path: root/crypto/mcryptd.c
2018-02-25crypto: hash - annotate algorithms taking optional keyEric Biggers
commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream. We need to consistently enforce that keyed hashes cannot be used without setting the key. To do this we need a reliable way to determine whether a given hash algorithm is keyed or not. AF_ALG currently does this by checking for the presence of a ->setkey() method. However, this is actually slightly broken because the CRC-32 algorithms implement ->setkey() but can also be used without a key. (The CRC-32 "key" is not actually a cryptographic key but rather represents the initial state. If not overridden, then a default initial state is used.) Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which indicates that the algorithm has a ->setkey() method, but it is not required to be called. Then set it on all the CRC-32 algorithms. The same also applies to the Adler-32 implementation in Lustre. Also, the cryptd and mcryptd templates have to pass through the flag from their underlying algorithm. Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: mcryptd - pass through absence of ->setkey()Eric Biggers
commit fa59b92d299f2787e6bae1ff078ee0982e80211f upstream. When the mcryptd template is used to wrap an unkeyed hash algorithm, don't install a ->setkey() method to the mcryptd instance. This change is necessary for mcryptd to keep working with unkeyed hash algorithms once we start enforcing that ->setkey() is called when present. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29crypto: mcryptd - protect the per-CPU queue with a lockSebastian Andrzej Siewior
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream. mcryptd_enqueue_request() grabs the per-CPU queue struct and protects access to it with disabled preemption. Then it schedules a worker on the same CPU. The worker in mcryptd_queue_worker() guards access to the same per-CPU variable with disabled preemption. If we take CPU-hotplug into account then it is possible that between queue_work_on() and the actual invocation of the worker the CPU goes down and the worker will be scheduled on _another_ CPU. And here the preempt_disable() protection does not work anymore. The easiest thing is to add a spin_lock() to guard access to the list. Another detail: mcryptd_queue_worker() is not processing more than MCRYPTD_BATCH invocation in a row. If there are still items left, then it will invoke queue_work() to proceed with more later. *I* would suggest to simply drop that check because it does not use a system workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if preemption is required then the scheduler should do it. However if queue_work() is used then the work item is marked as CPU unbound. That means it will try to run on the local CPU but it may run on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y. Again, the preempt_disable() won't work here but lock which was introduced will help. In order to keep work-item on the local CPU (and avoid RR) I changed it to queue_work_on(). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-07crypto: mcryptd - Check mcryptd algorithm compatibilitytim
Algorithms not compatible with mcryptd could be spawned by mcryptd with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name construct. This causes mcryptd to crash the kernel if an arbitrary "alg" is incompatible and not intended to be used with mcryptd. It is an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally. But such algorithms must be used internally and not be exposed. We added a check to enforce that only internal algorithms are allowed with mcryptd at the time mcryptd is spawning an algorithm. Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2 Cc: stable@vger.kernel.org Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-13crypto: squash lines for simple wrapper functionsMasahiro Yamada
Remove unneeded variables and assignments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-06-23crypto: sha1-mb - async implementation for sha1-mbMegha Dey
Herbert wants the sha1-mb algorithm to have an async implementation: https://lkml.org/lkml/2016/4/5/286. Currently, sha1-mb uses an async interface for the outer algorithm and a sync interface for the inner algorithm. This patch introduces a async interface for even the inner algorithm. Signed-off-by: Megha Dey <megha.dey@linux.intel.com> Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-01-30crypto: mcryptd - Fix load failureWang, Rui Y
mcryptd_create_hash() fails by returning -EINVAL, causing any driver using mcryptd to fail to load. It is because it needs to set its statesize properly. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-11-23crypto: mcryptd - use list_first_entry_or_null()Geliang Tang
Simplify mcryptd_opportunistic_flush() with list_first_entry_or_null(). Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-31crypto: mcryptd - process CRYPTO_ALG_INTERNALStephan Mueller
The mcryptd is used as a wrapper around internal ciphers. Therefore, the mcryptd must process the internal cipher by marking mcryptd as internal if the underlying cipher is an internal cipher. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-26crypto: include crypto- module prefix in templateKees Cook
This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-26crypto: mcryptd - mcryptd_flist can be staticFengguang Wu
CC: Tim Chen <tim.c.chen@linux.intel.com> CC: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-25crypto: sha-mb - multibuffer crypto infrastructureTim Chen
This patch introduces the multi-buffer crypto daemon which is responsible for submitting crypto jobs in a work queue to the responsible multi-buffer crypto algorithm. The idea of the multi-buffer algorihtm is to put data streams from multiple jobs in a wide (AVX2) register and then take advantage of SIMD instructions to do crypto computation on several buffers simultaneously. The multi-buffer crypto daemon is also responsbile for flushing the remaining buffers to complete the computation if no new buffers arrive for a while. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
