance take a crypto_instance instead of a crypto_alg. This allows us to remove a duplicate CRYPTO_ALG_INSTANCE check in crypto_unregister_instance. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-26crypto: user - add MODULE_ALIASStephan Mueller
To allow automatic loading of the crypto_user kernel module, the netlink MODULE_ALIAS is added. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: user - Allow get request with empty driver nameHerbert Xu
Currently all get requests with an empty driver name fail with EINVAL. Since most users actually want to supply an empty driver name this patch removes this check. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-06-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/cryptodev-2.6 ↵Linus Torvalds
into next Pull crypto updates from Herbert Xu: "Here is the crypto update for 3.16: - Added test vectors for SHA/AES-CCM/DES-CBC/3DES-CBC. - Fixed a number of error-path memory leaks in tcrypt. - Fixed error-path memory leak in caam. - Removed unnecessary global mutex from mxs-dcp. - Added ahash walk interface that can actually be asynchronous. - Cleaned up caam error reporting. - Allow crypto_user get operation to be used by non-root users. - Add support for SSS module on Exynos. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/cryptodev-2.6: (60 commits) crypto: testmgr - add aead cbc des, des3_ede tests crypto: testmgr - Fix DMA-API warning crypto: cesa - tfm->__crt_alg->cra_type directly crypto: sahara - tfm->__crt_alg->cra_name directly crypto: padlock - tfm->__crt_alg->cra_name directly crypto: n2 - tfm->__crt_alg->cra_name directly crypto: dcp - tfm->__crt_alg->cra_name directly crypto: cesa - tfm->__crt_alg->cra_name directly crypto: ccp - tfm->__crt_alg->cra_name directly crypto: geode - Don't use tfm->__crt_alg->cra_name directly crypto: geode - Weed out printk() from probe() crypto: geode - Consistently use AES_KEYSIZE_128 crypto: geode - Kill AES_IV_LENGTH crypto: geode - Kill AES_MIN_BLOCK_SIZE crypto: mxs-dcp - Remove global mutex crypto: hash - Add real ahash walk interface hwrng: n2-drv - Introduce the use of the managed version of kzalloc crypto: caam - reinitialize keys_fit_inline for decrypt and givencrypt crypto: s5p-sss - fix multiplatform build hwrng: timeriomem - remove unnecessary OOM messages ...
2014-05-08crypto: user - Allow CRYPTO_MSG_GETALG without CAP_NET_ADMINMatthias-Christian Ott
CRYPTO_USER requires CAP_NET_ADMIN for all operations. Most information provided by CRYPTO_MSG_GETALG is also accessible through /proc/modules and AF_ALG. CRYPTO_MSG_GETALG should not require CAP_NET_ADMIN so that processes without CAP_NET_ADMIN can use CRYPTO_MSG_GETALG to get cipher details, such as cipher priorities, for AF_ALG. Signed-off-by: Matthias-Christian Ott <ott@mirix.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-24net: Use netlink_ns_capable to verify the permisions of netlink messagesEric W. Biederman
It is possible by passing a netlink socket to a more privileged executable and then to fool that executable into writing to the socket data that happens to be valid netlink message to do something that privileged executable did not intend to do. To keep this from happening replace bare capable and ns_capable calls with netlink_capable, netlink_net_calls and netlink_ns_capable calls. Which act the same as the previous calls except they verify that the opener of the socket had the desired permissions as well. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-10crypto: user - constify netlink dispatch tableMathias Krause
There is no need to modify the netlink dispatch table at runtime and making it const even makes the resulting object file slightly smaller. Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-19crypto: user - ensure user supplied strings are nul-terminatedMathias Krause
To avoid misuse, ensure cru_name and cru_driver_name are always nul-terminated strings. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-19crypto: user - fix empty string test in report APIMathias Krause
The current test for empty strings fails because it is testing the address of a field, not a pointer. So the test will always be true. Test the first character in the string to not be null instead. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-19crypto: user - fix info leaks in report APIMathias Krause
Three errors resulting in kernel memory disclosure: 1/ The structures used for the netlink based crypto algorithm report API are located on the stack. As snprintf() does not fill the remainder of the buffer with null bytes, those stack bytes will be disclosed to users of the API. Switch to strncpy() to fix this. 2/ crypto_report_one() does not initialize all field of struct crypto_user_alg. Fix this to fix the heap info leak. 3/ For the module name we should copy only as many bytes as module_name() returns -- not as much as the destination buffer could hold. But the current code does not and therefore copies random data from behind the end of the module name, as the module name is always shorter than CRYPTO_MAX_ALG_NAME. Also switch to use strncpy() to copy the algorithm's name and driver_name. They are strings, after all. