path: root/crypto/seqiv.c
2015-08-17crypto: seqiv - Use generic geniv init/exit helpersHerbert Xu
This patch replaces the seqiv init/exit handlers with the generic geniv helpers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-17crypto: seqiv - Remove AEAD compatibility codeHerbert Xu
Now that we no longer have any legacy AEAD implementations the compatibility code path can no longer be triggered. This patch removes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-17crypto: seqiv - Remove seqnivHerbert Xu
Now that IPsec no longer uses seqniv we can remove it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-14crypto: seqiv - Replace seqniv with seqivHerbert Xu
This patch replaces the seqniv generator with seqiv when the underlying algorithm understands the new calling convention. This not only makes more sense as now seqiv is solely responsible for IV generation rather than also determining how the IV is going to be used, it also allows for optimisations in the underlying implementation. For example, the space for the IV could be used to add padding for authentication. This patch also removes the unnecessary copying of IV to dst during seqiv decryption as the IV is part of the AD and not cipher text. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-22crypto: seqiv - Add compatibility support without RNGHerbert Xu
When seqiv is used in compatibility mode, this patch allows it to function even when an RNG Is not available. It also changes the RNG allocation for the new explicit seqiv interface so that we only hold a reference to the RNG during initialisation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-04crypto: seqiv - Move IV seeding into init functionHerbert Xu
We currently do the IV seeding on the first givencrypt call in order to conserve entropy. However, this does not work with DRBG which cannot be called from interrupt context. In fact, with DRBG we don't need to conserve entropy anyway. So this patch moves the seeding into the init function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28crypto: seqiv - Fix module unload/reload crashHerbert Xu
On module unload we weren't unregistering the seqniv template, thus leading to a crash the next time someone walks the template list. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28crypto: seqiv - Fix IV size in context size calculationHerbert Xu
This patch fixes a bug in the context size calculation where we were still referring to the old cra_aead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28crypto: seqiv - Use common IV generation codeHerbert Xu
This patch makes use of the new common IV generation code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28crypto: seqiv - Copy AD along with plain/cipher textHerbert Xu
As the AD does not necessarily exist in the destination buffer it must be copied along with the plain/cipher text. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-25crypto: aead - Remove unused cryptoff parameterHerbert Xu
This patch removes the cryptoff parameter now that all users set it to zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-25crypto: seqiv - Stop using cryptoffHerbert Xu
The cryptoff parameter was added to facilitate the skipping of IVs that sit between the AD and the plain/cipher text. However, it was never implemented correctly as and we do not handle users such as IPsec setting cryptoff. It is simply ignored. Implementing correctly is in fact more trouble than what it's worth. This patch removes the uses of cryptoff by moving the AD forward to fill the gap left by the IV. The AD is moved back after the underlying AEAD processing is finished. This is in fact beter than the cryptoff solution because it allows algorithms that use seqniv (i.e., GCM and CCM) to hash the whole packet as a single piece, while cryptoff meant that there was guaranteed to be a gap. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-25crypto: seqiv - Use aead_register_instanceHerbert Xu
New style AEAD instances must use aead_register_instance. This worked by chance because aead_geniv_alloc is still setting things the old way. This patch converts the template over to the create model where we are responsible for instance registration so that we can call the correct function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-22crypto: seqiv - Add seqnivHerbert Xu
This patch adds a new IV generator seqniv which is identical to seqiv except that it skips the IV when authenticating. This is intended to be used by algorithms such as rfc4106 that does the IV authentication implicitly. Note that the code used for seqniv is in fact identical to the compatibility case for seqiv. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-22crypto: seqiv - Add support for new AEAD interfaceHerbert Xu
This patch converts the seqiv IV generator to work with the new AEAD interface where IV generators are just normal AEAD algorithms. Full backwards compatibility is paramount at this point since no users have yet switched over to the new interface. Nor can they switch to the new interface until IV generation is fully supported by it. So this means we are adding two versions of seqiv alongside the existing one. The first one is the one that will be used when the underlying AEAD algorithm has switched over to the new AEAD interface. The second one handles the current case where the underlying AEAD algorithm still uses the old interface. Both versions export themselves through the new AEAD interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-13crypto: seqiv - Use crypto_aead_set_reqsize helperHerbert Xu
This patch uses the crypto_aead_set_reqsize helper to avoid directly touching the internals of aead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-20crypto: seqiv - Ensure that IV size is at least 8 bytesHerbert Xu
Since seqiv is designed for IPsec we need to be able to accomodate the whole IPsec sequence number in order to ensure the uniqueness of the IV. This patch forbids any algorithm with an IV size of less than 8 from using it. This should have no impact on existing users since they all have an IV size of 8. Reported-by: Maciej ?enczykowski <zenczykowski@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Maciej ?enczykowski <zenczykowski@gmail.com>
2014-11-26crypto: include crypto- module prefix in templateKees Cook
This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-01crypto: Resolve shadow warningsMark Rustad
Change formal parameters to not clash with global names to eliminate many W=2 warnings. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-04crypto: use ERR_CASTJulia Lawall
Replace PTR_ERR followed by ERR_PTR by ERR_CAST, to be more concise. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression err,x; @@ - err = PTR_ERR(x); if (IS_ERR(x)) - return ERR_PTR(err); + return ERR_CAST(x); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-08-29crypto: skcipher - Use RNG interface instead of get_random_bytesHerbert Xu
This patch makes the IV generators use the new RNG interface so that the user can pick an RNG other than the default get_random_bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] seqiv: Add AEAD supportHerbert Xu
This patch adds support for using seqiv with AEAD algorithms. This is useful for those AEAD algorithms that performs authentication before encryption because the IV generated by the underlying encryption algorithm won't be available for authentication. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] seqiv: Add Sequence Number IV GeneratorHerbert Xu
This generator generates an IV based on a sequence number by xoring it with a salt. This algorithm is mainly useful for CTR and similar modes. This patch also sets it as the default IV generator for ctr. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
