path: root/crypto/rmd320.c
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-01-04crypto: ripemd - Set module author and update email addressAdrian-Ken Rueegsegger
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd320 - Switch to shashHerbert Xu
This patch changes rmd320 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: rmd - sparse annotationsHarvey Harrison
Similar to the rmd128.c annotations, significantly cuts down on the noise. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] rmd: Use pointer form of endian swapping operationsHerbert Xu
This patch converts the relevant code in the rmd implementations to use the pointer form of the endian swapping operations. This allows certain architectures to generate more optimised code. For example, on sparc64 this more than halves the CPU cycles on a typical hashing operation. Based on a patch by David Miller. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] rmd320: Fix endian issuesAdrian-Ken Rueegsegger
This patch fixes endian issues making rmd320 work properly on big-endian machines. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Acked-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] ripemd: Add support for RIPEMD-256 and RIPEMD-320Adrian-Ken Rueegsegger
This patch adds support for the extended RIPEMD hash algorithms RIPEMD-256 and RIPEMD-320. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
