path: root/crypto/sha256_generic.c
2019-09-05crypto: sha256 - Merge crypto/sha256.h into crypto/sha.hHans de Goede
The generic sha256 implementation from lib/crypto/sha256.c uses data structs defined in crypto/sha.h, so lets move the function prototypes there too. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-08-22crypto: sha256_generic - Switch to the generic lib/crypto/sha256.c lib codeHans de Goede
Drop the duplicate generic sha256 (and sha224) implementation from crypto/sha256_generic.c and use the implementation from lib/crypto/sha256.c instead. "diff -u lib/crypto/sha256.c sha256_generic.c" shows that the core sha256_transform function from both implementations is identical and the other code is functionally identical too. Suggested-by: Eric Biggers <ebiggers@kernel.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-08-22crypto: sha256_generic - Fix some coding style issuesHans de Goede
Add a bunch of missing spaces after commas and arround operators. Note the main goal of this is to make sha256_transform and its helpers identical in formatting too the duplcate implementation in lib/sha256.c, so that "diff -u" can be used to compare them to prove that no functional changes are made when further patches in this series consolidate the 2 implementations into 1. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-18crypto: run initcalls for generic implementations earlierEric Biggers
Use subsys_initcall for registration of all templates and generic algorithm implementations, rather than module_init. Then change cryptomgr to use arch_initcall, to place it before the subsys_initcalls. This is needed so that when both a generic and optimized implementation of an algorithm are built into the kernel (not loadable modules), the generic implementation is registered before the optimized one. Otherwise, the self-tests for the optimized implementation are unable to allocate the generic implementation for the new comparison fuzz tests. Note that on arm, a side effect of this change is that self-tests for generic implementations may run before the unaligned access handler has been installed. So, unaligned accesses will crash the kernel. This is arguably a good thing as it makes it easier to detect that type of bug. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-07-09crypto: shash - remove useless setting of type flagsEric Biggers
Many shash algorithms set .cra_flags = CRYPTO_ALG_TYPE_SHASH. But this is redundant with the C structure type ('struct shash_alg'), and crypto_register_shash() already sets the type flag automatically, clearing any type flag that was already there. Apparently the useless assignment has just been copy+pasted around. So, remove the useless assignment from all the shash algorithms. This patch shouldn't change any actual behavior. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2018-07-09crypto: sha256_generic - add cra_priorityEric Biggers
sha256-generic and sha224-generic had a cra_priority of 0, so it wasn't possible to have a lower priority SHA-256 or SHA-224 implementation, as is desired for sha256_mb which is only useful under certain workloads and is otherwise extremely slow. Change them to priority 100, which is the priority used for many of the other generic algorithms. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-12-22crypto: hash - add zero length message hash for shax and md5LABBE Corentin
Some crypto drivers cannot process empty data message and return a precalculated hash for md5/sha1/sha224/sha256. This patch add thoses precalculated hash in include/crypto. Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-10crypto: sha256-generic - move to generic glue implementationArd Biesheuvel
This updates the generic SHA-256 implementation to use the new shared SHA-256 glue code. It also implements a .finup hook crypto_sha256_finup() and exports it to other modules. The import and export() functions and the .statesize member are dropped, since the default implementation is perfectly suitable for this module. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-13crypto: add missing crypto module aliasesMathias Krause
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"") changed the automatic module loading when requesting crypto algorithms to prefix all module requests with "crypto-". This requires all crypto modules to have a crypto specific module alias even if their file name would otherwise match the requested crypto algorithm. Even though commit 5d26a105b5a7 added those aliases for a vast amount of modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO annotations to those files to make them get loaded automatically, again. This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work with kernels v3.18 and below. Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former won't work for crypto modules any more. Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"") Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-10-24Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull /dev/random updates from Ted Ts'o: "This adds a memzero_explicit() call which is guaranteed not to be optimized away by GCC. This is important when we are wiping cryptographically sensitive material" * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: crypto: memzero_explicit - make sure to clear out sensitive data random: add and use memzero_explicit() for clearing data
2014-10-17crypto: memzero_explicit - make sure to clear out sensitive dataDaniel Borkmann
Recently, in commit 13aa93c70e71 ("random: add and use memzero_explicit() for clearing data"), we have found that GCC may optimize some memset() cases away when it detects a stack variable is not being used anymore and going out of scope. This can happen, for example, in cases when we are clearing out sensitive information such as keying material or any e.g. intermediate results from crypto computations, etc. With the help of Coccinelle, we can figure out and fix such occurences in the crypto subsytem as well. Julia Lawall provided the following Coccinelle program: @@ type T; identifier x; @@ T x; ... when exists when any -memset +memzero_explicit (&x, -0, ...) ... when != x when strict @@ type T; identifier x; @@ T x[...]; ... when exists when any -memset +memzero_explicit (x, -0, ...) ... when != x when strict Therefore, make use of the drop-in replacement memzero_explicit() for exactly such cases instead of using memset(). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2014-10-02crypto: sha - Handle unaligned input data in generic sha256 and sha512.David S. Miller
Like SHA1, use get_unaligned_be*() on the raw input data. Reported-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-03crypto: sha256 - Expose SHA256 generic routine to be callable externally.Tim Chen
Other SHA256 routine may need to use the generic routine when FPU is not available. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: sha256 - use crypto_[un]register_shashesJussi Kivilinna
Combine all shash algs to be registered and use new crypto_[un]register_shashes functions. This simplifies init/exit code. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256_generic - Add export/import supportHerbert Xu
This patch adds export/import support to sha256_generic. The exported type is defined by struct sha256_state, which is basically the entire descriptor state of sha256_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256_generic - Use 64-bit counter like sha1Herbert Xu
This patch replaces the two 32-bit counter code in sha256_generic with the simpler 64-bit counter code from sha1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: Fix dead linksAdrian-Ken Rueegsegger
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha256 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha256 and sha224 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] sha256-generic: Extend sha256_generic.c to support SHA-224Jonathan Lynch
Resubmitting this patch which extends sha256_generic.c to support SHA-224 as described in FIPS 180-2 and RFC 3874. HMAC-SHA-224 as described in RFC4231 is then supported through the hmac interface. Patch includes test vectors for SHA-224 and HMAC-SHA-224. SHA-224 chould be chosen as a hash algorithm when 112 bits of security strength is required. Patch generated against the 2.6.24-rc1 kernel and tested against 2.6.24-rc1-git14 which includes fix for scatter gather implementation for HMAC. Signed-off-by: Jonathan Lynch <jonathan.lynch@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10[CRYPTO] sha: Add header file for SHA definitionsJan Glauber
There are currently several SHA implementations that all define their own initialization vectors and size values. Since this values are idential move them to a header file under include/crypto. Signed-off-by: Jan Glauber <jang@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] sha: Load the SHA[1|256] module by an aliasSebastian Siewior
Loading the crypto algorithm by the alias instead of by module directly has the advantage that all possible implementations of this algorithm are loaded automatically and the crypto API can choose the best one depending on its priority. Additionally it ensures that the generic implementation as well as the HW driver (if available) is loaded in case the HW driver needs the generic version as fallback in corner cases. Also remove the probe for sha1 in padlock's init code. Quote from Herbert: The probe is actually pointless since we can always probe when the algorithm is actually used which does not lead to dead-locks like this. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
