path: root/crypto/tcrypt.c
2008-08-13crypto: tcrypt - Fix AEAD chunk testingHerbert Xu
My changeset 4b22f0ddb6564210c9ded7ba25b2a1007733e784 crypto: tcrpyt - Remove unnecessary kmap/kunmap calls introduced a typo that broke AEAD chunk testing. In particular, axbuf should really be xbuf. There is also an issue with testing the last segment when encrypting. The additional part produced by AEAD wasn't tested. Similarly, on decryption the additional part of the AEAD input is mistaken for corruption. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Move ahash functions into crypto/hash.hHerbert Xu
All new crypto interfaces should go into individual files as much as possible in order to ensure that crypto.h does not collapse under its own weight. This patch moves the ahash code into crypto/hash.h and crypto/internal/hash.h respectively. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: tcrpyt - Remove unnecessary kmap/kunmap callsHerbert Xu
Noticed by Neil Horman: we are doing unnecessary kmap/kunmap calls on kmalloced memory. This patch removes them. For the purposes of testing SG construction, the underlying crypto code already does plenty of kmap/kunmap calls anyway. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] tcrypt: Add self test for des3_ebe cipher operating in cbc modeNeil Horman
Patch to add checking of DES3 test vectors using CBC mode. FIPS-140-2 compliance mandates that any supported mode of operation must include a self test. This satisfies that requirement for cbc(des3_ede). The included test vector was generated by me using openssl. Key/IV was generated with the following command: openssl enc -des_ede_cbc -P input and output values were generated by repeating the string "Too many secrets" a few times over, truncating it to 128 bytes, and encrypting it with openssl using the aformentioned key. Tested successfully by myself Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] tcrypt: Use asynchronous hash interfaceLoc Ho
This patch changes tcrypt to use the new asynchronous hash interface for testing hash algorithm correctness. The speed tests will continue to use the existing interface for now. Signed-off-by: Loc Ho <lho@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] tcrypt: Add test vectors for RIPEMD-256 and RIPEMD-320Adrian-Ken Rueegsegger
This patch adds test vectors for RIPEMD-256 and RIPEMD-320 hash algorithms. The test vectors are taken from <http://homes.esat.kuleuven.be/~bosselae/ripemd160.html> Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] tcrypt: Catch cipher destination memory corruptionPatrick McHardy
Check whether the destination buffer is written to beyond the last byte contained in the scatterlist. Also change IDX1 of the cross-page access offsets to a multiple of 4. This triggers a corruption in the HIFN driver and doesn't seem to negatively impact other testcases. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] tcrpyt: Get rid of change log in sourceHerbert Xu
Change logs should be kept in source control systems, not the source. This patch removes the change log from tcrpyt to stop people from extending it any more. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] tcrypt: Add test vectors for RIPEMD-128 and RIPEMD-160Adrian-Ken Rueegsegger
This patch adds test vectors for RIPEMD-128 and RIPEMD-160 hash algorithms and digests (HMAC). The test vectors are taken from ISO:IEC 10118-3 (2004) and RFC2286. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-08crypto: tcrypt - Fix memory leak in test_cipherDarren Jenkins
Coverity CID: 2306 & 2307 RESOURCE_LEAK In the second for loop in test_cipher(), data is allocated space with kzalloc() and is only ever freed in an error case. Looking at this loop, data is written to this memory but nothing seems to read from it. So here is a patch removing the allocation, I think this is the right fix. Only compile tested. Signed-off-by: Darren Jenkins <darrenrjenkins@gmailcom> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] cts: Add CTS mode required for Kerberos AES supportKevin Coffman
Implement CTS wrapper for CBC mode required for support of AES encryption support for Kerberos (rfc3962). Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] tcrypt: Change the usage of the test vectorsSebastian Siewior
The test routines (test_{cipher,hash,aead}) are makeing a copy of the test template and are processing the encryption process in place. This patch changes the creation of the copy so it will work even if the source address of the input data isn't an array inside of the template but a pointer. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] tcrypt: Shrink speed templatesSebastian Siewior
The speed templates as it look always the same. The key size is repeated for each block size and we test always the same block size. The addition of one inner loop makes it possible to get rid of the struct and it is possible to use a tiny u8 array :) Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] tcrypt: Group common speed templatesSebastian Siewior
Some crypto ciphers which are impleneted support similar key sizes (16,24 & 32 byte). They can be grouped together and use a common templatte instead of their own which contains the same data. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Make xcbc available as a standalone testHerbert Xu
Currently the gcm(aes) tests have to be taken together with all other algorithms. This patch makes it available by itself at number 106. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Zero axbuf in the right functionHerbert Xu
