path: root/crypto/testmgr.c
2009-11-23crypto: testmgr - Add ghash algorithm test before provide to usersYouquan, Song
Add ghash algorithm test before provide it to users Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-27crypto: testmgr - Fix warningFelipe Contreras
crypto/testmgr.c: In function ‘test_cprng’: crypto/testmgr.c:1204: warning: ‘err’ may be used uninitialized in this function Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-02crypto: testmgr - Allow implementation-specific testsHerbert Xu
This patch adds the support for testing specific implementations. This should only be used in very specific situations. Right now this means specific implementations of random number generators. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-24crypto: testmgr - Remove hash size checkHerbert Xu
Until hash test vectors grow longer than 256 bytes, the only purpose of the check is to generate a gcc warning. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Allow hash test vectors longer than a pageHerbert Xu
As it stands we will each test hash vector both linearly and as a scatter list if applicable. This means that we cannot have vectors longer than a page, even with scatter lists. This patch fixes this by skipping test vectors with np != 0 when testing linearly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Check all test vector lengthsHerbert Xu
As we cannot guarantee the availability of contiguous pages at run-time, all test vectors must either fit within a page, or use scatter lists. In some cases vectors were not checked as to whether they fit inside a page. This patch adds all the missing checks. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: compress - Return produced bytes in crypto_{,de}compress_{update,final}Geert Uytterhoeven
If crypto_{,de}compress_{update,final}() succeed, return the actual number of bytes produced instead of zero, so their users don't have to calculate that theirselves. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Skip algs not flagged fips_allowed in fips modeJarod Wilson
Because all fips-allowed algorithms must be self-tested before they can be used, they will all have entries in testmgr.c's alg_test_descs[]. Skip self-tests for any algs not flagged as fips_approved and return -EINVAL when in fips mode. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Mark algs allowed in fips modeJarod Wilson
Set the fips_allowed flag in testmgr.c's alg_test_descs[] for algs that are allowed to be used when in fips mode. One caveat: des isn't actually allowed anymore, but des (and thus also ecb(des)) has to be permitted, because disallowing them results in des3_ede being unable to properly register (see des module init func). Also, crc32 isn't technically on the fips approved list, but I think it gets used in various places that necessitate it being allowed. This list is based on http://csrc.nist.gov/groups/STM/cavp/index.html Important note: allowed/approved here does NOT mean "validated", just that its an alg that *could* be validated. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add ctr(aes) test vectorsJarod Wilson
Now with multi-block test vectors, all from SP800-38A, Appendix F.5. Also added ctr(aes) to case 10 in tcrypt. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Dynamically allocate xbuf and axbufHerbert Xu
We currently allocate temporary memory that is used for testing statically. This renders the testing engine non-reentrant. As algorithms may nest, i.e., one may construct another in order to carry out a part of its operation, this is unacceptable. For example, it has been reported that an AEAD implementation allocates a cipher in its setkey function, which causes it to fail during testing as the temporary memory is overwritten. This patch replaces the static memory with dynamically allocated buffers. We need a maximum of 16 pages so this slightly increases the chances of an algorithm failing due to memory shortage. However, as testing usually occurs at registration, this shouldn't be a big problem. Reported-by: Shasi Pulijala <spulijala@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Print self-test pass notices in fips modeJarod Wilson
According to our FIPS CAVS testing lab guru, when we're in fips mode, we must print out notices of successful self-test completion for every alg to be compliant. New and improved v2, without strncmp crap. Doesn't need to touch a flag though, due to not moving the notest label around anymore. Applies atop '[PATCH v2] crypto: catch base cipher self-test failures in fips mode'. Personally, I wouldn't mind seeing this info printed out regardless of whether or not we're in fips mode, I think its useful info, but will stick with only in fips mode for now. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Catch base cipher self-test failures in fips modeJarod Wilson
2009-06-02crypto: testmgr - Add ansi_cprng test vectorsJarod Wilson
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode), aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10 of the NIST RNGVS document, found here: http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf Successfully tested against both the cryptodev-2.6 tree and a Red Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'. The selection of 150 was semi-arbitrary, didn't seem like it should go any place in particular, so I started a new range for rng tests. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add infrastructure for ansi_cprng self-testsJarod Wilson
Add some necessary infrastructure to make it possible to run self-tests for ansi_cprng. The bits are likely very specific to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should be named more specifically if/when we grow additional CPRNG support... Successfully tested against the cryptodev-2.6 tree and a Red Hat Enterprise Linux 5.x kernel with the follow-on patch that adds the actual test vectors. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add self-tests for rfc4309(ccm(aes))Jarod Wilson
Add an array of encryption and decryption + verification self-tests for rfc4309(ccm(aes)). Test vectors all come from sample FIPS CAVS files provided to Red Hat by a testing lab. Unfortunately, all the published sample vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce lengths that the kernel's rfc4309 implementation doesn't support, so while using some public domain vectors would have been preferred, its not possible at this time. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Handle AEAD test vectors expected to fail verificationJarod Wilson
Add infrastructure to tcrypt/testmgr to support handling ccm decryption test vectors that are expected to fail verification. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Kill test_comp() sparse warningsGeert Uytterhoeven
make C=1: | crypto/testmgr.c:846:45: warning: incorrect type in argument 5 (different signedness) | crypto/testmgr.c:846:45: expected unsigned int *dlen | crypto/testmgr.c:846:45: got int *<noident> | crypto/testmgr.c:878:47: warning: incorrect type in argument 5 (different signedness) | crypto/testmgr.c:878:47: expected unsigned int *dlen | crypto/testmgr.c:878:47: got int *<noident> Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: testmgr - add zlib testGeert Uytterhoeven
2009-03-04crypto: testmgr - Add support for the pcomp interfaceGeert Uytterhoeven
2008-12-25crypto: testmgr - Validate output length in (de)compression testsGeert Uytterhoeven
When self-testing (de)compression algorithms, make sure the actual size of the (de)compressed output data matches the expected output size. Otherwise, in case the actual output size would be smaller than the expected output size, the subsequent buffer compare test would still succeed, and no error would be reported. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: testmgr - Fix error flow of test_compIngo Molnar
This warning: crypto/testmgr.c: In function ‘test_comp’: crypto/testmgr.c:829: warning: ‘ret’ may be used uninitialized in this function triggers because GCC correctly notices that in the ctcount == 0 && dtcount != 0 input condition case this function can return an undefined value, if the second loop fails. Remove the shadowed 'ret' variable from the second loop that was probably unintended. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: crc32c - Test descriptor context formatHerbert Xu
This patch adds a test for the requirement that all crc32c algorithms shall store the partial result in the first four bytes of the descriptor context. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: testmgr - Trigger a panic when self test fails in FIPS modeNeil Horman
The FIPS specification requires that should self test for any supported crypto algorithm fail during operation in fips mode, we need to prevent the use of any crypto functionality until such time as the system can be re-initialized. Seems like the best way to handle that would be to panic the system if we were in fips mode and failed a self test. This patch implements that functionality. I've built and run it successfully. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Test ciphers using ECBHerbert Xu
As it is we only test ciphers when combined with a mode. That means users that do not invoke a mode of operations may get an untested cipher. This patch tests all ciphers using the ECB mode so that simple cipher users such as ansi-cprng are also protected. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
