path: root/crypto/salsa20_generic.c
2012-08-01crypto: cleanup - remove unneeded crypto_alg.cra_list initializationsJussi Kivilinna
Initialization of cra_list is currently mixed, most ciphers initialize this field and most shashes do not. Initialization however is not needed at all since cra_list is initialized/overwritten in __crypto_register_alg() with list_add(). Therefore perform cleanup to remove all unneeded initializations of this field in 'crypto/'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: salsa20 - Remove private wrappers around various operationsHarvey Harrison
ROTATE -> rol32 XOR was always used with the same destination, use ^= PLUS/PLUSONE use ++ or += Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20_generic: Fix multi-page processingTan Swee Heng
This patch fixes the multi-page processing bug that affects large test vectors (the same bug that previously affected ctr.c). There is an optimization for the case walk.nbytes == nbytes. Also we now use crypto_xor() instead of adhoc XOR routines. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20: Salsa20 stream cipherTan Swee Heng
This patch implements the Salsa20 stream cipher using the blkcipher interface. The core cipher code comes from Daniel Bernstein's submission to eSTREAM: http://www.ecrypt.eu.org/stream/svn/viewcvs.cgi/ecrypt/trunk/submissions/salsa20/full/ref/ The test vectors comes from: http://www.ecrypt.eu.org/stream/svn/viewcvs.cgi/ecrypt/trunk/submissions/salsa20/full/ It has been tested successfully with "modprobe tcrypt mode=34" on an UML instance. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
