path: root/crypto/deflate.c
2019-07-08Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "Here is the crypto update for 5.3: API: - Test shash interface directly in testmgr - cra_driver_name is now mandatory Algorithms: - Replace arc4 crypto_cipher with library helper - Implement 5 way interleave for ECB, CBC and CTR on arm64 - Add xxhash - Add continuous self-test on noise source to drbg - Update jitter RNG Drivers: - Add support for SHA204A random number generator - Add support for 7211 in iproc-rng200 - Fix fuzz test failures in inside-secure - Fix fuzz test failures in talitos - Fix fuzz test failures in qat" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (143 commits) crypto: stm32/hash - remove interruptible condition for dma crypto: stm32/hash - Fix hmac issue more than 256 bytes crypto: stm32/crc32 - rename driver file crypto: amcc - remove memset after dma_alloc_coherent crypto: ccp - Switch to SPDX license identifiers crypto: ccp - Validate the the error value used to index error messages crypto: doc - Fix formatting of new crypto engine content crypto: doc - Add parameter documentation crypto: arm64/aes-ce - implement 5 way interleave for ECB, CBC and CTR crypto: arm64/aes-ce - add 5 way interleave routines crypto: talitos - drop icv_ool crypto: talitos - fix hash on SEC1. crypto: talitos - move struct talitos_edesc into talitos.h lib/scatterlist: Fix mapping iterator when sg->offset is greater than PAGE_SIZE crypto/NX: Set receive window credits to max number of CRBs in RxFIFO crypto: asymmetric_keys - select CRYPTO_HASH where needed crypto: serpent - mark __serpent_setkey_sbox noinline crypto: testmgr - dynamically allocate crypto_shash crypto: testmgr - dynamically allocate testvec_config crypto: talitos - eliminate unneeded 'done' functions at build time ...
2019-06-13crypto: make all generic algorithms set cra_driver_nameEric Biggers
Most generic crypto algorithms declare a driver name ending in "-generic". The rest don't declare a driver name and instead rely on the crypto API automagically appending "-generic" upon registration. Having multiple conventions is unnecessarily confusing and makes it harder to grep for all generic algorithms in the kernel source tree. But also, allowing NULL driver names is problematic because sometimes people fail to set it, e.g. the case fixed by commit 417980364300 ("crypto: cavium/zip - fix collision with generic cra_driver_name"). Of course, people can also incorrectly name their drivers "-generic". But that's much easier to notice / grep for. Therefore, let's make cra_driver_name mandatory. In preparation for this, this patch makes all generic algorithms set cra_driver_name. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-18crypto: run initcalls for generic implementations earlierEric Biggers
Use subsys_initcall for registration of all templates and generic algorithm implementations, rather than module_init. Then change cryptomgr to use arch_initcall, to place it before the subsys_initcalls. This is needed so that when both a generic and optimized implementation of an algorithm are built into the kernel (not loadable modules), the generic implementation is registered before the optimized one. Otherwise, the self-tests for the optimized implementation are unable to allocate the generic implementation for the new comparison fuzz tests. Note that on arm, a side effect of this change is that self-tests for generic implementations may run before the unaligned access handler has been installed. So, unaligned accesses will crash the kernel. This is arguably a good thing as it makes it easier to detect that type of bug. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2017-04-24crypto: scomp - add support for deflate rfc1950 (zlib)Giovanni Cabiddu
Add scomp backend for zlib-deflate compression algorithm. This backend outputs data using the format defined in rfc1950 (raw deflate surrounded by zlib header and footer). Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-10-25crypto: acomp - add support for deflate via scompGiovanni Cabiddu
Add scomp backend for deflate compression algorithm. Signed-off-by: Giovanni Cabiddu <giovanni.cabiddu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cleanup - remove unneeded crypto_alg.cra_list initializationsJussi Kivilinna
Initialization of cra_list is currently mixed, most ciphers initialize this field and most shashes do not. Initialization however is not needed at all since cra_list is initialized/overwritten in __crypto_register_alg() with list_add(). Therefore perform cleanup to remove all unneeded initializations of this field in 'crypto/'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-06-29net+crypto: Use vmalloc for zlib inflate buffers.David S. Miller
They are 64K and result in order-4 allocations, even with SLUB. Therefore, just like we always have for the deflate buffers, use vmalloc. Reported-by: Martin Jackson <mjackson220.list@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-22zlib: slim down zlib_deflate() workspace when possibleJim Keniston
Instead of always creating a huge (268K) deflate_workspace with the maximum compression parameters (windowBits=15, memLevel=8), allow the caller to obtain a smaller workspace by specifying smaller parameter values. For example, when capturing oops and panic reports to a medium with limited capacity, such as NVRAM, compression may be the only way to capture the whole report. In this case, a small workspace (24K works fine) is a win, whether you allocate the workspace when you need it (i.e., during an oops or panic) or at boot time. I've verified that this patch works with all accepted values of windowBits (positive and negative), memLevel, and compression level. Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Miller <davem@davemloft.net> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-27crypto: Use vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-16crypto: deflate - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] api: Added cra_init/cra_exitHerbert Xu
This patch adds the hooks cra_init/cra_exit which are called during a tfm's construction and destruction respectively. This will be used by the instances to allocate child tfm's. For now this lets us get rid of the coa_init/coa_exit functions which are used for exactly that purpose (unlike the dia_init function which is called for each transaction). In fact the coa_exit path is currently buggy as it may get called twice when an error is encountered during initialisation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-03-21[CRYPTO] all: Use kzalloc where possibleEric Sesterhenn
this patch converts crypto/ to kzalloc usage. Compile tested with allyesconfig. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-04-16[PATCH] crypto: call zlib end functions on deflate exit pathArtem B. Bityuckiy
In the deflate_[compress|uncompress|pcompress] functions we call the zlib_[in|de]flateReset function at the beginning. This is OK. But when we unload the deflate module we don't call zlib_[in|de]flateEnd to free all the zlib internal data. It looks like a bug for me. Please, consider the attached patch. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
