path: root/crypto/tcrypt.c
2015-09-21crypto: tcrypt - avoid mapping from module image addressesHoria Geant?
The output buffer in test_ahash_speed will point to an address located within the tcrypt module image. This causes problems when trying to DMA map the buffer. For e.g. on ARM-based LS1021A, a page fault occurs within the DMA API when trying to access the struct page returned by virt_to_page(output): insmod tcrypt.ko mode=403 testing speed of async sha1 (sha1-caam) test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): Unable to handle kernel paging request at virtual address f07e9080 pgd = e58d0e00 [f07e9080] *pgd=80000080007003, *pmd=00000000 Internal error: Oops: 206 [#1] SMP THUMB2 Modules linked in: tcrypt(+) CPU: 1 PID: 1119 Comm: insmod Not tainted 4.2.0-rc1-256134-gbf433416e675 #1 Hardware name: Freescale LS1021A task: ea063900 ti: e5a34000 task.ti: e5a34000 PC is at dma_cache_maint_page+0x38/0xd0 LR is at __dma_page_cpu_to_dev+0x15/0x64 pc : [<800155a0>] lr : [<8001564d>] psr: 000f0033 sp : e5a35ca0 ip : 8063df00 fp : f07e9080 r10: 00000cd0 r9 : 8063df00 r8 : 805a2f04 r7 : 0017f804 r6 : 00000002 r5 : ee7f9000 r4 : 00000014 r3 : 80612d40 r2 : 01ff0080 r1 : 00000380 r0 : ee7f9000 Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user Control: 70c5387d Table: e58d0e00 DAC: 9b7ede70 Process insmod (pid: 1119, stack limit = 0xe5a34210) Stack: (0xe5a35ca0 to 0xe5a36000) [...] [<800155a0>] (dma_cache_maint_page) from [<8001564d>] (__dma_page_cpu_to_dev+0x15/0x64) [<8001564d>] (__dma_page_cpu_to_dev) from [<800156eb>] (arm_dma_map_page+0x1f/0x44) [<800156eb>] (arm_dma_map_page) from [<802935e3>] (ahash_digest+0x35f/0x510) [<802935e3>] (ahash_digest) from [<7f800d03>] (test_ahash_speed.constprop.6+0x24a/0x4e4 [tcrypt]) [<7f800d03>] (test_ahash_speed.constprop.6 [tcrypt]) from [<7f802fd5>] (do_test+0x1898/0x2058 [tcrypt]) [<7f802fd5>] (do_test [tcrypt]) from [<7f80802f>] (tcrypt_mod_init+0x2e/0x63 [tcrypt]) [<7f80802f>] (tcrypt_mod_init [tcrypt]) from [<80009517>] (do_one_initcall+0xb3/0x134) [<80009517>] (do_one_initcall) from [<80351ec7>] (do_init_module+0x3b/0x13c) [<80351ec7>] (do_init_module) from [<8005cc3f>] (load_module+0x97b/0x9dc) [<8005cc3f>] (load_module) from [<8005cd8d>] (SyS_finit_module+0x35/0x3e) [<8005cd8d>] (SyS_finit_module) from [<8000d101>] (ret_fast_syscall+0x1/0x4c) Code: 1aba 0152 eb00 0b02 (5882) 0f92 addr2line -f -i -e vmlinux 800155a0 page_zonenum include/linux/mm.h:728 page_zone include/linux/mm.h:881 dma_cache_maint_page arch/arm/mm/dma-mapping.c:822 Signed-off-by: Horia Geant? <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-17crypto: aead - Remove CRYPTO_ALG_AEAD_NEW flagHerbert Xu
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone has been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: tcrypt - Add ChaCha20/Poly1305 speed testsMartin Willi
Adds individual ChaCha20 and Poly1305 and a combined rfc7539esp AEAD speed test using mode numbers 214, 321 and 213. For Poly1305 we add a specific speed template, as it expects the key prepended to the input data. Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-14crypto: tcrypt - Add support for new IV conventionHerbert Xu
This patch allows the AEAD speed tests to cope with the new seqiv calling convention as well as the old one. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-08crypto: tcrypt - Fix AEAD speed testsVutla, Lokesh
The AEAD speed tests doesn't do a wait_for_completition, if the return value is EINPROGRESS or EBUSY. Fixing it here. Also add a test case for gcm(aes). Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-18crypto: tcrypt - Fixed AEAD speed test setupHerbert Xu
The AEAD speed test SG list setup did not correctly mark the AD, potentially causing a crash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-18crypto: tcrypt - Add rfc4309(ccm(aes)) speed testHerbert Xu
This patch adds a speed test for rfc4309(ccm(aes)) as mode 212. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28crypto: tcrypt - Switch to new AEAD interfaceHerbert Xu
This patch makes use of the new AEAD interface which uses a single SG list instead of separate lists for the AD and plain text. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-23crypto: tcrypt - Include crypto/aead.hHerbert Xu
All users of AEAD should include crypto/aead.h instead of include/linux/crypto.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net>
2015-04-23crypto: tcrypt - Include linux/fips.h for fips_enabledHerbert Xu
All users of fips_enabled should include linux/fips.h directly instead of getting it through internal.h which is reserved for internal crypto API implementors. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-23crypto: tcrypt - Handle async return from crypto_ahash_initHerbert Xu
The function crypto_ahash_init can also be asynchronous just like update and final. So all callers must be able to handle an async return. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-03-12crypto: tcrypt - fix uninit sg entries in test_acipher_speedHoria Geant?