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Optimised AES/SHA1 for ARM. - IPsec ESN support in talitos and caam. - x86_64/avx implementation of cast5/cast6. - Add/use multi-algorithm registration helpers where possible. - Added IBM Power7+ in-Nest support. - Misc fixes. Fix up trivial conflicts in crypto/Kconfig due to the sparc64 crypto config options being added next to the new ARM ones. [ Side note: cut-and-paste duplicate help texts make those conflicts harder to read than necessary, thanks to git being smart about minimizing conflicts and maximizing the common parts... ] * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits) crypto: x86/glue_helper - fix storing of new IV in CBC encryption crypto: cast5/avx - fix storing of new IV in CBC encryption crypto: tcrypt - add missing tests for camellia and ghash crypto: testmgr - make test_aead also test 'dst != src' code paths crypto: testmgr - make test_skcipher also test 'dst != src' code paths crypto: testmgr - add test vectors for CTR mode IV increasement crypto: testmgr - add test vectors for partial ctr(cast5) and ctr(cast6) crypto: testmgr - allow non-multi page and multi page skcipher tests from same test template crypto: caam - increase TRNG clocks per sample crypto, tcrypt: remove local_bh_disable/enable() around local_irq_disable/enable() crypto: tegra-aes - fix error return code crypto: crypto4xx - fix error return code crypto: hifn_795x - fix error return code crypto: ux500 - fix error return code crypto: caam - fix error IDs for SEC v5.x RNG4 hwrng: mxc-rnga - Access data via structure hwrng: mxc-rnga - Adapt clocks to new i.mx clock framework crypto: caam - add IPsec ESN support crypto: 842 - remove .cra_list initialization Revert "[CRYPTO] cast6: inline bloat--" ...
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-08netlink: hide struct module parameter in netlink_kernel_createPablo Neira Ayuso
This patch defines netlink_kernel_create as a wrapper function of __netlink_kernel_create to hide the struct module *me parameter (which seems to be THIS_MODULE in all existing netlink subsystems). Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07crypto: crypto_user - fix sparse warnings (symbol was not declared, should ↵Jussi Kivilinna
be static?) Fix "symbol 'x' was not declared. Should it be static?" sparse warnings. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-29netlink: add netlink_kernel_cfg parameter to netlink_kernel_createPablo Neira Ayuso
This patch adds the following structure: struct netlink_kernel_cfg { unsigned int groups; void (*input)(struct sk_buff *skb); struct mutex *cb_mutex; }; That can be passed to netlink_kernel_create to set optional configurations for netlink kernel sockets. I've populated this structure by looking for NULL and zero parameters at the existing code. The remaining parameters that always need to be set are still left in the original interface. That includes optional parameters for the netlink socket creation. This allows easy extensibility of this interface in the future. This patch also adapts all callers to use this new interface. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-02crypto: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-29crypto: user - Fix size of netlink dump messageSteffen Klassert
The default netlink message size limit might be exceeded when dumping a lot of algorithms to userspace. As a result, not all of the instantiated algorithms dumped to userspace. So calculate an upper bound on the message size and call netlink_dump_start() with that value. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-29crypto: user - Fix lookup of algorithms with IV generatorSteffen Klassert
We lookup algorithms with crypto_alg_mod_lookup() when instantiating via crypto_add_alg(). However, algorithms that are wrapped by an IV genearator (e.g. aead or genicv type algorithms) need special care. The userspace process hangs until it gets a timeout when we use crypto_alg_mod_lookup() to lookup these algorithms. So export the lookup functions for these algorithms and use them in crypto_add_alg(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "* sha512 bug fixes (already in your tree). * SHA224/SHA384 AEAD support in caam. * X86-64 optimised version of Camellia. * Tegra AES support. * Bulk algorithm registration interface to make driver registration easier. * padata race fixes. * Misc fixes." * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) padata: Fix race on sequence number wrap padata: Fix race in the serialization path crypto: camellia - add assembler implementation for x86_64 crypto: camellia - rename camellia.c to camellia_generic.c crypto: camellia - fix checkpatch warnings crypto: camellia - rename camellia module to camellia_generic crypto: tcrypt - add more camellia tests crypto: testmgr - add more camellia test vectors crypto: camellia - simplify key setup and CAMELLIA_ROUNDSM macro crypto: twofish-x86_64/i586 - set alignmask to zero crypto: blowfish-x86_64 - set alignmask to zero crypto: serpent-sse2 - combine ablk_*_init functions crypto: blowfish-x86_64 - use crypto_[un]register_algs crypto: twofish-x86_64-3way - use crypto_[un]register_algs crypto: serpent-sse2 - use crypto_[un]register_algs crypto: serpent-sse2 - remove dead code from serpent_sse2_glue.c::serpent_sse2_init() crypto: twofish-x86 - Remove dead code from twofish_glue_3way.c::init() crypto: In crypto_add_alg(), 'exact' wants to be initialized to 0 crypto: caam - fix gcc 4.6 warning crypto: Add bulk algorithm registration interface ...
