path: root/crypto/internal.h
2006-01-09[CRYPTO] Allow multiple implementations of the same algorithmHerbert Xu
This is the first step on the road towards asynchronous support in the Crypto API. It adds support for having multiple crypto_alg objects for the same algorithm registered in the system. For example, each device driver would register a crypto_alg object for each algorithm that it supports. While at the same time the user may load software implementations of those same algorithms. Users of the Crypto API may then select a specific implementation by name, or choose any implementation for a given algorithm with the highest priority. The priority field is a 32-bit signed integer. In future it will be possible to modify it from user-space. This also provides a solution to the problem of selecting amongst various AES implementations, that is, aes vs. aes-i586 vs. aes-padlock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-09-01[CRYPTO]: Added CRYPTO_TFM_REQ_MAY_SLEEP flagHerbert Xu
The crypto layer currently uses in_atomic() to determine whether it is allowed to sleep. This is incorrect since spin locks don't always cause in_atomic() to return true. Instead of that, this patch returns to an earlier idea of a per-tfm flag which determines whether sleeping is allowed. Unlike the earlier version, the default is to not allow sleeping. This ensures that no existing code can break. As usual, this flag may either be set through crypto_alloc_tfm(), or just before a specific crypto operation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-15[CRYPTO]: Fix zero-extension bug on 64-bit architectures.Herbert Xu
Noticed by Ken-ichirou MATSUZAWA. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Ensure cit_iv is aligned correctlyHerbert Xu
This patch ensures that cit_iv is aligned according to cra_alignmask by allocating it as part of the tfm structure. As a side effect the crypto layer will also guarantee that the tfm ctx area has enough space to be aligned by cra_alignmask. This allows us to remove the extra space reservation from the Padlock driver. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Make crypto_alg_lookup staticAdrian Bunk
This patch makes a needlessly global function static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-06[CRYPTO] Add support for low-level multi-block operationsHerbert Xu
This patch adds hooks for cipher algorithms to implement multi-block ECB/CBC operations directly. This is expected to provide significant performance boots to the VIA Padlock. It could also be used for improving software implementations such as AES where operating on multiple blocks at a time may enable certain optimisations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-23[CRYPTO]: Only reschedule if !in_atomic()Herbert Xu
The netlink gfp_any() problem made me double-check the uses of in_softirq() in crypto/*. It seems to me that we should be checking in_atomic() instead of in_softirq() in crypto_yield. Otherwise people calling the crypto ops with spin locks held or preemption disabled will get burnt, right? Signed-off-by: David S. Miller <davem@davemloft.net>
