Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI.
This work is based on Tom St Denis' earlier patch,
http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2
Cc: Tom St Denis <tstdenis@elliptictech.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
(cherry picked from commit 93b5e86a6d13c5dec18c6611933fb38d7d80f0d2)
This reverts commit 2afef0391f30a2831f8beed6a89351682c8a81f6.
Change-Id: Ieef8fd28ba78334a4a0a1b7c64ba6fd4d0f4cb05
Reviewed-on: http://git-master/r/90082
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Added ofb(aes) and cmac(aes) tests
Original-Change-Id: Ia79b0f979af88d337e91164f0b8b6d0eba18cd03
Reviewed-on: http://git-master/r/34701
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: R383d7f642cab41350f54367687861615f9484cf3
the fix add testcase for testing aes ofb mode.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
A self-test failure in fips mode means a panic. Well, gcm(aes)
self-tests currently fail in fips mode, as gcm is dependent on ghash,
which semi-recently got self-test vectors added, but wasn't marked as a
fips_allowed algorithm. Because of gcm's dependence on what is now seen
as a non-fips_allowed algorithm, its self-tests refuse to run.
Previously, ghash got a pass in fips mode, due to the lack of any test
vectors at all, and thus gcm self-tests were able to run. After this
patch, a 'modprobe tcrypt mode=35' no longer panics in fips mode, and
successful self-test of gcm(aes) is reported.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
We (Red Hat) are intending to include dm-crypt functionality, using
xts(aes) for disk encryption, as part of an upcoming FIPS-140-2
certification effort, and xts(aes) *is* on the list of possible
mode/cipher combinations that can be certified. To make that possible, we
need to mark xts(aes) as fips_allowed in the crypto subsystem.
A 'modprobe tcrypt mode=10' in fips mode shows xts(aes) self-tests
passing successfully after this change.
Updated RFC4106 AES-GCM testing. Some test vectors were taken from
http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/
gcm/gcm-test-vectors.tar.gz
Signed-off-by: Adrian Hoban <adrian.hoban@intel.com>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com>
Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com>
This patch fixes a serious bug in the test disabling patch where
it can cause an spurious load of the cryptomgr module even when
it's compiled in.
It also negates the test disabling option so that its absence
causes tests to be enabled.
The Kconfig option is also now behind EMBEDDED.
By default, CONFIG_CRYPTO_MANAGER_TESTS will be enabled and thus
self-tests will still run, but it is now possible to disable them
to gain some time during bootup.
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
Extend testmgr such that it tests async hash algorithms,
and that for both sync and async hashes it tests both
->digest() and ->update()/->final() sequences.
When load aesni-intel and ghash_clmulni-intel driver,kernel will complain no
test for some internal used algorithm.
The strange information as following:
alg: No test for __aes-aesni (__driver-aes-aesni)
alg: No test for __ecb-aes-aesni (__driver-ecb-aes-aesni)
alg: No test for __cbc-aes-aesni (__driver-cbc-aes-aesni)
alg: No test for __ecb-aes-aesni (cryptd(__driver-ecb-aes-aesni)
alg: No test for __ghash (__ghash-pclmulqdqni)
alg: No test for __ghash (cryptd(__ghash-pclmulqdqni))
This patch add NULL test entries for these algorithm and driver.
Signed-off-by: Youquan, Song <youquan.song@intel.com>
Signed-off-by: Ying, Huang <ying.huang@intel.com>
Add ghash algorithm test before provide it to users
crypto/testmgr.c: In function ‘test_cprng’:
crypto/testmgr.c:1204: warning: ‘err’ may be used uninitialized in this function
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
This patch adds VMAC (a fast MAC) support into crypto framework.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
This patch adds the support for testing specific implementations.
This should only be used in very specific situations. Right now
this means specific implementations of random number generators.
Until hash test vectors grow longer than 256 bytes, the only
purpose of the check is to generate a gcc warning.
As it stands we will each test hash vector both linearly and as
a scatter list if applicable. This means that we cannot have
vectors longer than a page, even with scatter lists.
This patch fixes this by skipping test vectors with np != 0 when
testing linearly.
As we cannot guarantee the availability of contiguous pages at
run-time, all test vectors must either fit within a page, or use
scatter lists. In some cases vectors were not checked as to
whether they fit inside a page. This patch adds all the missing
checks.
If crypto_{,de}compress_{update,final}() succeed, return the actual number of
bytes produced instead of zero, so their users don't have to calculate that
theirselves.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Because all fips-allowed algorithms must be self-tested before they
can be used, they will all have entries in testmgr.c's alg_test_descs[].
Skip self-tests for any algs not flagged as fips_approved and return
-EINVAL when in fips mode.