Commit 5be4d4c94b1f ("crypto: replace scatterwalk_sg_next with sg_next") did not consider the fact that scatterwalk_sg_next() was looking at sg entry length, while sg_next() looks at the "chained" sg bit. This should have no effect in theory. However in practice, there are cases where the sg table is initialized to a number of entries and some of them are not properly configured. While scatterwalk_sg_next() would have returned NULL (since sg length = 0 and sg page_link = 0), sg_next() happily returns the next unconfigured sg entry. insmod tcrypt.ko mode=500 sec=1 testing speed of async cbc(aes) (cbc-aes-talitos) encryption test 0 (128 bit key, 16 byte blocks): Unable to handle kernel paging request for data at address 0x00000000 Faulting instruction address: 0xc00d79e4 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=8 P1022 DS Modules linked in: tcrypt(+) talitos CPU: 0 PID: 2670 Comm: insmod Not tainted 4.0.0-rc1-QorIQ-SDK-V1.6+g904f1ca82209 #1 task: e8de3200 ti: e70bc000 task.ti: e70bc000 NIP: c00d79e4 LR: f92d223c CTR: c00d79c8 REGS: e70bda00 TRAP: 0300 Not tainted (4.0.0-rc1-QorIQ-SDK-V1.6+g904f1ca82209) MSR: 00029000 <CE,EE,ME> CR: 84428f22 XER: 00000000 DEAR: 00000000 ESR: 00000000 GPR00: f92d223c e70bdab0 e8de3200 00000000 e70bdbb8 00000001 00000000 00000000 GPR08: 00000000 00000000 c08b0380 27282010 c00d79c8 1003a634 00000000 e70bdf1c GPR16: e70bdef0 00000020 00000000 c08c0000 00000010 00000000 e70bdbb8 00000010 GPR24: e976d3a8 00000010 00000000 e70bdbd8 e8961010 00000001 c086e560 00000000 NIP [c00d79e4] page_address+0x1c/0x110 LR [f92d223c] talitos_map_sg+0x130/0x184 [talitos] Call Trace: [e70bdab0] [00000010] 0x10 (unreliable) [e70bdad0] [f92d223c] talitos_map_sg+0x130/0x184 [talitos] [e70bdb00] [f92d30d8] common_nonsnoop.constprop.13+0xc0/0x304 [talitos] [e70bdb30] [f933fd90] test_acipher_speed+0x434/0x7dc [tcrypt] [e70bdcc0] [f934318c] do_test+0x2478/0x306c [tcrypt] [e70bdd80] [f11fe058] tcrypt_mod_init+0x58/0x100 [tcrypt] [e70bdda0] [c0002354] do_one_initcall+0x90/0x1f4 [e70bde10] [c061fe00] do_init_module+0x60/0x1ac [e70bde30] [c00a79f0] load_module+0x185c/0x1f88 [e70bdee0] [c00a82b0] SyS_finit_module+0x7c/0x98 [e70bdf40] [c000e8b0] ret_from_syscall+0x0/0x3c Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-02-04crypto: tcrypt - do not allocate iv on stack for aead speed testsCristian Stoica
See also: 9bac019dad8098a77cce555d929f678e22111783 Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-02-04crypto: tcrypt - fix buflen reminder calculationCristian Stoica
- This fixes the intent of the code to limit the last scatterlist to either a full PAGE or a fraction of it, depending on the number of pages needed by buflen and the available space advertised by XBUFLEN. The original code always sets the last scatterlist to a fraction of a PAGE because the first 'if' is never executed. - Rearrange the second part of the code to remove the conditional from the loop Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-13crypto: testmgr - don't use interruptible wait in testsRabin Vincent
tcrypt/testmgr uses wait_for_completion_interruptible() everywhere when it waits for a request to be completed. If it's interrupted, then the test is aborted and the request is freed. However, if any of these calls actually do get interrupted, the result will likely be a kernel crash, when the driver handles the now-freed request. Use wait_for_completion() instead. Signed-off-by: Rabin Vincent <rabin.vincent@axis.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-12-05crypto: tcrypt - Allow speed testing of arbitrary hash functionsHerbert Xu
This patch allows the testing of arbitrary hash functions specified by the alg module parameter by using them in mode 300 (for sync hash) and mode 400 (for async hash). For example, you could do modprobe tcrypt mode=300 alg='vmac(aes)' Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-01crypto: Resolve shadow warningsMark Rustad
