path: root/crypto/tea.c
2012-08-01crypto: tea - use crypto_[un]register_algsJussi Kivilinna
Combine all crypto_alg to be registered and use new crypto_[un]register_algs functions. This simplifies init/exit code. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-09-21[CRYPTO] api: Get rid of flags argument to setkeyHerbert Xu
Now that the tfm is passed directly to setkey instead of the ctx, we no longer need to pass the &tfm->crt_flags pointer. This patch also gets rid of a few unnecessary checks on the key length for ciphers as the cipher layer guarantees that the key length is within the bounds specified by the algorithm. Rather than testing dia_setkey every time, this patch does it only once during crypto_alloc_tfm. The redundant check from crypto_digest_setkey is also removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] cipher: Set alignmask for multi-byte loadsHerbert Xu
Many cipher implementations use 4-byte/8-byte loads/stores which require alignment on some architectures. This patch explicitly sets the alignment requirements for them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Use standard byte order macros wherever possibleHerbert Xu
A lot of crypto code needs to read/write a 32-bit/64-bit words in a specific gender. Many of them open code them by reading/writing one byte at a time. This patch converts all the applicable usages over to use the standard byte order macros. This is based on a previous patch by Denis Vlasenko. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-09-01[CRYPTO]: Fix XTEA implementationAaron Grothe
The XTEA implementation was incorrect due to a misinterpretation of operator precedence. Because of the wide-spread nature of this error, the erroneous implementation will be kept, albeit under the new name of XETA. Signed-off-by: Aaron Grothe <ajgrothe@yahoo.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
