path: root/crypto/rsa.c
2017-06-10crypto: rsa - comply with crypto_akcipher_maxsize()Tudor-Dan Ambarus
crypto_akcipher_maxsize() asks for the output buffer size without caring for errors. It allways assume that will be called after a valid setkey. Comply with it and return what he wants. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-01crypto: rsa - Generate fixed-length outputHerbert Xu
Every implementation of RSA that we have naturally generates output with leading zeroes. The one and only user of RSA, pkcs1pad wants to have those leading zeroes in place, in fact because they are currently absent it has to write those zeroes itself. So we shouldn't be stripping leading zeroes in the first place. In fact this patch makes rsa-generic produce output with fixed length so that pkcs1pad does not need to do any extra work. This patch also changes DH to use the new interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-06-15crypto: rsa - return raw integers for the ASN.1 parserTudor Ambarus
Return the raw key with no other processing so that the caller can copy it or MPI parse it, etc. The scope is to have only one ANS.1 parser for all RSA implementations. Update the RSA software implementation so that it does the MPI conversion on top. Signed-off-by: Tudor Ambarus <tudor-dan.ambarus@nxp.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-12-09crypto: rsa - RSA padding algorithmAndrzej Zaborowski
This patch adds PKCS#1 v1.5 standard RSA padding as a separate template. This way an RSA cipher with padding can be obtained by instantiating "pkcs1pad(rsa)". The reason for adding this is that RSA is almost never used without this padding (or OAEP) so it will be needed for either certificate work in the kernel or the userspace, and I also hear that it is likely implemented by hardware RSA in which case hardware implementations of the whole of pkcs1pad(rsa) can be provided. Signed-off-by: Andrew Zaborowski <andrew.zaborowski@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-11-17crypto: rsa - only require output buffers as big as needed.Andrzej Zaborowski
rhe RSA operations explicitly left-align the integers being written skipping any leading zero bytes, but still require the output buffers to include just enough space for the integer + the leading zero bytes. Since the size of integer + the leading zero bytes (i.e. the key modulus size) can now be obtained more easily through crypto_akcipher_maxsize change the operations to only require as big a buffer as actually needed if the caller has that information. The semantics for request->dst_len don't change. Signed-off-by: Andrew Zaborowski <andrew.zaborowski@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-14crypto: akcipher - Changes to asymmetric key APITadeusz Struk
Setkey function has been split into set_priv_key and set_pub_key. Akcipher requests takes sgl for src and dst instead of void *. Users of the API i.e. two existing RSA implementation and test mgr code have been updated accordingly. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: rsa - limit supported key lengthsTadeusz Struk
Introduce constrains for RSA keys lengths. Only key lengths of 512, 1024, 1536, 2048, 3072, and 4096 bits will be supported. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: rsa - add a new rsa generic implementationTadeusz Struk
Add a new rsa generic SW implementation. This implements only cryptographic primitives. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Added select on ASN1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