Change formal parameters to not clash with global names to eliminate many W=2 warnings. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-07-03crypto: tcrypt - print cra driver name in tcrypt tests outputLuca Clementi
Print the driver name that is being tested. The driver name can be inferred parsing /proc/crypto but having it in the output is clearer Signed-off-by: Luca Clementi <luca.clementi@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-06-20crypto: tcrypt - add ctr(des3_ede) sync speed testJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-05-22crypto: testmgr - add aead cbc des, des3_ede testsNitesh Lal
Test vectors were taken from existing test for CBC(DES3_EDE). Associated data has been added to test vectors. HMAC computed with Crypto++ has been used. Following algos have been covered. (a) "authenc(hmac(sha1),cbc(des))" (b) "authenc(hmac(sha1),cbc(des3_ede))" (c) "authenc(hmac(sha224),cbc(des))" (d) "authenc(hmac(sha224),cbc(des3_ede))" (e) "authenc(hmac(sha256),cbc(des))" (f) "authenc(hmac(sha256),cbc(des3_ede))" (g) "authenc(hmac(sha384),cbc(des))" (h) "authenc(hmac(sha384),cbc(des3_ede))" (i) "authenc(hmac(sha512),cbc(des))" (j) "authenc(hmac(sha512),cbc(des3_ede))" Signed-off-by: Vakul Garg <vakul@freescale.com> [NiteshNarayanLal@freescale.com: added hooks for the missing algorithms test and tested the patch] Signed-off-by: Nitesh Lal <NiteshNarayanLal@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-28crypto: tcrypt - Fix leak of struct aead_request in test_aead_speed()Christian Engelmayer
Fix leakage of memory for struct aead_request that is allocated via aead_request_alloc() but not released via aead_request_free(). Reported by Coverity - CID 1163869. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-28crypto: tcrypt - Fix potential leak in test_aead_speed() if ↵Christian Engelmayer
crypto_alloc_aead() fails Fix a potential memory leak in the error handling of test_aead_speed(). In case crypto_alloc_aead() fails, the function returns without going through the centralized cleanup path. Reported by Coverity - CID 1163870. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-28crypto: tcrypt - Fix potential leak in test_aead_speed() if aad_size is too bigChristian Engelmayer
Fix a potential memory leak in the error handling of test_aead_speed(). In case the size check on the associate data length parameter fails, the function goes through the wrong exit label. Reported by Coverity - CID 1163870. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-03-21crypto: testmgr - add aead null encryption test vectorsHoria Geanta
Add test vectors for aead with null encryption and md5, respectively sha1 authentication. Input data is taken from test vectors listed in RFC2410. Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-12-20crypto: tcrypt - Added speed tests for AEAD crypto alogrithms in tcrypt test ↵Tim Chen
suite Adding simple speed tests for a range of block sizes for AEAD crypto algorithms. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-11-28crypto: caam - fix aead sglen for case 'dst != src'Horia Geanta
For aead case when source and destination buffers are different, there is an incorrect assumption that the source length includes the ICV length. Fix this, since it leads to an oops when using sg_count() to find the number of nents in the scatterlist: Unable to handle kernel paging request for data at address 0x00000004 Faulting instruction address: 0xf91f7634 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=8 P4080 DS Modules linked in: caamalg(+) caam_jr caam CPU: 1 PID: 1053 Comm: cryptomgr_test Not tainted 3.11.0 #16 task: eeb24ab0 ti: eeafa000 task.ti: eeafa000 NIP: f91f7634 LR: f91f7f24 CTR: f91f7ef0 REGS: eeafbbc0 TRAP: 0300 Not tainted (3.11.0) MSR: 00029002 <CE,EE,ME> CR: 44044044 XER: 00000000 DEAR: 00000004, ESR: 00000000 GPR00: f91f7f24 eeafbc70 eeb24ab0 00000002 ee8e0900 ee8e0800 00000024 c45c4462 GPR08: 00000010 00000000 00000014 0c0e4000 24044044 00000000 00000000 