path: root/crypto/deflate.c
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] api: Added cra_init/cra_exitHerbert Xu
This patch adds the hooks cra_init/cra_exit which are called during a tfm's construction and destruction respectively. This will be used by the instances to allocate child tfm's. For now this lets us get rid of the coa_init/coa_exit functions which are used for exactly that purpose (unlike the dia_init function which is called for each transaction). In fact the coa_exit path is currently buggy as it may get called twice when an error is encountered during initialisation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-03-21[CRYPTO] all: Use kzalloc where possibleEric Sesterhenn
this patch converts crypto/ to kzalloc usage. Compile tested with allyesconfig. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-04-16[PATCH] crypto: call zlib end functions on deflate exit pathArtem B. Bityuckiy
In the deflate_[compress|uncompress|pcompress] functions we call the zlib_[in|de]flateReset function at the beginning. This is OK. But when we unload the deflate module we don't call zlib_[in|de]flateEnd to free all the zlib internal data. It looks like a bug for me. Please, consider the attached patch. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
