path: root/crypto/md4.c
2011-10-31crypto: add module.h to those files that are explicitly using itPaul Gortmaker
Part of the include cleanups means that the implicit inclusion of module.h via device.h is going away. So fix things up in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-12-25crypto: md4 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md4 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md4 - Use ARRAY_SIZEJulia Lawall
ARRAY_SIZE is more concise to use when the size of an array is divided by the size of its type or the size of its first element. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @i@ @@ #include <linux/kernel.h> @depends on i using "paren.iso"@ type T; T[] E; @@ - (sizeof(E)/sizeof(T)) + ARRAY_SIZE(E) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Use standard byte order macros wherever possibleHerbert Xu
A lot of crypto code needs to read/write a 32-bit/64-bit words in a specific gender. Many of them open code them by reading/writing one byte at a time. This patch converts all the applicable usages over to use the standard byte order macros. This is based on a previous patch by Denis Vlasenko. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