Set the fips_allowed flag in testmgr.c's alg_test_descs[] for algs
that are allowed to be used when in fips mode.
One caveat: des isn't actually allowed anymore, but des (and thus also
ecb(des)) has to be permitted, because disallowing them results in
des3_ede being unable to properly register (see des module init func).
Also, crc32 isn't technically on the fips approved list, but I think
it gets used in various places that necessitate it being allowed.
This list is based on
http://csrc.nist.gov/groups/STM/cavp/index.html
Important note: allowed/approved here does NOT mean "validated", just
that its an alg that *could* be validated.
Now with multi-block test vectors, all from SP800-38A, Appendix F.5.
Also added ctr(aes) to case 10 in tcrypt.
We currently allocate temporary memory that is used for testing
statically. This renders the testing engine non-reentrant. As
algorithms may nest, i.e., one may construct another in order to
carry out a part of its operation, this is unacceptable. For
example, it has been reported that an AEAD implementation allocates
a cipher in its setkey function, which causes it to fail during
testing as the temporary memory is overwritten.
This patch replaces the static memory with dynamically allocated
buffers. We need a maximum of 16 pages so this slightly increases
the chances of an algorithm failing due to memory shortage.
However, as testing usually occurs at registration, this shouldn't
be a big problem.
Reported-by: Shasi Pulijala <spulijala@amcc.com>
According to our FIPS CAVS testing lab guru, when we're in fips mode,
we must print out notices of successful self-test completion for
every alg to be compliant.
New and improved v2, without strncmp crap. Doesn't need to touch a flag
though, due to not moving the notest label around anymore.
Applies atop '[PATCH v2] crypto: catch base cipher self-test failures
in fips mode'.
Personally, I wouldn't mind seeing this info printed out regardless of
whether or not we're in fips mode, I think its useful info, but will
stick with only in fips mode for now.
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode),
aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10
of the NIST RNGVS document, found here:
http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf
Successfully tested against both the cryptodev-2.6 tree and a Red
Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'.
The selection of 150 was semi-arbitrary, didn't seem like it should
go any place in particular, so I started a new range for rng tests.
Add some necessary infrastructure to make it possible to run
self-tests for ansi_cprng. The bits are likely very specific
to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should
be named more specifically if/when we grow additional CPRNG
support...
Successfully tested against the cryptodev-2.6 tree and a
Red Hat Enterprise Linux 5.x kernel with the follow-on
patch that adds the actual test vectors.
Add an array of encryption and decryption + verification self-tests
for rfc4309(ccm(aes)).
Test vectors all come from sample FIPS CAVS files provided to
Red Hat by a testing lab. Unfortunately, all the published sample
vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce
lengths that the kernel's rfc4309 implementation doesn't support, so
while using some public domain vectors would have been preferred, its
not possible at this time.
Add infrastructure to tcrypt/testmgr to support handling ccm decryption
test vectors that are expected to fail verification.
make C=1:
| crypto/testmgr.c:846:45: warning: incorrect type in argument 5 (different signedness)
| crypto/testmgr.c:846:45: expected unsigned int *dlen
| crypto/testmgr.c:846:45: got int *<noident>
| crypto/testmgr.c:878:47: warning: incorrect type in argument 5 (different signedness)
| crypto/testmgr.c:878:47: expected unsigned int *dlen
| crypto/testmgr.c:878:47: got int *<noident>
When self-testing (de)compression algorithms, make sure the actual size of
the (de)compressed output data matches the expected output size.
Otherwise, in case the actual output size would be smaller than the expected
output size, the subsequent buffer compare test would still succeed, and no
error would be reported.
This warning:
crypto/testmgr.c: In function ‘test_comp’:
crypto/testmgr.c:829: warning: ‘ret’ may be used uninitialized in this function
triggers because GCC correctly notices that in the ctcount == 0 &&
dtcount != 0 input condition case this function can return an undefined
value, if the second loop fails.
Remove the shadowed 'ret' variable from the second loop that was probably
unintended.
This patch adds a test for the requirement that all crc32c algorithms
shall store the partial result in the first four bytes of the descriptor
context.
The FIPS specification requires that should self test for any supported
crypto algorithm fail during operation in fips mode, we need to prevent
the use of any crypto functionality until such time as the system can
be re-initialized. Seems like the best way to handle that would be
to panic the system if we were in fips mode and failed a self test.
This patch implements that functionality. I've built and run it
successfully.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
As it is we only test ciphers when combined with a mode. That means
users that do not invoke a mode of operations may get an untested
cipher.
This patch tests all ciphers using the ECB mode so that simple cipher
users such as ansi-cprng are also protected.
This patch moves the newly created alg_test infrastructure into
cryptomgr. This shall allow us to use it for testing at algorithm
registrations.