The axbuf buffer is used by test_aead and therefore should be zeroed there instead of in test_hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Add CCM vectorsJoy Latten
This patch adds 7 test vectors to tcrypt for CCM. The test vectors are from rfc 3610. There are about 10 more test vectors in RFC 3610 and 4 or 5 more in NIST. I can add these as time permits. I also needed to set authsize. CCM has a prerequisite of authsize. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Refactor into ctr and rfc3686Herbert Xu
As discussed previously, this patch moves the basic CTR functionality into a chainable algorithm called ctr. The IPsec-specific variant of it is now placed on top with the name rfc3686. So ctr(aes) gives a chainable cipher with IV size 16 while the IPsec variant will be called rfc3686(ctr(aes)). This patch also adjusts gcm accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Added salsa20 speed testTan Swee Heng
This patch adds a simple speed test for salsa20. Usage: modprobe tcrypt mode=206 Signed-of-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] lzo: Add LZO compression algorithm supportZoltan Sogor
Add LZO compression algorithm support Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Add common compression tester functionZoltan Sogor
Add common compression tester function Modify deflate test case to use the common compressor test function Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Fix ICV handlingHerbert Xu
The crypto_aead convention for ICVs is to include it directly in the output. If we decided to change this in future then we would make the ICV (if the algorithm has an explicit one) available in the request itself. For now no algorithm needs this so this patch changes gcm to conform to this convention. It also adjusts the tcrypt aead tests to take this into account. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Make gcm available as a standalone testHerbert Xu
Currently the gcm(aes) tests have to be taken together with all other ciphers. This patch makes it available by itself at number 35. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Use print_hex_dump from linux/kernel.hDenis Cheng
These utilities implemented in lib/hexdump.c are more handy, please use this. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Support for large test vectorsTan Swee Heng
Currently the number of entries in a cipher test vector template is limited by TVMEMSIZE/sizeof(struct cipher_testvec). This patch circumvents the problem by pointing cipher_tv to each entry in the template, rather than the template itself. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: New algorithmMikko Herranen
Add GCM/GMAC support to cryptoapi. GCM (Galois/Counter Mode) is an AEAD mode of operations for any block cipher with a block size of 16. The typical example is AES-GCM. Signed-off-by: Mikko Herranen <mh1@iki.fi> Reviewed-by: Mika Kukkonen <mika.kukkonen@nsn.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Add aead supportMikko Herranen
Add AEAD support to tcrypt, needed by GCM. Signed-off-by: Mikko Herranen <mh1@iki.fi> Reviewed-by: Mika Kukkonen <mika.kukkonen@nsn.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20: Salsa20 stream cipherTan Swee Heng
This patch implements the Salsa20 stream cipher using the blkcipher interface. The core cipher code comes from Daniel Bernstein's submission to eSTREAM: http://www.ecrypt.eu.org/stream/svn/viewcvs.cgi/ecrypt/trunk/submissions/salsa20/full/ref/ The test vectors comes from: http://www.ecrypt.eu.org/stream/svn/viewcvs.cgi/ecrypt/trunk/submissions/salsa20/full/ It has been tested successfully with "modprobe tcrypt mode=34" on an UML instance. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] sha256-generic: Extend sha256_generic.c to support SHA-224Jonathan Lynch
Resubmitting this patch which extends sha256_generic.c to support SHA-224 as described in FIPS 180-2 and RFC 3874. HMAC-SHA-224 as described in RFC4231 is then supported through the hmac interface. Patch includes test vectors for SHA-224 and HMAC-SHA-224. SHA-224 chould be chosen as a hash algorithm when 112 bits of security strength is required. Patch generated against the 2.6.24-rc1 kernel and tested against 2.6.24-rc1-git14 which includes fix for scatter gather implementation for HMAC. Signed-off-by: Jonathan Lynch <jonathan.lynch@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Add countersizeJoy Latten
This patch adds countersize to CTR mode. The template is now ctr(algo,noncesize,ivsize,countersize). For example, ctr(aes,4,8,4) indicates the counterblock will be composed of a salt/nonce that is 4 bytes, an iv that is 8 bytes and the counter is 4 bytes. When noncesize + ivsize < blocksize, CTR initializes the last block - ivsize - noncesize portion of the block to zero. Otherwise the counter block is composed of the IV (and nonce if necessary). If noncesize + ivsize == blocksize, then this indicates that user is passing in entire counterblock. Thus countersize indicates the amount of bytes in counterblock to use as the counter for incrementing. CTR will increment counter portion by 1, and begin encryption with that value. Note that CTR assumes the counter portion of the block that will be incremented is stored in big endian. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Add CTR (Counter) block cipher modeJoy Latten
