path: root/crypto/lzo.c
2016-04-15crypto: lzo - get rid of superfluous __GFP_REPEATMichal Hocko
__GFP_REPEAT has a rather weak semantic but since it has been introduced around 2.6.12 it has been ignored for low order allocations. lzo_init uses __GFP_REPEAT to allocate LZO1X_MEM_COMPRESS 16K. This is order 3 allocation request and __GFP_REPEAT is ignored for this size as well as all <= PAGE_ALLOC_COSTLY requests. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-crypto@vger.kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-06-25crypto: lzo - use kvfree() helperEric Dumazet
kvfree() helper is now available, use it instead of open code it. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-06-20crypto: lzo - try kmalloc() before vmalloc()Eric Dumazet
zswap allocates one LZO context per online cpu. Using vmalloc() for small (16KB) memory areas has drawback of slowing down /proc/vmallocinfo and /proc/meminfo reads, TLB pressure and poor NUMA locality, as default NUMA policy at boot time is to interleave pages : edumazet:~# grep lzo /proc/vmallocinfo | head -4 0xffffc90006062000-0xffffc90006067000 20480 lzo_init+0x1b/0x30 pages=4 vmalloc N0=2 N1=2 0xffffc90006067000-0xffffc9000606c000 20480 lzo_init+0x1b/0x30 pages=4 vmalloc N0=2 N1=2 0xffffc9000606c000-0xffffc90006071000 20480 lzo_init+0x1b/0x30 pages=4 vmalloc N0=2 N1=2 0xffffc90006071000-0xffffc90006076000 20480 lzo_init+0x1b/0x30 pages=4 vmalloc N0=2 N1=2 This patch tries a regular kmalloc() and fallback to vmalloc in case memory is too fragmented. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cleanup - remove unneeded crypto_alg.cra_list initializationsJussi Kivilinna
Initialization of cra_list is currently mixed, most ciphers initialize this field and most shashes do not. Initialization however is not needed at all since cra_list is initialized/overwritten in __crypto_register_alg() with list_add(). Therefore perform cleanup to remove all unneeded initializations of this field in 'crypto/'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] lzo: Add LZO compression algorithm supportZoltan Sogor
Add LZO compression algorithm support Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