2012-02-26netlink: add netlink_dump_control structure for netlink_dump_start()Pablo Neira Ayuso
Davem considers that the argument list of this interface is getting out of control. This patch tries to address this issue following his proposal: struct netlink_dump_control c = { .dump = dump, .done = done, ... }; netlink_dump_start(..., &c); Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-05crypto: In crypto_add_alg(), 'exact' wants to be initialized to 0Jesper Juhl
We declare 'exact' without initializing it and then do: [...] if (strlen(p->cru_driver_name)) exact = 1; if (priority && !exact) return -EINVAL; [...] If the first 'if' is not true, then the second will test an uninitialized 'exact'. As far as I can tell, what we want is for 'exact' to be initialized to 0 (zero/false). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-14Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: capabilities: remove __cap_full_set definition security: remove the security_netlink_recv hook as it is equivalent to capable() ptrace: do not audit capability check when outputing /proc/pid/stat capabilities: remove task_ns_* functions capabitlies: ns_capable can use the cap helpers rather than lsm call capabilities: style only - move capable below ns_capable capabilites: introduce new has_ns_capabilities_noaudit capabilities: call has_ns_capability from has_capability capabilities: remove all _real_ interfaces capabilities: introduce security_capable_noaudit capabilities: reverse arguments to security_capable capabilities: remove the task from capable LSM hook entirely selinux: sparse fix: fix several warnings in the security server cod selinux: sparse fix: fix warnings in netlink code selinux: sparse fix: eliminate warnings for selinuxfs selinux: sparse fix: declare selinux_disable() in security.h selinux: sparse fix: move selinux_complete_init selinux: sparse fix: make selinux_secmark_refcount static SELinux: Fix RCU deref check warning in sel_netport_insert() Manually fix up a semantic mis-merge wrt security_netlink_recv(): - the interface was removed in commit fd7784615248 ("security: remove the security_netlink_recv hook as it is equivalent to capable()") - a new user of it appeared in commit a38f7907b926 ("crypto: Add userspace configuration API") causing no automatic merge conflict, but Eric Paris pointed out the issue.
2012-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (54 commits) crypto: gf128mul - remove leftover "(EXPERIMENTAL)" in Kconfig crypto: serpent-sse2 - remove unneeded LRW/XTS #ifdefs crypto: serpent-sse2 - select LRW and XTS crypto: twofish-x86_64-3way - remove unneeded LRW/XTS #ifdefs crypto: twofish-x86_64-3way - select LRW and XTS crypto: xts - remove dependency on EXPERIMENTAL crypto: lrw - remove dependency on EXPERIMENTAL crypto: picoxcell - fix boolean and / or confusion crypto: caam - remove DECO access initialization code crypto: caam - fix polarity of "propagate error" logic crypto: caam - more desc.h cleanups crypto: caam - desc.h - convert spaces to tabs crypto: talitos - convert talitos_error to struct device crypto: talitos - remove NO_IRQ references crypto: talitos - fix bad kfree crypto: convert drivers/crypto/* to use module_platform_driver() char: hw_random: convert drivers/char/hw_random/* to use module_platform_driver() crypto: serpent-sse2 - should select CRYPTO_CRYPTD crypto: serpent - rename serpent.c to serpent_generic.c crypto: serpent - cleanup checkpatch errors and warnings ...
2011-11-09crypto: Unlink and free instances when deletedSteffen Klassert
We leak the crypto instance when we unregister an instance with crypto_del_alg(). Therefore we introduce crypto_unregister_instance() to unlink the crypto instance from the template's instances list and to free the recources of the instance properly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-02crypto: user - Fix rwsem leak in crypto_userJonathan Corbet
The list_empty case in crypto_alg_match() will return without calling up_read() on crypto_alg_sem. We could do the "goto out" routine, but the function will clearly do the right thing with that test simply removed. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: user - Initialise match in crypto_alg_matchHerbert Xu
We need to default match to 0 as otherwise it may lead to a false positive. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add userspace report for compress type algorithmsSteffen Klassert
2011-10-21crypto: Add userspace report for cipher type algorithmsSteffen Klassert
2011-10-21crypto: Add userspace report for larval type algorithmsSteffen Klassert
2011-10-21crypto: Add a report function pointer to crypto_typeSteffen Klassert
We add a report function pointer to struct crypto_type. This function pointer is used from the crypto userspace configuration API to report crypto algorithms to userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add userspace configuration APISteffen Klassert
This patch adds a basic userspace configuration API for the crypto layer. With this it is possible to instantiate, remove and to show crypto algorithms from userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