c0691590 GPR16: eeab0000 eeb23000 00000000 00000000 00000000 00000001 00000001 eeafbcc8 GPR24: 000000d1 00000010 ee2d5000 ee49ea10 ee49ea10 ee46f640 ee46f640 c0691590 NIP [f91f7634] aead_edesc_alloc.constprop.14+0x144/0x780 [caamalg] LR [f91f7f24] aead_encrypt+0x34/0x288 [caamalg] Call Trace: [eeafbc70] [a1004000] 0xa1004000 (unreliable) [eeafbcc0] [f91f7f24] aead_encrypt+0x34/0x288 [caamalg] [eeafbcf0] [c020d77c] __test_aead+0x3ec/0xe20 [eeafbe20] [c020f35c] test_aead+0x6c/0xe0 [eeafbe40] [c020f420] alg_test_aead+0x50/0xd0 [eeafbe60] [c020e5e4] alg_test+0x114/0x2e0 [eeafbee0] [c020bd1c] cryptomgr_test+0x4c/0x60 [eeafbef0] [c0047058] kthread+0xa8/0xb0 [eeafbf40] [c000eb0c] ret_from_kernel_thread+0x5c/0x64 Instruction dump: 69084321 7d080034 5508d97e 69080001 0f080000 81290024 552807fe 0f080000 3a600001 5529003a 2f8a0000 40dd0028 <80e90004> 3ab50001 8109000c 70e30002 ---[ end trace b3c3e23925c7484e ]--- While here, add a tcrypt mode for making it easy to test authenc (needed for triggering case above). Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-24Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This reverts commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Unfortunately this change broke boot on some systems that used an initrd which does not include the newly created crct10dif modules. As these modules are required by sd_mod under certain configurations this is a serious problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-24crypto: crct10dif - Simple correctness and speed test for CRCT10DIF hashTim Chen
These are simple tests to do sanity check of CRC T10 DIF hash. The correctness of the transform can be checked with the command modprobe tcrypt mode=47 The speed of the transform can be evaluated with the command modprobe tcrypt mode=320 Set the cpu frequency to constant and turn turbo off when running the speed test so the frequency governor will not tweak the frequency and affects the measurements. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: tcrypt - add async cipher speed tests for blowfishJussi Kivilinna
2013-04-25crypto: add CMAC support to CryptoAPIJussi Kivilinna
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI. This work is based on Tom St Denis' earlier patch, http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2 Cc: Tom St Denis <tstdenis@elliptictech.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: testmgr - add AES GMAC test vectorsJussi Kivilinna
2013-01-08crypto: ctr - make rfc3686 asynchronous block cipherJussi Kivilinna
Some hardware crypto drivers register asynchronous ctr(aes), which is left unused in IPSEC because rfc3686 template only supports synchronous block ciphers. Some other drivers register rfc3686(ctr(aes)) to workaround this limitation but not all. This patch changes rfc3686 to use asynchronous block ciphers, to allow async ctr(aes) algorithms to be utilized automatically by IPSEC. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2012-11-09crypto: tcrypt - add async speed test for camellia cipherJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger DES3_EDE testvectorsJussi Kivilinna
Most DES3_EDE testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with DES3_EDE. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger DES testvectorsJussi Kivilinna
Most DES testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with DES. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-15crypto: tcrypt - Added speed test in tcrypt for crc32cTim Chen
This patch adds a test case in tcrypt to perform speed test for crc32c checksum calculation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto: tcrypt - add missing tests for camellia and ghashJussi Kivilinna
Add missing tests for ctr(camellia), lrw(camellia), xts(camellia) and ghash, as these have test vectors available. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto, tcrypt: remove local_bh_disable/enable() around ↵Suresh Siddha