This patch implements CTR mode for IPsec. It is based off of RFC 3686. Please note: 1. CTR turns a block cipher into a stream cipher. Encryption is done in blocks, however the last block may be a partial block. A "counter block" is encrypted, creating a keystream that is xor'ed with the plaintext. The counter portion of the counter block is incremented after each block of plaintext is encrypted. Decryption is performed in same manner. 2. The CTR counterblock is composed of, nonce + IV + counter The size of the counterblock is equivalent to the blocksize of the cipher. sizeof(nonce) + sizeof(IV) + sizeof(counter) = blocksize The CTR template requires the name of the cipher algorithm, the sizeof the nonce, and the sizeof the iv. ctr(cipher,sizeof_nonce,sizeof_iv) So for example, ctr(aes,4,8) specifies the counterblock will be composed of 4 bytes from a nonce, 8 bytes from the iv, and 4 bytes for counter since aes has a blocksize of 16 bytes. 3. The counter portion of the counter block is stored in big endian for conformance to rfc 3686. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-27[CRYPTO] tcrypt: Move sg_init_table out of timing loopsHerbert Xu
This patch moves the sg_init_table out of the timing loops for hash algorithms so that it doesn't impact on the speed test results. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-26[CRYPTO]: Initialize TCRYPT on-stack scatterlist objects correctly.David S. Miller
Use sg_init_one() and sg_init_table() as needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[SG] Update crypto/ to sg helpersJens Axboe
2007-10-10[CRYPTO] xts: XTS blockcipher mode implementation without partial blocksRik Snel
XTS currently considered to be the successor of the LRW mode by the IEEE1619 workgroup. LRW was discarded, because it was not secure if the encyption key itself is encrypted with LRW. XTS does not have this problem. The implementation is pretty straightforward, a new function was added to gf128mul to handle GF(128) elements in ble format. Four testvectors from the specification http://grouper.ieee.org/groups/1619/email/pdf00086.pdf were added, and they verify on my system. Signed-off-by: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] seed: New cipher algorithmHye-Shik Chang
This patch adds support for the SEED cipher (RFC4269). This patch have been used in few VPN appliance vendors in Korea for several years. And it was verified by KISA, who developed the algorithm itself. As its importance in Korean banking industry, it would be great if linux incorporates the support. Signed-off-by: Hye-Shik Chang <perky@FreeBSD.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-18[CRYPTO] tcrypt: Add missing error checkHerbert Xu
The return value of crypto_hash_final isn't checked in test_hash_cycles. This patch corrects this. Thanks to Eric Sesterhenn for reporting this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] tcrypt: Use async blkcipher interfaceHerbert Xu
This patch converts the tcrypt module to use the asynchronous block cipher interface. As all synchronous block ciphers can be used through the async interface, tcrypt is still able to test them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-03-21[CRYPTO] tcrypt: Fix error checking for comp allocationSebastian Siewior
This patch fixes loading the tcrypt module while deflate isn't available at all (isn't build). Signed-off-by: Sebastian Siewior <linux-crypto@ml.breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] camellia: added the testing code of Camellia cipherNoriaki TAKAMIYA
This patch adds the code of Camellia code for testing module. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] tcrypt: Removed vestigial crypto_alloc_tfm callHerbert Xu
The crypto_comp conversion missed the last remaining crypto_alloc_tfm call. This patch replaces it with crypto_alloc_comp. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] fcrypt: Add FCrypt from RxRPCDavid Howells
Add a crypto module to provide FCrypt encryption as used by RxRPC. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] tcrypt: Added test vectors for sha384/sha512Andrew Donofrio
This patch adds tests for SHA384 HMAC and SHA512 HMAC to the tcrypt module. Test data was taken from RFC4231. This patch is a follow-up to the discovery (bug 7646) that the kernel SHA384 HMAC implementation was not generating proper SHA384 HMACs. Signed-off-by: Andrew Donofrio <linuxbugzilla@kriptik.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[CRYPTO] tcrypt: LRW test vectorsRik Snel
Do modprobe tcrypt mode=10 to check the included test vectors, they are from: http://grouper.ieee.org/groups/1619/email/pdf00017.pdf and from http://www.mail-archive.com/stds-p1619@listserv.ieee.org/msg00173.html. To make the last test vector fit, I had to increase the buffer size of input and result to 512 bytes. Signed-off-by: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[CRYPTO] tcrypt: Add test vectors of AES_XCBCKazunori MIYAZAWA
est vectors of XCBC with AES-128. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] users: Use crypto_comp and crypto_has_*Herbert Xu
This patch converts all users to use the new crypto_comp type and the crypto_has_* functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] tcrypt: Use HMAC template and hash interfaceHerbert Xu
This patch converts tcrypt to use the new HMAC template rather than the hard-coded version of HMAC. It also converts all digest users to use the new cipher interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] tcrypt: Use block ciphers where applicableHerbert Xu
This patch converts tcrypt to use the new block cipher type where applicable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] tcrypt: Use test_hash for crc32cHerbert Xu
Now that crc32c has been fixed to conform with standard digest semantics, we can use test_hash for it. I've turned the last test into a chunky test. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
