path: root/crypto/mcryptd.c
2015-03-31crypto: mcryptd - process CRYPTO_ALG_INTERNALStephan Mueller
The mcryptd is used as a wrapper around internal ciphers. Therefore, the mcryptd must process the internal cipher by marking mcryptd as internal if the underlying cipher is an internal cipher. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-26crypto: include crypto- module prefix in templateKees Cook
This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-26crypto: mcryptd - mcryptd_flist can be staticFengguang Wu
CC: Tim Chen <tim.c.chen@linux.intel.com> CC: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-25crypto: sha-mb - multibuffer crypto infrastructureTim Chen
This patch introduces the multi-buffer crypto daemon which is responsible for submitting crypto jobs in a work queue to the responsible multi-buffer crypto algorithm. The idea of the multi-buffer algorihtm is to put data streams from multiple jobs in a wide (AVX2) register and then take advantage of SIMD instructions to do crypto computation on several buffers simultaneously. The multi-buffer crypto daemon is also responsbile for flushing the remaining buffers to complete the computation if no new buffers arrive for a while. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