local_irq_disable/enable() Ran into this while looking at some new crypto code using FPU hitting a WARN_ON_ONCE(!irq_fpu_usable()) in the kernel_fpu_begin() on a x86 kernel that uses the new eagerfpu model. In short, current eagerfpu changes return 0 for interrupted_kernel_fpu_idle() and the in_interrupt() thinks it is in the interrupt context because of the local_bh_disable(). Thus resulting in the WARN_ON(). Remove the local_bh_disable/enable() calls around the existing local_irq_disable/enable() calls. local_irq_disable/enable() already disables the BH. [ If there are any other legitimate users calling kernel_fpu_begin() from the process context but with BH disabled, then we can look into fixing the irq_fpu_usable() in future. ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: testmgr - add larger cast6 testvectorsJohannes Goetzfried
New ECB, CBC, CTR, LRW and XTS testvectors for cast6. We need larger testvectors to check parallel code paths in the optimized implementation. Tests have also been added to the tcrypt module. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: testmgr - add larger cast5 testvectorsJohannes Goetzfried
New ECB, CBC and CTR testvectors for cast5. We need larger testvectors to check parallel code paths in the optimized implementation. Tests have also been added to the tcrypt module. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: atmel - add new tests to tcryptNicolas Royer
- set sg buffers size equals to message size - add cfb & ofb tests for AES, DES & TDES Signed-off-by: Nicolas Royer <nicolas@eukrea.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Eric Bénard <eric@eukrea.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-14crypto: testmgr - add ecb(arc4) speed testsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-12crypto: twofish - add x86_64/avx assembler implementationJohannes Goetzfried
This patch adds a x86_64/avx assembler implementation of the Twofish block cipher. The implementation processes eight blocks in parallel (two 4 block chunk AVX operations). The table-lookups are done in general-purpose registers. For small blocksizes the 3way-parallel functions from the twofish-x86_64-3way module are called. A good performance increase is provided for blocksizes greater or equal to 128B. Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmark results: Intel Core i5-2500 CPU (fam:6, model:42, step:7) twofish-avx-x86_64 vs. twofish-x86_64-3way 128bit key: (lrw:256bit) (xts:256bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.96x 0.97x 1.00x 0.95x 0.97x 0.97x 0.96x 0.95x 0.95x 0.98x 64B 0.99x 0.99x 1.00x 0.99x 0.98x 0.98x 0.99x 0.98x 0.99x 0.98x 256B 1.20x 1.21x 1.00x 1.19x 1.15x 1.14x 1.19x 1.20x 1.18x 1.19x 1024B 1.29x 1.30x 1.00x 1.28x 1.23x 1.24x 1.26x 1.28x 1.26x 1.27x 8192B 1.31x 1.32x 1.00x 1.31x 1.25x 1.25x 1.28x 1.29x 1.28x 1.30x 256bit key: (lrw:384bit) (xts:512bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.96x 0.96x 1.00x 0.96x 0.97x 0.98x 0.95x 0.95x 0.95x 0.96x 64B 1.00x 0.99x 1.00x 0.98x 0.98x 1.01x 0.98x 0.98x 0.98x 0.98x 256B 1.20x 1.21x 1.00x 1.21x 1.15x 1.15x 1.19x 1.20x 1.18x 1.19x 1024B 1.29x 1.30x 1.00x 1.28x 1.23x 1.23x 1.26x 1.27x 1.26x 1.27x 8192B 1.31x 1.33x 1.00x 1.31x 1.26x 1.26x 1.29x 1.29x 1.28x 1.30x twofish-avx-x86_64 vs aes-asm (8kB block): 128bit 256bit ecb-enc 1.19x 1.63x ecb-dec 1.18x 1.62x cbc-enc 0.75x 1.03x cbc-dec 1.23x 1.67x ctr-enc 1.24x 1.65x ctr-dec 1.24x 1.65x lrw-enc 1.15x 1.53x lrw-dec 1.14x 1.52x xts-enc 1.16x 1.56x xts-dec 1.16x 1.56x Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-12crypto: testmgr - Add new test cases for Blackfin CRC crypto driverSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: tcrypt - add more camellia testsJussi Kivilinna
Add tests for CTR, LRW and XTS modes. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add xts(twofish) testsJussi Kivilinna
2011-11-09crypto: tcrypt - add xts(serpent) testsJussi Kivilinna
2011-11-09crypto: tcrypt - add lrw(twofish) testsJussi Kivilinna
