path: root/crypto/pcompress.c
2015-04-21crypto: pcomp - Use crypto_alg_extsize helperHerbert Xu
This patch replaces crypto_pcomp_extsize function with crypto_alg_extsize. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-19crypto: user - fix info leaks in report APIMathias Krause
Three errors resulting in kernel memory disclosure: 1/ The structures used for the netlink based crypto algorithm report API are located on the stack. As snprintf() does not fill the remainder of the buffer with null bytes, those stack bytes will be disclosed to users of the API. Switch to strncpy() to fix this. 2/ crypto_report_one() does not initialize all field of struct crypto_user_alg. Fix this to fix the heap info leak. 3/ For the module name we should copy only as many bytes as module_name() returns -- not as much as the destination buffer could hold. But the current code does not and therefore copies random data from behind the end of the module name, as the module name is always shorter than CRYPTO_MAX_ALG_NAME. Also switch to use strncpy() to copy the algorithm's name and driver_name. They are strings, after all. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-04-02crypto: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-11crypto: algapi - Fix build problem with NET disabledHerbert Xu
The report functions use NLA_PUT so we need to ensure that NET is enabled. Reported-by: Luis Henriques <henrix@camandro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add userspace report for pcompress type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: api - Remove frontend argument from extsize/init_tfmHerbert Xu
As the extsize and init_tfm functions belong to the frontend the frontend argument is superfluous. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: pcomp - pcompress.c should include crypto/internal/compress.hGeert Uytterhoeven
make C=1: | crypto/pcompress.c:77:5: warning: symbol 'crypto_register_pcomp' was not declared. Should it be static? | crypto/pcompress.c:89:5: warning: symbol 'crypto_unregister_pcomp' was not declared. Should it be static? Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: compress - Add pcomp interfaceGeert Uytterhoeven
The current "comp" crypto interface supports one-shot (de)compression only, i.e. the whole data buffer to be (de)compressed must be passed at once, and the whole (de)compressed data buffer will be received at once. In several use-cases (e.g. compressed file systems that store files in big compressed blocks), this workflow is not suitable. Furthermore, the "comp" type doesn't provide for the configuration of (de)compression parameters, and always allocates workspace memory for both compression and decompression, which may waste memory. To solve this, add a "pcomp" partial (de)compression interface that provides the following operations: - crypto_compress_{init,update,final}() for compression, - crypto_decompress_{init,update,final}() for decompression, - crypto_{,de}compress_setup(), to configure (de)compression parameters (incl. allocating workspace memory). The (de)compression methods take a struct comp_request, which was mimicked after the z_stream object in zlib, and contains buffer pointer and length pairs for input and output. The setup methods take an opaque parameter pointer and length pair. Parameters are supposed to be encoded using netlink attributes, whose meanings depend on the actual (name of the) (de)compression algorithm. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
