commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
The lz4 library has two functions for decompression, with slightly
different signatures and behaviour. The lz4_decompress_crypto() function
seemed to be using the one that assumes that the decompressed length is
known in advance.
This patch switches to the other decompression function and makes sure
that the length of the decompressed output is properly returned to the
caller.
The same issue was present in the lz4hc algorithm.
Coincidentally, this change also makes very basic lz4 and lz4hc
compression tests in testmgr pass.
Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu>
Add support for lz4 and lz4hc compression algorithm using the lib/lz4/*
codebase.
[akpm@linux-foundation.org: fix warnings]
Signed-off-by: Chanho Min <chanho.min@lge.com>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Cc: Bob Pearson <rpearson@systemfabricworks.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Herbert Xu <herbert@gondor.hengli.com.au>
Cc: Yann Collet <yann.collet.73@gmail.com>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
