path: root/crypto/crypto_user_stat.c
2019-12-13crypto: user - fix memory leak in crypto_reportstatNavid Emamdoost
commit c03b04dcdba1da39903e23cc4d072abf8f68f2dd upstream. In crypto_reportstat, a new skb is created by nlmsg_new(). This skb is leaked if crypto_reportstat_alg() fails. Required release for skb is added. Fixes: cac5818c25d0 ("crypto: user - Implement a generic crypto statistics") Cc: <stable@vger.kernel.org> Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-26crypto: user - make NETLINK_CRYPTO work inside netnsOndrej Mosnacek
Currently, NETLINK_CRYPTO works only in the init network namespace. It doesn't make much sense to cut it out of the other network namespaces, so do the minor plumbing work necessary to make it work in any network namespace. Code inspired by net/core/sock_diag.c. Tested using kcapi-dgst from libkcapi [1]: Before: # unshare -n kcapi-dgst -c sha256 </dev/null | wc -c libkcapi - Error: Netlink error: sendmsg failed libkcapi - Error: Netlink error: sendmsg failed libkcapi - Error: NETLINK_CRYPTO: cannot obtain cipher information for hmac(sha512) (is required crypto_user.c patch missing? see documentation) 0 After: # unshare -n kcapi-dgst -c sha256 </dev/null | wc -c 32 [1] https://github.com/smuellerDD/libkcapi Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-01-18crypto: stat - remove unused mutexEric Biggers
crypto_cfg_mutex in crypto_user_stat.c is unused. Remove it. Cc: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-01-18crypto: user - forward declare crypto_nlskEric Biggers
Move the declaration of crypto_nlsk into internal/cryptouser.h. This fixes the following sparse warning: crypto/crypto_user_base.c:41:13: warning: symbol 'crypto_nlsk' was not declared. Should it be static? Cc: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-23crypto: user - remove unused dump functionsCorentin Labbe
This patch removes unused dump functions for crypto_user_stats. There are remains of the copy/paste of crypto_user_base to crypto_user_stat and I forgot to remove them. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-07crypto: user - rename err_cnt parameterCorentin Labbe
Since now all crypto stats are on their own structures, it is now useless to have the algorithm name in the err_cnt member. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-07crypto: user - Split stats in multiple structuresCorentin Labbe
Like for userspace, this patch splits stats into multiple structures, one for each algorithm class. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-07crypto: user - remove intermediate variableCorentin Labbe
The use of the v64 intermediate variable is useless, and removing it bring to much readable code. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-07crypto: user - Fix invalid stat reportingCorentin Labbe
Some error count use the wrong name for getting this data. But this had not caused any reporting problem, since all error count are shared in the same union. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-07crypto: user - split user space crypto stat structuresCorentin Labbe
It is cleaner to have each stat in their own structures. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-12-07crypto: user - convert all stats from u32 to u64Corentin Labbe
All the 32-bit fields need to be 64-bit. In some cases, UINT32_MAX crypto operations can be done in seconds. Reported-by: Eric Biggers <ebiggers@kernel.org> Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-11-09crypto: user - clean up report structure copyingEric Biggers
There have been a pretty ridiculous number of issues with initializing the report structures that are copied to userspace by NETLINK_CRYPTO. Commit 4473710df1f8 ("crypto: user - Prepare for CRYPTO_MAX_ALG_NAME expansion") replaced some strncpy()s with strlcpy()s, thereby introducing information leaks. Later two other people tried to replace other strncpy()s with strlcpy() too, which would have introduced even more information leaks: - https://lore.kernel.org/patchwork/patch/954991/ - https://patchwork.kernel.org/patch/10434351/ Commit cac5818c25d0 ("crypto: user - Implement a generic crypto statistics") also uses the buggy strlcpy() approach and therefore leaks uninitialized memory to userspace. A fix was proposed, but it was originally incomplete. Seeing as how apparently no one can get this right with the current approach, change all the reporting functions to: - Start by memsetting the report structure to 0. This guarantees it's always initialized, regardless of what happens later. - Initialize all strings using strscpy(). This is safe after the memset, ensures null termination of long strings, avoids unnecessary work, and avoids the -Wstringop-truncation warnings from gcc. - Use sizeof(var) instead of sizeof(type). This is more robust against copy+paste errors. For simplicity, also reuse the -EMSGSIZE return value from nla_put(). Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-11-09crypto: user - Zeroize whole structure given to user spaceCorentin Labbe
For preventing uninitialized data to be given to user-space (and so leak potential useful data), the crypto_stat structure must be correctly initialized. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: cac5818c25d0 ("crypto: user - Implement a generic crypto statistics") Signed-off-by: Corentin Labbe <clabbe@baylibre.com> [EB: also fix it in crypto_reportstat_one()] [EB: use sizeof(var) rather than sizeof(type)] Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-09-28crypto: user - Implement a generic crypto statisticsCorentin Labbe
This patch implement a generic way to get statistics about all crypto usages. Signed-off-by: Corentin Labbe <clabbe@baylibre.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
